Unable to acquire target extension for attended transfer.
sergey3d
Сообщение sergey3d »
Доброго дня! Asterisk 13.3.2, последнее время наблюдается странная проблема с DTMF после набора 4х цифр сбрасывает донабор. На транках только alaw, на юзерах alaw и ulaw (оставлял alaw - не помогло), dtmfmode=rfc2833 везде.
Сама ошибка
[2020-07-16 17:12:26] VERBOSE[22746][C-00001269] app_dial.c: SIP/2202-00001760 answered SIP/account4-0000175f
[2020-07-16 17:12:26] VERBOSE[22746][C-00001269] pbx.c: Executing [s@macro-callcenter:1] Set("SIP/2202-00001760", "dialid=1594908742.15545") in new stack
[2020-07-16 17:12:26] VERBOSE[22746][C-00001269] pbx.c: Executing [s@macro-callcenter:2] Set("SIP/2202-00001760", "cid=2202") in new stack
[2020-07-16 17:12:26] VERBOSE[22746][C-00001269] pbx.c: Executing [s@macro-callcenter:3] Set("SIP/2202-00001760", "DB(callcenter/1594908742.15545)=2202") in new stack
[2020-07-16 17:12:26] VERBOSE[22746][C-00001269] pbx.c: Executing [s@macro-callcenter:4] Set("SIP/2202-00001760", "DB(callcenter/1594908742.15545inum)=74952839244") in new stack
[2020-07-16 17:12:26] VERBOSE[22746][C-00001269] pbx.c: Executing [s@macro-callcenter:5] Set("SIP/2202-00001760", "dphone=74955650172") in new stack
[2020-07-16 17:12:26] VERBOSE[22746][C-00001269] pbx.c: Executing [s@macro-callcenter:6] Set("SIP/2202-00001760", "save=2: 2202 - 4955650172") in new stack
[2020-07-16 17:12:26] VERBOSE[22746][C-00001269] bridge_channel.c: Channel SIP/account4-0000175f joined 'simple_bridge' basic-bridge <7cd4695a-bedc-4967-adb8-40abcec81973>
[2020-07-16 17:12:26] VERBOSE[22758][C-00001269] bridge_channel.c: Channel SIP/2202-00001760 joined 'simple_bridge' basic-bridge <7cd4695a-bedc-4967-adb8-40abcec81973>
[2020-07-16 17:17:29] DTMF[22758][C-00001269] channel.c: DTMF begin '*' received on SIP/2202-00001760
[2020-07-16 17:17:29] DTMF[22758][C-00001269] channel.c: DTMF begin passthrough '*' on SIP/2202-00001760
[2020-07-16 17:17:30] DTMF[22758][C-00001269] channel.c: DTMF end '*' received on SIP/2202-00001760, duration 120 ms
[2020-07-16 17:17:30] DTMF[22758][C-00001269] channel.c: DTMF end accepted with begin '*' on SIP/2202-00001760
[2020-07-16 17:17:30] DTMF[22758][C-00001269] channel.c: DTMF end passthrough '*' on SIP/2202-00001760
[2020-07-16 17:17:30] DTMF[22758][C-00001269] channel.c: DTMF begin '2' received on SIP/2202-00001760
[2020-07-16 17:17:30] DTMF[22758][C-00001269] channel.c: DTMF begin passthrough '2' on SIP/2202-00001760
[2020-07-16 17:17:30] DTMF[22758][C-00001269] channel.c: DTMF end '2' received on SIP/2202-00001760, duration 120 ms
[2020-07-16 17:17:30] DTMF[22758][C-00001269] channel.c: DTMF end accepted with begin '2' on SIP/2202-00001760
[2020-07-16 17:17:30] DTMF[22758][C-00001269] channel.c: DTMF end passthrough '2' on SIP/2202-00001760
[2020-07-16 17:17:30] VERBOSE[22746][C-00001269] res_musiconhold.c: Started music on hold, class 'default', on channel 'SIP/account4-0000175f'
[2020-07-16 17:17:30] VERBOSE[22758][C-00001269] file.c: <SIP/2202-00001760> Playing 'pbx-transfer.gsm' (language 'en')
