Исходящие вызовы через ТРАНК!
Re: Исходящие вызовы через ТРАНК!
Ключевой параметр
проверять
sip show peers like ipecsTR
oleg.ware
Сообщение oleg.ware »
Изменил, статус sip show peers изменился на Unmonitored (неконтролируемый), и после набора номера в трубке тишина.
Попробую на стороне iPECSa покопаться.
oleg.ware
Интересно:
-- Executing [s@macro-dialout-trunk:21] GotoIf("SIP/800-0000004f", "0?customtrunk") in new stack
-- Executing [s@macro-dialout-trunk:22] Dial("SIP/800-0000004f", "SIP/ipecsTR/500,300,Tt") in new stack
== Using SIP RTP TOS bits 184
-- Called SIP/ipecsTR/500
[2014-09-26 10:38:42] WARNING[1848]: chan_sip.c:3830 retrans_pkt: Retransmission timeout reached on transmission 3b7d81c76f63a6354194329373ae35f8@192.168.20.108:5060 for seqno 102 (Critical Request) -- See https://wiki.asterisk.org/wiki/display/ ... nsmissions
Packet timed out after 32000ms with no response
[2014-09-26 10:38:42] WARNING[1848]: chan_sip.c:3859 retrans_pkt: Hanging up call 3b7d81c76f63a6354194329373ae35f8@192.168.20.108:5060 - no reply to our critical packet (see https://wiki.asterisk.org/wiki/display/ ... nsmissions).
-- Executing [s@macro-dialout-trunk:23] NoOp("SIP/800-0000004f", "Dial failed for some reason with DIALSTATUS = CHANUNAVAIL and HANGUPCAUSE = 18") in new stack
-- Executing [s@macro-dialout-trunk:24] GotoIf("SIP/800-0000004f", "0?continue,1:s-CHANUNAVAIL,1") in new stack
-- Goto (macro-dialout-trunk,s-CHANUNAVAIL,1)
-- Executing [s-CHANUNAVAIL@macro-dialout-trunk:1] Set("SIP/800-0000004f", "RC=18") in new stack
-- Executing [s-CHANUNAVAIL@macro-dialout-trunk:2] Goto("SIP/800-0000004f", "18,1") in new stack
-- Goto (macro-dialout-trunk,18,1)
-- Executing [18@macro-dialout-trunk:1] Goto("SIP/800-0000004f", "s-NOANSWER,1") in new stack
-- Goto (macro-dialout-trunk,s-NOANSWER,1)
-- Executing [s-NOANSWER@macro-dialout-trunk:1] NoOp("SIP/800-0000004f", "Dial failed due to trunk reporting NOANSWER - giving up") in new stack
-- Executing [s-NOANSWER@macro-dialout-trunk:2] Progress("SIP/800-0000004f", "") in new stack
-- Executing [s-NOANSWER@macro-dialout-trunk:3] Playback("SIP/800-0000004f", "number-not-answering,noanswer") in new stack
-- <SIP/800-0000004f> Playing 'number-not-answering.ulaw' (language 'en')
-- Executing [s-NOANSWER@macro-dialout-trunk:4] Congestion("SIP/800-0000004f", "20") in new stack
[2014-09-26 10:38:44] WARNING[8517]: channel.c:4796 ast_prod: Prodding channel 'SIP/800-0000004f' failed
== Spawn extension (macro-dialout-trunk, s-NOANSWER, 4) exited non-zero on 'SIP/800-0000004f' in macro 'dialout-trunk'
При этом после набора номера в трубке тишина секунд 30 и обрыв. Помогите развеять все сомнения, получается Aster не дождался ответа со стороны iPECSa и вывалился в ошибку? Или все таки есть проблема на стороне Astera??????
астер ждет поток RTP в течении 30 секунд - не увидев его закрывает соединение
Есть проблема в конфигурировании сети .
traceroute на адрес ipecsTR
oleg.ware
С Сеткой проблем не должно быть
[root@localhost asterisk]# traceroute 192.168.0.200
traceroute to 192.168.0.200 (192.168.0.200), 30 hops max, 60 byte packets
1 192.168.0.200 (192.168.0.200) 2.108 ms 2.260 ms 2.379 ms
Сообщение Retransmission timeout reached on transmission говорит о том, что там не RTP не получает, а нет ответа даже на сигнальные пакеты при вызове
И это увидите при tcpdump host IP_addr_ipecsTR
operor1
Сообщение operor1 »
oleg.ware писал(а):переводить нет надобности мне и так все понятно! Непонятно только одно .... как недоступна???
входящие звонки с iPESA проходят а исходящие с Astera нет .... и как решить эту проблему непонятно!
аналогичная проблема :cry:
