Облачная телефония Ростелеком FreePBX 13
dogidogi
Сообщение dogidogi »
Добрый день! Есть услуга облачная телефония, предоставленная оператором Ростелеком. В личном кабинете настроены внутренние номера (короткие), которые используются как SIP транки для Asterisk. На Freepbx (13.0.192.17, asterisk 11.22) настроен IVR. Периодически возникает проблема при входящем звонке, звонок "сбрасывается". В CLI это выглядит вот так:
localhost*CLI>
-- Goto (from-trunk,202,11)
-- Executing [202@from-trunk:11] NoOp("SIP/SIP_RT_Trunk1-0000068e", "") in new stack
-- Executing [202@from-trunk:12] Set("SIP/SIP_RT_Trunk1-0000068e", "__CALLINGNAMEPRES_SV=allowed_not_screened") in new stack
-- Executing [201@from-trunk:3] Gosub("SIP/SIP_RT_Trunk1-0000068f", "app-blacklist-check,s,1()") in new stack
-- Executing [202@from-trunk:13] Set("SIP/SIP_RT_Trunk1-0000068e", "__CALLINGNUMPRES_SV=allowed_not_screened") in new stack
-- Executing [s@app-blacklist-check:1] GotoIf("SIP/SIP_RT_Trunk1-0000068f", "0?blacklisted") in new stack
-- Executing [202@from-trunk:14] Set("SIP/SIP_RT_Trunk1-0000068e", "CALLERID(name-pres)=allowed_not_screened") in new stack
-- Executing [202@from-trunk:15] Set("SIP/SIP_RT_Trunk1-0000068e", "CALLERID(num-pres)=allowed_not_screened") in new stack
-- Executing [202@from-trunk:16] NoOp("SIP/SIP_RT_Trunk1-0000068e", "CallerID Entry Point") in new stack
-- Executing [202@from-trunk:17] Goto("SIP/SIP_RT_Trunk1-0000068e", "ivr-1,s,1") in new stack
-- Goto (ivr-1,s,1)
-- Executing [s@ivr-1:1] Set("SIP/SIP_RT_Trunk1-0000068e", "INVALID_LOOPCOUNT=0") in new stack
-- Executing [s@app-blacklist-check:2] Set("SIP/SIP_RT_Trunk1-0000068f", "CALLED_BLACKLIST=1") in new stack
-- Executing [s@app-blacklist-check:3] Return("SIP/SIP_RT_Trunk1-0000068f", "") in new stack
-- Executing [s@ivr-1:2] Set("SIP/SIP_RT_Trunk1-0000068e", "_IVR_CONTEXT_ivr-1=") in new stack
-- Executing [s@ivr-1:3] Set("SIP/SIP_RT_Trunk1-0000068e", "_IVR_CONTEXT=ivr-1") in new stack
-- Executing [s@ivr-1:4] Set("SIP/SIP_RT_Trunk1-0000068e", "__IVR_RETVM=") in new stack
-- Executing [s@ivr-1:5] GotoIf("SIP/SIP_RT_Trunk1-0000068e", "0?skip") in new stack
-- Executing [s@ivr-1:6] Answer("SIP/SIP_RT_Trunk1-0000068e", "") in new stack
-- Executing [201@from-trunk:4] Set("SIP/SIP_RT_Trunk1-0000068f", "__FROM_DID=201") in new stack
-- Executing [201@from-trunk:5] Set("SIP/SIP_RT_Trunk1-0000068f", "CDR(did)=201") in new stack
-- Executing [201@from-trunk:6] ExecIf("SIP/SIP_RT_Trunk1-0000068f", "0 ?Set(CALLERID(name)=84742219999)") in new stack
-- Executing [201@from-trunk:7] Set("SIP/SIP_RT_Trunk1-0000068f", "__MOHCLASS=") in new stack
-- Executing [201@from-trunk:8] Set("SIP/SIP_RT_Trunk1-0000068f", "__REVERSAL_REJECT=FALSE") in new stack
-- Executing [201@from-trunk:9] GotoIf("SIP/SIP_RT_Trunk1-0000068f", "1?post-reverse-charge") in new stack
-- Goto (from-trunk,201,11)
-- Executing [201@from-trunk:11] NoOp("SIP/SIP_RT_Trunk1-0000068f", "") in new stack
-- Executing [201@from-trunk:12] Set("SIP/SIP_RT_Trunk1-0000068f", "__CALLINGNAMEPRES_SV=allowed_not_screened") in new stack
-- Executing [201@from-trunk:13] Set("SIP/SIP_RT_Trunk1-0000068f", "__CALLINGNUMPRES_SV=allowed_not_screened") in new stack
-- Executing [201@from-trunk:14] Set("SIP/SIP_RT_Trunk1-0000068f", "CALLERID(name-pres)=allowed_not_screened") in new stack
-- Executing [201@from-trunk:15] Set("SIP/SIP_RT_Trunk1-0000068f", "CALLERID(num-pres)=allowed_not_screened") in new stack
-- Executing [201@from-trunk:16] NoOp("SIP/SIP_RT_Trunk1-0000068f", "CallerID Entry Point") in new stack
-- Executing [201@from-trunk:17] Goto("SIP/SIP_RT_Trunk1-0000068f", "ivr-1,s,1") in new stack
-- Goto (ivr-1,s,1)
-- Executing [s@ivr-1:1] Set("SIP/SIP_RT_Trunk1-0000068f", "INVALID_LOOPCOUNT=0") in new stack
-- Executing [s@ivr-1:2] Set("SIP/SIP_RT_Trunk1-0000068f", "_IVR_CONTEXT_ivr-1=") in new stack
-- Executing [s@ivr-1:3] Set("SIP/SIP_RT_Trunk1-0000068f", "_IVR_CONTEXT=ivr-1") in new stack
-- Executing [s@ivr-1:4] Set("SIP/SIP_RT_Trunk1-0000068f", "__IVR_RETVM=") in new stack
-- Executing [s@ivr-1:5] GotoIf("SIP/SIP_RT_Trunk1-0000068f", "0?skip") in new stack
-- Executing [s@ivr-1:6] Answer("SIP/SIP_RT_Trunk1-0000068f", "") in new stack
== Spawn extension (ivr-1, s, 6) exited non-zero on 'SIP/SIP_RT_Trunk1-0000068e'
-- Executing [h@ivr-1:1] Hangup("SIP/SIP_RT_Trunk1-0000068e", "") in new stack
== Spawn extension (ivr-1, h, 1) exited non-zero on 'SIP/SIP_RT_Trunk1-0000068e'
== Spawn extension (ivr-1, s, 6) exited non-zero on 'SIP/SIP_RT_Trunk1-0000068f'
-- Executing [h@ivr-1:1] Hangup("SIP/SIP_RT_Trunk1-0000068f", "") in new stack
== Spawn extension (ivr-1, h, 1) exited non-zero on 'SIP/SIP_RT_Trunk1-0000068f'
-- Executing [s@ivr-1:7] Wait("SIP/SIP_RT_Trunk1-0000068d", "1") in new stack
> 0xb721bed0 -- Probation passed - setting RTP source address to 77.51.247.44:12516
-- Executing [s@ivr-1:8] Set("SIP/SIP_RT_Trunk1-0000068d", "IVR_MSG=custom/---") in new stack
-- Executing [s@ivr-1:9] Set("SIP/SIP_RT_Trunk1-0000068d", "TIMEOUT(digit)=3") in new stack
-- Digit timeout set to 3.000
-- Executing [s@ivr-1:10] ExecIf("SIP/SIP_RT_Trunk1-0000068d", "1?Background(custom/---)") in new stack
-- <SIP/SIP_RT_Trunk1-0000068d> Playing 'custom/---.slin' (language 'ru')
== Spawn extension (ivr-1, s, 10) exited non-zero on 'SIP/SIP_RT_Trunk1-0000068d'
-- Executing [h@ivr-1:1] Hangup("SIP/SIP_RT_Trunk1-0000068d", "") in new stack
== Spawn extension (ivr-1, h, 1) exited non-zero on 'SIP/SIP_RT_Trunk1-0000068d'
== Using SIP RTP TOS bits 184
-- Executing [203@from-trunk:1] Set("SIP/SIP_RT_Trunk1-00000690", "__DIRECTION=INBOUND") in new stack
-- Executing [203@from-trunk:2] Gosub("SIP/SIP_RT_Trunk1-00000690", "sub-record-check,s,1(in,203,dontcare)") in new stack
-- Executing [s@sub-record-check:1] GotoIf("SIP/SIP_RT_Trunk1-00000690", "0?initialized") in new stack
-- Executing [s@sub-record-check:2] Set("SIP/SIP_RT_Trunk1-00000690", "__REC_STATUS=INITIALIZED") in new stack
-- Executing [s@sub-record-check:3] Set("SIP/SIP_RT_Trunk1-00000690", "NOW=1505382722") in new stack
-- Executing [s@sub-record-check:4] Set("SIP/SIP_RT_Trunk1-00000690", "__DAY=14") in new stack
-- Executing [s@sub-record-check:5] Set("SIP/SIP_RT_Trunk1-00000690", "__MONTH=09") in new stack
-- Executing [s@sub-record-check:6] Set("SIP/SIP_RT_Trunk1-00000690", "__YEAR=2017") in new stack
-- Executing [s@sub-record-check:7] Set("SIP/SIP_RT_Trunk1-00000690", "__TIMESTR=20170914-125202") in new stack
-- Executing [s@sub-record-check:8] Set("SIP/SIP_RT_Trunk1-00000690", "__FROMEXTEN=unknown") in new stack
-- Executing [s@sub-record-check:9] Set("SIP/SIP_RT_Trunk1-00000690", "__MON_FMT=wav") in new stack
-- Executing [s@sub-record-check:10] NoOp("SIP/SIP_RT_Trunk1-00000690", "Recordings initialized") in new stack
-- Executing [s@sub-record-check:11] ExecIf("SIP/SIP_RT_Trunk1-00000690", "0?Set(ARG3=dontcare)") in new stack
-- Executing [s@sub-record-check:12] Set("SIP/SIP_RT_Trunk1-00000690", "REC_POLICY_MODE_SAVE=") in new stack
-- Executing [s@sub-record-check:13] ExecIf("SIP/SIP_RT_Trunk1-00000690", "0?Set(REC_STATUS=NO)") in new stack
-- Executing [202@from-trunk:1] Set("SIP/SIP_RT_Trunk1-00000691", "__DIRECTION=INBOUND") in new stack
-- Executing [s@sub-record-check:14] GotoIf("SIP/SIP_RT_Trunk1-00000690", "2?checkaction") in new stack
-- Executing [202@from-trunk:2] Gosub("SIP/SIP_RT_Trunk1-00000691", "sub-record-check,s,1(in,202,dontcare)") in new stack
-- Executing [201@from-trunk:1] Set("SIP/SIP_RT_Trunk1-00000692", "__DIRECTION=INBOUND") in new stack
-- Executing [s@sub-record-check:17] GotoIf("SIP/SIP_RT_Trunk1-00000690", "1?sub-record-check,in,1") in new stack
-- Executing [201@from-trunk:2] Gosub("SIP/SIP_RT_Trunk1-00000692", "sub-record-check,s,1(in,201,dontcare)") in new stack
-- Goto (sub-record-check,in,1)
-- Executing [in@sub-record-check:1] NoOp("SIP/SIP_RT_Trunk1-00000690", "Inbound Recording Check to 203") in new stack
-- Executing [in@sub-record-check:2] Set("SIP/SIP_RT_Trunk1-00000690", "FROMEXTEN=unknown") in new stack
-- Executing [s@sub-record-check:1] GotoIf("SIP/SIP_RT_Trunk1-00000691", "0?initialized") in new stack
-- Executing [in@sub-record-check:3] ExecIf("SIP/SIP_RT_Trunk1-00000690", "11?Set(FROMEXTEN=84742219999)") in new stack
-- Executing [s@sub-record-check:2] Set("SIP/SIP_RT_Trunk1-00000691", "__REC_STATUS=INITIALIZED") in new stack
-- Executing [s@sub-record-check:1] GotoIf("SIP/SIP_RT_Trunk1-00000692", "0?initialized") in new stack
-- Executing [s@sub-record-check:3] Set("SIP/SIP_RT_Trunk1-00000691", "NOW=1505382722") in new stack
-- Executing [in@sub-record-check:4] Gosub("SIP/SIP_RT_Trunk1-00000690", "recordcheck,1(dontcare,in,203)") in new stack
-- Executing [s@sub-record-check:2] Set("SIP/SIP_RT_Trunk1-00000692", "__REC_STATUS=INITIALIZED") in new stack
-- Executing [s@sub-record-check:4] Set("SIP/SIP_RT_Trunk1-00000691", "__DAY=14") in new stack
-- Executing [s@sub-record-check:3] Set("SIP/SIP_RT_Trunk1-00000692", "NOW=1505382722") in new stack
-- Executing [s@sub-record-check:5] Set("SIP/SIP_RT_Trunk1-00000691", "__MONTH=09") in new stack
-- Executing [s@sub-record-check:6] Set("SIP/SIP_RT_Trunk1-00000691", "__YEAR=2017") in new stack
-- Executing [recordcheck@sub-record-check:1] NoOp("SIP/SIP_RT_Trunk1-00000690", "Starting recording check against dontcare") in new stack
-- Executing [s@sub-record-check:4] Set("SIP/SIP_RT_Trunk1-00000692", "__DAY=14") in new stack
-- Executing [recordcheck@sub-record-check:2] Goto("SIP/SIP_RT_Trunk1-00000690", "dontcare") in new stack
-- Goto (sub-record-check,recordcheck,3)
-- Executing [recordcheck@sub-record-check:3] Return("SIP/SIP_RT_Trunk1-00000690", "") in new stack
-- Executing [s@sub-record-check:5] Set("SIP/SIP_RT_Trunk1-00000692", "__MONTH=09") in new stack
-- Executing [s@sub-record-check:7] Set("SIP/SIP_RT_Trunk1-00000691", "__TIMESTR=20170914-125202") in new stack
-- Executing [in@sub-record-check:5] Return("SIP/SIP_RT_Trunk1-00000690", "") in new stack
-- Executing [s@sub-record-check:6] Set("SIP/SIP_RT_Trunk1-00000692", "__YEAR=2017") in new stack
-- Executing [s@sub-record-check:8] Set("SIP/SIP_RT_Trunk1-00000691", "__FROMEXTEN=unknown") in new stack
-- Executing [s@sub-record-check:7] Set("SIP/SIP_RT_Trunk1-00000692", "__TIMESTR=20170914-125202") in new stack
-- Executing [203@from-trunk:3] Gosub("SIP/SIP_RT_Trunk1-00000690", "app-blacklist-check,s,1()") in new stack
-- Executing [s@app-blacklist-check:1] GotoIf("SIP/SIP_RT_Trunk1-00000690", "0?blacklisted") in new stack
-- Executing [s@sub-record-check:8] Set("SIP/SIP_RT_Trunk1-00000692", "__FROMEXTEN=unknown") in new stack
-- Executing [s@sub-record-check:9] Set("SIP/SIP_RT_Trunk1-00000691", "__MON_FMT=wav") in new stack
-- Executing [s@sub-record-check:10] NoOp("SIP/SIP_RT_Trunk1-00000691", "Recordings initialized") in new stack
-- Executing [s@sub-record-check:11] ExecIf("SIP/SIP_RT_Trunk1-00000691", "0?Set(ARG3=dontcare)") in new stack
-- Executing [s@app-blacklist-check:2] Set("SIP/SIP_RT_Trunk1-00000690", "CALLED_BLACKLIST=1") in new stack
-- Executing [s@sub-record-check:9] Set("SIP/SIP_RT_Trunk1-00000692", "__MON_FMT=wav") in new stack
-- Executing [s@sub-record-check:12] Set("SIP/SIP_RT_Trunk1-00000691", "REC_POLICY_MODE_SAVE=") in new stack
-- Executing [s@app-blacklist-check:3] Return("SIP/SIP_RT_Trunk1-00000690", "") in new stack
-- Executing [s@sub-record-check:10] NoOp("SIP/SIP_RT_Trunk1-00000692", "Recordings initialized") in new stack
-- Executing [s@sub-record-check:11] ExecIf("SIP/SIP_RT_Trunk1-00000692", "0?Set(ARG3=dontcare)") in new stack
-- Executing [s@sub-record-check:13] ExecIf("SIP/SIP_RT_Trunk1-00000691", "0?Set(REC_STATUS=NO)") in new stack
-- Executing [s@sub-record-check:12] Set("SIP/SIP_RT_Trunk1-00000692", "REC_POLICY_MODE_SAVE=") in new stack
-- Executing [s@sub-record-check:14] GotoIf("SIP/SIP_RT_Trunk1-00000691", "2?checkaction") in new stack
-- Executing [s@sub-record-check:17] GotoIf("SIP/SIP_RT_Trunk1-00000691", "1?sub-record-check,in,1") in new stack
-- Executing [s@sub-record-check:13] ExecIf("SIP/SIP_RT_Trunk1-00000692", "0?Set(REC_STATUS=NO)") in new stack
-- Executing [203@from-trunk:4] Set("SIP/SIP_RT_Trunk1-00000690", "__FROM_DID=203") in new stack
-- Executing [s@sub-record-check:14] GotoIf("SIP/SIP_RT_Trunk1-00000692", "2?checkaction") in new stack
-- Executing [203@from-trunk:5] Set("SIP/SIP_RT_Trunk1-00000690", "CDR(did)=203") in new stack
-- Executing [203@from-trunk:6] ExecIf("SIP/SIP_RT_Trunk1-00000690", "0 ?Set(CALLERID(name)=84742219999)") in new stack
-- Executing [in@sub-record-check:1] NoOp("SIP/SIP_RT_Trunk1-00000691", "Inbound Recording Check to 202") in new stack
-- Executing [203@from-trunk:7] Set("SIP/SIP_RT_Trunk1-00000690", "__MOHCLASS=") in new stack
-- Executing [in@sub-record-check:2] Set("SIP/SIP_RT_Trunk1-00000691", "FROMEXTEN=unknown") in new stack
-- Executing [s@sub-record-check:17] GotoIf("SIP/SIP_RT_Trunk1-00000692", "1?sub-record-check,in,1") in new stack
-- Executing [203@from-trunk:8] Set("SIP/SIP_RT_Trunk1-00000690", "__REVERSAL_REJECT=FALSE") in new stack
-- Executing [in@sub-record-check:1] NoOp("SIP/SIP_RT_Trunk1-00000692", "Inbound Recording Check to 201") in new stack
-- Executing [in@sub-record-check:3] ExecIf("SIP/SIP_RT_Trunk1-00000691", "11?Set(FROMEXTEN=84742219999)") in new stack
-- Executing [in@sub-record-check:2] Set("SIP/SIP_RT_Trunk1-00000692", "FROMEXTEN=unknown") in new stack
-- Executing [203@from-trunk:9] GotoIf("SIP/SIP_RT_Trunk1-00000690", "1?post-reverse-charge") in new stack
-- Executing [in@sub-record-check:3] ExecIf("SIP/SIP_RT_Trunk1-00000692", "11?Set(FROMEXTEN=84742219999)") in new stack
-- Executing [in@sub-record-check:4] Gosub("SIP/SIP_RT_Trunk1-00000691", "recordcheck,1(dontcare,in,202)") in new stack
-- Goto (from-trunk,203,11)
-- Executing [203@from-trunk:11] NoOp("SIP/SIP_RT_Trunk1-00000690", "") in new stack
-- Executing [203@from-trunk:12] Set("SIP/SIP_RT_Trunk1-00000690", "__CALLINGNAMEPRES_SV=allowed_not_screened") in new stack
-- Executing [in@sub-record-check:4] Gosub("SIP/SIP_RT_Trunk1-00000692", "recordcheck,1(dontcare,in,201)") in new stack
-- Executing [203@from-trunk:13] Set("SIP/SIP_RT_Trunk1-00000690", "__CALLINGNUMPRES_SV=allowed_not_screened") in new stack
-- Executing [recordcheck@sub-record-check:1] NoOp("SIP/SIP_RT_Trunk1-00000691", "Starting recording check against dontcare") in new stack
-- Executing [recordcheck@sub-record-check:2] Goto("SIP/SIP_RT_Trunk1-00000691", "dontcare") in new stack
-- Executing [203@from-trunk:14] Set("SIP/SIP_RT_Trunk1-00000690", "CALLERID(name-pres)=allowed_not_screened") in new stack
-- Executing [recordcheck@sub-record-check:1] NoOp("SIP/SIP_RT_Trunk1-00000692", "Starting recording check against dontcare") in new stack
-- Executing [recordcheck@sub-record-check:3] Return("SIP/SIP_RT_Trunk1-00000691", "") in new stack
-- Executing [203@from-trunk:15] Set("SIP/SIP_RT_Trunk1-00000690", "CALLERID(num-pres)=allowed_not_screened") in new stack
-- Executing [recordcheck@sub-record-check:2] Goto("SIP/SIP_RT_Trunk1-00000692", "dontcare") in new stack
-- Executing [203@from-trunk:16] NoOp("SIP/SIP_RT_Trunk1-00000690", "CallerID Entry Point") in new stack
-- Executing [recordcheck@sub-record-check:3] Return("SIP/SIP_RT_Trunk1-00000692", "") in new stack
-- Executing [in@sub-record-check:5] Return("SIP/SIP_RT_Trunk1-00000691", "") in new stack
-- Executing [203@from-trunk:17] Goto("SIP/SIP_RT_Trunk1-00000690", "ivr-1,s,1") in new stack
-- Executing [202@from-trunk:3] Gosub("SIP/SIP_RT_Trunk1-00000691", "app-blacklist-check,s,1()") in new stack
-- Executing [in@sub-record-check:5] Return("SIP/SIP_RT_Trunk1-00000692", "") in new stack
-- Goto (ivr-1,s,1)
-- Executing [s@ivr-1:1] Set("SIP/SIP_RT_Trunk1-00000690", "INVALID_LOOPCOUNT=0") in new stack
-- Executing [201@from-trunk:3] Gosub("SIP/SIP_RT_Trunk1-00000692", "app-blacklist-check,s,1()") in new stack
-- Executing [s@ivr-1:2] Set("SIP/SIP_RT_Trunk1-00000690", "_IVR_CONTEXT_ivr-1=") in new stack
-- Executing [s@app-blacklist-check:1] GotoIf("SIP/SIP_RT_Trunk1-00000691", "0?blacklisted") in new stack
-- Executing [s@ivr-1:3] Set("SIP/SIP_RT_Trunk1-00000690", "_IVR_CONTEXT=ivr-1") in new stack
-- Executing [s@app-blacklist-check:2] Set("SIP/SIP_RT_Trunk1-00000691", "CALLED_BLACKLIST=1") in new stack
-- Executing [s@app-blacklist-check:1] GotoIf("SIP/SIP_RT_Trunk1-00000692", "0?blacklisted") in new stack
-- Executing [s@ivr-1:4] Set("SIP/SIP_RT_Trunk1-00000690", "__IVR_RETVM=") in new stack
-- Executing [s@app-blacklist-check:3] Return("SIP/SIP_RT_Trunk1-00000691", "") in new stack
-- Executing [s@app-blacklist-check:2] Set("SIP/SIP_RT_Trunk1-00000692", "CALLED_BLACKLIST=1") in new stack
-- Executing [202@from-trunk:4] Set("SIP/SIP_RT_Trunk1-00000691", "__FROM_DID=202") in new stack
-- Executing [s@ivr-1:5] GotoIf("SIP/SIP_RT_Trunk1-00000690", "0?skip") in new stack
-- Executing [s@app-blacklist-check:3] Return("SIP/SIP_RT_Trunk1-00000692", "") in new stack
-- Executing [s@ivr-1:6] Answer("SIP/SIP_RT_Trunk1-00000690", "") in new stack
-- Executing [202@from-trunk:5] Set("SIP/SIP_RT_Trunk1-00000691", "CDR(did)=202") in new stack
-- Executing [201@from-trunk:4] Set("SIP/SIP_RT_Trunk1-00000692", "__FROM_DID=201") in new stack
-- Executing [202@from-trunk:6] ExecIf("SIP/SIP_RT_Trunk1-00000691", "0 ?Set(CALLERID(name)=84742219999)") in new stack
-- Executing [201@from-trunk:5] Set("SIP/SIP_RT_Trunk1-00000692", "CDR(did)=201") in new stack
-- Executing [202@from-trunk:7] Set("SIP/SIP_RT_Trunk1-00000691", "__MOHCLASS=") in new stack
-- Executing [201@from-trunk:6] ExecIf("SIP/SIP_RT_Trunk1-00000692", "0 ?Set(CALLERID(name)=84742219999)") in new stack
-- Executing [202@from-trunk:8] Set("SIP/SIP_RT_Trunk1-00000691", "__REVERSAL_REJECT=FALSE") in new stack
-- Executing [201@from-trunk:7] Set("SIP/SIP_RT_Trunk1-00000692", "__MOHCLASS=") in new stack
-- Executing [202@from-trunk:9] GotoIf("SIP/SIP_RT_Trunk1-00000691", "1?post-reverse-charge") in new stack
-- Executing [201@from-trunk:8] Set("SIP/SIP_RT_Trunk1-00000692", "__REVERSAL_REJECT=FALSE") in new stack
-- Executing [202@from-trunk:11] NoOp("SIP/SIP_RT_Trunk1-00000691", "") in new stack
-- Executing [201@from-trunk:9] GotoIf("SIP/SIP_RT_Trunk1-00000692", "1?post-reverse-charge") in new stack
-- Executing [202@from-trunk:12] Set("SIP/SIP_RT_Trunk1-00000691", "__CALLINGNAMEPRES_SV=allowed_not_screened") in new stack
-- Executing [201@from-trunk:11] NoOp("SIP/SIP_RT_Trunk1-00000692", "") in new stack
-- Executing [202@from-trunk:13] Set("SIP/SIP_RT_Trunk1-00000691", "__CALLINGNUMPRES_SV=allowed_not_screened") in new stack
-- Executing [201@from-trunk:12] Set("SIP/SIP_RT_Trunk1-00000692", "__CALLINGNAMEPRES_SV=allowed_not_screened") in new stack
-- Executing [202@from-trunk:14] Set("SIP/SIP_RT_Trunk1-00000691", "CALLERID(name-pres)=allowed_not_screened") in new stack
-- Executing [201@from-trunk:13] Set("SIP/SIP_RT_Trunk1-00000692", "__CALLINGNUMPRES_SV=allowed_not_screened") in new stack
-- Executing [202@from-trunk:15] Set("SIP/SIP_RT_Trunk1-00000691", "CALLERID(num-pres)=allowed_not_screened") in new stack
-- Executing [201@from-trunk:14] Set("SIP/SIP_RT_Trunk1-00000692", "CALLERID(name-pres)=allowed_not_screened") in new stack
-- Executing [202@from-trunk:16] NoOp("SIP/SIP_RT_Trunk1-00000691", "CallerID Entry Point") in new stack
-- Executing [201@from-trunk:15] Set("SIP/SIP_RT_Trunk1-00000692", "CALLERID(num-pres)=allowed_not_screened") in new stack
-- Executing [202@from-trunk:17] Goto("SIP/SIP_RT_Trunk1-00000691", "ivr-1,s,1") in new stack
-- Executing [201@from-trunk:16] NoOp("SIP/SIP_RT_Trunk1-00000692", "CallerID Entry Point") in new stack
-- Goto (ivr-1,s,1)
-- Executing [s@ivr-1:1] Set("SIP/SIP_RT_Trunk1-00000691", "INVALID_LOOPCOUNT=0") in new stack
