Астер посылает в отбивку, так как не находит такой внутренний номер (с приставкой)
Да покажи блин лог вызова! ?‍♂️
Cообщение от   Telegram-канал ZhurAndre
[2025-03-20 14:30:47] -- Executing [3422055@from-pstn:1] Set("PJSIP/MSK-000063d4", "__FROM_DID=3422055") in new stack
[2025-03-20 14:30:47] -- Executing [3422055@from-pstn:2] NoOp("PJSIP/MSK-000063d4", "Received an unknown call with DID set to 3422055") in new stack
[2025-03-20 14:30:47] -- Executing [3422055@from-pstn:3] Goto("PJSIP/MSK-000063d4", "s,a2") in new stack
[2025-03-20 14:30:47] -- Goto (from-pstn,s,2)
[2025-03-20 14:30:47] -- Executing [s@from-pstn:2] Answer("PJSIP/MSK-000063d4", "") in new stack
[2025-03-20 14:30:47] > 0x7fb2cc0484b0 -- Strict RTP learning after remote address set to: 10.20.X.X:5200
[2025-03-20 14:30:48] ERROR[14473][C-00003a76]: pbx_functions.c:651 ast_func_read2: Function SIP_HEADER not registered
[2025-03-20 14:30:48] -- Executing [s@from-pstn:3] Log("PJSIP/MSK-000063d4", "WARNING,Friendly Scanner from ") in new stack
[2025-03-20 14:30:48] WARNING[14473][C-00003a76]: Ext. s:3 @ from-pstn: Friendly Scanner from
[2025-03-20 14:30:48] -- Executing [s@from-pstn:4] Wait("PJSIP/MSK-000063d4", "2") in new stack
[2025-03-20 14:30:48] > 0x7fb2cc0484b0 -- Strict RTP switching to RTP target address 10.20.X.X:5200 as source
[2025-03-20 14:30:50] -- Executing [s@from-pstn:5] Playback("PJSIP/MSK-000063d4", "ss-noservice") in new stack
[2025-03-20 14:30:50] -- Playing 'ss-noservice.ulaw' (language 'ru')
[2025-03-20 14:30:52] > 0x7fb2cc0484b0 -- Strict RTP learning complete - Locking on source address 10.20.X.X:5200
[2025-03-20 14:30:54] -- Executing [s@from-pstn:6] SayAlpha("PJSIP/MSK-000063d4", "3422055") in new stack
[2025-03-20 14:30:54] -- Playing 'digits/3.ulaw' (language 'ru')
[2025-03-20 14:30:54] == Spawn extension (from-pstn, s, 6) exited non-zero on 'PJSIP/MSK-000063d4'
[2025-03-20 14:30:55] -- Executing [h@from-pstn:1] Macro("PJSIP/MSK-000063d4", "hangupcall,") in new stack
[2025-03-20 14:30:55] -- Executing [s@macro-hangupcall:1] Set("PJSIP/MSK-000063d4", "__MCVMSTATUS=") in new stack
[2025-03-20 14:30:55] -- Executing [s@macro-hangupcall:2] Gosub("PJSIP/MSK-000063d4", "app-missedcall-hangup,s,1()") in new stack
[2025-03-20 14:30:55] -- Executing [s@app-missedcall-hangup:1] NoOp("PJSIP/MSK-000063d4", "Dialed: s") in new stack
[2025-03-20 14:30:55] -- Executing [s@app-missedcall-hangup:2] NoOp("PJSIP/MSK-000063d4", "Caller: ") in new stack
[2025-03-20 14:30:55] -- Executing [s@app-missedcall-hangup:3] GotoIf("PJSIP/MSK-000063d4", "0?exit") in new stack
[2025-03-20 14:30:55] -- Executing [s@app-missedcall-hangup:4] Set("PJSIP/MSK-000063d4", "EXTENNUM=s") in new stack
[2025-03-20 14:30:55] -- Executing [s@app-missedcall-hangup:5] Set("PJSIP/MSK-000063d4", "FEXTENNUM=s") in new stack
[2025-03-20 14:30:55] -- Executing [s@app-missedcall-hangup:6] GotoIf("PJSIP/MSK-000063d4", "0?exit") in new stack
[2025-03-20 14:30:55] -- Executing [s@app-missedcall-hangup:7] AGI("PJSIP/MSK-000063d4", "agi://127.0.0.1/missedcallnotify.php,s,,s,0,,PJSIP/MSK-000063d4,,,,") in new stack
[2025-03-20 14:30:55] -- AGI Script agi://127.0.0.1/missedcallnotify.php completed, returning 0
[2025-03-20 14:30:55] -- Executing [s@app-missedcall-hangup:8] Return("PJSIP/MSK-000063d4", "") in new stack
[2025-03-20 14:30:55] -- Executing [s@macro-hangupcall:3] GotoIf("PJSIP/MSK-000063d4", "1?theend") in new stack
[2025-03-20 14:30:55] -- Goto (macro-hangupcall,s,5)
[2025-03-20 14:30:55] -- Executing [s@macro-hangupcall:5] ExecIf("PJSIP/MSK-000063d4", "0?Set(CDR(recordingfile)=)") in new stack
[2025-03-20 14:30:55] -- Executing [s@macro-hangupcall:6] Hangup("PJSIP/MSK-000063d4", "") in new stack
[2025-03-20 14:30:55] == Spawn extension (macro-hangupcall, s, 6) exited non-zero on 'PJSIP/MSK-000063d4' in macro 'hangupcall'
[2025-03-20 14:30:55] == Spawn extension (from-pstn, h, 1) exited non-zero on 'PJSIP/MSK-000063d4'
название транка "MSK"
магическое слово pastebin
необходимо при получении из транка 342XXXX сделать XXXX, это и будет необходимый внутренний номер
Cообщение от   Telegram-канал kipalex
Ну отрезать 342
Ну отрезать 342
я понимаю что надо отрезать, но где это сделать на FreePBX пока не разобрался
Cообщение от   Telegram-канал brost1986
что надо отрезать? номер А или Б
при входящем звонке из транка на внутренний необходимо отрезать приставку, из 342ХХХХ оставить ХХХХ
и далее перенаправить на внутренний ХХХХ
