Cообщение от   Telegram-канал DenisKost678
telnet 127.0.0.1 5038
Trying 127.0.0.1...
telnet: connect to address 127.0.0.1: Connection refused
внезапно)
Trying 127.0.0.1...
module show like manager показывает ?
freepbx*CLI> module show like manager
Module Description Use Count Status Support Level
cdr_manager.so Asterisk Manager Interface CDR Backend 0 Not Running core
cel_manager.so Asterisk Manager Interface CEL Backend 0 Running core
res_manager_devicestate.so Manager Device State Topic Forwarder 0 Running core
res_manager_presencestate.so Manager Presence State Topic Forwarder 0 Running core
4 modules loaded
4 modules loaded
module load manager.so
[2024-12-26 09:26:18] WARNING[5237]: loader.c:577 load_dlopen: Error loading module 'manager.so': /usr/lib64/asterisk/modules/manager.so: cannot open shared object file: No such file or directory
[2024-12-26 09:26:18] WARNING[5237]: loader.c:1180 load_resource: Module 'manager.so' could not be loaded.
модуль про...
стоп! а такого модуля нет, по крайней мере в 18 астере ))
Cообщение от   Telegram-канал Coolminan
4 modules loaded
Manager show settings
Manager (AMI): Yes
Web Manager (AMI/HTTP): No
TCP Bindaddress: 192.168.2.190:5038
HTTP Timeout (seconds): 60
TLS Enable: No
TLS Bindaddress: Disabled
TLS Certfile: asterisk.pem
TLS Privatekey:
TLS Cipher:
Allow multiple login: Yes
Display connects: No
Timestamp events: No
Channel vars:
Debug: No
