тада нифиХ нинада))))
Не за 8 т.р. точно ?
кассовый чек будет?
Cообщение от   Telegram-канал ZIlIllII
English or Russian please.
Are you help me
Are you help me
Asked your question
Asked your question
Can you setup asterisk for me with anydesk
Cообщение от   Telegram-канал R0LSEN
Can you pay 2000$ for the job?
Very expensive
Cообщение от   Telegram-канал Konstantin
Dear, it’s important to note that providing a clear and comprehensive technical specification is essential. Without a detailed description of the desired functionalities, requirements, and objectives for the Asterisk system, it would be challenging to ensure the setup meets your expectations. Specifically, we would need to know the intended use cases, the scale/reliable of the system, any integrations or customizations required. This clarity will allow to deliver a solution that aligns perfectly with your needs.
I can give to you .az domains
Азербайджан чтоли?
