входящий звонок снаружи не проходит
modsamara
Сообщение modsamara »
транк зарегистрирован. что в астере что у провайдера
железная леди говорит
you have dialed is not in use
в логах
[2019-11-22 17:42:18] WARNING[14689][C-00000012] app_dial.c: Unable to create channel of type 'SIP' (cause 20 - Subscriber absent)
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] app_dial.c: Everyone is busy/congested at this time (1:0/0/1)
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx.c: Executing [s@macro-dial:25] Set("SIP/siplink_NUX-00000012", "DIALSTATUS=CHANUNAVAIL") in new stack
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx.c: Executing [s@macro-dial:26] GosubIf("SIP/siplink_NUX-00000012", "0?CHANUNAVAIL,1()") in new stack
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx.c: Executing [s@macro-dial:27] NoOp("SIP/siplink_NUX-00000012", "Returning since nobody answered") in new stack
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx.c: Executing [s@macro-dial:28] MacroExit("SIP/siplink_NUX-00000012", "") in new stack
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx.c: Executing [301@followme-sub:41] Goto("SIP/siplink_NUX-00000012", "nextstep") in new stack
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx_builtins.c: Goto (followme-sub,301,46)
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx.c: Executing [301@followme-sub:46] Set("SIP/siplink_NUX-00000012", "RingGroupMethod=") in new stack
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx.c: Executing [301@followme-sub:47] GotoIf("SIP/siplink_NUX-00000012", "0?nodest") in new stack
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx.c: Executing [301@followme-sub:48] Set("SIP/siplink_NUX-00000012", "__NODEST=") in new stack
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx.c: Executing [301@followme-sub:49] Set("SIP/siplink_NUX-00000012", "__PICKUPMARK=") in new stack
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx.c: Executing [301@followme-sub:50] Macro("SIP/siplink_NUX-00000012", "blkvm-clr,") in new stack
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx.c: Executing [s@macro-blkvm-clr:1] Set("SIP/siplink_NUX-00000012", "SHARED(BLKVM,SIP/siplink_NUX-00000012)=") in new stack
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx.c: Executing [s@macro-blkvm-clr:2] Set("SIP/siplink_NUX-00000012", "GOSUB_RETVAL=") in new stack
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx.c: Executing [s@macro-blkvm-clr:3] MacroExit("SIP/siplink_NUX-00000012", "") in new stack
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx.c: Executing [301@followme-sub:51] Set("SIP/siplink_NUX-00000012", "DIALSTATUS=CHANUNAVAIL") in new stack
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx.c: Executing [301@followme-sub:52] GotoIf("SIP/siplink_NUX-00000012", "0?dohangup") in new stack
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx.c: Executing [301@followme-sub:53] Goto("SIP/siplink_NUX-00000012", "ext-local,301,dest") in new stack
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx_builtins.c: Goto (ext-local,301,3)
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx.c: Executing [301@ext-local:3] Set("SIP/siplink_NUX-00000012", "__PICKUPMARK=") in new stack
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx.c: Executing [301@ext-local:4] GotoIf("SIP/siplink_NUX-00000012", "0?,return,1") in new stack
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx.c: Auto fallthrough, channel 'SIP/siplink_NUX-00000012' status is 'CHANUNAVAIL'
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx.c: Executing [h@ext-local:1] Macro("SIP/siplink_NUX-00000012", "hangupcall,") in new stack
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx.c: Executing [s@macro-hangupcall:1] GotoIf("SIP/siplink_NUX-00000012", "1?theend") in new stack
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx_builtins.c: Goto (macro-hangupcall,s,3)
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx.c: Executing [s@macro-hangupcall:3] ExecIf("SIP/siplink_NUX-00000012", "0?Set(CDR(recordingfile)=)") in new stack
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx.c: Executing [s@macro-hangupcall:4] NoOp("SIP/siplink_NUX-00000012", " montior file= ") in new stack
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx.c: Executing [s@macro-hangupcall:5] GotoIf("SIP/siplink_NUX-00000012", "1?skipagi") in new stack
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx_builtins.c: Goto (macro-hangupcall,s,7)
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx.c: Executing [s@macro-hangupcall:7] Hangup("SIP/siplink_NUX-00000012", "") in new stack
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] app_macro.c: Spawn extension (macro-hangupcall, s, 7) exited non-zero on 'SIP/siplink_NUX-00000012' in macro 'hangupcall'
[2019-11-22 17:42:18] VERBOSE[14689][C-00000012] pbx.c: Spawn extension (ext-local, h, 1) exited non-zero on 'SIP/siplink_NUX-00000012'
[2019-11-22 17:42:19] VERBOSE[1798][C-00000013] netsock2.c: Using SIP RTP TOS bits 184
[2019-11-22 17:42:19] VERBOSE[1798][C-00000013] netsock2.c: Using SIP RTP CoS mark 5
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [73494927850@from-trunk-sip-siplink_NUX:1] Set("SIP/siplink_NUX-00000013", "GROUP()=OUT_1") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [73494927850@from-trunk-sip-siplink_NUX:2] Goto("SIP/siplink_NUX-00000013", "from-trunk,73494927850,1") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx_builtins.c: Goto (from-trunk,73494927850,1)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [73494927850@from-trunk:1] NoOp("SIP/siplink_NUX-00000013", "Catch-All DID Match - Found 73494927850 - You probably want a DID for this.") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [73494927850@from-trunk:2] Set("SIP/siplink_NUX-00000013", "__FROM_DID=73494927850") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [73494927850@from-trunk:3] Goto("SIP/siplink_NUX-00000013", "ext-did,s,1") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx_builtins.c: Goto (ext-did,s,1)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@ext-did:1] Set("SIP/siplink_NUX-00000013", "__DIRECTION=INBOUND") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@ext-did:2] Set("SIP/siplink_NUX-00000013", "CHANNEL(language)=ru") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@ext-did:3] Gosub("SIP/siplink_NUX-00000013", "sub-record-check,s,1(in,s,dontcare)") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@sub-record-check:1] GotoIf("SIP/siplink_NUX-00000013", "0?initialized") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@sub-record-check:2] Set("SIP/siplink_NUX-00000013", "__REC_STATUS=INITIALIZED") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@sub-record-check:3] Set("SIP/siplink_NUX-00000013", "NOW=1574426539") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@sub-record-check:4] Set("SIP/siplink_NUX-00000013", "__DAY=22") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@sub-record-check:5] Set("SIP/siplink_NUX-00000013", "__MONTH=11") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@sub-record-check:6] Set("SIP/siplink_NUX-00000013", "__YEAR=2019") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@sub-record-check:7] Set("SIP/siplink_NUX-00000013", "__TIMESTR=20191122-174219") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@sub-record-check:8] Set("SIP/siplink_NUX-00000013", "__FROMEXTEN=unknown") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@sub-record-check:9] Set("SIP/siplink_NUX-00000013", "__MON_FMT=wav") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@sub-record-check:10] NoOp("SIP/siplink_NUX-00000013", "Recordings initialized") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@sub-record-check:11] ExecIf("SIP/siplink_NUX-00000013", "0?Set(ARG3=dontcare)") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@sub-record-check:12] Set("SIP/siplink_NUX-00000013", "REC_POLICY_MODE_SAVE=") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@sub-record-check:13] ExecIf("SIP/siplink_NUX-00000013", "0?Set(REC_STATUS=NO)") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@sub-record-check:14] GotoIf("SIP/siplink_NUX-00000013", "2?checkaction") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx_builtins.c: Goto (sub-record-check,s,17)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@sub-record-check:17] GotoIf("SIP/siplink_NUX-00000013", "1?sub-record-check,in,1") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx_builtins.c: Goto (sub-record-check,in,1)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [in@sub-record-check:1] NoOp("SIP/siplink_NUX-00000013", "Inbound Recording Check to s") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [in@sub-record-check:2] Set("SIP/siplink_NUX-00000013", "FROMEXTEN=unknown") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [in@sub-record-check:3] ExecIf("SIP/siplink_NUX-00000013", "11?Set(FROMEXTEN=74956401671)") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [in@sub-record-check:4] Gosub("SIP/siplink_NUX-00000013", "recordcheck,1(dontcare,in,s)") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [recordcheck@sub-record-check:1] NoOp("SIP/siplink_NUX-00000013", "Starting recording check against dontcare") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [recordcheck@sub-record-check:2] Goto("SIP/siplink_NUX-00000013", "dontcare") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx_builtins.c: Goto (sub-record-check,recordcheck,3)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [recordcheck@sub-record-check:3] Return("SIP/siplink_NUX-00000013", "") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [in@sub-record-check:5] Return("SIP/siplink_NUX-00000013", "") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@ext-did:4] Set("SIP/siplink_NUX-00000013", "CHANNEL(tonezone)=us") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@ext-did:5] ExecIf("SIP/siplink_NUX-00000013", "0?Set(__FROM_DID=s)") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@ext-did:6] Set("SIP/siplink_NUX-00000013", "returnhere=1") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@ext-did:7] Gosub("SIP/siplink_NUX-00000013", "app-blacklist-check,s,1()") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@app-blacklist-check:1] GotoIf("SIP/siplink_NUX-00000013", "0?blacklisted") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@app-blacklist-check:2] Set("SIP/siplink_NUX-00000013", "CALLED_BLACKLIST=1") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@app-blacklist-check:3] Return("SIP/siplink_NUX-00000013", "") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@ext-did:8] Set("SIP/siplink_NUX-00000013", "CDR(did)=73494927850") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@ext-did:9] GotoIf("SIP/siplink_NUX-00000013", "0?") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@ext-did:10] ExecIf("SIP/siplink_NUX-00000013", "1 ?Set(CALLERID(name)=74956401671)") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@ext-did:11] Set("SIP/siplink_NUX-00000013", "__MOHCLASS=") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@ext-did:12] Set("SIP/siplink_NUX-00000013", "__REVERSAL_REJECT=FALSE") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@ext-did:13] GotoIf("SIP/siplink_NUX-00000013", "1?post-reverse-charge") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx_builtins.c: Goto (ext-did,s,15)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@ext-did:15] NoOp("SIP/siplink_NUX-00000013", "") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@ext-did:16] Set("SIP/siplink_NUX-00000013", "__CALLINGNAMEPRES_SV=allowed_not_screened") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@ext-did:17] Set("SIP/siplink_NUX-00000013", "__CALLINGNUMPRES_SV=allowed_not_screened") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@ext-did:18] Set("SIP/siplink_NUX-00000013", "CALLERID(name-pres)=allowed_not_screened") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@ext-did:19] Set("SIP/siplink_NUX-00000013", "CALLERID(num-pres)=allowed_not_screened") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@ext-did:20] NoOp("SIP/siplink_NUX-00000013", "CallerID Entry Point") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@ext-did:21] Goto("SIP/siplink_NUX-00000013", "from-did-direct,301,1") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx_builtins.c: Goto (from-did-direct,301,1)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@from-did-direct:1] GotoIf("SIP/siplink_NUX-00000013", "0?ext-local,301,1:followme-check,301,1") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx_builtins.c: Goto (followme-check,301,1)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-check:1] Gosub("SIP/siplink_NUX-00000013", "followme-sub,301,1()") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:1] Macro("SIP/siplink_NUX-00000013", "user-callerid,") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-user-callerid:1] Set("SIP/siplink_NUX-00000013", "TOUCH_MONITOR=1574426539.19") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-user-callerid:2] Set("SIP/siplink_NUX-00000013", "AMPUSER=74956401671") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-user-callerid:3] GotoIf("SIP/siplink_NUX-00000013", "0?report") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-user-callerid:4] ExecIf("SIP/siplink_NUX-00000013", "1?Set(REALCALLERIDNUM=74956401671)") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-user-callerid:5] Set("SIP/siplink_NUX-00000013", "AMPUSER=") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-user-callerid:6] GotoIf("SIP/siplink_NUX-00000013", "0?limit") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-user-callerid:7] Set("SIP/siplink_NUX-00000013", "AMPUSERCIDNAME=") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-user-callerid:8] ExecIf("SIP/siplink_NUX-00000013", "0?Set(__CIDMASQUERADING=TRUE)") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-user-callerid:9] GotoIf("SIP/siplink_NUX-00000013", "1?report") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx_builtins.c: Goto (macro-user-callerid,s,17)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-user-callerid:17] NoOp("SIP/siplink_NUX-00000013", "Macro Depth is 1") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-user-callerid:18] GotoIf("SIP/siplink_NUX-00000013", "1?report2:macroerror") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx_builtins.c: Goto (macro-user-callerid,s,19)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-user-callerid:19] GotoIf("SIP/siplink_NUX-00000013", "0?continue") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-user-callerid:20] Set("SIP/siplink_NUX-00000013", "__TTL=64") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-user-callerid:21] GotoIf("SIP/siplink_NUX-00000013", "1?continue") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx_builtins.c: Goto (macro-user-callerid,s,37)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-user-callerid:37] Set("SIP/siplink_NUX-00000013", "CALLERID(number)=74956401671") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-user-callerid:38] Set("SIP/siplink_NUX-00000013", "CALLERID(name)=74956401671") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-user-callerid:39] GotoIf("SIP/siplink_NUX-00000013", "0?cnum") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-user-callerid:40] Set("SIP/siplink_NUX-00000013", "CDR(cnam)=74956401671") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-user-callerid:41] Set("SIP/siplink_NUX-00000013", "CDR(cnum)=74956401671") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-user-callerid:42] Set("SIP/siplink_NUX-00000013", "CHANNEL(language)=ru") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:2] Set("SIP/siplink_NUX-00000013", "DIAL_OPTIONS=HhTtrI") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:3] Set("SIP/siplink_NUX-00000013", "CONNECTEDLINE(num,i)=301") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:4] Gosub("SIP/siplink_NUX-00000013", "sub-presencestate-display,s,1(301)") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@sub-presencestate-display:1] Goto("SIP/siplink_NUX-00000013", "state-not_set,1") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx_builtins.c: Goto (sub-presencestate-display,state-not_set,1)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [state-not_set@sub-presencestate-display:1] Set("SIP/siplink_NUX-00000013", "PRESENCESTATE_DISPLAY=") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [state-not_set@sub-presencestate-display:2] Return("SIP/siplink_NUX-00000013", "") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:5] Set("SIP/siplink_NUX-00000013", "CONNECTEDLINE(name)=301") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:6] Set("SIP/siplink_NUX-00000013", "FM_DIALSTATUS=UNAVAILABLE") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:7] Set("SIP/siplink_NUX-00000013", "__EXTTOCALL=301") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:8] Set("SIP/siplink_NUX-00000013", "__PICKUPMARK=301") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:9] Macro("SIP/siplink_NUX-00000013", "blkvm-setifempty,") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-blkvm-setifempty:1] GotoIf("SIP/siplink_NUX-00000013", "1?init") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx_builtins.c: Goto (macro-blkvm-setifempty,s,4)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-blkvm-setifempty:4] Set("SIP/siplink_NUX-00000013", "__BLKVM_CHANNEL=SIP/siplink_NUX-00000013") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-blkvm-setifempty:5] Set("SIP/siplink_NUX-00000013", "SHARED(BLKVM,SIP/siplink_NUX-00000013)=TRUE") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-blkvm-setifempty:6] Set("SIP/siplink_NUX-00000013", "GOSUB_RETVAL=TRUE") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-blkvm-setifempty:7] MacroExit("SIP/siplink_NUX-00000013", "") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:10] GotoIf("SIP/siplink_NUX-00000013", "1?skipov") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx_builtins.c: Goto (followme-sub,301,13)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:13] Set("SIP/siplink_NUX-00000013", "RRNODEST=") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:14] Set("SIP/siplink_NUX-00000013", "__NODEST=301") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:15] GosubIf("SIP/siplink_NUX-00000013", "0?sub-fmsetcid,s,1()") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:16] GotoIf("SIP/siplink_NUX-00000013", "1?skipprepend") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx_builtins.c: Goto (followme-sub,301,18)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:18] Set("SIP/siplink_NUX-00000013", "RecordMethod=Group") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:19] Gosub("SIP/siplink_NUX-00000013", "sub-record-check,s,1(exten,301,)") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@sub-record-check:1] GotoIf("SIP/siplink_NUX-00000013", "11?initialized") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx_builtins.c: Goto (sub-record-check,s,10)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@sub-record-check:11] ExecIf("SIP/siplink_NUX-00000013", "1?Set(ARG3=dontcare)") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@sub-record-check:14] GotoIf("SIP/siplink_NUX-00000013", "5?checkaction") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@sub-record-check:17] GotoIf("SIP/siplink_NUX-00000013", "1?sub-record-check,exten,1") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx_builtins.c: Goto (sub-record-check,exten,1)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [exten@sub-record-check:1] NoOp("SIP/siplink_NUX-00000013", "Exten Recording Check between 74956401671 and 301") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [exten@sub-record-check:2] Set("SIP/siplink_NUX-00000013", "CALLTYPE=external") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [exten@sub-record-check:3] ExecIf("SIP/siplink_NUX-00000013", "0?Set(CALLTYPE=)") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [exten@sub-record-check:4] Set("SIP/siplink_NUX-00000013", "CALLEE=dontcare") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [exten@sub-record-check:5] ExecIf("SIP/siplink_NUX-00000013", "0?Set(CALLEE=dontcare)") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [exten@sub-record-check:6] GotoIf("SIP/siplink_NUX-00000013", "1?callee") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx_builtins.c: Goto (sub-record-check,exten,11)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [exten@sub-record-check:11] Gosub("SIP/siplink_NUX-00000013", "recordcheck,1(dontcare,external,301)") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [exten@sub-record-check:12] Return("SIP/siplink_NUX-00000013", "") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:20] GotoIf("SIP/siplink_NUX-00000013", "1?skipdring") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx_builtins.c: Goto (followme-sub,301,23)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:23] Set("SIP/siplink_NUX-00000013", "STRATEGY=ringallv2-prim") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:24] Set("SIP/siplink_NUX-00000013", "__RVOL=") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:25] GotoIf("SIP/siplink_NUX-00000013", "1?skipsimple") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx_builtins.c: Goto (followme-sub,301,28)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:28] Set("SIP/siplink_NUX-00000013", "RingGroupMethod=ringallv2-prim") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:29] Set("SIP/siplink_NUX-00000013", "_FMGRP=301") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:30] GotoIf("SIP/siplink_NUX-00000013", "1?DIALGRP") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx_builtins.c: Goto (followme-sub,301,34)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:34] ExecIf("SIP/siplink_NUX-00000013", "1?Set(DOPTS=HhTtrI):Set(DOPTS=m(Ring)HhTtI)") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:35] Set("SIP/siplink_NUX-00000013", "__ALT_CONFIRM_MSG=") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:36] GotoIf("SIP/siplink_NUX-00000013", "0?doconfirm") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:37] GotoIf("SIP/siplink_NUX-00000013", "1?ringallv21") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx_builtins.c: Goto (followme-sub,301,40)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:40] Macro("SIP/siplink_NUX-00000013", "dial,27,HhTtrI,301") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-dial:1] NoOp("SIP/siplink_NUX-00000013", "Blind Transfer: , Attended Transfer: , User: , Alert Info: ") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-dial:2] ExecIf("SIP/siplink_NUX-00000013", "0?Set(ALERT_INFO=)") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-dial:3] ExecIf("SIP/siplink_NUX-00000013", "0?Set(ALERT_INFO=)") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-dial:4] ExecIf("SIP/siplink_NUX-00000013", "0?Set(ALERT_INFO=)") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-dial:5] ExecIf("SIP/siplink_NUX-00000013", "0?Set(CHANNEL(musicclass)=)") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-dial:6] AGI("SIP/siplink_NUX-00000013", "agi://127.0.0.1/dialparties.agi") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] res_agi.c: agi://127.0.0.1/dialparties.agi: Starting New Dialparties.agi
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] res_agi.c: agi://127.0.0.1/dialparties.agi: Caller ID name is '74956401671' number is '74956401671'
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] res_agi.c: agi://127.0.0.1/dialparties.agi: CW Ignore is:
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] res_agi.c: agi://127.0.0.1/dialparties.agi: CF Ignore is:
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] res_agi.c: agi://127.0.0.1/dialparties.agi: CW IN_USE/BUSY is: 1
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] res_agi.c: agi://127.0.0.1/dialparties.agi: Methodology of ring is 'ringallv2-prim'
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] res_agi.c: agi://127.0.0.1/dialparties.agi: Added extension 301 to extension map
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] res_agi.c: agi://127.0.0.1/dialparties.agi: Extension 301 cf is disabled
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] res_agi.c: agi://127.0.0.1/dialparties.agi: Extension 301 do not disturb is disabled
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] res_agi.c: agi://127.0.0.1/dialparties.agi: EXTENSION_STATE: 4 (UNAVAILABLE)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] res_agi.c: agi://127.0.0.1/dialparties.agi: Extension 301 has ExtensionState: 4
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] res_agi.c: agi://127.0.0.1/dialparties.agi: dbset CALLTRACE/301 to 74956401671
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] res_agi.c: agi://127.0.0.1/dialparties.agi: Filtered ARG3: 301
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] res_agi.c: agi://127.0.0.1/dialparties.agi: RING ALL V2 :
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] res_agi.c: agi://127.0.0.1/dialparties.agi: RVOL_MODE ''
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] res_agi.c: agi://127.0.0.1/dialparties.agi: RVOL is:
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] res_agi.c: agi://127.0.0.1/dialparties.agi: RVOLPARENT is:
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] res_agi.c: <SIP/siplink_NUX-00000013>AGI Script agi://127.0.0.1/dialparties.agi completed, returning 0
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-dial:7] GotoIf("SIP/siplink_NUX-00000013", "1?normdial") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx_builtins.c: Goto (macro-dial,s,10)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-dial:10] NoOp("SIP/siplink_NUX-00000013", "Returned from dialparties with groups to dial") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-dial:11] NoOp("SIP/siplink_NUX-00000013", "ringall array ") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-dial:12] Set("SIP/siplink_NUX-00000013", "__FMGL_DIAL=") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-dial:13] Set("SIP/siplink_NUX-00000013", "LOOPCNT=1") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-dial:14] Set("SIP/siplink_NUX-00000013", "ITER=1") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-dial:15] Set("SIP/siplink_NUX-00000013", "__EXTTOCALL=301") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-dial:16] NoOp("SIP/siplink_NUX-00000013", "Working with 301") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-dial:17] ExecIf("SIP/siplink_NUX-00000013", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-dial:18] ExecIf("SIP/siplink_NUX-00000013", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-dial:19] Set("SIP/siplink_NUX-00000013", "ITER=2") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-dial:20] GotoIf("SIP/siplink_NUX-00000013", "0?ndloopbegin") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-dial:21] Macro("SIP/siplink_NUX-00000013", "dial-ringall-predial-hook,") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-dial-ringall-predial-hook:1] MacroExit("SIP/siplink_NUX-00000013", "") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-dial:22] ExecIf("SIP/siplink_NUX-00000013", "0?Set(CWRING=r(callwaiting)):Set(CWRING=)") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-dial:23] ExecIf("SIP/siplink_NUX-00000013", "0?Set(ds=SIP/301,27,HhtrIM(auto-blkvm)g)") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-dial:24] Dial("SIP/siplink_NUX-00000013", "SIP/301,27,HhtrIM(auto-blkvm)b(func-apply-sipheaders^s^1),") in new stack
[2019-11-22 17:42:19] WARNING[14693][C-00000013] app_dial.c: Unable to create channel of type 'SIP' (cause 20 - Subscriber absent)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] app_dial.c: Everyone is busy/congested at this time (1:0/0/1)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-dial:25] Set("SIP/siplink_NUX-00000013", "DIALSTATUS=CHANUNAVAIL") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-dial:26] GosubIf("SIP/siplink_NUX-00000013", "0?CHANUNAVAIL,1()") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-dial:27] NoOp("SIP/siplink_NUX-00000013", "Returning since nobody answered") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-dial:28] MacroExit("SIP/siplink_NUX-00000013", "") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:41] Goto("SIP/siplink_NUX-00000013", "nextstep") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx_builtins.c: Goto (followme-sub,301,46)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:46] Set("SIP/siplink_NUX-00000013", "RingGroupMethod=") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:47] GotoIf("SIP/siplink_NUX-00000013", "0?nodest") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:48] Set("SIP/siplink_NUX-00000013", "__NODEST=") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:49] Set("SIP/siplink_NUX-00000013", "__PICKUPMARK=") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:50] Macro("SIP/siplink_NUX-00000013", "blkvm-clr,") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-blkvm-clr:1] Set("SIP/siplink_NUX-00000013", "SHARED(BLKVM,SIP/siplink_NUX-00000013)=") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-blkvm-clr:2] Set("SIP/siplink_NUX-00000013", "GOSUB_RETVAL=") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-blkvm-clr:3] MacroExit("SIP/siplink_NUX-00000013", "") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:51] Set("SIP/siplink_NUX-00000013", "DIALSTATUS=CHANUNAVAIL") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:52] GotoIf("SIP/siplink_NUX-00000013", "0?dohangup") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@followme-sub:53] Goto("SIP/siplink_NUX-00000013", "ext-local,301,dest") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx_builtins.c: Goto (ext-local,301,3)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@ext-local:3] Set("SIP/siplink_NUX-00000013", "__PICKUPMARK=") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [301@ext-local:4] GotoIf("SIP/siplink_NUX-00000013", "0?,return,1") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Auto fallthrough, channel 'SIP/siplink_NUX-00000013' status is 'CHANUNAVAIL'
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [h@ext-local:1] Macro("SIP/siplink_NUX-00000013", "hangupcall,") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-hangupcall:1] GotoIf("SIP/siplink_NUX-00000013", "1?theend") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx_builtins.c: Goto (macro-hangupcall,s,3)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-hangupcall:3] ExecIf("SIP/siplink_NUX-00000013", "0?Set(CDR(recordingfile)=)") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-hangupcall:4] NoOp("SIP/siplink_NUX-00000013", " montior file= ") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-hangupcall:5] GotoIf("SIP/siplink_NUX-00000013", "1?skipagi") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx_builtins.c: Goto (macro-hangupcall,s,7)
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Executing [s@macro-hangupcall:7] Hangup("SIP/siplink_NUX-00000013", "") in new stack
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] app_macro.c: Spawn extension (macro-hangupcall, s, 7) exited non-zero on 'SIP/siplink_NUX-00000013' in macro 'hangupcall'
[2019-11-22 17:42:19] VERBOSE[14693][C-00000013] pbx.c: Spawn extension (ext-local, h, 1) exited non-zero on 'SIP/siplink_NUX-00000013'
Re: входящий звонок снаружи не проходит
Дебажить проблему по сообщениям железной тётеньки в трубке - путь неверный. Вы не блондинка?
