Нет видео с домофона
moredel
Сообщение moredel »
Помогите разобраться .
Видео телефоны друг на друга звонят, всё хорошо.
Настраиваю домофон Beward DS06MP звонок проходит нормально, но изображения на видео телефоне нет.
лог звонка снял, но ничего не могу там найти такого.
[2019-12-20 10:00:18] VERBOSE[4001] netsock2.c: == Using SIP VIDEO TOS bits 136
[2019-12-20 10:00:18] VERBOSE[4001] netsock2.c: == Using SIP VIDEO CoS mark 6
[2019-12-20 10:00:18] VERBOSE[4001] netsock2.c: == Using SIP RTP TOS bits 184
[2019-12-20 10:00:18] VERBOSE[4001] netsock2.c: == Using SIP RTP CoS mark 5
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [95@from-internal:1] Macro("SIP/10215-0001f2d6", "exten-vm,95,95") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-exten-vm:1] Macro("SIP/10215-0001f2d6", "user-callerid,") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-user-callerid:1] Set("SIP/10215-0001f2d6", "AMPUSER=10215") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-user-callerid:2] GotoIf("SIP/10215-0001f2d6", "0?report") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-user-callerid:3] ExecIf("SIP/10215-0001f2d6", "1?Set(REALCALLERIDNUM=10215)") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-user-callerid:4] Set("SIP/10215-0001f2d6", "AMPUSER=10215") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-user-callerid:5] Set("SIP/10215-0001f2d6", "AMPUSERCIDNAME=Beward215") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-user-callerid:6] GotoIf("SIP/10215-0001f2d6", "0?report") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-user-callerid:7] Set("SIP/10215-0001f2d6", "AMPUSERCID=10215") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-user-callerid:8] Set("SIP/10215-0001f2d6", "CALLERID(all)="Beward215" <10215>") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-user-callerid:9] ExecIf("SIP/10215-0001f2d6", "1?Set(CHANNEL(language)=ru)") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-user-callerid:10] GotoIf("SIP/10215-0001f2d6", "0?continue") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-user-callerid:11] Set("SIP/10215-0001f2d6", "__TTL=64") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-user-callerid:12] GotoIf("SIP/10215-0001f2d6", "1?continue") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Goto (macro-user-callerid,s,19)
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-user-callerid:19] NoOp("SIP/10215-0001f2d6", "Using CallerID "Beward215" <10215>") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-exten-vm:2] Set("SIP/10215-0001f2d6", "RingGroupMethod=none") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-exten-vm:3] Set("SIP/10215-0001f2d6", "VMBOX=95") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-exten-vm:4] Set("SIP/10215-0001f2d6", "__EXTTOCALL=95") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-exten-vm:5] Set("SIP/10215-0001f2d6", "CFUEXT=") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-exten-vm:6] Set("SIP/10215-0001f2d6", "CFBEXT=") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-exten-vm:7] Set("SIP/10215-0001f2d6", "RT=15") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-exten-vm:8] Macro("SIP/10215-0001f2d6", "record-enable,95,IN") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-record-enable:1] GotoIf("SIP/10215-0001f2d6", "1?check") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Goto (macro-record-enable,s,3)
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-record-enable:3] ExecIf("SIP/10215-0001f2d6", "0?MacroExit()") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-record-enable:4] GotoIf("SIP/10215-0001f2d6", "0?Group:OUT") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Goto (macro-record-enable,s,14)
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-record-enable:14] GotoIf("SIP/10215-0001f2d6", "1?IN") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Goto (macro-record-enable,s,19)
