asterisk + cisco 1750 FXO звонки с города
joneg
Re: asterisk + cisco 1750 FXO звонки с города
Сообщение joneg »
tcpdump -n -i eth1.10 -vv -s 128 -A host 192.168.2.248 and port 5060
tcpdump: listening on eth1.10, link-type EN10MB (Ethernet), capture size 128 bytes
15:58:13.250373 IP (tos 0x0, ttl 254, id 0, offset 0, flags [none], proto UDP (17), length 767)
    192.168.2.248.49717 > 192.168.221.130.5060: SIP, length: 739
	INVITE sip:5002@192.168.221.130;user=phone;phone-context=unknown SIP/2.0
	Via: SIP/2.[|sip]
E.........X".........5.....WINVITE sip:5002@192.168.221.130;user=phone;phone-context=unknown SIP/2.0
Via: SIP/2.0
15:58:13.756037 IP (tos 0x0, ttl 254, id 1, offset 0, flags [none], proto UDP (17), length 767)
	Via: SIP/2.[|sip]
E.........X!.........5.....WINVITE sip:5002@192.168.221.130;user=phone;phone-context=unknown SIP/2.0
Via: SIP/2.0
15:58:14.755941 IP (tos 0x0, ttl 254, id 2, offset 0, flags [none], proto UDP (17), length 767)
	Via: SIP/2.[|sip]
E.........X .........5.....WINVITE sip:5002@192.168.221.130;user=phone;phone-context=unknown SIP/2.0
Via: SIP/2.0
15:58:16.755710 IP (tos 0x0, ttl 254, id 3, offset 0, flags [none], proto UDP (17), length 767)
	Via: SIP/2.[|sip]
E.........X..........5.....WINVITE sip:5002@192.168.221.130;user=phone;phone-context=unknown SIP/2.0
Via: SIP/2.0
15:58:20.755367 IP (tos 0x0, ttl 254, id 4, offset 0, flags [none], proto UDP (17), length 767)
	Via: SIP/2.[|sip]
E.........X..........5....xWINVITE sip:5002@192.168.221.130;user=phone;phone-context=unknown SIP/2.0
Via: SIP/2.0
15:58:28.754545 IP (tos 0x0, ttl 254, id 5, offset 0, flags [none], proto UDP (17), length 767)
	Via: SIP/2.[|sip]
E.........X..........5....|UINVITE sip:5002@192.168.221.130;user=phone;phone-context=unknown SIP/2.0
Via: SIP/2.0
15:58:44.753087 IP (tos 0x0, ttl 254, id 6, offset 0, flags [none], proto UDP (17), length 767)
	Via: SIP/2.[|sip]
E.........X..........5.....VINVITE sip:5002@192.168.221.130;user=phone;phone-context=unknown SIP/2.0
Via: SIP/2.0
А Вы там часом не зашифровали ли свои ИП адреса?
То есть
- слушает ли Астериск адрес 192.168.221.130 на порту 5060 ??
- знает ли Астериск 192.168.221.130 где находится адрес 1750??
mtr 192.168.2.248 ??
joneg
Сообщение joneg »
Нет со связью все нормально, просто подсети разные. В той же 192.168.2.х стоит GSM шлюз AddPac который прекрасно работает с астером
Vlad1983 писал(а): в sip.conf на пире
dtmfmode=rfc2833
deny=0.0.0.0/0
permit=192.168.2.248/32
Неверный синтаксис. Там надо
deny=0.0.0.0/0.0.0.0
permit=192.168.2.248/255.255.255.255
а лучше бы вообще открыть пока
permit=0.0.0.0/0.0.0.0
Update: Вспомнил!
На Cisco 1750 надо включить роутинг, который по дефолту выключен.
joneg
Сообщение joneg »
Роутинг включен, иначе бы до астера вообще ничего не доходило.
В общем проблему установить не удалось, но с помощью Vlad1983-а, за что ему огромное спасибо, удалось выяснить, что эта циска нормально работает с FreeSwitch. Завтра попробую разные версии астера или просто поставлю freeswitch в качестве переходника к астериску
первый раз с таким столкнулся, что астер вообще никаким боком не реагирует на сообщения.
так же замечен лишний пробел в заголовке Via от кошки
Via: SIP/2.0/UDP 192.168.2.248:5060
Если Астериск никак не реагировал на входящиее SIP пакеты от цыски, но нормально взаимодействует при этом с АддПак, то проблема могла быть в цыске? Или в версии Астериска?
проблема скорей в формировании заголовков кошкой
пробовали ещё на одном из ветки 1.8
до 1.4 дело не дошло за неименеем такого под рукой на паблике
но реакция астериска одинаковая, т.е. полное отсутствие реакции
Update IOS? Уж очень древний!
IOS (tm) C1700 Software (C1700-SV3Y-M), Version 12.2(7b)
И я даже знаю почему нельзя - не влазит в её родной flash на борту.
Поэтому то голосывае цыски этой серии имеют номера 1751-V - там флэш больше.
Но тема поправимая: загружать её IOS с tftp server = Asterisk, который типа рядом.
Последний раз редактировалось ded 08 окт 2012, 14:11, всего редактировалось 1 раз.
ну что тут остается будут пробовать
накрайняк через FS запустят