-- Executing [201@from-trunk:17] Goto("SIP/SIP_RT_Trunk1-00000692", "ivr-1,s,1") in new stack
-- Executing [s@ivr-1:2] Set("SIP/SIP_RT_Trunk1-00000691", "_IVR_CONTEXT_ivr-1=") in new stack
-- Goto (ivr-1,s,1)
-- Executing [s@ivr-1:1] Set("SIP/SIP_RT_Trunk1-00000692", "INVALID_LOOPCOUNT=0") in new stack
-- Executing [s@ivr-1:3] Set("SIP/SIP_RT_Trunk1-00000691", "_IVR_CONTEXT=ivr-1") in new stack
-- Executing [s@ivr-1:2] Set("SIP/SIP_RT_Trunk1-00000692", "_IVR_CONTEXT_ivr-1=") in new stack
-- Executing [s@ivr-1:4] Set("SIP/SIP_RT_Trunk1-00000691", "__IVR_RETVM=") in new stack
-- Executing [s@ivr-1:3] Set("SIP/SIP_RT_Trunk1-00000692", "_IVR_CONTEXT=ivr-1") in new stack
-- Executing [s@ivr-1:5] GotoIf("SIP/SIP_RT_Trunk1-00000691", "0?skip") in new stack
-- Executing [s@ivr-1:4] Set("SIP/SIP_RT_Trunk1-00000692", "__IVR_RETVM=") in new stack
-- Executing [s@ivr-1:6] Answer("SIP/SIP_RT_Trunk1-00000691", "") in new stack
-- Executing [s@ivr-1:5] GotoIf("SIP/SIP_RT_Trunk1-00000692", "0?skip") in new stack
-- Executing [s@ivr-1:6] Answer("SIP/SIP_RT_Trunk1-00000692", "") in new stack
== Spawn extension (ivr-1, s, 6) exited non-zero on 'SIP/SIP_RT_Trunk1-00000691'
-- Executing [h@ivr-1:1] Hangup("SIP/SIP_RT_Trunk1-00000691", "") in new stack
== Spawn extension (ivr-1, h, 1) exited non-zero on 'SIP/SIP_RT_Trunk1-00000691'
== Spawn extension (ivr-1, s, 6) exited non-zero on 'SIP/SIP_RT_Trunk1-00000692'
-- Executing [h@ivr-1:1] Hangup("SIP/SIP_RT_Trunk1-00000692", "") in new stack
== Spawn extension (ivr-1, h, 1) exited non-zero on 'SIP/SIP_RT_Trunk1-00000692'
-- Executing [s@ivr-1:7] Wait("SIP/SIP_RT_Trunk1-00000690", "1") in new stack
> 0xb7253750 -- Probation passed - setting RTP source address to 77.51.247.44:12172
-- Executing [s@ivr-1:8] Set("SIP/SIP_RT_Trunk1-00000690", "IVR_MSG=custom/---") in new stack
-- Executing [s@ivr-1:9] Set("SIP/SIP_RT_Trunk1-00000690", "TIMEOUT(digit)=3") in new stack
-- Executing [s@ivr-1:10] ExecIf("SIP/SIP_RT_Trunk1-00000690", "1?Background(custom/---)") in new stack
-- <SIP/SIP_RT_Trunk1-00000690> Playing 'custom/---.slin' (language 'ru')
== Spawn extension (ivr-1, s, 10) exited non-zero on 'SIP/SIP_RT_Trunk1-00000690'
-- Executing [h@ivr-1:1] Hangup("SIP/SIP_RT_Trunk1-00000690", "") in new stack
== Spawn extension (ivr-1, h, 1) exited non-zero on 'SIP/SIP_RT_Trunk1-00000690'
-- Executing [203@from-trunk:1] Set("SIP/SIP_RT_Trunk1-00000693", "__DIRECTION=INBOUND") in new stack
-- Executing [203@from-trunk:2] Gosub("SIP/SIP_RT_Trunk1-00000693", "sub-record-check,s,1(in,203,dontcare)") in new stack
-- Executing [s@sub-record-check:1] GotoIf("SIP/SIP_RT_Trunk1-00000693", "0?initialized") in new stack
-- Executing [s@sub-record-check:2] Set("SIP/SIP_RT_Trunk1-00000693", "__REC_STATUS=INITIALIZED") in new stack
-- Executing [s@sub-record-check:3] Set("SIP/SIP_RT_Trunk1-00000693", "NOW=1505382730") in new stack
-- Executing [s@sub-record-check:4] Set("SIP/SIP_RT_Trunk1-00000693", "__DAY=14") in new stack
-- Executing [s@sub-record-check:5] Set("SIP/SIP_RT_Trunk1-00000693", "__MONTH=09") in new stack
-- Executing [s@sub-record-check:6] Set("SIP/SIP_RT_Trunk1-00000693", "__YEAR=2017") in new stack
-- Executing [s@sub-record-check:7] Set("SIP/SIP_RT_Trunk1-00000693", "__TIMESTR=20170914-125210") in new stack
-- Executing [s@sub-record-check:8] Set("SIP/SIP_RT_Trunk1-00000693", "__FROMEXTEN=unknown") in new stack
-- Executing [s@sub-record-check:9] Set("SIP/SIP_RT_Trunk1-00000693", "__MON_FMT=wav") in new stack
-- Executing [s@sub-record-check:10] NoOp("SIP/SIP_RT_Trunk1-00000693", "Recordings initialized") in new stack
-- Executing [s@sub-record-check:11] ExecIf("SIP/SIP_RT_Trunk1-00000693", "0?Set(ARG3=dontcare)") in new stack
-- Executing [s@sub-record-check:12] Set("SIP/SIP_RT_Trunk1-00000693", "REC_POLICY_MODE_SAVE=") in new stack
-- Executing [s@sub-record-check:13] ExecIf("SIP/SIP_RT_Trunk1-00000693", "0?Set(REC_STATUS=NO)") in new stack
-- Executing [s@sub-record-check:14] GotoIf("SIP/SIP_RT_Trunk1-00000693", "2?checkaction") in new stack
-- Executing [s@sub-record-check:17] GotoIf("SIP/SIP_RT_Trunk1-00000693", "1?sub-record-check,in,1") in new stack
-- Executing [in@sub-record-check:1] NoOp("SIP/SIP_RT_Trunk1-00000693", "Inbound Recording Check to 203") in new stack
-- Executing [in@sub-record-check:2] Set("SIP/SIP_RT_Trunk1-00000693", "FROMEXTEN=unknown") in new stack
-- Executing [in@sub-record-check:3] ExecIf("SIP/SIP_RT_Trunk1-00000693", "11?Set(FROMEXTEN=84742219999)") in new stack
-- Executing [in@sub-record-check:4] Gosub("SIP/SIP_RT_Trunk1-00000693", "recordcheck,1(dontcare,in,203)") in new stack
-- Executing [recordcheck@sub-record-check:1] NoOp("SIP/SIP_RT_Trunk1-00000693", "Starting recording check against dontcare") in new stack
-- Executing [recordcheck@sub-record-check:2] Goto("SIP/SIP_RT_Trunk1-00000693", "dontcare") in new stack
-- Executing [recordcheck@sub-record-check:3] Return("SIP/SIP_RT_Trunk1-00000693", "") in new stack