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-record-enable:19] ExecIf("SIP/10215-0001f2d6", "0?MacroExit()") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-record-enable:20] NoOp("SIP/10215-0001f2d6", "Recording enable for 95") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-record-enable:21] Set("SIP/10215-0001f2d6", "CALLFILENAME=1576825218.381186-1576825218.381186---10215-95-2019-12-20-10:00:18-i") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-record-enable:22] Set("SIP/10215-0001f2d6", "CALLDIRNAME=2019-12-20") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-record-enable:23] Set("SIP/10215-0001f2d6", "CALLDIR2NAME=10") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-record-enable:24] Set("SIP/10215-0001f2d6", "MIXMON_DIR2=2019-12-20/10/") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-record-enable:25] System("SIP/10215-0001f2d6", "mkdir /var/spool/asterisk/monitor/2019-12-20/10/ -p -m 0705") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-record-enable:26] Set("SIP/10215-0001f2d6", "AUDIOHOOK_INHERIT(MixMonitor)=yes") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-record-enable:27] CELGenUserEvent("SIP/10215-0001f2d6", "RECORDINGFILE,2019-12-20/10/1576825218.381186-1576825218.381186---10215-95-2019-12-20-10:00:18-i.wav") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-record-enable:28] MixMonitor("SIP/10215-0001f2d6", "/var/spool/asterisk/monitor/2019-12-20/10/1576825218.381186-1576825218.381186---10215-95-2019-12-20-10:00:18-i.wav,,") in new stack
[2019-12-20 10:00:18] VERBOSE[14923] app_mixmonitor.c: == Begin MixMonitor Recording SIP/10215-0001f2d6
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-record-enable:29] MacroExit("SIP/10215-0001f2d6", "") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-exten-vm:9] Macro("SIP/10215-0001f2d6", "dial-one,15,tTrwW,95") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:1] Set("SIP/10215-0001f2d6", "DEXTEN=95") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:2] Set("SIP/10215-0001f2d6", "DIALSTATUS_CW=") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:3] GosubIf("SIP/10215-0001f2d6", "0?screen,1") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:4] GosubIf("SIP/10215-0001f2d6", "0?cf,1") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:5] GotoIf("SIP/10215-0001f2d6", "1?skip1") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Goto (macro-dial-one,s,8)
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:8] GotoIf("SIP/10215-0001f2d6", "0?nodial") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:9] GotoIf("SIP/10215-0001f2d6", "0?continue") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:10] Set("SIP/10215-0001f2d6", "EXTHASCW=ENABLED") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:11] GotoIf("SIP/10215-0001f2d6", "0?next1:cwinusebusy") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Goto (macro-dial-one,s,23)
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:23] GotoIf("SIP/10215-0001f2d6", "1?next3:continue") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Goto (macro-dial-one,s,24)
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:24] ExecIf("SIP/10215-0001f2d6", "0?Set(DIALSTATUS_CW=BUSY)") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:25] GotoIf("SIP/10215-0001f2d6", "0?nodial") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:26] GosubIf("SIP/10215-0001f2d6", "1?dstring,1:dlocal,1") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [dstring@macro-dial-one:1] Set("SIP/10215-0001f2d6", "DSTRING=") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [dstring@macro-dial-one:2] Set("SIP/10215-0001f2d6", "DEVICES=95") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [dstring@macro-dial-one:3] ExecIf("SIP/10215-0001f2d6", "0?Return()") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [dstring@macro-dial-one:4] ExecIf("SIP/10215-0001f2d6", "0?Set(DEVICES=5)") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [dstring@macro-dial-one:5] Set("SIP/10215-0001f2d6", "LOOPCNT=1") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [dstring@macro-dial-one:6] Set("SIP/10215-0001f2d6", "ITER=1") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [dstring@macro-dial-one:7] Set("SIP/10215-0001f2d6", "THISDIAL=SIP/95") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [dstring@macro-dial-one:8] GosubIf("SIP/10215-0001f2d6", "1?zap2dahdi,1") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [zap2dahdi@macro-dial-one:1] ExecIf("SIP/10215-0001f2d6", "0?Return()") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [zap2dahdi@macro-dial-one:2] Set("SIP/10215-0001f2d6", "NEWDIAL=") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [zap2dahdi@macro-dial-one:3] Set("SIP/10215-0001f2d6", "LOOPCNT2=1") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [zap2dahdi@macro-dial-one:4] Set("SIP/10215-0001f2d6", "ITER2=1") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [zap2dahdi@macro-dial-one:5] Set("SIP/10215-0001f2d6", "THISPART2=SIP/95") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [zap2dahdi@macro-dial-one:6] ExecIf("SIP/10215-0001f2d6", "0?Set(THISPART2=DAHDI/95)") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [zap2dahdi@macro-dial-one:7] Set("SIP/10215-0001f2d6", "NEWDIAL=SIP/95&") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [zap2dahdi@macro-dial-one:8] Set("SIP/10215-0001f2d6", "ITER2=2") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [zap2dahdi@macro-dial-one:9] GotoIf("SIP/10215-0001f2d6", "0?begin2") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [zap2dahdi@macro-dial-one:10] Set("SIP/10215-0001f2d6", "THISDIAL=SIP/95") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [zap2dahdi@macro-dial-one:11] Return("SIP/10215-0001f2d6", "") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [dstring@macro-dial-one:9] Set("SIP/10215-0001f2d6", "DSTRING=SIP/95&") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [dstring@macro-dial-one:10] Set("SIP/10215-0001f2d6", "ITER=2") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [dstring@macro-dial-one:11] GotoIf("SIP/10215-0001f2d6", "0?begin") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [dstring@macro-dial-one:12] Set("SIP/10215-0001f2d6", "DSTRING=SIP/95") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [dstring@macro-dial-one:13] Return("SIP/10215-0001f2d6", "") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:27] GotoIf("SIP/10215-0001f2d6", "0?nodial") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:28] GotoIf("SIP/10215-0001f2d6", "1?skiptrace") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Goto (macro-dial-one,s,30)
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:30] Set("SIP/10215-0001f2d6", "D_OPTIONS=tTrwW") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:31] ExecIf("SIP/10215-0001f2d6", "0?SIPAddHeader(Alert-Info: )") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:32] ExecIf("SIP/10215-0001f2d6", "0?SIPAddHeader()") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:33] ExecIf("SIP/10215-0001f2d6", "0?SetMusicOnHold()") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:34] GosubIf("SIP/10215-0001f2d6", "0?qwait,1") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:35] Set("SIP/10215-0001f2d6", "__CWIGNORE=") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:36] Set("SIP/10215-0001f2d6", "__KEEPCID=TRUE") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:37] ExecIf("SIP/10215-0001f2d6", "0?Set(D_OPTIONS=tTrwWL(0))") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:38] GotoIf("SIP/10215-0001f2d6", "0?dial:noautoanswer") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Goto (macro-dial-one,s,39)
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:39] SIPRemoveHeader("SIP/10215-0001f2d6", "") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:40] Set("SIP/10215-0001f2d6", "__AUTO_ANSWER=1") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:41] Dial("SIP/10215-0001f2d6", "SIP/95,15,tTrwWg") in new stack
[2019-12-20 10:00:18] VERBOSE[14920] netsock2.c: == Using SIP VIDEO TOS bits 136
[2019-12-20 10:00:18] VERBOSE[14920] netsock2.c: == Using SIP VIDEO CoS mark 6
[2019-12-20 10:00:18] VERBOSE[14920] netsock2.c: == Using SIP RTP TOS bits 184
[2019-12-20 10:00:18] VERBOSE[14920] netsock2.c: == Using SIP RTP CoS mark 5
[2019-12-20 10:00:18] VERBOSE[14920] app_dial.c: -- Called SIP/95
[2019-12-20 10:00:18] VERBOSE[14920] app_dial.c: -- SIP/95-0001f2d7 is ringing
[2019-12-20 10:00:20] VERBOSE[14920] app_dial.c: -- SIP/95-0001f2d7 answered SIP/10215-0001f2d6
[2019-12-20 10:00:25] DEBUG[14920] ams_cdr_mysql.c: CDR logging