[2020-07-16 17:17:32] DTMF[22758][C-00001269] channel.c: DTMF begin '7' received on SIP/2202-00001760
[2020-07-16 17:17:32] DTMF[22758][C-00001269] channel.c: DTMF begin ignored '7' on SIP/2202-00001760
[2020-07-16 17:17:32] DTMF[22758][C-00001269] channel.c: DTMF end '7' received on SIP/2202-00001760, duration 120 ms
[2020-07-16 17:17:32] DTMF[22758][C-00001269] channel.c: DTMF end passthrough '7' on SIP/2202-00001760
[2020-07-16 17:17:32] DTMF[22758][C-00001269] channel.c: DTMF begin '4' received on SIP/2202-00001760
[2020-07-16 17:17:32] DTMF[22758][C-00001269] channel.c: DTMF begin ignored '4' on SIP/2202-00001760
[2020-07-16 17:17:33] DTMF[22758][C-00001269] channel.c: DTMF end '4' received on SIP/2202-00001760, duration 120 ms
[2020-07-16 17:17:33] DTMF[22758][C-00001269] channel.c: DTMF end passthrough '4' on SIP/2202-00001760
[2020-07-16 17:17:33] DTMF[22758][C-00001269] channel.c: DTMF begin '9' received on SIP/2202-00001760
[2020-07-16 17:17:33] DTMF[22758][C-00001269] channel.c: DTMF begin ignored '9' on SIP/2202-00001760
[2020-07-16 17:17:33] DTMF[22758][C-00001269] channel.c: DTMF end '9' received on SIP/2202-00001760, duration 120 ms
[2020-07-16 17:17:33] DTMF[22758][C-00001269] channel.c: DTMF end passthrough '9' on SIP/2202-00001760
[2020-07-16 17:17:33] DTMF[22758][C-00001269] channel.c: DTMF begin '5' received on SIP/2202-00001760
[2020-07-16 17:17:33] DTMF[22758][C-00001269] channel.c: DTMF begin ignored '5' on SIP/2202-00001760
[2020-07-16 17:17:34] DTMF[22758][C-00001269] channel.c: DTMF end '5' received on SIP/2202-00001760, duration 120 ms
[2020-07-16 17:17:34] DTMF[22758][C-00001269] channel.c: DTMF end passthrough '5' on SIP/2202-00001760
[2020-07-16 17:17:34] DTMF[22758][C-00001269] channel.c: DTMF begin '9' received on SIP/2202-00001760
[2020-07-16 17:17:34] DTMF[22758][C-00001269] channel.c: DTMF begin ignored '9' on SIP/2202-00001760
[2020-07-16 17:17:34] DTMF[22758][C-00001269] channel.c: DTMF end '9' received on SIP/2202-00001760, duration 120 ms
[2020-07-16 17:17:34] DTMF[22758][C-00001269] channel.c: DTMF end passthrough '9' on SIP/2202-00001760
[2020-07-16 17:17:34] VERBOSE[22758][C-00001269] file.c: <SIP/2202-00001760> Playing 'pbx-invalid.gsm' (language 'en')
[2020-07-16 17:17:34] DTMF[22758][C-00001269] channel.c: DTMF begin '2' received on SIP/2202-00001760
[2020-07-16 17:17:34] DTMF[22758][C-00001269] channel.c: DTMF begin ignored '2' on SIP/2202-00001760
[2020-07-16 17:17:35] DTMF[22758][C-00001269] channel.c: DTMF end '2' received on SIP/2202-00001760, duration 120 ms
[2020-07-16 17:17:35] DTMF[22758][C-00001269] channel.c: DTMF end passthrough '2' on SIP/2202-00001760
[2020-07-16 17:17:35] DTMF[22758][C-00001269] channel.c: DTMF begin '6' received on SIP/2202-00001760
[2020-07-16 17:17:35] DTMF[22758][C-00001269] channel.c: DTMF begin ignored '6' on SIP/2202-00001760
[2020-07-16 17:17:35] DTMF[22758][C-00001269] channel.c: DTMF end '6' received on SIP/2202-00001760, duration 120 ms
[2020-07-16 17:17:35] DTMF[22758][C-00001269] channel.c: DTMF end passthrough '6' on SIP/2202-00001760
