включать дебаг общий и sip
будет видно как происходит выбор пира
<--- SIP read from UDP:192.168.111.111:5060 --->
INVITE sip:333@192.168.100.111 SIP/2.0
Via: SIP/2.0/UDP 192.168.111.111:5060;branch=z9hG4bK2fa87a26
From: "202" <sip:202@192.168.111.111>;tag=as1dbbe900
To: <sip:333@192.168.100.111>
Contact: <sip:202@192.168.111.111:5060>
Call-ID: 379b003c1392bdc56ac5fb446692ce60@192.168.111.111:5060
CSeq: 102 INVITE
User-Agent: Asterisk PBX 1.8.20.0
Date: Wed, 12 Mar 2014 12:13:40 GMT
Content-Length: 260
v=0
o=root 598210340 598210340 IN IP4 192.168.111.111
s=Asterisk PBX 1.8.20.0
c=IN IP4 192.168.111.111
t=0 0
m=audio 13524 RTP/AVP 8 101
a=rtpmap:8 PCMA/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
--- (14 headers 12 lines) ---
Sending to 192.168.111.111:5060 (NAT)
Using INVITE request as basis request - 379b003c1392bdc56ac5fb446692ce60@192.168.111.111:5060
Found peer '202' for '202' from 192.168.111.111:5060
<--- Reliably Transmitting (no NAT) to 192.168.111.111:5060 --->
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 192.168.111.111:5060;branch=z9hG4bK2fa87a26;received=192.168.111.111
To: <sip:333@192.168.100.111>;tag=as1bcd3d5c
CSeq: 102 INVITE
Server: Asterisk PBX 1.8.15.1
WWW-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="15a93fec"
Scheduling destruction of SIP dialog '379b003c1392bdc56ac5fb446692ce60@192.168.111.111:5060' in 6400 ms (Method: INVITE)
ACK sip:333@192.168.100.111 SIP/2.0
CSeq: 102 ACK
<--- Reliably Transmitting (no NAT) to 192.168.0.102:5060 --->
SIP/2.0 403 Forbidden
Via: SIP/2.0/UDP 192.168.0.102:5060;branch=z9hG4bK1257472033145347;received=192.168.0.102;rport=5060
From: Test202 <sip:202@192.168.111.111:5060>;tag=120161177
To: "333" <sip:333@192.168.111.111:5060>;tag=as269826dd
Call-ID: 25211640630300-93132832711735@192.168.0.102
CSeq: 1 INVITE
Server: Asterisk PBX 1.8.20.0
Really destroying SIP dialog '176a9116193919393d012858512a46a4@192.168.111.111:5060' Method: INVITE
<--- SIP read from UDP:192.168.0.102:5060 --->
ACK sip:333@192.168.111.111:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.102:5060;branch=z9hG4bK1257472033145347;rport
CSeq: 1 ACK
--- (8 headers 0 lines) ---
Reliably Transmitting (no NAT) to 192.168.100.111:5060:
OPTIONS sip:192.168.100.111 SIP/2.0
Via: SIP/2.0/UDP 192.168.111.111:5060;branch=z9hG4bK2b941aa0
From: "asterisk" <sip:asterisk@192.168.111.111>;tag=as36625927
To: <sip:192.168.100.111>
Contact: <sip:asterisk@192.168.111.111:5060>
Call-ID: 60a3a4ad70c653f70b40671b5f4dff5b@192.168.111.111:5060
CSeq: 102 OPTIONS
Date: Wed, 12 Mar 2014 12:21:44 GMT
<--- SIP read from UDP:192.168.100.111:5060 --->
SIP/2.0 404 Not Found
Via: SIP/2.0/UDP 192.168.111.111:5060;branch=z9hG4bK2b941aa0;received=192.168.111.111;rport=5060
To: <sip:192.168.100.111>;tag=as049c8c5e
CSeq: 102 OPTIONS
Accept: application/sdp
--- (11 headers 0 lines) ---
Really destroying SIP dialog '60a3a4ad70c653f70b40671b5f4dff5b@192.168.111.111:5060' Method: OPTIONS
OPTIONS sip:192.168.111.111 SIP/2.0
Via: SIP/2.0/UDP 192.168.100.111:5060;branch=z9hG4bK542b2a6b
From: "asterisk" <sip:asterisk@192.168.100.111>;tag=as3c0d29d6
To: <sip:192.168.111.111>
Contact: <sip:asterisk@192.168.100.111:5060>