[2019-12-20 10:00:25] DEBUG[14920] ams_cdr_mysql.c: cdr_mysql: inserting a CDR record.
[2019-12-20 10:00:25] DEBUG[14920] ams_cdr_mysql.c: SQL for translation rules: SELECT pr_replace, RIGHT('95',LENGTH('95') - LENGTH(prefix)) FROM trules WHERE (BIN(prefix)=BIN(LEFT('95',LENGTH(prefix))) AND LOCATE(CONVERT(accountcode USING utf8), CONVERT('default' USING utf8))) ORDER BY prefix DESC LIMIT 1
[2019-12-20 10:00:25] DEBUG[14920] ams_cdr_mysql.c: ams_cdr_mysql: SQL : INSERT INTO cdr (calldate,name,clid,src,dst,dst_bill,dcontext,channel,dstchannel,lastapp,lastdata,duration, billsec,ratesec,disposition,amaflags,accountcode,userfield,rate,cost,bstep,currency,t_name,t_accountcode,department) VALUES ('2019-12-20 10:00:18','Unknown','\"Beward215\" <10215>','10215','95','95', 'from-internal','SIP/10215-0001f2d6','SIP/95-0001f2d7','Dial','SIP/95,15,tTrwWg',7,5,5,'ANSWERED',3,'default','',0.000000,0.000000,'','','','',IFNULL(CONVERT((SELECT department FROM users WHERE phone_office='10215' LIMIT 1) USING utf8),CONVERT('' USING utf8)))
[2019-12-20 10:00:25] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:42] GotoIf("SIP/10215-0001f2d6", "1?completeagent:completeskip") in new stack
[2019-12-20 10:00:25] VERBOSE[14920] pbx.c: -- Goto (macro-dial-one,s,43)
[2019-12-20 10:00:25] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:43] Set("SIP/10215-0001f2d6", "CHANNEL(userfield)=COMPLETEAGENT") in new stack
[2019-12-20 10:00:25] VERBOSE[14920] pbx.c: -- Executing [s@macro-dial-one:44] Goto("SIP/10215-0001f2d6", "h,1") in new stack
[2019-12-20 10:00:25] VERBOSE[14920] pbx.c: -- Goto (macro-dial-one,h,1)
[2019-12-20 10:00:25] VERBOSE[14920] pbx.c: -- Executing [h@macro-dial-one:1] Macro("SIP/10215-0001f2d6", "hangupcall,") in new stack
[2019-12-20 10:00:25] VERBOSE[14920] pbx.c: -- Executing [s@macro-hangupcall:1] GotoIf("SIP/10215-0001f2d6", "1?skiprg") in new stack
[2019-12-20 10:00:25] VERBOSE[14920] pbx.c: -- Goto (macro-hangupcall,s,4)
[2019-12-20 10:00:25] VERBOSE[14920] pbx.c: -- Executing [s@macro-hangupcall:4] GotoIf("SIP/10215-0001f2d6", "1?skipblkvm") in new stack
[2019-12-20 10:00:25] VERBOSE[14920] pbx.c: -- Goto (macro-hangupcall,s,7)
[2019-12-20 10:00:25] VERBOSE[14920] pbx.c: -- Executing [s@macro-hangupcall:7] GotoIf("SIP/10215-0001f2d6", "1?theend") in new stack
[2019-12-20 10:00:25] VERBOSE[14920] pbx.c: -- Goto (macro-hangupcall,s,9)
[2019-12-20 10:00:25] VERBOSE[14920] pbx.c: -- Executing [s@macro-hangupcall:9] Set("SIP/10215-0001f2d6", "CDR(from_did)=") in new stack
[2019-12-20 10:00:25] VERBOSE[14920] pbx.c: -- Executing [s@macro-hangupcall:10] Hangup("SIP/10215-0001f2d6", "") in new stack
[2019-12-20 10:00:25] VERBOSE[14920] app_macro.c: == Spawn extension (macro-hangupcall, s, 10) exited non-zero on 'SIP/10215-0001f2d6' in macro 'hangupcall'
[2019-12-20 10:00:25] VERBOSE[14920] app_macro.c: == Spawn extension (macro-dial-one, h, 1) exited non-zero on 'SIP/10215-0001f2d6' in macro 'dial-one'
[2019-12-20 10:00:25] VERBOSE[14920] app_macro.c: == Spawn extension (macro-exten-vm, s, 9) exited non-zero on 'SIP/10215-0001f2d6' in macro 'exten-vm'
[2019-12-20 10:00:25] VERBOSE[14920] pbx.c: == Spawn extension (from-internal, 95, 1) exited non-zero on 'SIP/10215-0001f2d6'
[2019-12-20 10:00:25] VERBOSE[14920] pbx.c: -- Executing [h@from-internal:1] Macro("SIP/10215-0001f2d6", "hangupcall") in new stack
[2019-12-20 10:00:25] VERBOSE[14920] pbx.c: == Spawn extension (from-internal, h, 1) exited non-zero on 'SIP/10215-0001f2d6'
[2019-12-20 10:00:25] VERBOSE[14923] app_mixmonitor.c: == MixMonitor close filestream
[2019-12-20 10:00:25] VERBOSE[14923] app_mixmonitor.c: == End MixMonitor Recording SIP/10215-0001f2d6
Re: Нет видео с домофона
Думаете всё из коробки заработает? Нет.
Надо
1. проверить, что вообще у вас включен
videosupport=yes
и что в разрешённые кодеки на видеопирах включен тот, которым они связываются, например
allow=h264
Затем вы включите
sip set debug peer 95
и сделаете по крайней мере селф тест - на *43
Должны увидеть сами себя.
Проанализировать инвайт и sdp.
И тогда всё получится между домофонами.
moredel
Сообщение moredel »
Дак вроде всё включено, я просто из веб интерфейса настраивал
ded писал(а): включите
