Ошибка при запуске fail2ban
elsd
Сообщение elsd »
Уважаемые знатоки. Подскажите в чем ошибка.
[root@test1 fail2ban]# cat  /etc/fail2ban/filter.d/asterisk.conf
[INCLUDES]
[Definition]
#_daemon = asterisk
failregex = NOTICE.* .*: Registration from '.*' failed for '<HOST>' - Wrong password
            NOTICE.* .*: Registration from '.*' failed for '<HOST>' - No matching peer found
            NOTICE.* .*: Registration from '.*' failed for '<HOST>' - Username/auth name mismatch
            NOTICE.* .*: Registration from '.*' failed for '<HOST>' - Device does not match ACL
            NOTICE.* <HOST> failed to authenticate as '.*'$
            NOTICE.* .*: No registration for peer '.*' \(from <HOST>\)
            NOTICE.* .*: Host <HOST> failed MD5 authentication for '.*' (.*)
            NOTICE.* .*: Failed to authenticate user .*@<HOST>.*
ignoreregex =
 cat  /etc/fail2ban/jail.conf
# Fail2Ban configuration file
# Author: Cyril Jaquier
# $Revision: 747 $
# The DEFAULT allows a global definition of the options. They can be override
# in each jail afterwards.
[DEFAULT]
# "ignoreip" can be an IP address, a CIDR mask or a DNS host. Fail2ban will not
# ban a host which matches an address in this list. Several addresses can be
# defined using space separator.
ignoreip = 127.0.0.1 172.31.0.0/24 10.10.0.0/24 192.168.0.0/24
# "bantime" is the number of seconds that a host is banned.
bantime  = 28600
# A host is banned if it has generated "maxretry" during the last "findtime"
# seconds.
findtime  = 218600
# "maxretry" is the number of failures before a host get banned.
maxretry = 3
# "backend" specifies the backend used to get files modification. Available
# options are "gamin", "polling" and "auto". This option can be overridden in
# each jail too (use "gamin" for a jail and "polling" for another).
# gamin:   requires Gamin (a file alteration monitor) to be installed. If Gamin
#          is not installed, Fail2ban will use polling.
# polling: uses a polling algorithm which does not require external libraries.
# auto:    will choose Gamin if available and polling otherwise.
backend = auto
# This jail corresponds to the standard configuration in Fail2ban 0.6.
# The mail-whois action send a notification e-mail with a whois request
# in the body.
[asterisk-iptables]
enabled = true
filter = asterisk
action = iptables-allports[name=ASTERISK, port=5060, protocol=all]
sendmail-whois[name=ASTERISK, dest=root, sender=fail2ban@example.org]
logpath = /var/log/asterisk/messages
maxretry = 5
bantime = 21600
[ssh-iptables]
enabled  = false
filter   = sshd
action   = iptables[name=SSH, port=ssh, protocol=tcp]
           sendmail-whois[name=SSH, dest=you@mail.ru, sender=fail2ban@mail.com]
logpath  = /var/log/sshd.log
maxretry = 5
[proftpd-iptables]
enabled  = false
filter   = proftpd
action   = iptables[name=ProFTPD, port=ftp, protocol=tcp]
           sendmail-whois[name=ProFTPD, dest=you@mail.ru]
logpath  = /var/log/proftpd/proftpd.log
maxretry = 6
# This jail forces the backend to "polling".
[sasl-iptables]
enabled  = false
filter   = sasl
backend  = polling
action   = iptables[name=sasl, port=smtp, protocol=tcp]
           sendmail-whois[name=sasl, dest=you@mail.ru]
logpath  = /var/log/mail.log
# Here we use TCP-Wrappers instead of Netfilter/Iptables. "ignoreregex" is
# used to avoid banning the user "myuser".
[ssh-tcpwrapper]
enabled     = false
filter      = sshd
action      = hostsdeny
              sendmail-whois[name=SSH, dest=you@mail.ru]
ignoreregex = for myuser from
# This jail demonstrates the use of wildcards in "logpath".
# Moreover, it is possible to give other files on a new line.
[apache-tcpwrapper]
enabled  = false
filter   = apache-auth
action   = hostsdeny
logpath  = /var/log/apache*/*error.log
           /home/www/myhomepage/error.log
maxretry = 6
# The hosts.deny path can be defined with the "file" argument if it is
# not in /etc.
[postfix-tcpwrapper]
enabled  = false
filter   = postfix
action   = hostsdeny[file=/not/a/standard/path/hosts.deny]
           sendmail[name=Postfix, dest=you@mail.ru]
logpath  = /var/log/postfix.log
bantime  = 23300
# Do not ban anybody. Just report information about the remote host.
# A notification is sent at most every 600 seconds (bantime).
[vsftpd-notification]
enabled  = false
filter   = vsftpd
action   = sendmail-whois[name=VSFTPD, dest=you@mail.ru]
logpath  = /var/log/vsftpd.log
maxretry = 5
bantime  = 211800
# Same as above but with banning the IP address.
[vsftpd-iptables]
enabled  = false
filter   = vsftpd
action   = iptables[name=VSFTPD, port=ftp, protocol=tcp]
