Digium TE220P. Ошибки
tachiorz
Сообщение tachiorz »
В карточку включены 2 потока от АТС. Через пару, тройку часов понемногу появляются ошибки:
Sep  3 17:46:08 asterisk kernel: wct4xxp0: wct2xxp: LOF/LFA detected on span 1 but debouncing for 2500 ms
Sep  3 18:20:08 asterisk kernel: wct4xxp0: wct2xxp: LOF/LFA detected on span 1 but debouncing for 2500 ms
Sep  3 19:23:59 asterisk kernel: wct4xxp0: wct2xxp: LOF/LFA detected on span 1 but debouncing for 2500 ms
Sep  3 19:27:48 asterisk last message repeated 2 times
Sep  3 19:58:15 asterisk kernel: wct4xxp0: wct2xxp: LOF/LFA detected on span 1 but debouncing for 2500 ms
Sep  3 19:58:15 asterisk kernel: wct4xxp0: wct2xxp: yellow (RAI) detected on span 1 but debouncing for 500 ms
Sep  3 20:00:56 asterisk kernel: wct4xxp0: wct2xxp: LOF/LFA detected on span 1 but debouncing for 2500 ms
Sep  3 20:01:46 asterisk kernel: wct4xxp0: wct2xxp: LOF/LFA detected on span 1 but debouncing for 2500 ms
Sep  3 20:01:46 asterisk kernel: wct4xxp0: wct2xxp: yellow (RAI) detected on span 1 but debouncing for 500 ms
Sep  3 20:43:54 asterisk kernel: wct4xxp0: wct2xxp: LOF/LFA detected on span 1 but debouncing for 2500 ms
Со временем их становится всё больше, появляются:
Sep  3 22:15:59 asterisk kernel: wct4xxp0: TE210P: RECEIVE slip NEGATIVE on span 1
Sep  3 22:15:59 asterisk kernel: wct4xxp0: TE210P: RECEIVE slip NEGATIVE on span 2
пока через пару дней потоки не начнут периодически падать.
Сейчас я один поток завернул локально dahdi_maint, на 2й пачкорд просто одел loopback adapter.
Тестирую patlooptest. Оба потока уже второй час без ошибок.
Софт
dahdi-2.4.0rc5_6
libpri-1.4.12
asterisk18-1.8.13.0
system.conf
loadzone = ru
defaultzone = ru
span=1,1,0,ccs,hdb3,crc4
bchan=1-15,17-31
dchan=16
clear=1-31
span=2,2,0,ccs,hdb3,crc4
bchan=32-46,48-62
dchan=47
chan_dahdi.conf
[channels]
language=ru
;rxwink=300 ; Atlas seems to use long (250ms) winks
usecallerid=yes
callwaiting=yes
usecallingpres=yes
callwaitingcallerid=yes
threewaycalling=yes
transfer=yes
canpark=yes
cancallforward=yes
callreturn=yes
echocancel=no
echocancelwhenbridged=no
echotraining=no
callerid=asreceived
pridialplan=Unknown
prilocaldialplan=national
group = 1
signaling = pri_cpe
switchtype = euroisdn
resetinterval=never
context = DID_span_1_default
channel => 1-15,17-31
group = 2
signaling = pri_cpe
resetinterval=never
context = DID_span_2_default
channel => 32-46,48-62
dmesg.boot
Copyright (c) 1992-2012 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
        The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 9.0-RELEASE #0: Tue Jan  3 07:46:30 UTC 2012
    root@farrell.cse.buffalo.edu:/usr/obj/usr/src/sys/GENERIC amd64
CPU: Intel(R) Xeon(R) CPU E31240 @ 3.30GHz (3292.60-MHz K8-class CPU)
  Origin = "GenuineIntel"  Id = 0x206a7  Family = 6  Model = 2a  Stepping = 7
  Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,P                                                       SE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
  Features2=0x15bae3ff<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,SMX,EST,TM2,SSSE3,CX16,xTPR,P                                                       DCM,PCID,SSE4.1,SSE4.2,x2APIC,POPCNT,TSCDLT,XSAVE,AVX>
  AMD Features=0x28000800<SYSCALL,RDTSCP,LM>
  AMD Features2=0x1<LAHF>
  TSC: P-state invariant, performance statistics
real memory  = 8589934592 (8192 MB)
avail memory = 8208355328 (7828 MB)
Event timer "LAPIC" quality 600
ACPI APIC Table: <SUPERM SMCI--MB>
FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
FreeBSD/SMP: 1 package(s) x 4 core(s)
 cpu0 (BSP): APIC ID:  0
 cpu1 (AP): APIC ID:  2
 cpu2 (AP): APIC ID:  4
 cpu3 (AP): APIC ID:  6
ioapic0 <Version 2.0> irqs 0-23 on motherboard
kbd1 at kbdmux0
acpi0: <SUPERM SMCI--MB> on motherboard
acpi0: Power Button (fixed)
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
cpu2: <ACPI CPU> on acpi0
cpu3: <ACPI CPU> on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> irq 16 at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