[2020-07-16 17:17:35] DTMF[22758][C-00001269] channel.c: DTMF begin '1' received on SIP/2202-00001760
[2020-07-16 17:17:35] DTMF[22758][C-00001269] channel.c: DTMF begin ignored '1' on SIP/2202-00001760
[2020-07-16 17:17:35] DTMF[22758][C-00001269] channel.c: DTMF end '1' received on SIP/2202-00001760, duration 120 ms
[2020-07-16 17:17:35] DTMF[22758][C-00001269] channel.c: DTMF end passthrough '1' on SIP/2202-00001760
[2020-07-16 17:17:36] DTMF[22758][C-00001269] channel.c: DTMF begin '4' received on SIP/2202-00001760
[2020-07-16 17:17:36] DTMF[22758][C-00001269] channel.c: DTMF begin ignored '4' on SIP/2202-00001760
[2020-07-16 17:17:36] DTMF[22758][C-00001269] channel.c: DTMF end '4' received on SIP/2202-00001760, duration 120 ms
[2020-07-16 17:17:36] DTMF[22758][C-00001269] channel.c: DTMF end passthrough '4' on SIP/2202-00001760
[2020-07-16 17:17:36] DTMF[22758][C-00001269] channel.c: DTMF begin '5' received on SIP/2202-00001760
[2020-07-16 17:17:36] DTMF[22758][C-00001269] channel.c: DTMF begin ignored '5' on SIP/2202-00001760
[2020-07-16 17:17:36] DTMF[22758][C-00001269] channel.c: DTMF end '5' received on SIP/2202-00001760, duration 120 ms
[2020-07-16 17:17:36] DTMF[22758][C-00001269] channel.c: DTMF end passthrough '5' on SIP/2202-00001760
[2020-07-16 17:17:36] DTMF[22758][C-00001269] channel.c: DTMF begin '8' received on SIP/2202-00001760
[2020-07-16 17:17:36] DTMF[22758][C-00001269] channel.c: DTMF begin ignored '8' on SIP/2202-00001760
[2020-07-16 17:17:37] DTMF[22758][C-00001269] channel.c: DTMF end '8' received on SIP/2202-00001760, duration 120 ms
[2020-07-16 17:17:37] DTMF[22758][C-00001269] channel.c: DTMF end passthrough '8' on SIP/2202-00001760
[2020-07-16 17:17:38] WARNING[22758][C-00001269] bridge_basic.c: Unable to acquire target extension for attended transfer.
[2020-07-16 17:17:38] VERBOSE[22746][C-00001269] res_musiconhold.c: Stopped music on hold on SIP/account4-0000175f
[2020-07-16 17:17:39] DTMF[22758][C-00001269] channel.c: DTMF begin '*' received on SIP/2202-00001760
[2020-07-16 17:17:39] DTMF[22758][C-00001269] channel.c: DTMF begin passthrough '*' on SIP/2202-00001760
[2020-07-16 17:17:39] DTMF[22758][C-00001269] channel.c: DTMF end '*' received on SIP/2202-00001760, duration 120 ms
[2020-07-16 17:17:39] DTMF[22758][C-00001269] channel.c: DTMF end accepted with begin '*' on SIP/2202-00001760
[2020-07-16 17:17:39] DTMF[22758][C-00001269] channel.c: DTMF end passthrough '*' on SIP/2202-00001760
[2020-07-16 17:17:39] DTMF[22758][C-00001269] channel.c: DTMF begin '2' received on SIP/2202-00001760
[2020-07-16 17:17:39] DTMF[22758][C-00001269] channel.c: DTMF begin passthrough '2' on SIP/2202-00001760
[2020-07-16 17:17:39] DTMF[22758][C-00001269] channel.c: DTMF end '2' received on SIP/2202-00001760, duration 120 ms
[2020-07-16 17:17:39] DTMF[22758][C-00001269] channel.c: DTMF end accepted with begin '2' on SIP/2202-00001760
[2020-07-16 17:17:39] DTMF[22758][C-00001269] channel.c: DTMF end passthrough '2' on SIP/2202-00001760