Call-ID: 1f5a4a676d2e40132ca12256051d8d76@192.168.100.111:5060
CSeq: 102 OPTIONS
User-Agent: Asterisk PBX 1.8.15.1
Date: Wed, 12 Mar 2014 12:21:18 GMT
--- (13 headers 0 lines) ---
Looking for s in default (domain 192.168.111.111)
<--- Transmitting (NAT) to 192.168.100.111:5060 --->
Via: SIP/2.0/UDP 192.168.100.111:5060;branch=z9hG4bK542b2a6b;received=192.168.100.111;rport=5060
To: <sip:192.168.111.111>;tag=as62d70710
CSeq: 102 OPTIONS
Scheduling destruction of SIP dialog '1f5a4a676d2e40132ca12256051d8d76@192.168.100.111:5060' in 32000 ms (Method: OPTIONS)
Really destroying SIP dialog '25211640630300-93132832711735@192.168.0.102' Method: ACK
REGISTER sip:192.168.111.111 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.102:5060;branch=z9hG4bK1889202402375319992;rport
From: Test202 <sip:202@192.168.111.111:5060>;tag=3014613116
To: Test202 <sip:202@192.168.111.111:5060>
Call-ID: 253071584526290-3333111729886@192.168.0.102
CSeq: 2823 REGISTER
Contact: <sip:202@192.168.0.102:5060>
Expires: 60
Supported: path
User-Agent: Voip Phone 1.0
--- (12 headers 0 lines) ---
Sending to 192.168.0.102:5060 (NAT)
<--- Transmitting (no NAT) to 192.168.0.102:5060 --->
Via: SIP/2.0/UDP 192.168.0.102:5060;branch=z9hG4bK1889202402375319992;received=192.168.0.102;rport=5060
To: Test202 <sip:202@192.168.111.111:5060>;tag=as31b9a581
CSeq: 2823 REGISTER
WWW-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="5d6c16cc"
Scheduling destruction of SIP dialog '253071584526290-3333111729886@192.168.0.102' in 32000 ms (Method: REGISTER)
Via: SIP/2.0/UDP 192.168.0.102:5060;branch=z9hG4bK2762178091941213003;rport
CSeq: 2824 REGISTER
Authorization: Digest username="202", realm="asterisk", nonce="5d6c16cc", uri="sip:192.168.111.111", response="17fc324282a4e4e91263a2b8849f259a", algorithm=MD5
Expires: 60
Supported: path
Sending to 192.168.0.102:5060 (no NAT)
Reliably Transmitting (no NAT) to 192.168.0.102:5060:
OPTIONS sip:202@192.168.0.102:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.111.111:5060;branch=z9hG4bK51cce668
From: "asterisk" <sip:202@192.168.111.111>;tag=as5a0d946b
To: <sip:202@192.168.0.102:5060>
Call-ID: 166448c11700fa7b57a32c694b8293c7@192.168.111.111:5060
CSeq: 102 OPTIONS
Date: Wed, 12 Mar 2014 12:21:50 GMT
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.0.102:5060;branch=z9hG4bK2762178091941213003;received=192.168.0.102;rport=5060
CSeq: 2824 REGISTER
Expires: 60
Contact: <sip:202@192.168.0.102:5060>;expires=60
SIP/2.0 200 OK
CSeq: 102 OPTIONS
Supported: 100rel, replaces, timer
Allow: INVITE, ACK, OPTIONS, BYE, CANCEL, REFER, NOTIFY, INFO, PRACK, UPDATE, MESSAGE
Accept: application/sdp, message/sipfrag, application/dtmf-relay
Really destroying SIP dialog '166448c11700fa7b57a32c694b8293c7@192.168.111.111:5060' Method: OPTIONS
<--- SIP read from UDP:192.168.0.101:5060 --->
Via: SIP/2.0/UDP 192.168.0.101:5060;branch=z9hG4bK32329250922916629246;rport
From: Test <sip:201@192.168.111.111:5060>;tag=2974532410
To: Test <sip:201@192.168.111.111:5060>
Call-ID: 249002951313917-24202153814174@192.168.0.101
CSeq: 3265 REGISTER
Contact: <sip:201@192.168.0.101:5060>
Expires: 60
Supported: path
Sending to 192.168.0.101:5060 (NAT)