-- Executing [202@from-trunk:1] Set("SIP/SIP_RT_Trunk1-00000694", "__DIRECTION=INBOUND") in new stack
-- Executing [201@from-trunk:1] Set("SIP/SIP_RT_Trunk1-00000695", "__DIRECTION=INBOUND") in new stack
-- Executing [in@sub-record-check:5] Return("SIP/SIP_RT_Trunk1-00000693", "") in new stack
-- Executing [202@from-trunk:2] Gosub("SIP/SIP_RT_Trunk1-00000694", "sub-record-check,s,1(in,202,dontcare)") in new stack
-- Executing [201@from-trunk:2] Gosub("SIP/SIP_RT_Trunk1-00000695", "sub-record-check,s,1(in,201,dontcare)") in new stack
-- Executing [203@from-trunk:3] Gosub("SIP/SIP_RT_Trunk1-00000693", "app-blacklist-check,s,1()") in new stack
-- Executing [s@sub-record-check:1] GotoIf("SIP/SIP_RT_Trunk1-00000694", "0?initialized") in new stack
-- Executing [s@sub-record-check:2] Set("SIP/SIP_RT_Trunk1-00000694", "__REC_STATUS=INITIALIZED") in new stack
-- Executing [s@sub-record-check:1] GotoIf("SIP/SIP_RT_Trunk1-00000695", "0?initialized") in new stack
-- Executing [s@app-blacklist-check:1] GotoIf("SIP/SIP_RT_Trunk1-00000693", "0?blacklisted") in new stack
-- Executing [s@app-blacklist-check:2] Set("SIP/SIP_RT_Trunk1-00000693", "CALLED_BLACKLIST=1") in new stack
-- Executing [s@sub-record-check:2] Set("SIP/SIP_RT_Trunk1-00000695", "__REC_STATUS=INITIALIZED") in new stack
-- Executing [s@app-blacklist-check:3] Return("SIP/SIP_RT_Trunk1-00000693", "") in new stack
-- Executing [s@sub-record-check:3] Set("SIP/SIP_RT_Trunk1-00000695", "NOW=1505382730") in new stack
-- Executing [203@from-trunk:4] Set("SIP/SIP_RT_Trunk1-00000693", "__FROM_DID=203") in new stack
-- Executing [s@sub-record-check:4] Set("SIP/SIP_RT_Trunk1-00000695", "__DAY=14") in new stack
-- Executing [203@from-trunk:5] Set("SIP/SIP_RT_Trunk1-00000693", "CDR(did)=203") in new stack
-- Executing [203@from-trunk:6] ExecIf("SIP/SIP_RT_Trunk1-00000693", "0 ?Set(CALLERID(name)=84742219999)") in new stack
-- Executing [s@sub-record-check:5] Set("SIP/SIP_RT_Trunk1-00000695", "__MONTH=09") in new stack
-- Executing [203@from-trunk:7] Set("SIP/SIP_RT_Trunk1-00000693", "__MOHCLASS=") in new stack
-- Executing [s@sub-record-check:3] Set("SIP/SIP_RT_Trunk1-00000694", "NOW=1505382730") in new stack
-- Executing [s@sub-record-check:4] Set("SIP/SIP_RT_Trunk1-00000694", "__DAY=14") in new stack
-- Executing [s@sub-record-check:6] Set("SIP/SIP_RT_Trunk1-00000695", "__YEAR=2017") in new stack
-- Executing [s@sub-record-check:5] Set("SIP/SIP_RT_Trunk1-00000694", "__MONTH=09") in new stack
-- Executing [203@from-trunk:8] Set("SIP/SIP_RT_Trunk1-00000693", "__REVERSAL_REJECT=FALSE") in new stack
-- Executing [s@sub-record-check:6] Set("SIP/SIP_RT_Trunk1-00000694", "__YEAR=2017") in new stack
-- Executing [s@sub-record-check:7] Set("SIP/SIP_RT_Trunk1-00000695", "__TIMESTR=20170914-125210") in new stack
-- Executing [s@sub-record-check:7] Set("SIP/SIP_RT_Trunk1-00000694", "__TIMESTR=20170914-125210") in new stack
-- Executing [203@from-trunk:9] GotoIf("SIP/SIP_RT_Trunk1-00000693", "1?post-reverse-charge") in new stack
-- Executing [s@sub-record-check:8] Set("SIP/SIP_RT_Trunk1-00000694", "__FROMEXTEN=unknown") in new stack
-- Executing [203@from-trunk:11] NoOp("SIP/SIP_RT_Trunk1-00000693", "") in new stack
-- Executing [203@from-trunk:12] Set("SIP/SIP_RT_Trunk1-00000693", "__CALLINGNAMEPRES_SV=allowed_not_screened") in new stack
-- Executing [s@sub-record-check:9] Set("SIP/SIP_RT_Trunk1-00000694", "__MON_FMT=wav") in new stack
-- Executing [203@from-trunk:13] Set("SIP/SIP_RT_Trunk1-00000693", "__CALLINGNUMPRES_SV=allowed_not_screened") in new stack
-- Executing [s@sub-record-check:10] NoOp("SIP/SIP_RT_Trunk1-00000694", "Recordings initialized") in new stack
-- Executing [s@sub-record-check:11] ExecIf("SIP/SIP_RT_Trunk1-00000694", "0?Set(ARG3=dontcare)") in new stack
-- Executing [s@sub-record-check:12] Set("SIP/SIP_RT_Trunk1-00000694", "REC_POLICY_MODE_SAVE=") in new stack
-- Executing [s@sub-record-check:13] ExecIf("SIP/SIP_RT_Trunk1-00000694", "0?Set(REC_STATUS=NO)") in new stack
-- Executing [s@sub-record-check:14] GotoIf("SIP/SIP_RT_Trunk1-00000694", "2?checkaction") in new stack
-- Executing [s@sub-record-check:17] GotoIf("SIP/SIP_RT_Trunk1-00000694", "1?sub-record-check,in,1") in new stack
-- Executing [in@sub-record-check:1] NoOp("SIP/SIP_RT_Trunk1-00000694", "Inbound Recording Check to 202") in new stack
-- Executing [in@sub-record-check:2] Set("SIP/SIP_RT_Trunk1-00000694", "FROMEXTEN=unknown") in new stack
-- Executing [203@from-trunk:14] Set("SIP/SIP_RT_Trunk1-00000693", "CALLERID(name-pres)=allowed_not_screened") in new stack
-- Executing [in@sub-record-check:3] ExecIf("SIP/SIP_RT_Trunk1-00000694", "11?Set(FROMEXTEN=84742219999)") in new stack
-- Executing [in@sub-record-check:4] Gosub("SIP/SIP_RT_Trunk1-00000694", "recordcheck,1(dontcare,in,202)") in new stack
-- Executing [s@sub-record-check:8] Set("SIP/SIP_RT_Trunk1-00000695", "__FROMEXTEN=unknown") in new stack