maxretry = 5
bantime  = 2121800
# Ban hosts which agent identifies spammer robots crawling the web
# for email addresses. The mail outputs are buffered.
[apache-badbots]
enabled  = false
filter   = apache-badbots
action   = iptables-multiport[name=BadBots, port="http,https"]
           sendmail-buffered[name=BadBots, lines=5, dest=you@mail.com]
logpath  = /var/www/*/logs/access_log
bantime  = 172800
maxretry = 1
# Use shorewall instead of iptables.
[apache-shorewall]
enabled  = false
filter   = apache-noscript
action   = shorewall
logpath  = /var/log/apache2/error_log
# Ban attackers that try to use PHP's URL-fopen() functionality
# through GET/POST variables. - Experimental, with more than a year
# of usage in production environments.
[php-url-fopen]
enabled = false
port    = http,https
filter  = php-url-fopen
maxretry = 1
# A simple PHP-fastcgi jail which works with lighttpd.
# If you run a lighttpd server, then you probably will
# find these kinds of messages in your error_log:
# ALERT Б─⌠ tried to register forbidden variable Б─≤GLOBALSБ─≥
# through GET variables (attacker '1.2.3.4', file '/var/www/default/htdocs/index.php')
# This jail would block the IP 1.2.3.4.
[lighttpd-fastcgi]
enabled = false
port    = http,https
filter  = lighttpd-fastcgi
# adapt the following two items as needed
logpath = /var/log/lighttpd/error.log
maxretry = 2
# This jail uses ipfw, the standard firewall on FreeBSD. The "ignoreip"
# option is overridden in this jail. Moreover, the action "mail-whois" defines
# the variable "name" which contains a comma using "". The characters '' are
# valid too.
[ssh-ipfw]
enabled  = false
filter   = sshd
action   = ipfw[localhost=192.168.0.1]
           sendmail-whois[name="SSH,IPFW", dest=you@mail.ru]
logpath  = /var/log/auth.log
ignoreip = 168.192.0.1
# These jails block attacks against named (bind9). By default, logging is off
# with bind9 installation. You will need something like this:
# logging {
#     channel security_file {
#         file "/var/log/named/security.log" versions 3 size 30m;
#         severity dynamic;
#         print-time yes;
#     category security {
#         security_file;
# in your named.conf to provide proper logging.
# This jail blocks UDP traffic for DNS requests.
[named-refused-udp]
enabled  = false
filter   = named-refused
action   = iptables-multiport[name=Named, port="domain,953", protocol=udp]
           sendmail-whois[name=Named, dest=you@mail.ru]
logpath  = /var/log/named/security.log
# This jail blocks TCP traffic for DNS requests.
[named-refused-tcp]
enabled  = false
action   = iptables-multiport[name=Named, port="domain,953", protocol=tcp]
Стартую iptables start, все нормально. При старте fail2ban start, выдает ошибку:
[root@test1 fail2ban]# /etc/init.d/iptables start
[root@test1 fail2ban]# /etc/init.d/fail2ban start
Starting fail2ban: Traceback (most recent call last):
  File "/usr/bin/fail2ban-client", line 402, in ?
    if client.start(sys.argv):
  File "/usr/bin/fail2ban-client", line 371, in start
    return self.__processCommand(args)
  File "/usr/bin/fail2ban-client", line 181, in __processCommand
    ret = self.__readConfig()
  File "/usr/bin/fail2ban-client", line 375, in __readConfig
    self.__configurator.readAll()
  File "/usr/share/fail2ban/client/configurator.py", line 58, in readAll
    self.__jails.read()
  File "/usr/share/fail2ban/client/jailsreader.py", line 41, in read
    ConfigReader.read(self, "jail")
  File "/usr/share/fail2ban/client/configreader.py", line 59, in read
    SafeConfigParserWithIncludes.read(self, [bConf, bLocal])
  File "/usr/share/fail2ban/client/configparserinc.py", line 105, in read
    fileNamesFull += SafeConfigParserWithIncludes.getIncludes(filename)
  File "/usr/share/fail2ban/client/configparserinc.py", line 76, in getIncludes
    parser.read(resource)
  File "/usr/lib/python2.4/ConfigParser.py", line 267, in read
    self._read(fp, filename)
  File "/usr/lib/python2.4/ConfigParser.py", line 462, in _read
    raise MissingSectionHeaderError(fpname, lineno, line)
ConfigParser.MissingSectionHeaderError: File contains no section headers.
file: /etc/fail2ban/jail.conf, line: 1
'^7+L[M v5# Fail2Ban configuration file\n'
                                                           [FAILED]
Re: Ошибка при запуске fail2ban
перед ignoreregex = добавьте перевод строки
sendmail-whois[name=ASTERISK, dest=root, sender=fail2ban@example.org] подвиньте отступом.
elsd
Сообщение elsd »
Перевод строки добавил:
[INCLUDES]
[Definition]
#_daemon = asterisk
failregex = NOTICE.* .*: Registration from '..*' failed for '<HOST>' - Wrong password
# Optin: ignoreregex
# Notes.: regex to ignore. If this regex matches, the line is ignored.
# Values: TEXT
ignoreregex =
Строку: sendmail-whois[name=ASTERISK, dest=root, sender=fail2ban@example.org]----подвинул. Ошибка не ушла.
