Elastix - детализация вх звонков
Re: Elastix - детализация вх звонков
не путайте /etc/host.conf с /etc/hosts
multi on
в первом
Kir
Сообщение Kir »
добавил multi on, но вэб так и не открывается(
netstat -lpn
melkey
Сообщение melkey »
Kir писал(а):добавил multi on, но вэб так и не открывается(
Да не добавить надо, а заменить вашу строку в /etc/host.conf
127.0.0.1 localhost
на
multi on
И лог апача выложите, если не получится
Kir
Сообщение Kir »
multi on не помогло
Логи
[Wed Apr 13 11:03:12 2016] [notice] SSL FIPS mode disabled
[Wed Apr 13 11:03:12 2016] [notice] Digest: generating secret for digest authentication ...
[Wed Apr 13 11:03:12 2016] [notice] Digest: done
[Wed Apr 13 11:03:13 2016] [notice] Apache/2.2.3 (CentOS) configured -- resuming normal operations
[Wed Apr 13 11:03:27 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 11:03:35 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 11:06:30 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 11:12:04 2016] [error] [client 192.168.1.4] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 11:53:47 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 11:53:53 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 11:54:53 2016] [error] [client 192.168.1.4] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 11:55:30 2016] [error] [client 192.168.1.4] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 11:55:33 2016] [error] [client 192.168.1.4] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 12:01:44 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 12:11:18 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 12:11:57 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 12:13:18 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 12:13:31 2016] [notice] caught SIGTERM, shutting down
[Wed Apr 13 12:13:31 2016] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Wed Apr 13 12:13:31 2016] [notice] SSL FIPS mode disabled
[Wed Apr 13 12:13:31 2016] [notice] Digest: generating secret for digest authentication ...
[Wed Apr 13 12:13:31 2016] [notice] Digest: done
[Wed Apr 13 12:13:31 2016] [notice] Apache/2.2.3 (CentOS) configured -- resuming normal operations
[Wed Apr 13 12:13:37 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 12:13:38 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 12:13:40 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 12:14:01 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 12:18:01 2016] [notice] caught SIGTERM, shutting down
[Wed Apr 13 12:18:01 2016] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Wed Apr 13 12:18:01 2016] [notice] SSL FIPS mode disabled
[Wed Apr 13 12:18:01 2016] [notice] Digest: generating secret for digest authentication ...
[Wed Apr 13 12:18:01 2016] [notice] Digest: done
[Wed Apr 13 12:18:01 2016] [notice] Apache/2.2.3 (CentOS) configured -- resuming normal operations
[Wed Apr 13 12:23:26 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 12:24:04 2016] [notice] caught SIGTERM, shutting down
[Wed Apr 13 12:24:04 2016] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Wed Apr 13 12:24:04 2016] [notice] SSL FIPS mode disabled
[Wed Apr 13 12:24:05 2016] [notice] Digest: generating secret for digest authentication ...
[Wed Apr 13 12:24:05 2016] [notice] Digest: done
[Wed Apr 13 12:24:05 2016] [notice] SSL FIPS mode disabled
[Wed Apr 13 12:24:05 2016] [notice] Apache/2.2.3 (CentOS) configured -- resuming normal operations
[Wed Apr 13 12:29:41 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
/etc/host.conf: line 1: bad command `127.0.0.1 localhost'
[Wed Apr 13 12:32:59 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 12:33:01 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 12:33:19 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 12:33:24 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 12:40:18 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 12:43:55 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 13:14:02 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 13:18:22 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 14:02:55 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 14:10:29 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 14:10:30 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 14:15:35 2016] [notice] caught SIGTERM, shutting down
[Wed Apr 13 14:15:35 2016] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Wed Apr 13 14:15:35 2016] [notice] SSL FIPS mode disabled
[Wed Apr 13 14:15:36 2016] [notice] Digest: generating secret for digest authentication ...
[Wed Apr 13 14:15:36 2016] [notice] Digest: done
[Wed Apr 13 14:15:36 2016] [notice] SSL FIPS mode disabled
[Wed Apr 13 14:15:36 2016] [notice] Apache/2.2.3 (CentOS) configured -- resuming normal operations
[Wed Apr 13 14:15:41 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 14:15:43 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 14:15:45 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 14:15:50 2016] [error] [client 192.168.1.78] PHP Parse error: syntax error, unexpected T_STRING in /var/www/asterisk-cdr-viewer/include/config.inc.php on line 8
[Wed Apr 13 14:16:57 2016] [notice] caught SIGTERM, shutting down
[Wed Apr 13 14:16:57 2016] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Wed Apr 13 14:16:57 2016] [notice] SSL FIPS mode disabled
[Wed Apr 13 14:16:57 2016] [notice] Digest: generating secret for digest authentication ...