Пробовали свой лог читать? Что происходит на 53-м шаге для абонента 301@followme-sub - откуда передаётся в
301@ext-local и почему он ищет его дальше на транке SIP/siplink_NUX?
Намудрить логику и запутать можно легко.
modsamara
да я вроде не настраивал ничего пока что, чтобы логику намудрить
modsamara
добавил свой CID во входящий маршрут
теперь по русски говорит :)
набранный вами номер отключен, проверьте номер и повторите попытку
в логе при этом
[2019-11-23 17:23:48] VERBOSE[29357] loader.c: Reloading module 'func_odbc.so' (ODBC lookups)
[2019-11-23 17:23:48] VERBOSE[29357] loader.c: Reloading module 'app_queue.so' (True Call Queueing)
[2019-11-23 17:23:48] NOTICE[29357] app_queue.c: queuerules.conf has not changed since it was last loaded. Not taking any action.
[2019-11-23 17:23:48] VERBOSE[29357] asterisk.c: Remote UNIX connection disconnected
[2019-11-23 17:24:09] VERBOSE[1798][C-00000017] netsock2.c: Using SIP RTP TOS bits 184
[2019-11-23 17:24:09] VERBOSE[1798][C-00000017] netsock2.c: Using SIP RTP CoS mark 5
[2019-11-23 17:24:09] VERBOSE[29460][C-00000017] pbx.c: Executing [73494927850@from-trunk-sip-siplink_NUX:1] Set("SIP/siplink_NUX-00000017", "GROUP()=OUT_1") in new stack
[2019-11-23 17:24:09] VERBOSE[29460][C-00000017] pbx.c: Executing [73494927850@from-trunk-sip-siplink_NUX:2] Goto("SIP/siplink_NUX-00000017", "from-trunk,73494927850,1") in new stack
[2019-11-23 17:24:09] VERBOSE[29460][C-00000017] pbx_builtins.c: Goto (from-trunk,73494927850,1)
[2019-11-23 17:24:09] VERBOSE[29460][C-00000017] pbx.c: Executing [73494927850@from-trunk:1] Set("SIP/siplink_NUX-00000017", "__FROM_DID=73494927850") in new stack
[2019-11-23 17:24:09] VERBOSE[29460][C-00000017] pbx.c: Executing [73494927850@from-trunk:2] NoOp("SIP/siplink_NUX-00000017", "Received an unknown call with DID set to 73494927850") in new stack
[2019-11-23 17:24:09] VERBOSE[29460][C-00000017] pbx.c: Executing [73494927850@from-trunk:3] Goto("SIP/siplink_NUX-00000017", "s,a2") in new stack
[2019-11-23 17:24:09] VERBOSE[29460][C-00000017] pbx_builtins.c: Goto (from-trunk,s,2)
[2019-11-23 17:24:09] VERBOSE[29460][C-00000017] pbx.c: Executing [s@from-trunk:2] Answer("SIP/siplink_NUX-00000017", "") in new stack
[2019-11-23 17:24:10] VERBOSE[29460][C-00000017] pbx.c: Executing [s@from-trunk:3] Log("SIP/siplink_NUX-00000017", "WARNING,Friendly Scanner from 89.108.107.101") in new stack
[2019-11-23 17:24:10] WARNING[29460][C-00000017] Ext. s: Friendly Scanner from 89.108.107.101
[2019-11-23 17:24:10] VERBOSE[29460][C-00000017] pbx.c: Executing [s@from-trunk:4] Wait("SIP/siplink_NUX-00000017", "2") in new stack
[2019-11-23 17:24:12] VERBOSE[29460][C-00000017] pbx.c: Executing [s@from-trunk:5] Playback("SIP/siplink_NUX-00000017", "ss-noservice") in new stack
[2019-11-23 17:24:12] VERBOSE[29460][C-00000017] file.c: <SIP/siplink_NUX-00000017> Playing 'ss-noservice.ulaw' (language 'ru')
[2019-11-23 17:24:16] VERBOSE[29460][C-00000017] pbx.c: Executing [s@from-trunk:6] SayAlpha("SIP/siplink_NUX-00000017", "73494927850") in new stack
[2019-11-23 17:24:16] VERBOSE[29460][C-00000017] file.c: <SIP/siplink_NUX-00000017> Playing 'digits/7.ulaw' (language 'ru')
[2019-11-23 17:24:17] VERBOSE[29460][C-00000017] file.c: <SIP/siplink_NUX-00000017> Playing 'digits/3.ulaw' (language 'ru')
[2019-11-23 17:24:17] VERBOSE[29460][C-00000017] pbx.c: Spawn extension (from-trunk, s, 6) exited non-zero on 'SIP/siplink_NUX-00000017'
[2019-11-23 17:24:17] VERBOSE[29460][C-00000017] pbx.c: Executing [h@from-trunk:1] Macro("SIP/siplink_NUX-00000017", "hangupcall,") in new stack