pcib2: <ACPI PCI-PCI bridge> irq 16 at device 1.1 on pci0
pci2: <ACPI PCI bus> on pcib2
pcib3: <PCI-PCI bridge> at device 0.0 on pci2
pci3: <PCI bus> on pcib3
pci3: <simple comms> at device 8.0 (no driver attached)
pcib4: <ACPI PCI-PCI bridge> irq 17 at device 28.0 on pci0
pci4: <ACPI PCI bus> on pcib4
pcib5: <ACPI PCI-PCI bridge> irq 17 at device 28.4 on pci0
pci5: <ACPI PCI bus> on pcib5
em0: <Intel(R) PRO/1000 Network Connection 7.2.3> port 0xe000-0xe01f mem 0xfba00000-0xfba                                                       1ffff,0xfba20000-0xfba23fff irq 16 at device 0.0 on pci5
em0: Using MSIX interrupts with 3 vectors
em0: Ethernet address: 00:25:90:56:19:ac
pcib6: <ACPI PCI-PCI bridge> irq 18 at device 28.6 on pci0
pci6: <ACPI PCI bus> on pcib6
em1: <Intel(R) PRO/1000 Network Connection 7.2.3> port 0xd000-0xd01f mem 0xfb900000-0xfb9                                                       1ffff,0xfb920000-0xfb923fff irq 18 at device 0.0 on pci6
em1: Using MSIX interrupts with 3 vectors
em1: Ethernet address: 00:25:90:56:19:ad
pcib7: <ACPI PCI-PCI bridge> at device 30.0 on pci0
pci7: <ACPI PCI bus> on pcib7
vgapci0: <VGA-compatible display> mem 0xfa000000-0xfaffffff,0xfb800000-0xfb803fff,0xfb000                                                       000-0xfb7fffff irq 23 at device 3.0 on pci7
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
ahci0: <Intel ICH8 AHCI SATA controller> port 0xf050-0xf057,0xf040-0xf043,0xf030-0xf037,0                                                       xf020-0xf023,0xf000-0xf01f mem 0xfbc01000-0xfbc017ff irq 19 at device 31.2 on pci0
ahci0: AHCI v1.30 with 6 3Gbps ports, Port Multiplier not supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich3: <AHCI channel> at channel 3 on ahci0
ahcich4: <AHCI channel> at channel 4 on ahci0
ahcich5: <AHCI channel> at channel 5 on ahci0
pci0: <serial bus, SMBus> at device 31.3 (no driver attached)
acpi_button0: <Power Button> on acpi0
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
Event timer "HPET" frequency 14318180 Hz quality 550
Event timer "HPET1" frequency 14318180 Hz quality 440
Event timer "HPET2" frequency 14318180 Hz quality 440
Event timer "HPET3" frequency 14318180 Hz quality 440
Event timer "HPET4" frequency 14318180 Hz quality 440
attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
Event timer "RTC" frequency 32768 Hz quality 0
atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
uart2: <16550 or compatible> port 0x3e8-0x3ef irq 10 on acpi0
orm0: <ISA Option ROM> at iomem 0xc0000-0xc7fff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
ppc0: cannot reserve I/O port range
est0: <Enhanced SpeedStep Frequency Control> on cpu0
est: CPU supports Enhanced Speedstep, but is not recognized.
est: cpu_vendor GenuineIntel, msr 273b00002100
device_attach: est0 attach returned 6
p4tcc0: <CPU Frequency Thermal Control> on cpu0
est1: <Enhanced SpeedStep Frequency Control> on cpu1
device_attach: est1 attach returned 6
p4tcc1: <CPU Frequency Thermal Control> on cpu1
est2: <Enhanced SpeedStep Frequency Control> on cpu2
device_attach: est2 attach returned 6
p4tcc2: <CPU Frequency Thermal Control> on cpu2
est3: <Enhanced SpeedStep Frequency Control> on cpu3
device_attach: est3 attach returned 6
p4tcc3: <CPU Frequency Thermal Control> on cpu3
Timecounters tick every 1.000 msec
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
ada0: <Hitachi HUA722010CLA330 JP4OA3EA> ATA-8 SATA 2.x device
ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
ada0: Previously was known as ad4
ada1 at ahcich1 bus 0 scbus1 target 0 lun 0
ada1: <Hitachi HUA722010CLA330 JP4OA3EA> ATA-8 SATA 2.x device
ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
ada1: Previously was known as ad6
SMP: AP CPU #2 Launched!
SMP: AP CPU #1 Launched!
SMP: AP CPU #3 Launched!
Timecounter "TSC-low" frequency 12861708 Hz quality 1000
GEOM_RAID: Intel-18f7c6a1: Array Intel-18f7c6a1 created.
