asterisk + cisco 1750 FXO звонки с города
joneg
Сообщение joneg »
Здравствуйте. Не могу принять входящие звонки через этот маршрутизатор. Исходящие нормально работают.
sh ver:
Cisco Internetwork Operating System Software
IOS (tm) C1700 Software (C1700-SV3Y-M), Version 12.2(7b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Tue 05-Mar-02 02:19 by pwade
Image text-base: 0x800080E0, data-base: 0x80AA706C
ROM: System Bootstrap, Version 12.0(3r)T1, RELEASE SOFTWARE (fc1)
itk-fxo uptime is 2 days, 17 hours, 50 minutes
System returned to ROM by power-on
System image file is "flash:c1700-sv3y-mz.122-7b.bin"
cisco 1750 (MPC860) processor (revision 0x801) with 24576K/8192K bytes of memory.
Processor board ID JAD06230PUB (3902846991), with hardware revision 0000
M860 processor: part number 0, mask 32
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
2 Voice FXO interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
Configuration register is 0x2102
sh diag:
Slot 0:
	C1750 1FE VE Mainboard Port adapter, 3 ports
	Port adapter is analyzed
	Port adapter insertion time unknown
	EEPROM contents at hardware discovery:
	Hardware Revision        : 8.1
	PCB Serial Number        : JAD06230PUB
	Part Number              : 73-3743-08
	Board Revision           : A0
	Fab Version              : 04
	EEPROM format version 4
	EEPROM contents (hex):
	  0x00: 04 FF 40 00 C9 41 08 01 C1 8B 4A 41 44 30 36 32
	  0x10: 33 30 50 55 42 82 49 0E 9F 08 42 41 30 02 04 FF
	  0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	  0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	  0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	  0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	  0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	  0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	Packet Voice DSP Module Slot 0:
	Hardware Revision        : 3.2
	Part Number              : 73-3741-02
	Board Revision           : A0
	Deviation Number         : 0-0
	Fab Version              : 02
	PCB Serial Number        : ICP0624004D
	RMA Test History         : 00
	RMA Number               : 0-0-0-0
	RMA History              : 00
	Processor type           : 02
        Number of DSP's          : 1
	Type of DSP              : TMS320C549
	0x00:	04 FF 40 01 5A 41 03 02 82 49 0E 9D 02 42 41 30
	0x10:	80 00 00 00 00 02 02 C1 8B 49 43 50 30 36 32 34
	0x20:	30 30 34 44 03 00 81 00 00 00 00 04 00 09 02 FF
	WIC Slot 1:
	Dual FXO Voice Interface Card
	Hardware revision 1.1	Board revision J0
	Serial number     0026698118	Part number    800-02495-01
	Test history      0x00		RMA number     00-00-00
	Connector type    WAN Module
	EEPROM format version 1
	0x20:	01 0D 01 01 01 97 61 86 50 09 BF 01 00 00 00 00
	0x30:	98 00 00 00 01 09 28 01 FF FF FF FF FF FF FF FF
show voice dsp
DSP  DSP             DSPWARE CURR  BOOT                         PAK     TX/RX
TYPE NUM CH CODEC    VERSION STATE STATE   RST AI VOICEPORT TS ABORT  PACK COUNT
DSP# 0: state IN SERVICE, 2 channels allocated