[2020-07-16 17:17:39] VERBOSE[22746][C-00001269] res_musiconhold.c: Started music on hold, class 'default', on channel 'SIP/account4-0000175f'
[2020-07-16 17:17:39] VERBOSE[22758][C-00001269] file.c: <SIP/2202-00001760> Playing 'pbx-transfer.gsm' (language 'en')
[2020-07-16 17:17:41] DTMF[22758][C-00001269] channel.c: DTMF begin '7' received on SIP/2202-00001760
[2020-07-16 17:17:41] DTMF[22758][C-00001269] channel.c: DTMF begin ignored '7' on SIP/2202-00001760
[2020-07-16 17:17:41] DTMF[22758][C-00001269] channel.c: DTMF end '7' received on SIP/2202-00001760, duration 120 ms
[2020-07-16 17:17:41] DTMF[22758][C-00001269] channel.c: DTMF end passthrough '7' on SIP/2202-00001760
[2020-07-16 17:17:41] DTMF[22758][C-00001269] channel.c: DTMF begin '4' received on SIP/2202-00001760
[2020-07-16 17:17:41] DTMF[22758][C-00001269] channel.c: DTMF begin ignored '4' on SIP/2202-00001760
[2020-07-16 17:17:41] DTMF[22758][C-00001269] channel.c: DTMF end '4' received on SIP/2202-00001760, duration 120 ms
[2020-07-16 17:17:41] DTMF[22758][C-00001269] channel.c: DTMF end passthrough '4' on SIP/2202-00001760
[2020-07-16 17:17:42] DTMF[22758][C-00001269] channel.c: DTMF begin '9' received on SIP/2202-00001760
[2020-07-16 17:17:42] DTMF[22758][C-00001269] channel.c: DTMF begin ignored '9' on SIP/2202-00001760
[2020-07-16 17:17:42] DTMF[22758][C-00001269] channel.c: DTMF end '9' received on SIP/2202-00001760, duration 120 ms
[2020-07-16 17:17:42] DTMF[22758][C-00001269] channel.c: DTMF end passthrough '9' on SIP/2202-00001760
[2020-07-16 17:17:42] DTMF[22758][C-00001269] channel.c: DTMF begin '5' received on SIP/2202-00001760
[2020-07-16 17:17:42] DTMF[22758][C-00001269] channel.c: DTMF begin ignored '5' on SIP/2202-00001760
[2020-07-16 17:17:42] DTMF[22758][C-00001269] channel.c: DTMF end '5' received on SIP/2202-00001760, duration 120 ms
[2020-07-16 17:17:42] DTMF[22758][C-00001269] channel.c: DTMF end passthrough '5' on SIP/2202-00001760
[2020-07-16 17:17:42] VERBOSE[22758][C-00001269] file.c: <SIP/2202-00001760> Playing 'pbx-invalid.gsm' (language 'en')
[2020-07-16 17:17:43] DTMF[22758][C-00001269] channel.c: DTMF begin '2' received on SIP/2202-00001760
[2020-07-16 17:17:43] DTMF[22758][C-00001269] channel.c: DTMF begin ignored '2' on SIP/2202-00001760
[2020-07-16 17:17:43] DTMF[22758][C-00001269] channel.c: DTMF end '2' received on SIP/2202-00001760, duration 120 ms
[2020-07-16 17:17:43] DTMF[22758][C-00001269] channel.c: DTMF end passthrough '2' on SIP/2202-00001760
[2020-07-16 17:17:43] DTMF[22758][C-00001269] channel.c: DTMF begin '6' received on SIP/2202-00001760
[2020-07-16 17:17:43] DTMF[22758][C-00001269] channel.c: DTMF begin ignored '6' on SIP/2202-00001760
[2020-07-16 17:17:44] DTMF[22758][C-00001269] channel.c: DTMF end '6' received on SIP/2202-00001760, duration 120 ms
[2020-07-16 17:17:44] DTMF[22758][C-00001269] channel.c: DTMF end passthrough '6' on SIP/2202-00001760
[2020-07-16 17:17:47] WARNING[22758][C-00001269] bridge_basic.c: Unable to acquire target extension for attended transfer.