-- Executing [203@from-trunk:15] Set("SIP/SIP_RT_Trunk1-00000693", "CALLERID(num-pres)=allowed_not_screened") in new stack
-- Executing [203@from-trunk:16] NoOp("SIP/SIP_RT_Trunk1-00000693", "CallerID Entry Point") in new stack
-- Executing [203@from-trunk:17] Goto("SIP/SIP_RT_Trunk1-00000693", "ivr-1,s,1") in new stack
-- Executing [s@sub-record-check:9] Set("SIP/SIP_RT_Trunk1-00000695", "__MON_FMT=wav") in new stack
-- Goto (ivr-1,s,1)
-- Executing [s@ivr-1:1] Set("SIP/SIP_RT_Trunk1-00000693", "INVALID_LOOPCOUNT=0") in new stack
-- Executing [s@sub-record-check:10] NoOp("SIP/SIP_RT_Trunk1-00000695", "Recordings initialized") in new stack
-- Executing [s@ivr-1:2] Set("SIP/SIP_RT_Trunk1-00000693", "_IVR_CONTEXT_ivr-1=") in new stack
-- Executing [s@sub-record-check:11] ExecIf("SIP/SIP_RT_Trunk1-00000695", "0?Set(ARG3=dontcare)") in new stack
-- Executing [s@sub-record-check:12] Set("SIP/SIP_RT_Trunk1-00000695", "REC_POLICY_MODE_SAVE=") in new stack
-- Executing [s@ivr-1:3] Set("SIP/SIP_RT_Trunk1-00000693", "_IVR_CONTEXT=ivr-1") in new stack
-- Executing [s@ivr-1:4] Set("SIP/SIP_RT_Trunk1-00000693", "__IVR_RETVM=") in new stack
-- Executing [s@sub-record-check:13] ExecIf("SIP/SIP_RT_Trunk1-00000695", "0?Set(REC_STATUS=NO)") in new stack
-- Executing [s@ivr-1:5] GotoIf("SIP/SIP_RT_Trunk1-00000693", "0?skip") in new stack
-- Executing [s@sub-record-check:14] GotoIf("SIP/SIP_RT_Trunk1-00000695", "2?checkaction") in new stack
-- Executing [s@ivr-1:6] Answer("SIP/SIP_RT_Trunk1-00000693", "") in new stack
-- Executing [recordcheck@sub-record-check:1] NoOp("SIP/SIP_RT_Trunk1-00000694", "Starting recording check against dontcare") in new stack
-- Executing [recordcheck@sub-record-check:2] Goto("SIP/SIP_RT_Trunk1-00000694", "dontcare") in new stack
-- Executing [recordcheck@sub-record-check:3] Return("SIP/SIP_RT_Trunk1-00000694", "") in new stack
-- Executing [in@sub-record-check:5] Return("SIP/SIP_RT_Trunk1-00000694", "") in new stack
-- Executing [s@sub-record-check:17] GotoIf("SIP/SIP_RT_Trunk1-00000695", "1?sub-record-check,in,1") in new stack
-- Executing [202@from-trunk:3] Gosub("SIP/SIP_RT_Trunk1-00000694", "app-blacklist-check,s,1()") in new stack
-- Executing [in@sub-record-check:1] NoOp("SIP/SIP_RT_Trunk1-00000695", "Inbound Recording Check to 201") in new stack
-- Executing [s@app-blacklist-check:1] GotoIf("SIP/SIP_RT_Trunk1-00000694", "0?blacklisted") in new stack
-- Executing [s@app-blacklist-check:2] Set("SIP/SIP_RT_Trunk1-00000694", "CALLED_BLACKLIST=1") in new stack
-- Executing [in@sub-record-check:2] Set("SIP/SIP_RT_Trunk1-00000695", "FROMEXTEN=unknown") in new stack
-- Executing [s@app-blacklist-check:3] Return("SIP/SIP_RT_Trunk1-00000694", "") in new stack
-- Executing [202@from-trunk:4] Set("SIP/SIP_RT_Trunk1-00000694", "__FROM_DID=202") in new stack
-- Executing [202@from-trunk:5] Set("SIP/SIP_RT_Trunk1-00000694", "CDR(did)=202") in new stack
-- Executing [in@sub-record-check:3] ExecIf("SIP/SIP_RT_Trunk1-00000695", "11?Set(FROMEXTEN=84742219999)") in new stack
-- Executing [202@from-trunk:6] ExecIf("SIP/SIP_RT_Trunk1-00000694", "0 ?Set(CALLERID(name)=84742219999)") in new stack
-- Executing [202@from-trunk:7] Set("SIP/SIP_RT_Trunk1-00000694", "__MOHCLASS=") in new stack
-- Executing [202@from-trunk:8] Set("SIP/SIP_RT_Trunk1-00000694", "__REVERSAL_REJECT=FALSE") in new stack
-- Executing [202@from-trunk:9] GotoIf("SIP/SIP_RT_Trunk1-00000694", "1?post-reverse-charge") in new stack
-- Executing [in@sub-record-check:4] Gosub("SIP/SIP_RT_Trunk1-00000695", "recordcheck,1(dontcare,in,201)") in new stack
-- Executing [202@from-trunk:11] NoOp("SIP/SIP_RT_Trunk1-00000694", "") in new stack
-- Executing [202@from-trunk:12] Set("SIP/SIP_RT_Trunk1-00000694", "__CALLINGNAMEPRES_SV=allowed_not_screened") in new stack
-- Executing [202@from-trunk:13] Set("SIP/SIP_RT_Trunk1-00000694", "__CALLINGNUMPRES_SV=allowed_not_screened") in new stack
-- Executing [202@from-trunk:14] Set("SIP/SIP_RT_Trunk1-00000694", "CALLERID(name-pres)=allowed_not_screened") in new stack
-- Executing [recordcheck@sub-record-check:1] NoOp("SIP/SIP_RT_Trunk1-00000695", "Starting recording check against dontcare") in new stack
-- Executing [202@from-trunk:15] Set("SIP/SIP_RT_Trunk1-00000694", "CALLERID(num-pres)=allowed_not_screened") in new stack
-- Executing [recordcheck@sub-record-check:2] Goto("SIP/SIP_RT_Trunk1-00000695", "dontcare") in new stack
-- Executing [202@from-trunk:16] NoOp("SIP/SIP_RT_Trunk1-00000694", "CallerID Entry Point") in new stack
-- Executing [recordcheck@sub-record-check:3] Return("SIP/SIP_RT_Trunk1-00000695", "") in new stack
-- Executing [202@from-trunk:17] Goto("SIP/SIP_RT_Trunk1-00000694", "ivr-1,s,1") in new stack
-- Goto (ivr-1,s,1)
-- Executing [s@ivr-1:1] Set("SIP/SIP_RT_Trunk1-00000694", "INVALID_LOOPCOUNT=0") in new stack
-- Executing [s@ivr-1:2] Set("SIP/SIP_RT_Trunk1-00000694", "_IVR_CONTEXT_ivr-1=") in new stack