 channel# 0: voice port 1/0, codec g711ulaw, state UP
 channel# 1: voice port 1/1, codec g711ulaw, state UP
При звонке в астериск приходят запросы INVITE
<--- SIP read from UDP:192.168.2.248:58702 --->
INVITE sip:5002@192.168.221.130;user=phone;phone-context=unknown SIP/2.0
Via: SIP/2.0/UDP 192.168.2.248:5060
To: <sip:5002@192.168.221.130;user=phone;phone-context=unknown>
Date: Wed, 03 Mar 1993 17:56:06 GMT
Call-ID: 31575761-171711CC-804AE15D-EEB949FC@192.168.2.248
Cisco-Guid: 827727633-387387852-2152259933-4005120508
User-Agent: Cisco VoIP Gateway/ IOS 12.x/ SIP enabled
CSeq: 101 INVITE
Max-Forwards: 6
Timestamp: 731181366
Contact: <sip:unknown@192.168.2.248:5060>
Expires: 180
Content-Length: 136
v=0
o=CiscoSystemsSIP-GW-UserAgent 467 5707 IN IP4 192.168.2.248
s=SIP Call
c=IN IP4 192.168.2.248
t=0 0
m=audio 20264 RTP/AVP 18
--- (15 headers 6 lines) ---
Date: Wed, 03 Mar 1993 17:56:07 GMT
CSeq: 101 INVITE
Max-Forwards: 6
Timestamp: 731181367
Expires: 180
Content-Length: 136
v=0
s=SIP Call
t=0 0
Date: Wed, 03 Mar 1993 17:56:08 GMT
CSeq: 101 INVITE
Max-Forwards: 6
Timestamp: 731181368
Expires: 180
Content-Length: 136
v=0
s=SIP Call
t=0 0
Date: Wed, 03 Mar 1993 17:56:10 GMT
CSeq: 101 INVITE
Max-Forwards: 6
Timestamp: 731181370
Expires: 180
Content-Length: 136
v=0
s=SIP Call
t=0 0
Date: Wed, 03 Mar 1993 17:56:14 GMT
CSeq: 101 INVITE
Max-Forwards: 6
Timestamp: 731181374
Expires: 180
Content-Length: 136
v=0
s=SIP Call
t=0 0
Date: Wed, 03 Mar 1993 17:56:22 GMT
CSeq: 101 INVITE
Max-Forwards: 6
Timestamp: 731181382
Expires: 180
Content-Length: 136
v=0
s=SIP Call
t=0 0
На которые астериск никак не отвечает и ничего не пишет в консоль. Запросы видно только в дебаг режиме.
Пир настроен следующим образом:
[cisco-fxo]
type=peer
context=from-fxo
dtmfmode=auto
host=192.168.2.248
permit=0.0.0.0/0.0.0.0
insecure=port,invite
Конфиг c1750
call rsvp-sync
voice service pots
voice service voip
interface FastEthernet0
 ip address 192.168.2.248 255.255.255.0
 no ip mroute-cache
 speed auto
 full-duplex
 no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.2.1
no ip http server
ip pim bidir-enable
voice-port 1/0
 connection plar 5001
 dial-type pulse
voice-port 1/1
 cptone RU
 connection plar 5002
dial-peer voice 1 voip
 destination-pattern .T
 session protocol sipv2
 session target ipv4:192.168.221.130:5060
 dtmf-relay cisco-rtp
 no vad
dial-peer voice 100 pots
 preference 2
 port 1/0
dial-peer voice 200 pots
 preference 1
 port 1/1
gateway
sip-ua
 sip-server ipv4:192.168.221.130:5060
Звоню на 1/1 порт. Подскажите, что может быть не так? почему Ast не отвечает на запросы и при этом не пишет ни о каких ошибках?
Re: asterisk + cisco 1750 FXO звонки с города
скрипт для cisco
conf t
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
session transport udp
voice-class codec 1
dtmf-relay rtp-nte
в sip.conf на пире
dtmfmode=rfc2833
deny=0.0.0.0/0
permit=192.168.2.248/32
*CLI> sip reload
*CLI> sip show peer cisco-fxo
joneg
Сообщение joneg »
У меня есть только:
#dtmf-relay ?
