Не работают отчеты в FreePBX
Re: Не работают отчеты в FreePBX
нормальные ответы:
CLI> module reload cdr_addon_mysql.so
    -- Reloading module 'cdr_addon_mysql.so' (MySQL CDR Backend)
CLI> cdr show status
Call Detail Record (CDR) settings
  Logging:                    Enabled
  Mode:                       Simple
  Log unanswered calls:       No
* Registered Backends
    mysql
CLI> cdr mysql status
Connected to asteriskcdrdb on socket file default using table cdr for 1 days, 5 hours, 25 minutes, 9 seconds.
  Wrote 0 records since last restart.
Parenek
Сообщение Parenek »
asterisk*CLI> module reload cdr_addon_mysql.so
No such module 'cdr_addon_mysql.so'
asterisk*CLI> cdr show status
  Logging:                    Enabled
  Mode:                       Simple
    (none)
asterisk*CLI>
asterisk*CLI> cdr mysql status
No such command 'cdr mysql status' (type 'core show help cdr mysql' for other possible commands)
asterisk*CLI> module show like mysql
Module                         Description                              Use Count
0 modules loaded
[root@asterisk ~]# cat /etc/asterisk/cdr_mysql.conf
; Note - if the database server is hosted on the same machine as the
; asterisk server, you can achieve a local Unix socket connection by
; setting hostname = localhost
; port and sock are both optional parameters.  If hostname is specified
; and is not "localhost", then cdr_mysql will attempt to connect to the
; port specified or use the default port.  If hostname is not specified
; or if hostname is "localhost", then cdr_mysql will attempt to connect
; to the socket file specified by sock or otherwise use the default socket
; file.
[global]
dbname=asteriskcdrdb
password = fpbx
user = freepbx
userfield=1
port=3306
sock=/tmp/mysql.sock
[root@asterisk ~]# rpm -qa | grep mysql
mysql-5.0.77-4.el5_6.6
mysql-server-5.0.77-4.el5_6.6
php-mysql-5.1.6-27.el5
asterisk16-addons-mysql-1.6.2.3-1_centos5
mysql-devel-5.0.77-4.el5_6.6
mysql-connector-odbc-3.51.26r1127-1.el5
забей в /etc/asterisk/cdr_mysql.conf логин и пароль вы данные по
cat /etc/amportal.conf | grep AMPDBUSER
cat /etc/amportal.conf | grep AMPDBPASS
заодно проверь вывод
cat /etc/amportal.conf | grep CDR
# Set Agent Name in CDR dstchannel
QUEUES_UPDATECDR=FALSE
# --- CATEGORY: Remote CDR Database ---
# Remote CDR DB Host
CDRDBHOST=
# Remote CDR DB Name
CDRDBNAME=
# Remote CDR DB Password
CDRDBPASS=
# Remote CDR DB Port
CDRDBPORT=
# Remote CDR DB Table
CDRDBTABLENAME=
# Remote CDR DB Type
CDRDBTYPE=
# Remote CDR DB User
CDRDBUSER=
и заодно
mysql -uroot -p
mysql> GRANT ALL PRIVILEGES ON asteriskcdrdb.* TO asteriskcdruser@localhost IDENTIFIED BY 'MYSQLCDRDBPASSWORD';
mysql> flush-privileges;
логин и пароль естественно свои
