SPA3102 и Asterisk 13.17.0
logdog
Сообщение logdog »
Добрый!
Перенастраиваю с Elastix на AsteriskNow...
Проблема возникла со SPA3102 (используется только PSTN Line), при одинаковых настройках, не работает на AsteriskNow
Для cisco 7940 настроил pjsip, а для SPA3102 ни sip, ни pjsip не взлетает(
<--- SIP read from UDP:10.0.0.249:5160 --->
SIP/2.0 200 OK
To: <sip:10.0.0.249>;tag=86b62726fbe5c793i1
From: "Unknown" <sip:SPA3102@10.0.0.251:5160>;tag=as5d19dc4a
Call-ID: 4c395c2a3f27dea90fb2407c7ea50538@10.0.0.251:5160
CSeq: 102 OPTIONS
Via: SIP/2.0/UDP 10.0.0.251:5160;branch=z9hG4bK6f75b9e8
Server: Linksys/SPA3102-5.2.13(GW002)
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
Supported: x-sipura, replaces
15:11:44.159382 IP 10.0.0.251.5160 > 10.0.0.249.5160: UDP, length 526
E`.*....@.R.
....(.(....OPTIONS sip:10.0.0.249 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.251:5160;branch=z9hG4bK4f7922d6
From: "Unknown" <sip:SPA3102@10.0.0.251:5160>;tag=as753cd34c
Contact: <sip:SPA3102@10.0.0.251:5160>
Call-ID: 3b79b5526e1ed607587b4f72600a78cd@10.0.0.251:5160
CSeq: 102 OPTIONS
User-Agent: FPBX-13.0.192.16(13.17.0)
Date: Sun, 13 Aug 2017 15:11:44 GMT
15:11:44.166753 IP 10.0.0.249.5160 > 10.0.0.251.5160: UDP, length 412
Eh.../......
....(.(....SIP/2.0 200 OK
To: <sip:10.0.0.249>;tag=81173b9aee989dc1i1
CSeq: 102 OPTIONS
15:12:14.816096 ARP, Request who-has 10.0.0.249 tell 10.0.0.107, length 46
..........D.o.
..k......
......B..n...........
15:12:44.167047 IP 10.0.0.251.5160 > 10.0.0.249.5160: UDP, length 526
E`.*....@.R.
Via: SIP/2.0/UDP 10.0.0.251:5160;branch=z9hG4bK710ed2f0
From: "Unknown" <sip:SPA3102@10.0.0.251:5160>;tag=as3cfaea2a
Call-ID: 6d4aa8541023673432b74b5d0fa6b65b@10.0.0.251:5160
CSeq: 102 OPTIONS
Date: Sun, 13 Aug 2017 15:12:44 GMT
15:12:44.176508 IP 10.0.0.249.5160 > 10.0.0.251.5160: UDP, length 412
Eh..._.....z
CSeq: 102 OPTIONS
15:12:49.166829 ARP, Request who-has 10.0.0.249 tell 10.0.0.251, length 28
........@.\..P
15:12:49.167049 ARP, Reply 10.0.0.249 is-at 00:0e:08:de:03:63 (oui Unknown), length 46
.............c
...@.\..P
Настройка спа http://joxi.ru/4Ak0nv0fy79dvr
Настройка freepbx http://joxi.ru/Dr8WBvWi461wVA
Просьба подсказать с настройками.
Заранее спасибо!
не помогло
https://wiki.freepbx.org/pages/viewpage ... d=55476525
https://forum.asterisk.ru/viewtopic.php?f=5&t=5043
Re: SPA3102 и Asterisk 13.17.0
logdog
Сообщение logdog »
ну это точно не для 13 версии *, так как там он стучится на 5160.
Народная легенда гласит = желтый цвет машины добавляет 10 лошадей к мощности.
PS трудно порт сменить ?
logdog
Сообщение logdog »
Естественно порт менял (и на 5165 менял... и указывал на *, что 5165 и nat=never)... не ходят звонки....
а где инвайт то ....
у меня работают два 3102, где стоят не знаю, но по сети видно. работают больше 5 лет.
пробуйте . зарегистрировать SPA на астериске.
Э, я понял - вы меняете порт на устройстве и ждете что он на asterisk будет по другому порту стучаться ?
менять надо в параметре вызова - там где указан сервере - примерно так 192.168.0.5:5161
logdog
Сообщение logdog »
awsswa писал(а):Э, я понял - вы меняете порт на устройстве и ждете что он на asterisk будет по другому порту стучаться ?
port=5165 ставил ... но опять же, говорю, дефолтовый 5160 я ставил для PSTN линии (только PSTN использую), все равно не работает... хотелось, конечно, с регистрацией сделать (не как у вас в примере).
april22 писал(а):а где инвайт то ....
и сейчас на 12,13 версия астерикса работают?
на 11 версию spa у меня нормально регистрируется и работает.
у меня стоит 1.8 .
могу , просто ради интере5са попробовать и ан 12\13 , но ! Это будут не раньше чем через месяц , по причине не хватки времени.
думаю , ни какой разницы не должно быть .
logdog
Сообщение logdog »
april22 писал(а):у меня стоит 1.8 .
я еще попробую перебрать пару вариантов на sip и на pjsip ...я вот тоже думаю, что поменять порт на 5160, больше ничего не должно меняться между 11 и 13 версией, ан нет...
если не получится, готов дать удаленный доступ и оплатить тесты и если будет специфика, заодно и народу выложите инфу.