  cisco-rtp          Cisco Proprietary RTP
  h245-alphanumeric  DTMF Relay via H245 Alphanumeric IE
  h245-signal        DTMF Relay via H245 Signal IE
В остальном никаких изменений
Так же выяснилось, если минуту с лишним слушать тишину в трубке, то по истечении минуты начинаются короткие гудки, а потом и вовсе сброс. При этом, примерно через ту же минуту в отладке астериска появляется все тет же инвойс + какой то ответ:
<--- SIP read from UDP:192.168.2.248:52698 --->
Date: Wed, 03 Mar 1993 21:35:27 GMT
Call-ID: CC7637A0-173511CC-813FE15D-EEB949FC@192.168.2.248
Cisco-Guid: 3430219600-389353932-2168316253-4005120508
CSeq: 101 INVITE
Max-Forwards: 6
Timestamp: 731194527
Expires: 180
Content-Length: 141
v=0
o=CiscoSystemsSIP-GW-UserAgent 4527 2940 IN IP4 192.168.2.248
s=SIP Call
t=0 0
m=audio 20776 RTP/AVP 8 0 18
Reliably Transmitting (NAT) to 192.168.2.248:5060:
OPTIONS sip:192.168.2.248 SIP/2.0
Via: SIP/2.0/UDP 192.168.221.130:5060;branch=z9hG4bK28f5e69c;rport
From: "asterisk" <sip:asterisk@192.168.221.130>;tag=as3b0419f7
To: <sip:192.168.2.248>
Contact: <sip:asterisk@192.168.221.130:5060>
Call-ID: 38bc58234b513b3a2ae78bea15c273f7@192.168.221.130:5060
CSeq: 102 OPTIONS
User-Agent: Asterisk PBX 1.8.15.1
Date: Mon, 08 Oct 2012 05:18:25 GMT
<--- SIP read from UDP:192.168.2.248:5060 --->
SIP/2.0 200 OK
To: <sip:192.168.2.248>;tag=EEEFCA4-217D
Date: Wed, 03 Mar 1993 21:35:43 GMT
Server: Cisco VoIP Gateway/ IOS 12.x/ SIP enabled
CSeq: 102 OPTIONS
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK
Accept: application/sdp
Content-Length: 138
v=0
o=CiscoSystemsSIP-GW-UserAgent 0 0 IN IP4 192.168.2.248
s=SIP Call
t=0 0
m=audio 0 RTP/AVP 18 0 8 4 2 15
--- (12 headers 6 lines) ---
Really destroying SIP dialog '38bc58234b513b3a2ae78bea15c273f7@192.168.221.130:5060' Method: OPTIONS
CSeq: 101 INVITE
Max-Forwards: 6
Timestamp: 731194543
Expires: 180
Content-Length: 141
v=0
s=SIP Call
t=0 0
Via: SIP/2.0/UDP 192.168.221.130:5060;branch=z9hG4bK3e129a9d;rport
From: "asterisk" <sip:asterisk@192.168.221.130>;tag=as54f0b4ed
Call-ID: 16100f2b2777b3bb6d5e0ee347ccf2ed@192.168.221.130:5060
CSeq: 102 OPTIONS
Date: Mon, 08 Oct 2012 05:19:25 GMT
SIP/2.0 200 OK
To: <sip:192.168.2.248>;tag=EEFE71C-260B
Date: Wed, 03 Mar 1993 21:36:43 GMT
CSeq: 102 OPTIONS
Content-Length: 138
v=0
s=SIP Call
t=0 0
Really destroying SIP dialog '16100f2b2777b3bb6d5e0ee347ccf2ed@192.168.221.130:5060' Method: OPTIONS
Via: SIP/2.0/UDP 192.168.221.130:5060;branch=z9hG4bK3376b99e;rport
From: "asterisk" <sip:asterisk@192.168.221.130>;tag=as3c804634
Call-ID: 57cb28286c3f6132710d549f45f85e72@192.168.221.130:5060
CSeq: 102 OPTIONS
Date: Mon, 08 Oct 2012 05:20:25 GMT
SIP/2.0 200 OK
To: <sip:192.168.2.248>;tag=EF0D194-1CE0
Date: Wed, 03 Mar 1993 21:37:43 GMT
CSeq: 102 OPTIONS
Content-Length: 138
v=0
s=SIP Call
t=0 0