[Wed Apr 13 14:16:57 2016] [notice] Digest: done
[Wed Apr 13 14:16:57 2016] [notice] Apache/2.2.3 (CentOS) configured -- resuming normal operations
[Wed Apr 13 14:25:14 2016] [notice] caught SIGTERM, shutting down
[Wed Apr 13 14:25:14 2016] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Wed Apr 13 14:25:14 2016] [notice] SSL FIPS mode disabled
[Wed Apr 13 14:25:14 2016] [notice] Digest: generating secret for digest authentication ...
[Wed Apr 13 14:25:14 2016] [notice] Digest: done
[Wed Apr 13 14:25:14 2016] [notice] Apache/2.2.3 (CentOS) configured -- resuming normal operations
[Thu Apr 14 14:47:19 2016] [notice] caught SIGTERM, shutting down
[Thu Apr 14 14:47:19 2016] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Thu Apr 14 14:47:19 2016] [notice] SSL FIPS mode disabled
[Thu Apr 14 14:47:19 2016] [notice] Digest: generating secret for digest authentication ...
[Thu Apr 14 14:47:19 2016] [notice] Digest: done
[Thu Apr 14 14:47:19 2016] [notice] Apache/2.2.3 (CentOS) configured -- resuming normal operations
[Thu Apr 14 14:58:56 2016] [notice] caught SIGTERM, shutting down
[Thu Apr 14 14:58:56 2016] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Thu Apr 14 14:58:56 2016] [notice] SSL FIPS mode disabled
[Thu Apr 14 14:58:56 2016] [notice] Digest: generating secret for digest authentication ...
[Thu Apr 14 14:58:56 2016] [notice] Digest: done
[Thu Apr 14 14:58:57 2016] [notice] Apache/2.2.3 (CentOS) configured -- resuming normal operations
[Thu Apr 14 17:03:20 2016] [error] [client 185.25.148.240] client denied by server configuration: /var/www/html/testproxy.php
[Thu Apr 14 17:19:36 2016] [notice] caught SIGTERM, shutting down
[Thu Apr 14 17:21:57 2016] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Thu Apr 14 17:21:58 2016] [notice] SSL FIPS mode disabled
[Thu Apr 14 17:21:58 2016] [notice] Digest: generating secret for digest authentication ...
[Thu Apr 14 17:21:58 2016] [notice] Digest: done
[Thu Apr 14 17:21:58 2016] [notice] Apache/2.2.3 (CentOS) configured -- resuming normal operations
[Thu Apr 14 19:28:09 2016] [error] [client 92.222.65.232] client denied by server configuration: /var/www/html/a2billing/customer
[Thu Apr 14 19:46:16 2016] [error] [client 163.172.13.43] client denied by server configuration: /var/www/html/
[Thu Apr 14 19:46:16 2016] [error] [client 163.172.13.43] client denied by server configuration: /var/www/html/HNAP1, referer: http://46.38.46.27/
[Thu Apr 14 20:21:09 2016] [error] [client 178.162.198.132] client denied by server configuration: /var/www/html/a2billing/admin/Public/index.php
[Thu Apr 14 21:02:03 2016] [error] [client 180.97.106.161] client denied by server configuration: /var/www/html/robots.txt
[Thu Apr 14 21:40:40 2016] [error] [client 92.222.65.232] client denied by server configuration: /var/www/html/a2billing/customer
[Thu Apr 14 22:47:49 2016] [error] [client 118.161.69.244] client denied by server configuration: /var/www/html/
[Thu Apr 14 22:48:02 2016] [error] [client 118.161.69.244] client denied by server configuration: /var/www/html/
[Thu Apr 14 23:11:30 2016] [error] [client 85.25.197.58] client denied by server configuration: /var/www/html/
[Thu Apr 14 23:37:19 2016] [error] [client 85.25.218.219] client denied by server configuration: /var/www/html/a2billing/admin/Public/index.php
[Fri Apr 15 00:44:21 2016] [error] [client 150.70.188.167] client denied by server configuration: /var/www/html/
[Fri Apr 15 01:26:09 2016] [error] [client 192.187.126.242] client denied by server configuration: /var/www/html/
[Fri Apr 15 02:04:11 2016] [error] [client 85.114.105.159] client denied by server configuration: /var/www/html/
[Fri Apr 15 03:45:27 2016] [error] [client 173.224.117.166] client denied by server configuration: /var/www/html/a2billing/admin/Public/index.php
[Fri Apr 15 03:46:10 2016] [error] [client 173.224.117.166] client denied by server configuration: /var/www/html/
[Fri Apr 15 06:36:18 2016] [error] [client 80.82.78.38] client denied by server configuration: /var/www/html/cache
[Fri Apr 15 08:22:40 2016] [error] [client 37.48.124.118] client denied by server configuration: /var/www/html/
[Fri Apr 15 09:02:46 2016] [error] [client 85.25.218.219] client denied by server configuration: /var/www/html/
[Fri Apr 15 09:13:28 2016] [error] [client 173.224.117.166] client denied by server configuration: /var/www/html/a2billing/admin/Public/index.php
[Fri Apr 15 09:14:51 2016] [error] [client 173.224.117.166] client denied by server configuration: /var/www/html/
[Fri Apr 15 10:08:29 2016] [error] [client 37.142.255.205] client denied by server configuration: /var/www/html/
[Fri Apr 15 10:41:15 2016] [notice] caught SIGTERM, shutting down
[Fri Apr 15 10:41:15 2016] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Fri Apr 15 10:41:15 2016] [notice] SSL FIPS mode disabled
[Fri Apr 15 10:41:15 2016] [notice] Digest: generating secret for digest authentication ...