[2019-11-23 17:24:17] VERBOSE[29460][C-00000017] pbx.c: Executing [s@macro-hangupcall:1] GotoIf("SIP/siplink_NUX-00000017", "1?theend") in new stack
[2019-11-23 17:24:17] VERBOSE[29460][C-00000017] pbx_builtins.c: Goto (macro-hangupcall,s,3)
[2019-11-23 17:24:17] VERBOSE[29460][C-00000017] pbx.c: Executing [s@macro-hangupcall:3] ExecIf("SIP/siplink_NUX-00000017", "0?Set(CDR(recordingfile)=)") in new stack
[2019-11-23 17:24:17] VERBOSE[29460][C-00000017] pbx.c: Executing [s@macro-hangupcall:4] NoOp("SIP/siplink_NUX-00000017", " montior file= ") in new stack
[2019-11-23 17:24:17] VERBOSE[29460][C-00000017] pbx.c: Executing [s@macro-hangupcall:5] GotoIf("SIP/siplink_NUX-00000017", "1?skipagi") in new stack
[2019-11-23 17:24:17] VERBOSE[29460][C-00000017] pbx_builtins.c: Goto (macro-hangupcall,s,7)
[2019-11-23 17:24:17] VERBOSE[29460][C-00000017] pbx.c: Executing [s@macro-hangupcall:7] Hangup("SIP/siplink_NUX-00000017", "") in new stack
[2019-11-23 17:24:17] VERBOSE[29460][C-00000017] app_macro.c: Spawn extension (macro-hangupcall, s, 7) exited non-zero on 'SIP/siplink_NUX-00000017' in macro 'hangupcall'
[2019-11-23 17:24:17] VERBOSE[29460][C-00000017] pbx.c: Spawn extension (from-trunk, h, 1) exited non-zero on 'SIP/siplink_NUX-00000017'
[2019-11-23 17:25:53] VERBOSE[1798][C-00000018] netsock2.c: Using SIP RTP TOS bits 184
[2019-11-23 17:25:53] VERBOSE[1798][C-00000018] netsock2.c: Using SIP RTP CoS mark 5
[2019-11-23 17:25:53] VERBOSE[29558][C-00000018] pbx.c: Executing [73494927850@from-trunk-sip-siplink_NUX:1] Set("SIP/siplink_NUX-00000018", "GROUP()=OUT_1") in new stack
[2019-11-23 17:25:53] VERBOSE[29558][C-00000018] pbx.c: Executing [73494927850@from-trunk-sip-siplink_NUX:2] Goto("SIP/siplink_NUX-00000018", "from-trunk,73494927850,1") in new stack
[2019-11-23 17:25:53] VERBOSE[29558][C-00000018] pbx_builtins.c: Goto (from-trunk,73494927850,1)
[2019-11-23 17:25:53] VERBOSE[29558][C-00000018] pbx.c: Executing [73494927850@from-trunk:1] Set("SIP/siplink_NUX-00000018", "__FROM_DID=73494927850") in new stack
[2019-11-23 17:25:53] VERBOSE[29558][C-00000018] pbx.c: Executing [73494927850@from-trunk:2] NoOp("SIP/siplink_NUX-00000018", "Received an unknown call with DID set to 73494927850") in new stack
[2019-11-23 17:25:53] VERBOSE[29558][C-00000018] pbx.c: Executing [73494927850@from-trunk:3] Goto("SIP/siplink_NUX-00000018", "s,a2") in new stack
[2019-11-23 17:25:53] VERBOSE[29558][C-00000018] pbx_builtins.c: Goto (from-trunk,s,2)
[2019-11-23 17:25:53] VERBOSE[29558][C-00000018] pbx.c: Executing [s@from-trunk:2] Answer("SIP/siplink_NUX-00000018", "") in new stack
[2019-11-23 17:25:54] VERBOSE[29558][C-00000018] pbx.c: Executing [s@from-trunk:3] Log("SIP/siplink_NUX-00000018", "WARNING,Friendly Scanner from 89.108.107.101") in new stack
[2019-11-23 17:25:54] WARNING[29558][C-00000018] Ext. s: Friendly Scanner from 89.108.107.101
[2019-11-23 17:25:54] VERBOSE[29558][C-00000018] pbx.c: Executing [s@from-trunk:4] Wait("SIP/siplink_NUX-00000018", "2") in new stack
[2019-11-23 17:25:56] VERBOSE[29558][C-00000018] pbx.c: Executing [s@from-trunk:5] Playback("SIP/siplink_NUX-00000018", "ss-noservice") in new stack
[2019-11-23 17:25:56] VERBOSE[29558][C-00000018] file.c: <SIP/siplink_NUX-00000018> Playing 'ss-noservice.ulaw' (language 'ru')
[2019-11-23 17:26:00] VERBOSE[29558][C-00000018] pbx.c: Executing [s@from-trunk:6] SayAlpha("SIP/siplink_NUX-00000018", "73494927850") in new stack
