Unable to create channel of type Dahdi 17 User busy
Squidy
Сообщение Squidy »
hs1# dahdi_scan
[1]
active=yes
alarms=OK
description=Wildcard TDM410P Board 1
name=WCTDM/0
manufacturer=Digium
devicetype=Wildcard TDM410P (VPM100M)
location=PCI Bus 07 Slot 09
basechan=1
totchans=4
irq=18
type=analog
port=1,FXO
port=2,FXS
port=3,none
port=4,none
hs1# dahdi_cfg -vv
DAHDI Tools Version - 2.4.0-rc1
DAHDI Version: 2.4.0-rc5
Echo Canceller(s): MG2
Configuration
Channel map:
Channel 01: FXS Kewlstart (Default) (Echo Canceler: mg2) (Slaves: 01)
Channel 02: FXO Kewlstart (Default) (Echo Canceler: mg2) (Slaves: 02)
2 channels to configure.
Setting echocan for channel 1 to mg2
Setting echocan for channel 2 to mg2
hs1#
hs1# cat /usr/local/etc/dahdi/system.conf
fxsks=1
fxoks=2
echocanceller=mg2,1-2
loadzone        = ru
defaultzone     = ru
hs1#
; DAHDI telephony
; Configuration file
[trunkgroups]
[channels]
switchtype => euroisdn
language=ru
usecallerid=yes
callwaiting=yes
usecallingpres=yes
callwaitingcallerid=yes
threewaycalling=yes
transfer=yes
canpark=yes
cancallforward=yes
callreturn=yes
echocancel=yes
echocancelwhenbridged=no
echotraining=yes
group=1
callgroup=1
pickupgroup=1
callprogress=yes
progzone=us
tonezone = 0 ; 0 is US
jbenable = yes
;;;[home-phones]
context=out ; Uses the [internal] context in extensions.conf
signalling=auto ; fxo_ks Use FXO signalling for an FXS channel - as set in sytem.conf.conf
busydetect=yes
callprogress => yes
channel => 1 ; Telephone attached to port 1
;dahdichan => 1
group=2
;;;[pstn]
context=home ; Incoming calls go to [incoming-pstn-line] in extensions.conf
signalling=auto ; fxs_ks Use FXS signalling for an FXO channel - use as set in system.conf
faxdetect=incoming
busydetect=yes
channel => 2
;dahdichan => 2 ; PSTN attached to port 2
exten=> _7XXXXXXXXXX,1,Dial(SIP/${EXTEN}@multifon-out,30,r)
exten=> _8XXXXXXXXXX,1,Dial(SIP/${EXTEN}@sipnet,30,r)
exten=> _9XXXXXXX,1,Dial(Dahdi/1/${EXTEN:1})
hs1*CLI> dahdi show channels
  Chan Extension  Context         Language   MOH Interpret        Blocked    State
pseudo            default                    default                         In Service
     1            out             ru         default                         In Service
     2            home            ru         default                         In Service
hs1*CLI>
[Nov 4 12:21:47] WARNING[1710]: app_dial.c:2198 dial_exec_full: Unable to create channel of type 'Dahdi' (cause 17 - User busy)
hs1*CLI> dahdi show version
DAHDI Version: SVN-trunk-r10321 Echo Canceller: MG2
Re: Unable to create channel of type Dahdi 17 User busy
Услуги перевода слова "BUSY" - недорого.
Squidy
Сообщение Squidy »
Линия сводободна
Не верю.
Squidy
Сообщение Squidy »
Я бы не обращался тогда за помощью
То есть не задавая вопроса , Вы предлагаете задать его нам , нам же?. И потом дальше из вас вытягивать необходимую информацию, например , о том откуда эта линия, как подключена и прочее?
Squidy
Сообщение Squidy »
в FXO порт подключена линия городская от, городской АТС
Вообразите, но она может быть занятой! В смысле - в зависоне. Не распознала сигнал отбоя и ту-тукает себе!
Смотрим и слушаем
dahdi_monitor -v
Кстати, канала pseudo не должно быть. Он нужен, если нет никакой карты, а при наличии TD410 - надо убрать pseudo. Теперь о главном. Вижу -
Channel map:
Вы в курсе в чём отличие портов FXS и FXO? Говоря языком диалплана, в чём отличие Dial(Dahdi/1/${EXTEN:1} от Dial(Dahdi/2 /${EXTEN:1}??
Если да, то как можно
exten=> _9XXXXXXX,1,Dial(Dahdi/1/${EXTEN:1}) ???
Ещё одно неверное движение - и ваш порт FXS сгорит. Если уже не сгорел.
Squidy
Сообщение Squidy »
какая то путоница
hs1# dahdi_scan
[1]
active=yes
alarms=OK
name=WCTDM/0
manufacturer=Digium
basechan=1
totchans=4
irq=18
type=analog
port=1,FXO
port=2,FXS
port=3,none
port=4,none
hs1#
говорит так, но если в сеттингс указать как по сканеру то dadhi_cfg выдаёт ошибку
hs1# dahdi_cfg -vv
Configuration
Channel map:
Channel 01: FXO Kewlstart (Default) (Echo Canceler: mg2) (Slaves: 01)
Channel 02: FXS Kewlstart (Default) (Echo Canceler: mg2) (Slaves: 02)
Changing signalling on channel 1 from FXS Kewlstart to FXO Kewlstart
DAHDI_CHANCONFIG failed on channel 1: Invalid argument (22)
Selected signaling not supported
Possible causes:
        FXO signaling is being used on a FXO interface (use a FXS signaling variant)
        RBS signaling is being used on a E1 CCS span
        Signaling is being assigned to channel 16 of an E1 CAS span
hs1#
а вот что с монитором
hs1# dahdi_monitor 1 -v
Nothing to do with the stream(s) ...
Путанница у вас под ногами, и сделана вашими руками.
В платный суппорт.
