Настройка модуля confbridge
SunWay
Сообщение SunWay »
Добрый день.
Настраиваю confbridge.
Файл конфига confbridge -
; The general section of this config
; is not currently used, but reserved
; for future use.
; --- Default Information ---
; The default_user and default_bridge sections are applied
; automatically to all ConfBridge instances invoked without
; a user, or bridge argument.  No menu is applied by default.
; Note that while properties of the default_user or default_bridge
; profile can be overridden, if removed, they will be automatically
; added and made available to the dialplan upon module load.
; --- ConfBridge User Profile Options ---
[conf_test]
type=bridge
;max_members=20
max_members=20
record_conference=no
internal_sample_rate=auto
mixing_interval=20
sound_join= beep
;sound=leave= beeperr
sound_leave= beeperr
;pin=456
[user_test]
type=user
admin=yes
marked=no
startmuted=no
music_on_hold_when_empty=yes
;denoise=yes ;need codec_speex
denoise=no
;announce_user_count=yes
;announce_user_count_all=yes
[menu_test]
type= menu
*=playback_and_continue(press&digits/1&press&digits/2&press&digits/3&press&digits/4&press&digits/5&press&digits/6&press&digits/7&press&digits/8press&digits/9&
1=toggle_mute
2=leave_conference
3=dialplan_exec(invitar,1234,1)
4=decrease_listening_volume
5=reset_listening_volume
6=increase_listening_volume
7=decrease_talking_volume
8=reset_talking_volume
9=increase_talking_volume
0=no_op
При попытке позвонить на конфу получаю -
chan_sip.c:24071 handle_response_invite: Received response: "Forbidden" from '"Video1"
extensions.conf
exten => 6659,1,Goto(6659,6659,1)
exten => 6659,1,Answer()
exten => 6659,n,ConfBridge(conf_test)
sip.conf
[6671]
username=6671
secret=6671
context=avaya
callerid=Video1
canreinvite=no
disallow=all ; Windows Messenger выбирает неправильные кодеки, если указать: allow=all
allow=ulaw
allow=speex
allow=gsm
allow=h261
;allow=h263
;allow=h263p
От модератора:
Используйте теги ! Сообщение отредактировано.
Re: Настройка модуля confbridge
За такую мерзопакость богопротивную вас надо сечь, розгами.
extensions.conf
Читайте основы основ диалплана, прежде чем конфигурировать ConfBridge.
SunWay
Сообщение SunWay »
ded писал(а):Читайте основы основ диалплана, прежде чем конфигурировать ConfBridge.
Не совсем понял, в чем именно ошибка. Можете помочь, пожалуйста?
Можем. Помогаем.
Достаточно 6-й главы:
https://yadi.sk/i/HQclFiBt3YRYu8
SunWay
Сообщение SunWay »
Добрый день.
Поправил конфиг, построил конференцию. Спасибо за советы, нашел ошибку в диалплане.
После того, как конференция строится, я хочу помимо голоса, чтобы работало еще и видео.
Вот, что я получаю на этапе подключения к конференции -
== Using SIP VIDEO CoS mark 6
[Jul 18 17:01:49] WARNING[32576][C-00000004]: file.c:774 ast_openstream_full: File conf-onlyperson does not exist in any format
[Jul 18 17:01:49] WARNING[32576][C-00000004]: file.c:1247 ast_streamfile: Unable to open conf-onlyperson (format (h261|ulaw)): No such file or directory
[Jul 18 17:01:49] WARNING[32576][C-00000004]: app_confbridge.c:824 sound_file_exists: File confbridge-join does not exist in any format
[Jul 18 17:03:03] WARNING[32428][C-00000005]: res_format_attr_siren7.c:54 siren7_parse_sdp_fmtp: Got Siren7 offer at 24000 bps, but only 32000 bps supported; ignoring.
[Jul 18 17:03:04] WARNING[32606][C-00000005]: app_confbridge.c:824 sound_file_exists: File confbridge-join does not exist in any format
[Jul 18 17:03:33] WARNING[32606][C-00000005]: app_confbridge.c:824 sound_file_exists: File confbridge-leave does not exist in any format
[Jul 18 17:03:38] WARNING[32576][C-00000004]: app_confbridge.c:824 sound_file_exists: File confbridge-leave does not exist in any format
Голос есть, общаемся нормально, но видео друг друга не видим.
- это надо переводить? Или и так понятно?
Извините, конечно, но ваше "хочу видео" - продолжение дилетантства, из первого сообщения. Для смешивания видео нескольких источников и построения видео-картинки конференции нужно специальное аппаратно-программное устройство - MCU (на жаргоне - видеомиксер), которого у вас нет. Модуль confbridge делает микс только из голосовых аудио потоков, видео туда не входит.
Из понятных вам терминов: есть проект OpenMCU. Если думаете, что вот так вам можно почитать, разобраться, скачать, инсталлировать - это заблуждение.