[Fri Apr 15 10:41:15 2016] [notice] Digest: done
[Fri Apr 15 10:41:16 2016] [notice] Apache/2.2.3 (CentOS) configured -- resuming normal operations
[Fri Apr 15 10:46:20 2016] [notice] caught SIGTERM, shutting down
[Fri Apr 15 10:46:20 2016] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Fri Apr 15 10:46:20 2016] [notice] SSL FIPS mode disabled
[Fri Apr 15 10:46:20 2016] [notice] Digest: generating secret for digest authentication ...
[Fri Apr 15 10:46:20 2016] [notice] Digest: done
[Fri Apr 15 10:46:21 2016] [notice] Apache/2.2.3 (CentOS) configured -- resuming normal operations
[Fri Apr 15 11:56:44 2016] [error] [client 193.124.183.56] client denied by server configuration: /var/www/html/
[Fri Apr 15 12:12:20 2016] [error] [client 212.220.99.94] request failed: error reading the headers
[Fri Apr 15 13:26:00 2016] [error] [client 197.89.55.27] client denied by server configuration: /var/www/html/
[Fri Apr 15 13:35:28 2016] [notice] caught SIGTERM, shutting down
[Fri Apr 15 13:35:28 2016] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Fri Apr 15 13:35:28 2016] [notice] SSL FIPS mode disabled
[Fri Apr 15 13:35:28 2016] [notice] Digest: generating secret for digest authentication ...
[Fri Apr 15 13:35:28 2016] [notice] Digest: done
[Fri Apr 15 13:35:29 2016] [notice] Apache/2.2.3 (CentOS) configured -- resuming normal operations
[Fri Apr 15 15:26:20 2016] [error] [client 65.129.0.220] client denied by server configuration: /var/www/html/
[Fri Apr 15 15:59:04 2016] [error] [client 141.212.122.161] client denied by server configuration: /var/www/html/
[Fri Apr 15 16:02:14 2016] [error] [client 194.28.112.173] client denied by server configuration: /var/www/html/
[Fri Apr 15 16:02:14 2016] [error] [client 194.28.112.173] client denied by server configuration: /var/www/html/HNAP1, referer: http://46.38.46.27/
[Fri Apr 15 16:15:19 2016] [notice] caught SIGTERM, shutting down
[Fri Apr 15 16:15:19 2016] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Fri Apr 15 16:15:19 2016] [notice] SSL FIPS mode disabled
[Fri Apr 15 16:15:19 2016] [notice] Digest: generating secret for digest authentication ...
[Fri Apr 15 16:15:19 2016] [notice] Digest: done
[Fri Apr 15 16:15:19 2016] [notice] Apache/2.2.3 (CentOS) configured -- resuming normal operations
[Sun Apr 17 04:02:16 2016] [notice] SIGHUP received. Attempting to restart
httpd: Could not reliably determine the server's fully qualified domain name, using 127.0.0.1 for ServerName
Вы вообще ответы читаете? Почему не реагируете?
Vlad1983 писал(а):не путайте /etc/host.conf с /etc/hosts
Kir
Сообщение Kir »
Вот лог.
[root@pbx httpd]# cat error_log
[Sun Apr 17 04:02:16 2016] [notice] Digest: generating secret for digest authentication ...
[Sun Apr 17 04:02:16 2016] [notice] Digest: done
[Sun Apr 17 04:02:16 2016] [notice] SSL FIPS mode disabled
[Sun Apr 17 04:02:16 2016] [notice] Apache/2.2.3 (CentOS) configured -- resuming normal operations
[Mon Apr 18 10:28:02 2016] [notice] caught SIGTERM, shutting down
[Mon Apr 18 10:28:02 2016] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Mon Apr 18 10:28:02 2016] [notice] SSL FIPS mode disabled
[Mon Apr 18 10:28:02 2016] [notice] Digest: generating secret for digest authentication ...
[Mon Apr 18 10:28:02 2016] [notice] Digest: done
[Mon Apr 18 10:28:02 2016] [notice] Apache/2.2.3 (CentOS) configured -- resuming normal operations