-- Executing [s@ivr-1:3] Set("SIP/SIP_RT_Trunk1-00000694", "_IVR_CONTEXT=ivr-1") in new stack
-- Executing [in@sub-record-check:5] Return("SIP/SIP_RT_Trunk1-00000695", "") in new stack
-- Executing [s@ivr-1:4] Set("SIP/SIP_RT_Trunk1-00000694", "__IVR_RETVM=") in new stack
-- Executing [201@from-trunk:3] Gosub("SIP/SIP_RT_Trunk1-00000695", "app-blacklist-check,s,1()") in new stack
-- Executing [s@ivr-1:5] GotoIf("SIP/SIP_RT_Trunk1-00000694", "0?skip") in new stack
-- Executing [s@ivr-1:6] Answer("SIP/SIP_RT_Trunk1-00000694", "") in new stack
-- Executing [s@app-blacklist-check:1] GotoIf("SIP/SIP_RT_Trunk1-00000695", "0?blacklisted") in new stack
-- Executing [s@app-blacklist-check:2] Set("SIP/SIP_RT_Trunk1-00000695", "CALLED_BLACKLIST=1") in new stack
-- Executing [s@app-blacklist-check:3] Return("SIP/SIP_RT_Trunk1-00000695", "") in new stack
-- Executing [201@from-trunk:4] Set("SIP/SIP_RT_Trunk1-00000695", "__FROM_DID=201") in new stack
-- Executing [201@from-trunk:5] Set("SIP/SIP_RT_Trunk1-00000695", "CDR(did)=201") in new stack
-- Executing [201@from-trunk:6] ExecIf("SIP/SIP_RT_Trunk1-00000695", "0 ?Set(CALLERID(name)=84742219999)") in new stack
-- Executing [201@from-trunk:7] Set("SIP/SIP_RT_Trunk1-00000695", "__MOHCLASS=") in new stack
-- Executing [201@from-trunk:8] Set("SIP/SIP_RT_Trunk1-00000695", "__REVERSAL_REJECT=FALSE") in new stack
-- Executing [201@from-trunk:9] GotoIf("SIP/SIP_RT_Trunk1-00000695", "1?post-reverse-charge") in new stack
-- Executing [201@from-trunk:11] NoOp("SIP/SIP_RT_Trunk1-00000695", "") in new stack
-- Executing [201@from-trunk:12] Set("SIP/SIP_RT_Trunk1-00000695", "__CALLINGNAMEPRES_SV=allowed_not_screened") in new stack
-- Executing [201@from-trunk:13] Set("SIP/SIP_RT_Trunk1-00000695", "__CALLINGNUMPRES_SV=allowed_not_screened") in new stack
-- Executing [201@from-trunk:14] Set("SIP/SIP_RT_Trunk1-00000695", "CALLERID(name-pres)=allowed_not_screened") in new stack
-- Executing [201@from-trunk:15] Set("SIP/SIP_RT_Trunk1-00000695", "CALLERID(num-pres)=allowed_not_screened") in new stack
-- Executing [201@from-trunk:16] NoOp("SIP/SIP_RT_Trunk1-00000695", "CallerID Entry Point") in new stack
-- Executing [201@from-trunk:17] Goto("SIP/SIP_RT_Trunk1-00000695", "ivr-1,s,1") in new stack
-- Goto (ivr-1,s,1)
-- Executing [s@ivr-1:1] Set("SIP/SIP_RT_Trunk1-00000695", "INVALID_LOOPCOUNT=0") in new stack
-- Executing [s@ivr-1:2] Set("SIP/SIP_RT_Trunk1-00000695", "_IVR_CONTEXT_ivr-1=") in new stack
-- Executing [s@ivr-1:3] Set("SIP/SIP_RT_Trunk1-00000695", "_IVR_CONTEXT=ivr-1") in new stack
-- Executing [s@ivr-1:4] Set("SIP/SIP_RT_Trunk1-00000695", "__IVR_RETVM=") in new stack
-- Executing [s@ivr-1:5] GotoIf("SIP/SIP_RT_Trunk1-00000695", "0?skip") in new stack
-- Executing [s@ivr-1:6] Answer("SIP/SIP_RT_Trunk1-00000695", "") in new stack
== Spawn extension (ivr-1, s, 6) exited non-zero on 'SIP/SIP_RT_Trunk1-00000694'
-- Executing [h@ivr-1:1] Hangup("SIP/SIP_RT_Trunk1-00000694", "") in new stack
== Spawn extension (ivr-1, h, 1) exited non-zero on 'SIP/SIP_RT_Trunk1-00000694'
== Spawn extension (ivr-1, s, 6) exited non-zero on 'SIP/SIP_RT_Trunk1-00000695'
-- Executing [h@ivr-1:1] Hangup("SIP/SIP_RT_Trunk1-00000695", "") in new stack
== Spawn extension (ivr-1, h, 1) exited non-zero on 'SIP/SIP_RT_Trunk1-00000695'
== Spawn extension (ivr-1, s, 6) exited non-zero on 'SIP/SIP_RT_Trunk1-00000693'
-- Executing [h@ivr-1:1] Hangup("SIP/SIP_RT_Trunk1-00000693", "") in new stack
== Spawn extension (ivr-1, h, 1) exited non-zero on 'SIP/SIP_RT_Trunk1-00000693'
Проблема плавающая, не думаю, что проблема может быть в РТ, т.к. звонок-то приходит и его "сбрасывает" asterisk. Подскажите пожалуйста в чем может быть проблема?
Re: Облачная телефония Ростелеком FreePBX 13
Вопрос раз: включен ли дебаг DTMF
Вопрос два: в IVR есть настройки варианта с i (когда номер набран не правильно)
dogidogi
Дебаг включен. настройки, касаемые invalid есть (dest. retries и т.п. если речь о них). Проблема в том, что иногда даже гудка нет, просто сразу звонок "срывается". Но в CLI есть какая-то информация, то есть отлуп получается не на стороне РТ.
тогда надо смотреть подробнее
включаете дебаг
sip set debug peer ИМЯ on
dogidogi писал(а): звонок "срывается". Но в CLI есть какая-то информация, то есть отлуп получается не на стороне РТ.
sip debug пира РТ даст Вам точный ответ на этот вопрос. И тогда кусок SIP пакета - Cancel или Bye - что там прилетает - в техподдержку РТ.
dogidogi
После звонка в поддержку РТ выяснилось, что проблема в том, что, если указаны несколько внутренних абонентов, то при входящем звонке начинают звонить одновременно все линии и Asterisk одновременно поднимает трубки на всех линиях, что не нравится РТ и он посылает BYE. Исправляется отключением остальных внутренних номеров в облачной телефонии (так называемые пользователи, оставляя по 1 для каждого городского номера), либо указанием приоритета звонка у пользователя (в личном кабинете). Спасибо)
