WARNING: Port disallowed in <IP>:<PORT>
kuzzz
Сообщение kuzzz »
Доброго дня всем!
При регистрации Астериска на другом сервере на нестандартный порт началда вылезать интересная не виденная мной до этого ошибка:
WARNING[10879]: netsock2.c:216 ast_sockaddr_split_hostport: Port disallowed in 123.123.123.123:5068
Использую Realtime, настройки:
*CLI> sip show peer u00513
  * Name       : u00513
  Description  : Ivanov
  Realtime peer: Yes, cached
  Secret       : <Set>
  MD5Secret    : <Not set>
  Remote Secret: <Not set>
  Context      : fmc
  Record On feature : automon
  Record Off feature : automon
  Subscr.Cont. : <Not set>
  Language     : ru
  Tonezone     : <Not set>
  Accountcode  : 12313132
  AMA flags    : Unknown
  Transfer mode: open
  FromUser     : u00513
  FromDomain   : 123.123.123.123 Port 5068
  Callgroup    : 1
  Pickupgroup  : 1
  Named Callgr :
  Nam. Pickupgr:
  MOH Suggest  :
  Mailbox      :
  VM Extension : asterisk
  LastMsgsSent : 0/0
  Call limit   : 0
  Max forwards : 0
  Dynamic      : No
  Callerid     : "" <>
  MaxCallBR    : 384 kbps
  Expire       : -1
  Insecure     : port,invite
  Force rport  : Yes
  Symmetric RTP: Yes
  ACL          : Yes
  DirectMedACL : No
  T.38 support : No
  T.38 EC mode : Unknown
  T.38 MaxDtgrm: 4294967295
  DirectMedia  : Yes
  PromiscRedir : No
  User=Phone   : No
  Video Support: No
  Text Support : No
  Ign SDP ver  : No
  Trust RPID   : Yes
  Send RPID    : Yes
  Path support : No
  Path         : N/A
  TrustIDOutbnd: Legacy
  Subscriptions: Yes
  Overlap dial : No
  DTMFmode     : rfc2833
  Timer T1     : 500
  Timer B      : 32000
  ToHost       : 123.123.123.123:5068
  Addr->IP     : 123.123.123.123:5068
  Defaddr->IP  : (null)
  Prim.Transp. : UDP
  Allowed.Trsp : UDP
  Def. Username: u00513
  SIP Options  : (none)
  Codecs       : (ulaw|alaw|gsm|h263)
  Auto-Framing : No
  Status       : UNKNOWN
  Useragent    :
  Reg. Contact :
  Qualify Freq : 60000 ms
  Keepalive    : 0 ms
  Sess-Timers  : Accept
  Sess-Refresh : uas
  Sess-Expires : 1800 secs
  Min-Sess     : 90 secs
  RTP Engine   : asterisk
  Parkinglot   :
  Use Reason   : No
  Encryption   : No
Настройки из базы:
id	60
allow	alaw;ulaw
context	default
dtmfmode	0
host	123.123.123.123:5068
deny	0
permit	0.0.0.0/0
insecure	port,invite
mailbox	0
musiconhold	0
nat	force_rport,comedia
secret	<PASSWORD>
type	friend
username	u00512
videosupport	no
name	512
ipaddr	0
disallow	g729;ilbc
port	5068
regseconds	0
lastms	5
fullcontact	0
useragent	0
regserver	123.123.123.123
pickupgroup	1
callgroup	1
callbackextension	512
qualify	yes
rtpkeepalive	10
callforward	0
description	u00512
fromuser	u00512
fromdomain	123.123.123.123:5068
sendrpid	yes
trustrpid	yes
rtcachefriends	yes
accountcode	XXXXXXX
Может подскажет кто, в чем проблема?
Заранее спасибо!
Re: WARNING: Port disallowed in <IP>:<PORT>
Попробуйте указать параметр в таком виде:
regserver 123.123.123.123:5068
kuzzz
Сообщение kuzzz »
ded писал(а):Попробуйте указать параметр в таком виде:
Неа, не помогло!
Уже пробовал, все равно варинг сыпет
Попробуйте заснять вывод консоли с CORE SET DEBUG 99.
SIP-пир как обозван?
Возможно вот этот случай:
http://forums.asterisk.org/viewtopic.php?f=1&t=84552
You have made the device name the same as the domain name. Devices have their port number specified in the device entry, not after the device name. The name has been parsed as a device, not a literal domain name.
I don't know if this has caused the failure to get a response. Gettting a SIP trace showing exactly what register was sent where might clarify that.
