Elastix и h.323
Xenium
Re: Elastix и h.323
Сообщение Xenium »
Вроде дело маленько продвинулось. Теперь могу звонить с Алкательки на Elastix, и звонок и голос проходит отлично. А вот в обратную сторону не получается.
Вот мои конфиги.
ooh323.conf
port=1720
bindaddr=X.X.X.X
e164=100
callerid=PostMet-Asterisk
gateway=no
gatekeeper=DISABLE
h245tunneling=yes
mediawaitforconnect=yes
logfile=/var/log/asterisk/h323_log
context=h323in
allow=ulaw
allow=g723
allow=g729
[Alcatel]
context=from-internal
ip=X.X.X.X
port=1720
rtptimeout=60
dtmfmode=rfc2833
h245tunneling=yes
allow=ulaw
allow=g723
Причем даже не редактирую файл extension.conf, а вызов все равно идет. Что нужно прописать чтобы пошел звонок на Алкатель.
Re: Elastix и h.323
А вот мои:
; ---  ******* IMPORTANT NOTE ***********
; ---  This module is currently unsupported.  Use it at your own risk.
; Objective System's H323 Configuration example for Asterisk
; ooh323c driver configuration
; [general] section defines global parameters
; This is followed by profiles which can be of three types - user/peer/friend
; Name of the user profile should match with the h323id of the user device.
; For peer/friend profiles, host ip address must be provided as "dynamic" is
; not supported as of now.
; Syntax for specifying a H323 device in extensions.conf is
; For Registered peers/friends profiles:
;        OOH323/name where name is the name of the peer/friend profile.
; For unregistered H.323 phones:
;        OOH323/ip[:port] OR if gk is used OOH323/alias where alias can be any H323
;                          alias
; For dialing into another asterisk peer at a specific exten
;       OOH323/exten/peer OR OOH323/exten@ip
; Domain name resolution is not yet supported.
; When a H.323 user calls into asterisk, his H323ID is matched with the profile
; name and context is determined to route the call
; The channel driver will register all global aliases and aliases defined in
; peer profiles with the gatekeeper, if one exists. So, that when someone
; outside our pbx (non-user) calls an extension, gatekeeper will route that
; call to our asterisk box, from where it will be routed as per dial plan.
;Define the asetrisk server h323 endpoint
;The port asterisk should listen for incoming H323 connections.
;Default - 1720
;port=1720
;The dotted IP address asterisk should listen on for incoming H323
;connections
;Default - tries to find out local ip address on it's own
bindaddr=0.0.0.0
;This parameter indicates whether channel driver should register with
;gatekeeper as a gateway or an endpoint.
;Default - no
;gateway=no
;Whether asterisk should use fast-start and tunneling for H323 connections.
;Default - yes
;faststart=no
;h245tunneling=no
;Whether media wait for connect
;Default - No
;mediawaitforconnect=yes
;H323-ID to be used for asterisk server
;Default - Asterisk PBX
h323id=ObjSysAsterisk
e164=100
;CallerID to use for calls
;Default - Same as h323id
callerid=asterisk
;Whether this asterisk server will use gatekeeper.
;Default - DISABLE
;gatekeeper = DISCOVER
;gatekeeper = a.b.c.d
gatekeeper = DISABLE
;Location for H323 log file
;Default - /var/log/asterisk/h323_log
;logfile=/var/log/asterisk/h323_log
;Following values apply to all users/peers/friends defined below, unless
;overridden within their client definition
;Sets default context all clients will be placed in.
;Default - default
context=default
;Sets rtptimeout for all clients, unless overridden
;Default - 60 seconds
;rtptimeout=60      ; Terminate call if 60 seconds of no RTP activity
                    ; when we're not on hold
;Type of Service
;Default - none (lowdelay, thoughput, reliability, mincost, none)
;tos=lowdelay
;amaflags = default
;The account code used by default for all clients.
;accountcode=h3230101
;The codecs to be used for all clients.Only ulaw and gsm supported as of now.
