AddPac GS1002C - не регистрируются одновременно GSM и FXO
aike
Сообщение aike »
Добрый день!
У меня проблема с одновременной регистрацией GSM и FXO портов.
Если в CLI консоли я пишу sip show peers, то получаю вид:
peer-gsm-1/peer-gsm-1 (Unspecified) D 0 Unmonitored
peer-pstn-1/peer-pstn-1 192.168.4.8 D A 5060 OK (16 ms)
Соответственно звонки на шлюз GSM не уходят. По отдельности каждый шлюз работает.
Вот конфигурация на asterisk (sip.conf)
[peer-gsm-1]
accountcode=sipgsm-1
call-limit=2
context=gsm-in
deny=0.0.0.0/0
permit=192.168.4.8
nat=no
canreinvite=no
allow=ulaw
;this username and password used only for input call
username=peer-gsm-1
;if not registed, then no input call
secret=1234zxcv
maxcallbitrate=64
dtmfmode=info
[peer-pstn-1]
accountcode=sippstn-1
call-limit=2
context=pstn-in
deny=0.0.0.0/0
permit=192.168.4.8
nat=no
canreinvite=no
allow=ulaw
username=peer-pstn-1
secret=1234zxcv
maxcallbitrate=64
dtmfmode=info
Вот конфиг портов с apos.cfg
! VoIP configuration.
! Voice service voip configuration.
voice service voip
protocol sip
dtmf-relay out-of-band
fax protocol t38 redundancy 0
fax rate 9600
h323 call start fast
h323 call tunnel enable
no call-barring unconfigured-ip-address
no voip-inbound-call-barring enable
! Voice port configuration.
! GSM
voice-port 0/0
connection plar 202
caller-id enable
! GSM
voice-port 0/1
connection plar 203
caller-id enable
! FXO
voice-port 0/2
connection plar 200
caller-id enable
! FXO
voice-port 0/3
connection plar 201
caller-id enable
! service port group configuration.
! Pots peer configuration.
dial-peer voice 0 pots
destination-pattern [78]9T
port 0/0
user-name peer-gsm-1
user-password 1234zxcv
preference 1
dial-peer voice 1 pots
port 0/1
preference 1
dial-peer voice 2 pots
destination-pattern 123T
port 0/2
user-name peer-pstn-1
translate-outgoing called-number 1
preference 2
dial-peer voice 3 pots
port 0/3
translate-outgoing called-number 2
preference 2
! Voip peer configuration.
dial-peer voice 300 voip
destination-pattern T
session target sip-server
session protocol sip
voice-class codec 0
no vad
dtmf-relay info
fax rate 9600
gatekeeper
! Gateway configuration.
gateway
h323-id voip.192.168.4.8
no ignore-msg-from-other-gk
! Codec classes configuration.
voice class codec 0
codec preference 1 g711alaw
codec preference 2 g711ulaw
! Translation Rule configuration.
translation-rule 1
rule 0 123T T
translation-rule 2
rule 0 123T T
! SIP UA configuration.
sip-ua
user-register
sip-server 192.168.4.1
register e164
hook-flash-info-ignore
Помогите!!!
Re: AddPac GS1002C - не регистрируются одновременно GSM и FX
1) Не обязательно регистрировать GSM & FXO, достаточно просто как-то зарегистрировать шлюз на Астериске.
2) Не обязательно вообще регистрировать шлюз, особенно если они в одной локальной сети. Создайте статический пир (friend), принимайте и отправляйте на него звоночки.
aike
Сообщение aike »
Добрый день!
Тогда дайте пожалуйста пример, как мне сделать два пира, один для GSM, а один для PSTN.
И еще, я понял что в pots я нигде не буду указывать user-name а один раз укажу
user-name в разделе sip-ua и просто под одним именем зарегестрирую весь шлюз.
Тогда вопрос, разделять звонки буду по destination-pattern и для обращения к шлюзу
будет один пир, или я смогу сделать два отдельных пира для GSM и PSTN и обращаться в
extensions.conf к ним отдельно?
Не нужно два пира.
Представьте для простоты, что ваш AddPac GS1002C - это просто провайдер, которому Вы направляете все звонки.
exten => _X.,1,Dial(SIP/AddPacGS1002C/${EXTEN})
Тогда вопрос, разделять звонки буду по destination-pattern и для обращения к шлюзу будет один пир, или я смогу сделать два отдельных пира для GSM и PSTN
Именно так, разделять по destination-pattern внутри AddPac. Например
dial-peer voice 100 pots
description GSM
destination-pattern 0[69].T
description FXO
destination-pattern [2-6]{5}.
aike
Сообщение aike »
Добрый день!
Я проверил, так у меня работает.
Но скажите, есть ли более красивое решение, без destination-pattern?
