Cообщение от   Telegram-канал asterisker_ru_bot
Asterisk Security Release 18.26.2 Now Available ???
Asterisk Release 18.26.2 The Asterisk Development Team would like to announce security release Asterisk 18.26.2. The release artifacts are available for immediate download at https://github.com/asterisk/asterisk/releases/tag/18.26.2 and https://downloads.asterisk.org/pub/telephony/asterisk Repository: https://github.com/asterisk/asterisk Tag: 18.26.2 Change Log for Release asterisk-18.26.2 Links: Full ChangeLog GitHub Diff Tarball Downloads Summary: Commits: 2 Commit Authors: 1 Issues Resolved: 0 Security Advisories Resolved: 2 ...
May 22, 2025
Подробности тут
Certified Asterisk Security Release 18.9-cert14 Now Available ???
Asterisk Release certified-18.9-cert14 The Asterisk Development Team would like to announce security release Certified Asterisk 18.9-cert14. The release artifacts are available for immediate download at https://github.com/asterisk/asterisk/releases/tag/certified-18.9-cert14 and https://downloads.asterisk.org/pub/telephony/certified-asterisk Repository: https://github.com/asterisk/asterisk Tag: certified-18.9-cert14 Change Log for Release asterisk-certified-18.9-cert14 Links: Full ChangeLog GitHub Diff Tarball Downloads Summary: Commits: 2 Commit Authors: 1 Issues Resolved: 0 Security Advisories Resolved: ...
May 22, 2025
Подробности тут
Certified Asterisk Security Release 20.7-cert5 Now Available ???
Asterisk Release certified-20.7-cert5 The Asterisk Development Team would like to announce security release Certified Asterisk 20.7-cert5. The release artifacts are available for immediate download at https://github.com/asterisk/asterisk/releases/tag/certified-20.7-cert5 and https://downloads.asterisk.org/pub/telephony/certified-asterisk Repository: https://github.com/asterisk/asterisk Tag: certified-20.7-cert5 Change Log for Release asterisk-certified-20.7-cert5 Links: Full ChangeLog GitHub Diff Tarball Downloads Summary: Commits: 2 Commit Authors: 1 Issues Resolved: 0 Security Advisories Resolved: ...
May 22, 2025
Подробности тут
Cообщение от   Telegram-канал vadimbergamot
а что, если убедительно обосновать выход нового персонала, нужно предоставить убедительные пруфы нехватки текущего?
В кгд Минздраве так и даже ещё веселее))) но нда)
❗cli_permissions.conf: deny option does not work for disallowing shell commands : (GHSA-c7p6-7mvq-8jq2)
GHSA-c7p6-7mvq-8jq2
May 22, 2025
❗Using malformed From header can forge identity with “;” or NULL in name portion : (GHSA-2grh-7mhv-fcfw)
GHSA-2grh-7mhv-fcfw
May 22, 2025
? 6 июня будет GetNet/25
Соберемся в тёплой кулуарной атмосфере, чтобы на фоне докладов о сетях пообщаться с коллегами по цеху.
GetNet - это митап для сетевиков и сисадминов компаний среднего бизнеса. Доклады как из серии "бери и делай", так и из концепции "на вырост": чтобы понимать, куда тебе нужно развиваться, чтобы со временем стать востребованным в крупных компаниях и на классных проектах.
Онлайн участие бесплатное. Можно зарегаться вот тут. В личном кабинете потом будут все записи и презентации (на ю(ру)тубы выложим далеко не сразу).
А лучше (особенно для граждан дефолт-сити и окрестностей) выползти из пещеры и доехать ногами. Для этого нужно обилетиться вот тут
Cообщение от   Telegram-канал od1n0d1n
у вас рег25.про отклеился?
Cообщение от   Telegram-канал Grushkovna
приклеили, спасибо)
Делимся с вами докладами, которые будут на конференции GetNet
Ключевые аспекты и тезисы
- Все точки входа для изменения конфигурации должны быть доступны только из сети управления — и точка
- Exchange Admin Panel без защиты на L7 — это билет в один конец к катастрофе
- RouterOS и сеть управления: дружим правильно или не дружим совсем
- DCOM-сервисы: как их перетащить в безопасную зону и не сломать всё вокруг
- Компрометация пользователя — это не конец света, если вы заранее позаботились о правильной архитектуре
Инструменты и методики
- Windows Firewall: настройки, которые реально работают, а не просто галочки для аудиторов
- RouterOS: превращаем его из потенциальной точки уязвимости в элемент защиты
- Выявляем и переносим критические сервисы управления туда, где их не достанут
- Практические шаги от проектирования до внедрения сети управления без остановки бизнес-процессов
Приходите очно пообщаться не только с Иваном, но и с участниками
Если у вас есть интересная тема, то ждем вас в роли спикера.