;Default - ulaw
; ONLY ulaw, gsm, g729 and g7231 supported as of now
disallow=all     ;Note order of disallow/allow is important.
allow=gsm
allow=ulaw
; dtmf mode to be used by default for all clients. Supports rfc2833, q931keypad
; h245alphanumeric, h245signal.
;Default - rfc 2833
dtmfmode=rfc2833
; round trip delay request, default = 0,0 (not send)
; x - count of unreplied requests before hangup, y - interval in sec between requests
;roundtrip=x,y
; FAX detection will cause the OOH323 channel to jump to the 'fax' extension (if it exists)
; based one or more events being detected. The events that can be detected are an incoming
; CNG tone or an incoming T.38 RequestMode packet
; yes - enable both detection (CNG & T.38)
; no - disable both
; cng - enable CNG detection (default)
; t38 - enable T.38 request detection
faxdetect = cng
; User/peer/friend definitions:
; User config options                    Peer config options
; context
; disallow                               disallow
; allow                                  allow
; accountcode                            accountcode
; amaflags                               amaflags
; dtmfmode                               dtmfmode
; rtptimeout                             ip
;                                        port
;                                        h323id
;                                        email
;                                        url
;                                        e164
;                                        rtptimeout
;       direct rtp between two remote peers, disabled by default
;       can be specified globally or per peer/user section
directmedia=no
;       early direct rtp (try to establish direct rtp before asnwer)
;       disabled by default, auto enabled by directmedia is enabled
;       can be disabled escpecially if directmedia is enabled.
directrtpsetup=no
;Define users here
;Section header is extension
[myuser1]
type=user
context=context1
allow=gsm
allow=ulaw
[mypeer1]
type=peer
context=context2
ip=a.b.c.d   ; UPDATE with appropriate ip address
port=1720    ; UPDATE with appropriate port
e164=101
[myfriend1]
context=default
ip=10.0.0.82   ; UPDATE with appropriate ip address
port=1820    ; UPDATE with appropriate port
allow=ulaw
e164=12345
rtptimeout=60
dtmfmode=rfc2833
и тоже ничего не редактирую!
amateur писал(а):Что нужно прописать чтобы пошел звонок на Алкатель.
— Вот машинка перемещения в пространстве… Так какой контакт мне нажимать, чтобы домой переместиться? Ведь время относительно, это-то вы понимаете?
— Значит, такое предложение. Сейчас мы нажимаем на контакты, и перемещаемся к вам. Но если эта машинка не сработает, тогда уж вы с нами переместитесь, куда мы вас переместим, идёт?
Xenium
Re: Elastix и h.323
Сообщение Xenium »
Здравствуйте. Прошу вашей помощи в следующей проблеме. Добился того, что теперь все звонки ходят нормально в обе стороны, но появилась другая проблема. Голос при звонке с Астера в Алкатель идет без задержки, а с Алкательки в Астер с задержкой 2-3 секунды. Пробовал играться с faststart и h245tunneling но это ни к чему не привело. Куда смотреть дальше?
amateur
Re: Elastix и h.323
Сообщение amateur »
Xenium писал(а):Куда смотреть дальше?
А дальше надо смотреть запись обмена сообщениями между Asterisk и Alcatel. Если сможете записать, помогу истолковать.
Xenium
Re: Elastix и h.323
Сообщение Xenium »
amateur писал(а):А дальше надо смотреть запись обмена сообщениями между Asterisk и Alcatel.
Как я понял вам нужен файл с логами при звонке. А какой tracelevel указать? Если ставить 10 то там оч. оч. много строк.
Re: Elastix и h.323
нужен дамп . а не то что вы предлагаете
amateur
Re: Elastix и h.323
Сообщение amateur »
Xenium писал(а):Как я понял вам нужен файл с логами при звонке.
Он конечно тоже не помешает, но в первую очередь нужна запись трафика, сделанная с помощью tcpdump или tshark. Перед проверочным вызовом включите отладку (ooh323 set debug). Потом прикрепите к теме то, что попало в log.
