Ищю настройки Addpac GS1002B
Re: Ищю настройки Addpac GS1002B
Исправляй уже
! Pots peer configuration.
dial-peer voice 0 pots
destination-pattern 301
port 0/2
user-password addpac301
! Voip peer configuration.
dial-peer voice 101 voip
destination-pattern T
session target sip-server
session protocol sip
voice-class codec 1
no vad
dtmf-relay rtp-2833
BooM
Сообщение BooM »
Доброе утро. Спасибо что не оставляете в пучине страстей цифровых)
Что имеем.
Конфиг Addpac
version 8.51.002
hostname GS1002
username root password router administrator
username guest password guest user
interface Loopback0
 ip address 127.0.0.1 255.0.0.0
interface FastEthernet0/0
 ip address 192.168.88.50 255.255.255.0
 ip nat outside
 speed auto
 no qos-control
interface FastEthernet0/1
 ip address 192.168.0.1 255.255.255.0
 ip nat inside
 speed auto
 no qos-control
no ip routing
ip route 0.0.0.0 0.0.0.0 192.168.88.1 10
http server
dns name-server 192.168.88.1
logging command
logging event 4-warning
logging on
! VoIP configuration.
! Voice service voip configuration.
voice service voip
 protocol sip
 dtmf-relay out-of-band
 fax protocol t38 redundancy 0
 fax rate 9600
 h323 call start fast
 h323 call tunnel enable
 no call-barring unconfigured-ip-address
 no voip-inbound-call-barring enable
! Voice port configuration.
! GSM
voice-port 0/0
 no caller-id enable
! GSM
voice-port 0/1
 no caller-id enable
! FXS
voice-port 0/2
 no announcement
 no caller-id enable
! FXS
voice-port 0/3
 no caller-id enable
! service port group configuration.
 port 0/2
 user-name Addpac1
 voice-class codec 1
 no vad
 dtmf-relay rtp-2833
gatekeeper
! Gateway configuration.
gateway
 h323-id voip.192.168.88.13
 no ignore-msg-from-other-gk
 register
! Codec classes configuration.
voice class codec 0
 codec preference 1 g711alaw
 codec preference 2 g711ulaw
 codec preference 3 g7231r53
 codec preference 4 g7231r63
 codec preference 5 g729
! SIP UA configuration.
sip-ua
 user-register
 sip-server 192.168.88.13
 call-transfer-mode attended
 remote-party-id
 register e164
! Tones
line console
line vty
gsm dev-restart-by-unreg 300
gsm 0/0
 sms-language utf8
gsm 0/1
 sms-language utf8
end
Дебаг Addpac при регистрации. Из него видно что Addpac не может пройти регистрацию, хз почему. В этом пока проблема.
2282 <CEP 000200> : Call Received
2283 <CEP 000200> : Call Initiated : calledNumber() crv(0) total(0)
2284 <SIP 261> : WriteREGISTER
2285 <SIP 0> : No authentication information available
2286 <SIP 261> : Send REGISTER Request
2287 <Call 21> : ****** Call Created status(InitiatedByFXS) ver(8.28:2006-02-06-00-00) time(1311242300) ****
2288 <CEP 000200> : Calling number(301)
2289 <CEP 000200> : Call id(3cf8274e-c99e-7d81-802a-0002a407910a) callNum(21)
2290 <SIP 261> : Receive 401 Unauthorized
2291 <SIP 261> : Transaction (261 REGISTER) completed
2292 <SIP 0> : No opaque in authentication
2293 <SIP 262> : WriteREGISTER
2294 <SIP 0> : Adding authentication information
2295 <SIP 262> : Send REGISTER Request
2296 <SIP 262> : Receive 403 Forbidden (Bad auth)
2297 <SIP 262> : Transaction (262 REGISTER) completed
2298 <Time 0> : Gatekeeper registration retry timeout.
2299 <GK 0> : Try registration to All candidated GKs exclude() exclusive()
2300 <GK 0> : Fail registration to all alternate GKs
no term mon2301 <SIP 261> : Set Terminated Success for 261 REGISTER
2302 <SIP 262> : Set Terminated Success for 262 REGISTER
Ну и на Астериске соответственно
Extension 301
User Addpac
Secret addpac301
На Asterisk инвайтов не каких не приходит, только Options сыпятся.
Россия. День 3-ий. Год 2011-ый.
Boom писал(а):На Asterisk инвайтов не каких не приходит, только Options сыпятся.
Не верю! ©
Там и не должно быть пока что инвайтов. А должен быть запрос на регистрацию REGISTER.
Вот это и наблюдается
2296 <SIP 262> : Receive 403 Forbidden (Bad auth) - это кто ответил? Ясно, Астериск!
CLI>sip set debug ip ip_addr_addpack
ну и смотрите там на Астериске SIP debug.
BooM
Сообщение BooM »
Так точно Кэп. Перепрописал Extension, заработало.
Щас буду GSM шлюзы прикручивать.)
Большое спасибо ded.
Чувствую себя просто донором, только что отдавшим 500 г крови, костный мозг, кусок роговицы и почку.
BooM
Сообщение BooM »
Ребят, что то не могу сообразить, как сделать чтобы Addpac определял номер звонящего по GSM шлюзу и траслировал его Sip клиентам подключённым через астериск.
Допустим в него вставлена симка с номером 89012345678
Делаем dial-peer voip
destination-pattern 89012345678
session-target sip-server
session-protocol sipv2
С таким дил пиром входящий из GSM будет отправляться на Астериск, где его надо просто принять в DID89012345678 , а уж Caller ID позвонившего там по умолчанию присутствует.
BooM
Сообщение BooM »
Спасибо, погляжу как доберусь до железки.
для GS1002A (только 2 канала GSM) прописан без регистрации
GS1002# show running-config
Building configuration...
Current configuration:
version 8.51.002
hostname GS1002
interface Loopback0
 ip address 192.168.0.153 255.255.255.0
 speed auto
 no qos-control
 no ip address
 speed auto
 no qos-control
interface FastEthernet0/1:1
 ip address 192.168.10.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip dhcp pool default
 network FastEthernet0/1
  range FastEthernet0/0
http server
ip connect default inside FastEthernet0/1 outside FastEthernet0/0
logging command
logging on
voice service voip
 protocol sip
 dtmf-relay rfc-2833
 fax rate 9600
  call-barring allow-ip 192.168.0.4
 voip-inbound-call-barring allow-digits 11 11
! GSM
voice-port 0/0
 connection plar 305102
 caller-id enable
! GSM
voice-port 0/1
 caller-id enable
dial-peer voice 1 pots
dial-peer voice 900 pots
 destination-pattern 8T
 port 0/0
 no register e164
dial-peer voice 3048 pots
 port 0/1
 no register e164
dial-peer voice 10100 voip
 destination-pattern [0-79]T
 voice-class codec 0
 no vad
 dtmf-relay rtp-2833
gatekeeper
gateway
 h323-id voip.192.168.0.153
voice class codec 0
sip-ua
 sip-server 192.168.0.4
 hook-flash-info-ignore
! Tones
line console
line vty
gsm 0/0
 sms-language utf8
gsm 0/1
 sms-language utf8
end
sip.conf
[gsm]
call-limit=2
host=192.168.0.153
port=5060
fromdomain=192.168.0.153
nat=no
canreinvite=no
context=from-sip
insecure=port,invite
dtmfmode=auto
allow=ulaw
BooM
Сообщение BooM »
Спасибо, уже разобрался и запустил. На деле оказалась отличная железка.