<--- Transmitting (no NAT) to 192.168.0.101:5060 --->
Via: SIP/2.0/UDP 192.168.0.101:5060;branch=z9hG4bK32329250922916629246;received=192.168.0.101;rport=5060
To: Test <sip:201@192.168.111.111:5060>;tag=as3a148f2a
CSeq: 3265 REGISTER
WWW-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="5edf9256"
Scheduling destruction of SIP dialog '249002951313917-24202153814174@192.168.0.101' in 32000 ms (Method: REGISTER)
Via: SIP/2.0/UDP 192.168.0.101:5060;branch=z9hG4bK74019297149558988;rport
CSeq: 3266 REGISTER
Authorization: Digest username="201", realm="asterisk", nonce="5edf9256", uri="sip:192.168.111.111", response="a36380e4782141d4dea19768a1cf7fb1", algorithm=MD5
Expires: 60
Supported: path
Sending to 192.168.0.101:5060 (no NAT)
Reliably Transmitting (no NAT) to 192.168.0.101:5060:
OPTIONS sip:201@192.168.0.101:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.111.111:5060;branch=z9hG4bK1a21f8ef
From: "asterisk" <sip:asterisk@192.168.111.111>;tag=as560c2457
To: <sip:201@192.168.0.101:5060>
Call-ID: 7293c4aa6ce517a239fc8b2c28a1903a@192.168.111.111:5060
CSeq: 102 OPTIONS
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.0.101:5060;branch=z9hG4bK74019297149558988;received=192.168.0.101;rport=5060
CSeq: 3266 REGISTER
Expires: 60
Contact: <sip:201@192.168.0.101:5060>;expires=60
SIP/2.0 200 OK
CSeq: 102 OPTIONS
Really destroying SIP dialog '7293c4aa6ce517a239fc8b2c28a1903a@192.168.111.111:5060' Method: OPTIONS
Via: SIP/2.0/UDP 192.168.0.102:5060;branch=z9hG4bK3095323891252212730;received=192.168.0.102;rport=5060
From: Test202 <sip:202@192.168.111.111:5060>;tag=845518332
To: "333" <sip:333@192.168.111.111:5060>;tag=as07357a29
Call-ID: 30953520110532-254862135811365@192.168.0.102
CSeq: 1 INVITE
Via: SIP/2.0/UDP 192.168.0.102:5060;branch=z9hG4bK3095323891252212730;rport
CSeq: 1 ACK
Really destroying SIP dialog '30953520110532-254862135811365@192.168.0.102' Method: ACK
Via: SIP/2.0/UDP 192.168.111.111:5060;branch=z9hG4bK5db79df7
From: "202" <sip:202@192.168.111.111>;tag=as069d621e
Call-ID: 6d47d4040d8375ba3fb6a47d767f6aa0@192.168.111.111:5060
CSeq: 102 INVITE
Date: Wed, 12 Mar 2014 13:22:06 GMT
Content-Length: 262
v=0
o=root 1607241875 1607241875 IN IP4 192.168.111.111
t=0 0
m=audio 19052 RTP/AVP 8 101
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
[Asterisk*CLI>
[0K--- (14 headers 12 lines) ---
[Asterisk*CLI>
[0KSending to 192.168.111.111:5060 (NAT)
[Asterisk*CLI>
[0KUsing INVITE request as basis request - 6d47d4040d8375ba3fb6a47d767f6aa0@192.168.111.111:5060
[Asterisk*CLI>
[0KFound peer '202' for '202' from 192.168.111.111:5060
[Asterisk*CLI>
[0K
Via: SIP/2.0/UDP 192.168.111.111:5060;branch=z9hG4bK5db79df7;received=192.168.111.111
To: <sip:333@192.168.100.111>;tag=as79b1b474
CSeq: 102 INVITE
WWW-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="2ed30f9b"
[Asterisk*CLI>
[0KScheduling destruction of SIP dialog '6d47d4040d8375ba3fb6a47d767f6aa0@192.168.111.111:5060' in 6400 ms (Method: INVITE)
[Asterisk*CLI>
[0K
CSeq: 102 ACK
ещё есть вопросы?Found peer '202' for '202' from 192.168.111.111:5060
Конечно ТС не смотрит на дебаг даже когда публикует его.test-sip писал(а):Ну а по поводу обид, обид нет. просто Вы задрали нос оочень высоко.
