elastix и iaxmodem
avolon
elastix и iaxmodem
Сообщение avolon »
Опять я ))
Не хотит заводится факсы ((
Делал все как тут
PRIME_BBCODE_SPOILER_SHOW PRIME_BBCODE_SPOILER: url
http://www.sipring.ru/overview/asterisk-hylafax-iaxmodem/79-fax-asterisk-elastix-without-tears.html?showall=1
Но получаю Waiting for modem to come ready on ttyIAX1
В логах
PRIME_BBCODE_SPOILER_SHOW PRIME_BBCODE_SPOILER: Log
tail -f iaxmodem-cfg.ttyIAX1
[2011-11-09 15:18:43] Error: invalid mode string () ? Leaving default modes on /dev/iaxmodem
[2011-11-09 15:18:43] Error: mode is 0, leaving default permissions
[2011-11-09 15:18:43] Registration failed.
[2011-11-09 15:21:05] Terminating on signal 15...
[2011-11-09 15:21:05] Error: group unspecified, using root instead
[2011-11-09 15:21:05] Error: user not found in passwd file, using root instead
[2011-11-09 15:21:05] Error: invalid mode string () ? Leaving default modes on /dev/iaxmodem
[2011-11-09 15:21:05] Error: mode is 0, leaving default permissions
[2011-11-09 15:21:05] Registration failed.
[2011-11-09 15:26:00] Registration failed.
Чет не пойму в 2.0 работало как часики ((((
А в messege
PRIME_BBCODE_SPOILER_SHOW PRIME_BBCODE_SPOILER: messege
Nov 9 15:29:06 localhost FaxQueuer[9043]: MODEM /dev/ttyIAX1 appears to be wedged
Nov 9 15:29:06 localhost FaxQueuer[9043]: MODEM WEDGED: bin/wedged "ttyIAX1" "/dev/ttyIAX1"
Nov 9 15:29:06 localhost FaxGetty[9908]: OPEN /dev/ttyIAX1 HylaFAX (tm) Version 4.3.10
Nov 9 15:29:06 localhost FaxGetty[9908]: /dev/ttyIAX1: Can not open modem (No such file or directory)
Nov 9 15:29:06 localhost FaxQueuer[9043]: NOTIFY exit status: 0 (9907)
Nov 9 15:29:36 localhost FaxGetty[9908]: /dev/ttyIAX1: Can not open modem (No such file or directory)
Nov 9 15:30:06 localhost FaxGetty[9908]: /dev/ttyIAX1: Can not open modem (No such file or directory)
Nov 9 15:30:06 localhost FaxGetty[9908]: Unable to setup modem on /dev/ttyIAX1; giving up after 2 attempts
Nov 9 15:30:06 localhost FaxGetty[9908]: CLOSE /dev/ttyIAX1
Nov 9 15:30:06 localhost FaxQueuer[9043]: MODEM /dev/ttyIAX1 appears to be wedged
Nov 9 15:30:06 localhost FaxQueuer[9043]: MODEM WEDGED: bin/wedged "ttyIAX1" "/dev/ttyIAX1"
Nov 9 15:30:06 localhost FaxGetty[10038]: OPEN /dev/ttyIAX1 HylaFAX (tm) Version 4.3.10
Nov 9 15:30:06 localhost FaxGetty[10038]: /dev/ttyIAX1: Can not open modem (No such file or directory)
Nov 9 15:30:06 localhost FaxQueuer[9043]: NOTIFY exit status: 0 (10037)
Nov 9 15:30:36 localhost FaxGetty[10038]: /dev/ttyIAX1: Can not open modem (No such file or directory)
Nov 9 15:31:06 localhost FaxGetty[10038]: /dev/ttyIAX1: Can not open modem (No such file or directory)
Nov 9 15:31:06 localhost FaxGetty[10038]: Unable to setup modem on /dev/ttyIAX1; giving up after 2 attempts
Nov 9 15:31:06 localhost FaxGetty[10038]: CLOSE /dev/ttyIAX1
Nov 9 15:31:06 localhost FaxQueuer[9043]: MODEM /dev/ttyIAX1 appears to be wedged
Nov 9 15:31:06 localhost FaxQueuer[9043]: MODEM WEDGED: bin/wedged "ttyIAX1" "/dev/ttyIAX1"
Nov 9 15:31:06 localhost FaxGetty[10165]: OPEN /dev/ttyIAX1 HylaFAX (tm) Version 4.3.10
Nov 9 15:31:06 localhost FaxGetty[10165]: /dev/ttyIAX1: Can not open modem (No such file or directory)
Nov 9 15:31:06 localhost FaxQueuer[9043]: NOTIFY exit status: 0 (10164)
[root@asterisk iaxmodem]#
в inittab строчка есть
# Don't remove or modify this comment. The following block is for fax setup.
fx1:2345:respawn:/usr/sbin/faxgetty ttyIAX1
файл в /etc/iaxmodem/
Пустой создается ((
Внутренний номер создал IAX2
пароли одинаковые ((
Где косяк
Re: elastix и iaxmodem
Не делать всё как на http://www.sipring.ru/overview/asterisk ... ?showall=1
Вероятно это неправильная инструкция. Найти правильную инструкцию по установке и выполнить.
avolon
Сообщение avolon »
ЭЭ я поэтой делал всвое время и работало ((
Ащас нехотит
Он создает iaxmodem-cfg.ttyIAX1 пустыми ((((
Походу гдето косяк с правами (( но где не пойму
Кто-то должен с этим разобраться и понять. Во кто?
avolon
Сообщение avolon »
Спасибо!!
Бум искать ((((((((((((( но факс не хотят работать
avolon
Сообщение avolon »
iaxmodem-cfg.ttyIAX1 пользователь root группа uupc
У всех так??
почти по-русcки же пишет
avolon
Сообщение avolon »
Почти да не так какая гр не определена то ???
Хз что не так то
так что не могем посмотреть принадлежность юзера к группе?
например, для пользователя billing
# groups billing
billing : billing daemon uucp lock
под кем запустить пытаемся для того и смотрим
avolon
Сообщение avolon »
АА дурак я просто вгруппу не вту ключил asterisk пользователя ((( Делал одно а сломал др
Пипец!!!!
