Cообщение от   Telegram-канал nurm21
[root@asterisk]# service asterisk status
● asterisk.service - LSB: Asterisk PBX
Loaded: loaded (/etc/rc.d/init.d/asterisk; generated)
Active: active (running) since Thu 2026-06-11 04:50:03 +05; 10h ago
Docs: man:systemd-sysv-generator(8)
Main PID: 1873937
Tasks: 754 (limit: 201947)
Memory: 27.1G
CPU: 4h 43min 1.809s
CGroup: /system.slice/asterisk.service
├─1873935 /bin/sh /usr/sbin/safe_asterisk
└─2339812 /usr/sbin/asterisk -f -vvvg -c
Jun 11 04:50:03 asterisk-01 systemd[1]: Starting LSB: Asterisk PBX...
Jun 11 04:50:03 asterisk-01 asterisk[1873907]: Starting asterisk:
Jun 11 04:50:03 asterisk-01 systemd[1]: asterisk.service: Can't open PID file /run/asterisk/asterisk.pid (yet?) after start: Operation not permitted
Jun 11 04:50:03 asterisk-01 systemd[1]: asterisk.service: Supervising process 1873937 which is not our child. We'll most likely not notice when it exits.
Jun 11 04:50:03 asterisk-01 systemd[1]: Started LSB: Asterisk PBX.
Jun 11 11:31:56 asterisk-01 systemd[1]: /run/systemd/generator.late/asterisk.service:30: PIDFile= references a path below legacy directory /var/run/, updating /var/run/asterisk/asterisk.pid → /run/asterisk/asterisk.pid; please update the unit file accordingly.
[root@asterisk]# find -L /var/spool/asterisk/monitor -name '*.wav' -mmin -1440 -print0 2>/dev/null | xargs -0 fincore -b --output RES --noheadings 2>/dev/null | awk '{s+=$1} END {printf "%.1f GB cached in %d wav files\n", s/1e9, NR}'
28.8 GB cached in 22656 wav files
[root@asterisk]# free -h
total used free shared buff/cache available
Mem: 30Gi 30Gi 375Mi 11Mi 28Gi 375Mi
Swap: 8.0Gi 884Mi 7.1Gi
можете помочь, из за чего астериск так много озу жрет?
как будто бы аудио файлы сохраняется в кэше и не очищается
примерно часа 2 назад, он юзал где то Memory: ~3-5gb
Main PID: 1873937
Memory: 27.1G
malloc trim помогает ?
Cообщение от   Telegram-канал unmtm
какая версия asterisk? что показывает core show taskprocessors?
Asterisk 23.2.2
asterisk -rx 'core show taskprocessors'
Processor Processed In Queue Max Depth Low water High water Low time(us) High time(us)
app_voicemail 0 0 0 450 500 0 0
ast_msg_queue 0 0 0 450 500 0 0
CCSS_core 0 0 0 450 500 0 0
dns_system_resolver_tp 0 0 0 450 500 0 0
pjsip/distributor-0000001f 4634 0 8 450 500 0 5334073
taskpool/s:stasis-00000004 266311 0 18 450 500 0 560983
2974 taskprocessors
2974 таск процессов
не пробовал, is it safe to execute?
absolutely
absolutely
я поизучал, говорят он особо не поможет, потому что тут проблема с page cache (файловый кэш WAV-записей)
а в top у астериска где растет потребление ?
И таких процессов много