[2020-07-16 17:17:47] VERBOSE[22746][C-00001269] res_musiconhold.c: Stopped music on hold on SIP/account4-0000175f
[2020-07-16 17:18:11] VERBOSE[22758][C-00001269] bridge_channel.c: Channel SIP/2202-00001760 left 'simple_bridge' basic-bridge <7cd4695a-bedc-4967-adb8-40abcec81973>
[2020-07-16 17:18:11] VERBOSE[22746][C-00001269] bridge_channel.c: Channel SIP/account4-0000175f left 'simple_bridge' basic-bridge <7cd4695a-bedc-4967-adb8-40abcec81973>
[2020-07-16 17:18:11] VERBOSE[22746][C-00001269] pbx.c: Spawn extension (account4, 74952839244, 9) exited non-zero on 'SIP/account4-0000175f'
[2020-07-16 17:18:11] VERBOSE[22749][C-00001269] app_mixmonitor.c: MixMonitor close filestream (mixed)
[2020-07-16 17:18:11] VERBOSE[22749][C-00001269] app_mixmonitor.c: End MixMonitor Recording SIP/account4-0000175f
пир 2202
[ats-malvid-callcenter-2202](!)
context=ats-malvid-callcenter-2202
call-limit=1
allow=ulaw
#transport=tcp
nat=force_rport,comedia
dtmfmode=rfc2833
insecure=port,invite
directmedia=no
canreinvite=no
call-limit=1
features.conf
;transferdigittimeout => 3
;xfersound = beep
;xferfailsound = beeperr
;pickupexten = *8
;pickupsound = beep
;pickupfailsound = beeperr
;featuredigittimeout = 1000
;recordingfailsound = beeperr
atxfernoanswertimeout = 60    .
;atxferdropcall = no
;atxferloopdelay = 10
;atxfercallbackretries = 2
;transferdialattempts = 3
;transferretrysound = "beep"
;transferinvalidsound = "beeperr"
;atxferabort = *1
atxfercomplete = *2
;atxferthreeway = *3
;atxferswap = *4
[featuremap]
;blindxfer => #1
disconnect => *0
;automon => *1
atxfer => *2
;parkcall => #72
;automixmon => *3
Нигде запретов на донабор не ставил. Иногда донабор срабатывает, иногда сбрасывает. s sip.conf relaxdtmf=true ставил - без изменений(
Re: Unable to acquire target extension for attended transfer
Смотрите контекст, в котором происходит донабор.
Позволяется ли там (вашими шаблонами) набрать номер длиннее.
Похоже что нет, отсюда и сообщение об ошибке.
пир 2202 живёт в контексте ats-malvid-callcenter-2202, откуда вполне может набирать номера любой значности.
Но в логе он вызывает макрос - macro-callcenter, и не выходит из него, смотрите какие шаблоны там в нём разрешены.
CLI> dial plan show macro-callcenter
sergey3d
макорс
dialplan show macro-callcenter
[ Context 'macro-callcenter' created by 'pbx_config' ]
  's' =>            1. Set(dialid=${CHANNEL(linkedid)})           [pbx_config]
                    2. Set(cid=${DIALEDPEERNUMBER})               [pbx_config]
                    3. Set(DB(callcenter/${dialid})=${cid})       [pbx_config]
                    4. Set(DB(callcenter/${dialid}inum)=${ARG2})  [pbx_config]
                    5. Set(dphone=${ARG1})                        [pbx_config]
                    6. Set(save=${SHELL(/usr/bin/php /sites/callback/a-scripts/save_anum_for_transfer.php ${cid} ${dphone:-10})}) [pbx_config]
-= 1 extension (6 priorities) in 1 context. =-
Это
чья-то безграмотность. Это не вы даже писали.
Комментировать не смогу.