[2019-11-23 17:26:00] VERBOSE[29558][C-00000018] file.c: <SIP/siplink_NUX-00000018> Playing 'digits/7.ulaw' (language 'ru')
[2019-11-23 17:26:01] VERBOSE[29558][C-00000018] file.c: <SIP/siplink_NUX-00000018> Playing 'digits/3.ulaw' (language 'ru')
[2019-11-23 17:26:01] VERBOSE[29558][C-00000018] file.c: <SIP/siplink_NUX-00000018> Playing 'digits/4.ulaw' (language 'ru')
[2019-11-23 17:26:02] VERBOSE[29558][C-00000018] file.c: <SIP/siplink_NUX-00000018> Playing 'digits/9.ulaw' (language 'ru')
[2019-11-23 17:26:02] VERBOSE[29558][C-00000018] pbx.c: Spawn extension (from-trunk, s, 6) exited non-zero on 'SIP/siplink_NUX-00000018'
[2019-11-23 17:26:02] VERBOSE[29558][C-00000018] pbx.c: Executing [h@from-trunk:1] Macro("SIP/siplink_NUX-00000018", "hangupcall,") in new stack
[2019-11-23 17:26:02] VERBOSE[29558][C-00000018] pbx.c: Executing [s@macro-hangupcall:1] GotoIf("SIP/siplink_NUX-00000018", "1?theend") in new stack
[2019-11-23 17:26:02] VERBOSE[29558][C-00000018] pbx_builtins.c: Goto (macro-hangupcall,s,3)
[2019-11-23 17:26:02] VERBOSE[29558][C-00000018] pbx.c: Executing [s@macro-hangupcall:3] ExecIf("SIP/siplink_NUX-00000018", "0?Set(CDR(recordingfile)=)") in new stack
[2019-11-23 17:26:02] VERBOSE[29558][C-00000018] pbx.c: Executing [s@macro-hangupcall:4] NoOp("SIP/siplink_NUX-00000018", " montior file= ") in new stack
[2019-11-23 17:26:02] VERBOSE[29558][C-00000018] pbx.c: Executing [s@macro-hangupcall:5] GotoIf("SIP/siplink_NUX-00000018", "1?skipagi") in new stack
[2019-11-23 17:26:02] VERBOSE[29558][C-00000018] pbx_builtins.c: Goto (macro-hangupcall,s,7)
[2019-11-23 17:26:02] VERBOSE[29558][C-00000018] pbx.c: Executing [s@macro-hangupcall:7] Hangup("SIP/siplink_NUX-00000018", "") in new stack
[2019-11-23 17:26:02] VERBOSE[29558][C-00000018] app_macro.c: Spawn extension (macro-hangupcall, s, 7) exited non-zero on 'SIP/siplink_NUX-00000018' in macro 'hangupcall'
[2019-11-23 17:26:02] VERBOSE[29558][C-00000018] pbx.c: Spawn extension (from-trunk, h, 1) exited non-zero on 'SIP/siplink_NUX-00000018'
modsamara писал(а):добавил свой CID во входящий маршрут
Ну вот и мудрить начали.
ded писал(а):Дебажить проблему по сообщениям железной тётеньки в трубке - путь неверный.
Звонок приходит с неизвестного Астериску пира 89.108.107.101 (у вас нет такого транка, пира, смотрите sip show peers)
и Астериск идентифицирует его как Friendly Scanner, сообщает
Если пир siplink_NUX с адресом 89.108.107.101 всё же создан, то его параметры некорректны.
Параметров много, у каждого оператора - свои, единой схемы нет.
modsamara
ну я через этот транк как раз звоню, всмысле входящий звонок снаружи приходит через этот транк, он единственный
89.108.107.101 это ип провайдера ип телефонии
правда в транке он именем а не ип прописан
у прова есть прям параметры транка в вики
[siplink]
type=peer
insecure=port,invite
username=SIP-ЛОГИН
secret=SIP-ПАРОЛЬ
host=sip.siplink.pro
fromdomain=sip.siplink.pro
qualify=no
dtmfmode=rfc2833
allow=ulaw
context=ВАШ_CONTEXT
у меня только контекст не прописан, просто убрана эта строка
и верхняя строка убрана
я так понимаю, они для для чистого астериска
modsamara писал(а):у меня только контекст не прописан, просто убрана эта строка
Нет, это и есть ошибка.
Для всех FreePBX / AsteriskNOW / Elastix надо указать
context=from-trunk
И в вэб-интерфейсе создать входящий маршрут по DID = 73494927850
это там обрабатывается:
modsamara
про контекст понял, про DID не очень
вот так сейчас сделал, до этого строчка DID была пустой
modsamara
проверил сейчас, ситуация не изменилась, логи то же
Поле Callerid заполнять не нужно.