GEOM_RAID: Intel-18f7c6a1: Disk ada0 state changed from NONE to ACTIVE.
GEOM_RAID: Intel-18f7c6a1: Subdisk Volume0:0-ada0 state changed from NONE to RESYNC.
GEOM_RAID: Intel-18f7c6a1: Disk ada1 state changed from NONE to ACTIVE.
GEOM_RAID: Intel-18f7c6a1: Subdisk Volume0:1-ada1 state changed from NONE to ACTIVE.
GEOM_RAID: Intel-18f7c6a1: Array started.
GEOM_RAID: Intel-18f7c6a1: Subdisk Volume0:0-ada0 rebuild start at 142070513664.
GEOM_RAID: Intel-18f7c6a1: Volume Volume0 state changed from STARTING to SUBOPTIMAL.
Root mount waiting for: GRAID
GEOM_RAID: Intel-18f7c6a1: Provider raid/r0 for volume Volume0 created.
Trying to mount root from ufs:/dev/raid/r0p2 [rw]...
em0: link state changed to UP
em1: link state changed to UP
vmstat -i
interrupt                          total       rate
irq1: atkbd0                        1279          0
irq17: wct4xxp0                  7850057        994
cpu0:timer                       7819683        990
irq256: em0:rx 0                  170885         21
irq257: em0:tx 0                  291416         36
irq259: em1:rx 0                   17759          2
irq260: em1:tx 0                    7186          0
irq262: ahci0                   11141876       1411
cpu2:timer                       1279351        162
cpu1:timer                       3685747        466
cpu3:timer                       1339880        169
Total                           33605119       4257
Re: Digium TE220P. Ошибки
dahdi_test -c 20 -v
tachiorz
Простите, забыл
dahdi_test -c 20 -v
Opened pseudo dahdi interface, measuring accuracy...
8192 samples in 8191.496 system clock sample intervals (99.994%)
8192 samples in 8191.304 system clock sample intervals (99.992%)
8192 samples in 8191.463 system clock sample intervals (99.993%)
8192 samples in 8191.488 system clock sample intervals (99.994%)
8192 samples in 8191.448 system clock sample intervals (99.993%)
8192 samples in 8191.473 system clock sample intervals (99.994%)
8192 samples in 8191.480 system clock sample intervals (99.994%)
8192 samples in 8191.479 system clock sample intervals (99.994%)
8192 samples in 8191.449 system clock sample intervals (99.993%)
8192 samples in 8191.464 system clock sample intervals (99.993%)
8192 samples in 8191.504 system clock sample intervals (99.994%)
8192 samples in 8191.408 system clock sample intervals (99.993%)
8192 samples in 8191.568 system clock sample intervals (99.995%)
--- Results after 20 passes ---
Best: 99.995 -- Worst: 99.992 -- Average: 99.993451, Difference: 99.993452
tachiorz писал(а):В карточку включены 2 потока от АТС.
от городской? от вашей офисной?
отсюда вывод - с Астериском всё в порядке, осматривать патч-кросс в Е1, пинать провайдера, и т.п.
И ещё: какой длины патч-кросс в Е1? как далеко находится АТС от сервера Астериск?
tachiorz
ded писал(а):от городской? от вашей офисной?
От городской.
ded писал(а): отсюда вывод - с Астериском всё в порядке, осматривать патч-кросс в Е1, пинать провайдера, и т.п.
Проверили с АТС линии вплоть до нашего отпического мультиплексора, они уверяют что всё в порядке.
Астериск находится в полуметре от мультиплексора, патчкорды соответственно чуть длиннее.
Как далеко АТС - без понятия.
Loopback на мультиплексор, смотреть ошибки на стороне провайдера. Если нет ошибок - отключать CRC4.
Астериск тут не при чём. Проверьте правильно ли собран Е1 кросс-патч.
Посмотрите не пересекаются ли прерывания IRQ карты с другим устройством, обычно usb_uhci
tachiorz
ded писал(а):Loopback на мультиплексор, смотреть ошибки на стороне провайдера. Если нет ошибок - отключать CRC4.
Loopback на мультиплексоре стоит, провайдер говорит ошибок нет.
Про CRC4 я специально спросил, должен быть.(хотя наверно стоит попробовать и без)
С неверно обжатым патчкордом оно бы вообще не завелось, но я их сменю и посмотрю что будет.
Карта сидит на отдельном прерывании, dmesg.boot и vmstat -i я приводил.
Она вообще не заводилась изначально, пока я не отключил HyperThreading. После чего я выключил все лишнее включая USB.
производитель, модель мультика?
оба потока в него?
tachiorz
Vlad1983 писал(а):производитель, модель мультика?
оба потока в него?
Оба в него. 4E1-EC-1SM-1550NM-20 китайский
отстойным мультик
из-за него слипы полюбому