Really destroying SIP dialog '57cb28286c3f6132710d549f45f85e72@192.168.221.130:5060' Method: OPTIONS
joneg
Сообщение joneg »
    * Name       : cisco-fxo
  Realtime peer: No
  Secret       : <Not set>
  MD5Secret    : <Not set>
  Remote Secret: <Not set>
  Context      : from-fxo
  Subscr.Cont. : <Not set>
  Language     :
  AMA flags    : Unknown
  Transfer mode: open
  Callgroup    :
  Pickupgroup  :
  MOH Suggest  :
  Mailbox      :
  VM Extension : asterisk
  LastMsgsSent : 32767/65535
  Call limit   : 0
  Max forwards : 0
  Dynamic      : No
  Callerid     : "" <>
  MaxCallBR    : 384 kbps
  Expire       : -1
  Insecure     : port,invite
  Force rport  : Yes
  ACL          : Yes
  DirectMedACL : No
  T.38 support : No
  T.38 EC mode : Unknown
  T.38 MaxDtgrm: -1
  DirectMedia  : Yes
  PromiscRedir : No
  User=Phone   : No
  Video Support: No
  Text Support : No
  Ign SDP ver  : No
  Trust RPID   : Yes
  Send RPID    : No
  Subscriptions: Yes
  Overlap dial : No
  DTMFmode     : rfc2833
  Timer T1     : 500
  Timer B      : 32000
  ToHost       : 192.168.2.248
  Addr->IP     : 192.168.2.248:5060
  Defaddr->IP  : (null)
  Prim.Transp. : UDP
  Allowed.Trsp : UDP
  Def. Username:
  SIP Options  : (none)
  Codecs       : 0x50c (ulaw|alaw|g729|ilbc)
  Codec Order  : (ulaw:20,ilbc:30,alaw:20,g729:20)
  Auto-Framing :  No
  Status       : Unmonitored
  Useragent    :
  Reg. Contact :
  Qualify Freq : 60000 ms
  Sess-Timers  : Accept
  Sess-Refresh : uas
  Sess-Expires : 1800 secs
  Min-Sess     : 90 secs
  RTP Engine   : asterisk
  Parkinglot   :
  Use Reason   : No
  Encryption   : No
У вас INVITE приходит без всяких кодеков
m=audio 20264 RTP/AVP 18 - это не кодек, а сообщение о формате DTMF
Vlad написал Вам, добавьте в пир
voice-class codec 1
no vad
А Вы пишите - нет таких команд. Так создайте сначала voice-class codec 1! Или просто укажите на диал пире хотя бы один кодек
voice codec g711a
no vad
Сколько живых примеров в интернете есть!
RTP/AVP 18 - g.729
http://www.iana.org/assignments/rtp-par ... meters.xml
в любом случае астериск должен было ответить хоть что-то
ACL походу где-то порылись
joneg
Сообщение joneg »
ded писал(а): А Вы пишите - нет таких команд. Так создайте сначала voice-class codec 1! Или просто укажите на диал пире хотя бы один кодек
Я написал, что у меня нет dtmf-relay rtp-nte и показал какие варианты есть. Кодеки я прописал как порекомендовал Влад
..и?
Если 192.168.221.130 - это Астериск, то на нём
tcpdump -s0 -A host _IP_ADDR_Cisco_1750_ and port 5060
Прибегает что-то или нет?
destination-pattern 500.
Последний раз редактировалось ded 08 окт 2012, 10:41, всего редактировалось 1 раз.
joneg
Сообщение joneg »
Ну а к чему вы мне про кодеки пишите, ведь я не говорил что не могу их указать.
Про ACL, ничего подобного не настраивал. Где их вообще там искать то?
