D-Link DPH-120s периодичеки отваливается мин на 30
zerghack007
Сообщение zerghack007 »
Дано:
1. Centos 6.2
2. Asterisk 1.8
3. FreePBX 2.9.0.7
4. D-Link DPH-120s
Проблема следующая. Телефон периодичеки отваливается мин на 30
Вот что в логах пишется.
tail -n 200 /var/log/asterisk/messages
[May 12 00:32:34] NOTICE[1561] chan_sip.c: Peer '559' is now UNREACHABLE! Last qualify: 139
[May 12 00:32:36] NOTICE[1561] chan_sip.c: Peer '558' is now UNREACHABLE! Last qualify: 117
[May 12 00:59:30] NOTICE[1561] chan_sip.c: Peer '559' is now Reachable. (106ms / 2000ms)
[May 12 01:23:37] NOTICE[1561] chan_sip.c: Peer '559' is now UNREACHABLE! Last qualify: 131
[May 12 01:29:30] NOTICE[1561] chan_sip.c: Peer '559' is now Reachable. (142ms / 2000ms)
[May 12 01:47:37] NOTICE[1561] chan_sip.c: Peer '559' is now UNREACHABLE! Last qualify: 99
[May 12 01:59:30] NOTICE[1561] chan_sip.c: Peer '559' is now Reachable. (43ms / 2000ms)
[May 12 02:15:35] NOTICE[1561] chan_sip.c: Peer '559' is now UNREACHABLE! Last qualify: 42
[May 12 02:29:30] NOTICE[1561] chan_sip.c: Peer '559' is now Reachable. (43ms / 2000ms)
[May 12 02:43:35] NOTICE[1561] chan_sip.c: Peer '559' is now UNREACHABLE! Last qualify: 43
[May 12 02:59:30] NOTICE[1561] chan_sip.c: Peer '559' is now Reachable. (45ms / 2000ms)
[May 12 03:06:34] NOTICE[1561] chan_sip.c: Peer '559' is now UNREACHABLE! Last qualify: 44
[May 12 03:29:30] NOTICE[1561] chan_sip.c: Peer '559' is now Reachable. (45ms / 2000ms)
[May 12 03:47:35] NOTICE[1561] chan_sip.c: Peer '559' is now UNREACHABLE! Last qualify: 42
[May 12 03:59:30] NOTICE[1561] chan_sip.c: Peer '559' is now Reachable. (43ms / 2000ms)
[May 12 04:25:35] NOTICE[1561] chan_sip.c: Peer '559' is now UNREACHABLE! Last qualify: 44
[May 12 04:29:30] NOTICE[1561] chan_sip.c: Peer '559' is now Reachable. (43ms / 2000ms)
[May 12 04:42:35] NOTICE[1561] chan_sip.c: Peer '559' is now UNREACHABLE! Last qualify: 42
[May 12 04:59:30] NOTICE[1561] chan_sip.c: Peer '559' is now Reachable. (46ms / 2000ms)
[May 12 05:13:35] NOTICE[1561] chan_sip.c: Peer '559' is now UNREACHABLE! Last qualify: 42
[May 12 05:29:30] NOTICE[1561] chan_sip.c: Peer '559' is now Reachable. (43ms / 2000ms)
[May 12 05:30:34] NOTICE[1561] chan_sip.c: Peer '559' is now UNREACHABLE! Last qualify: 43
[May 12 05:59:30] NOTICE[1561] chan_sip.c: Peer '559' is now Reachable. (45ms / 2000ms)
[May 12 06:37:34] NOTICE[1561] chan_sip.c: Peer '559' is now UNREACHABLE! Last qualify: 41
[May 12 06:59:30] NOTICE[1561] chan_sip.c: Peer '559' is now Reachable. (43ms / 2000ms)
[May 12 07:23:35] NOTICE[1561] chan_sip.c: Peer '559' is now UNREACHABLE! Last qualify: 44
[May 12 07:29:30] NOTICE[1561] chan_sip.c: Peer '559' is now Reachable. (43ms / 2000ms)
[May 12 07:31:34] NOTICE[1561] chan_sip.c: Peer '559' is now UNREACHABLE! Last qualify: 42
[May 12 07:59:39] NOTICE[1561] chan_sip.c: Peer '559' is now Reachable. (106ms / 2000ms)
[May 12 08:02:43] NOTICE[1561] chan_sip.c: Peer '559' is now UNREACHABLE! Last qualify: 44
[May 12 08:29:39] NOTICE[1561] chan_sip.c: Peer '559' is now Reachable. (44ms / 2000ms)
[May 12 08:40:43] NOTICE[1561] chan_sip.c: Peer '559' is now UNREACHABLE! Last qualify: 42
Телефон поменял на такой же. Проблема повторилась. Сбрасывал настройки до заводских и тоже самое.
Параллельно пользуюсь софтфоном x-lite. Он нормально работает всегда.
Подскажите кто-нибудь с этим встречался?
zerghack007
Re: D-Link DPH-120s периодичеки отваливается мин на 30
Может где-то в настройках телефона есть какая-то галочка, которая заставит телефон следить за состоянием соединения?
Аля keepalive
jugatsu
Сообщение jugatsu »
Ну а указать где телефон, в локалке там не надо?
zerghack007
К примеру на Fanvil 210 была такая проблема: при смене IP адреса по DHCP телефон не менял адрес в своем SIP стеке, в итоге отправлял неверные запросы на регистрацию: в SIP пакетах был старый адрес, а приходили они с нового.
Прописал статикой IP-адрес телефону.
Не помогло.
Самое странное, что free-pbx панель пишет, что телефон все время подключен, а вот
*CLI> sip show peers
выводит
559/559                    IP-адрес                              D   N   A  26247    UNREACHABLE
qualify=no на каждом
и мотреть действительно ли они перестают работать периодически
zerghack007
Vlad1983 писал(а):qualify=no на каждом
Не уловил идею. Зачем мне отключать периодическую проверку на доступность телефона?
Сделайте так, а потом уловите идею, ОК?
zerghack007
Сделал для внутреннего номера, на котором висел D-Link DPH-120s
rejik*CLI> sip show peers
Name/username              Host                                    Dyn Forcerport ACL Port     Status
558/558                    IP-адрес                                    D   N   A  25120    OK (21 ms)
559/559                    IP-адрес                                    D   N   A  18296    Unmonitored
Состяние Unmonitored
Получается след.
1. На экране горят цифры 559 (ТИПО ТЕЛЕФОН ПОДКЛЮЧЕН)
2. Звонки входящие не проходят.
3. Звонки исходящие есть.
После перезагрузки телефона звонки появляются входящие и исходящие, но чуть погодя та же картина.
Приведу на всякий случай настройку в sip.conf
[559]
deny=0.0.0.0/0.0.0.0
secret=secret
dtmfmode=rfc2833
canreinvite=no
context=from-internal
trustrpid=yes
sendrpid=no
nat=yes
port=5060
qualify=no
qualifyfreq=60
transport=udp
encryption=no
callgroup=
pickupgroup=
dial=SIP/559
mailbox=559@default
permit=0.0.0.0/0.0.0.0
callerid=device <559>
callcounter=yes
faxdetect=no
тогда однозначно виноват аппарат
1. попробовать прошить
2. мочить саппорт длинка
zerghack007
Vlad1983 писал(а):тогда однозначно виноват аппарат
У меня тоже подозрения на сам аппарат. И я вроде менял его на такой же идентичный.
Подскажите, "Vlad1983", для чего Вы советовали сделать
qualify=no
