asterisk 1.8.11 + oracle 11g2 cdr проблема с настройкой
holf
Сообщение holf »
Здравствуйте!. столкнулся с задачей писать cdr в оракл(на удаленный сервер) и вот бьюсь...
исходные данные:
Centos 5.7 x64
Asterisk 1.8.11-cert7(взял сертифицированный на всякий случай для стабильности)
unixODBC-2.2.15pre(пробовал уже и дефолтный(2.2.11), и последний, и 2.2.14, поэтому собран из исходников)
odbcinst.ini
[ODBC]
Trace = yes
TraceFile = /var/log/odbc.log
#driver for oracle 11.2
[ora11odbc]
Description     = Oracle ODBC driver for Oracle 11g
Driver          = /usr/lib/oracle/11.2/client64/lib/libsqora.so.11.1
Setup           = /usr/lib/oracle/11.2/client64/lib/libsqora.so.11.1
FileUsage       = 1
CPTimeout       =
CPReuse         =
odbc.ini
[ora11odbc]
Application Attributes = T
Attributes = W
BatchAutocommitMode = IfAllSuccessful
BindAsFLOAT = F
CloseCursor = F
DisableDPM = F
DisableMTS = T
Driver = ora11odbc
DSN = ora11odbc
EXECSchemaOpt =
EXECSyntax = T
Failover = T
FailoverDelay = 10
FailoverRetryCount = 10
FetchBufferSize = 64000
ForceWCHAR = F
Lobs = T
Longs = T
MetadataIdDefault = F
QueryTimeout = T
ResultSets = T
ServerName = //xx.xx.xx.xx:port/sid
SQLGetData extensions = F
Translation DLL =
Translation Option = 0
DisableRULEHint = T
UserID = asterisk
Password = asterisk
res_odbc.conf
[ora11]
enabled=>yes
dsn=>ora11odbc
username=>asterisk
password=>asterisk
pre-connect=>yes
cdr_odbc.conf
[global]
dsn=ora11odbc
username=asterisk
password=asterisk
loguniqueid=yes
table=intercdr
окружение
LD_LIBRARY_PATH=/usr/lib/oracle/11.2/client64/lib
LIBPATH=/usr/lib/oracle/11.2/client64/lib
PATH=/usr/kerberos/sbin:/usr/kerberos/bin:/usr/local/bin:/bin:/usr/bin:/home/beau/bin:/usr/sbin/:/usr/local/bin:/sbin/:/bin/:/etc/init.d/:/usr/lib/oracle/11.2/client64/bin/:/usr/sbin/:/usr/local/bin:/sbin/:/bin/:/etc/init.d/:/usr/lib/oracle/11.2/client64/bin/
TNS_ADMIN=/etc/oracle
ODBCSYSINI=/usr/local/etc
ODBCINI=/usr/local/etc/odbc.ini
CLASSPATH=/usr/lib/oracle/11.2/client64/lib
ORACLE_HOME=/usr/lib/oracle/11.2/client64
modules.conf
[modules]
autoload=yes
preload => res_odbc.so
;preload => res_config_odbc.so
что происходит.
isql -v ora11odbc asterisk asterisk
отрабатывает, селектится и инсертится.
при старте астериска с загрузкой в modules.conf res_odbc.so при указанных выше настройках астериск ложится и не грузится.
ошибки в /var/log/asterisk/messages отсутствуют. в режиме debug тоже ничего.
если в res_odbc.conf сделать
[ora11]
enabled=>yes
dsn=>ora11odbc
username=>asterisk
password=>asterisk
[b]pre-connect=>no[/b]
то всё загружается,
odbc show в консоли астериска выдает
*CLI> odbc show
ODBC DSN Settings
  DSN:    ora11odbc
    Last connection attempt: 1970-01-01 03:00:00
а cdr_odbc.so выдает на попытке записи cdr(что естественно, по-моему, так как res_odbc.so не создал оракловый коннект)
ERROR[19081]: cdr_odbc.c:149 odbc_log: Unable to retrieve database handle. CDR failed.
но на этом фантазия заканчивается.
может, подскажет кто, где искать?
нативные драйвера постгреса ставил, ставлю и использую без проблем, а вот odbc никогда не использовал, но вроде делал всё по многочисленным в сети мануалам и isql работает вполне корректно.
holf
Re: asterisk 1.8.11 + oracle 11g2 cdr проблема с настройкой
Сообщение holf »
ну что ж, спасибо, попробую. сегодня обновлюсь до последнего в 1.8
может и поможет.
holf
Сообщение holf »
ну, прикинув, я это и делаю - изолировал проблему и смотрю все отладочные данные, может, увижу какую-нибудь инфу, которая подскажет, где что зарыто.
holf
Сообщение holf »
итак, попробовал стартануть астериск в конфигурации, когда он ложится с выводом дебага и всего-всего в /var/log/messages
вышло вот что:
[Sep 12 22:28:24] VERBOSE[24506] config.c:   == Parsing '/etc/asterisk/logger.conf': [Sep 12 22:28:24] VERBOSE[24506] config.c:   == Found
[Sep 12 22:28:24] VERBOSE[24506] config.c:   == Parsing '/etc/asterisk/asterisk.conf': [Sep 12 22:28:24] DEBUG[24506] config.c: Parsing /etc/asterisk/asterisk.conf
[Sep 12 22:28:24] DEBUG[24506] xmldoc.c: gl_pathc 3
[Sep 12 22:28:24] VERBOSE[24506] pbx.c:   == Registered custom function 'MESSAGE'
[Sep 12 22:28:24] VERBOSE[24506] pbx.c:   == Registered custom function 'MESSAGE_DATA'
[Sep 12 22:28:24] VERBOSE[24506] pbx.c:   == Registered application 'MessageSend'
[Sep 12 22:28:24] DEBUG[24506] xmldoc.c: Cannot find variable 'description' in tree 'MessageSend'
[Sep 12 22:28:24] VERBOSE[24506] manager.c:   == Manager registered action MessageSend
[Sep 12 22:28:24] VERBOSE[24506] manager.c:   == Manager registered action DataGet
[Sep 12 22:28:24] VERBOSE[24506] config.c:   == Parsing '/etc/asterisk/codecs.conf': [Sep 12 22:28:24] DEBUG[24506] config.c: Parsing /etc/asterisk/codecs.conf
[Sep 12 22:28:24] VERBOSE[24506] loader.c:  Asterisk Dynamic Loader Starting:
[Sep 12 22:28:24] VERBOSE[24506] config.c:   == Parsing '/etc/asterisk/modules.conf': [Sep 12 22:28:24] DEBUG[24506] config.c: Parsing /etc/asterisk/modules.conf
[Sep 12 22:28:24] NOTICE[24506] loader.c: 1 modules will be loaded.
[Sep 12 22:28:24] VERBOSE[24506] config.c:   == Parsing '/etc/asterisk/res_odbc.conf': [Sep 12 22:28:24] DEBUG[24506] config.c: Parsing /etc/asterisk/res_odbc.conf
[Sep 12 22:28:24] NOTICE[24506] res_odbc.c: Connecting ora11
от предсмертной фразы Connecting ora11 яснее пока не стало...
holf
Сообщение holf »
в свою очередь, трэйс odbc выдал
[ODBC][9794][__handles.c][444]
                Exit:[SQL_SUCCESS]
                        Environment = 0x31f2990
[ODBC][9794][SQLSetEnvAttr.c][182]
                Entry:
                        Attribute = SQL_ATTR_ODBC_VERSION
                        Value = 0x3
                        StrLen = 0
[ODBC][9794][SQLSetEnvAttr.c][349]
                Exit:[SQL_SUCCESS]
[ODBC][9794][SQLAllocHandle.c][345]
                Entry:
                        Handle Type = 2
                        Input Handle = 0x31f2990
[ODBC][9794][SQLAllocHandle.c][463]
                Exit:[SQL_SUCCESS]
                        Output Handle = 0x31f2f70
[ODBC][9794][SQLSetConnectAttr.c][318]
                Entry:
                        Connection = 0x31f2f70
                        Attribute = SQL_ATTR_LOGIN_TIMEOUT
                        Value = 0xa
                        StrLen = 0
[ODBC][9794][SQLSetConnectAttr.c][500]
                Exit:[SQL_SUCCESS]
                Entry:
                        Attribute = SQL_ATTR_CONNECTION_TIMEOUT
                        Value = 0xa
                        StrLen = 0
                Exit:[SQL_SUCCESS]
[ODBC][9794][SQLConnect.c][3549]
                Entry:
                        Server Name = [ora11odbc][length = 9 (SQL_NTS)]
                        User Name = [asterisk][length = 8 (SQL_NTS)]
                        Authentication = [********][length = 8 (SQL_NTS)]
                UNICODE Using encoding ASCII 'ISO8859-1' and UNICODE 'UCS-2LE'
holf
Сообщение holf »
ddkprog писал(а):запускайте астериск через gdb
gdb asterisk
там не помню c или r
continue или run
и когда упадет
набираете bt
ентер
и все будет видно
спасибо, сейчас тоже попробую.
holf
Сообщение holf »
с gdb мне не очень понятно.
делаю так
#gdb /usr/sbin/asterisk
GNU gdb (GDB) Red Hat Enterprise Linux (7.0.1-37.el5_7.1)
Copyright (C) 2009 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-redhat-linux-gnu".
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>...
Reading symbols from /usr/sbin/asterisk...done.
(gdb) run -vvvcgf
Starting program: /usr/sbin/asterisk -vvvcgf
warning: no loadable sections found in added symbol-file system-supplied DSO at 0x2aaaaaaab000
[Thread debugging using libthread_db enabled]
[1]+  Stopped                 gdb /usr/sbin/asterisk
# ps ax | grep ast
 2655 ?        S<     0:00 [ib_mcast]
 4854 pts/1    T      0:00 gdb /usr/sbin/asterisk
 4856 pts/1    Tl     0:00 /usr/sbin/asterisk -vvvcgf
 4864 pts/1    S+     0:00 grep ast
непонятно. и никаких дамп-файлов в системе тоже не появляется. совсем непонятно.
У меня вот так запустился -
(gdb) run -vvvgc
# ps auxwf|grep asterisk
root     12213 29.8  1.9  47656 34580 pts/11   S    00:08   0:49  |               \_ gdb /usr/sbin/asterisk
root     12255  4.0  0.7  37616 13132 pts/11   Sl+  00:09   0:02  |                   \_ /usr/sbin/asterisk -vvvgc
holf
Сообщение holf »
(gdb) run -vvvgc
Starting program: /usr/sbin/asterisk -vvvgc
[2]+  Stopped                 gdb /usr/sbin/asterisk
# ps ax | grep ast
те же яйца. вид сбоку.
Я бы ещё указал сначала в modules.conf -
autoload = yes
noload => res_odbc.so
Тогда это позволит загрузить сначала астериск нормально, а потом командой
module load res_odbc.so
вызвать обрушение.
Но по-моему это всё сложняки, наверняка ошибка в конфиге, и к гадалке не ходи. Какая? Анализировать, изучать одним словом.
