Периодически UNREACHABLE на всех SIP транках
denergym
Сообщение denergym »
Периодически отваливаются сипы, соответственно юзеры звонящие в данный момент теряют связь.
[Aug 5 11:12:05] NOTICE[22674] chan_sip.c: Peer 'UPSTREAM' is now UNREACHABLE! Last qualify: 28
[Aug 5 11:12:05] NOTICE[22674] chan_sip.c: Peer '2263' is now UNREACHABLE! Last qualify: 7
[Aug 5 11:12:05] NOTICE[22674] chan_sip.c: Peer '2262' is now UNREACHABLE! Last qualify: 7
[Aug 5 11:12:05] NOTICE[22674] chan_sip.c: Peer '2261' is now UNREACHABLE! Last qualify: 7
[Aug 5 11:12:05] NOTICE[22674] chan_sip.c: Peer '2272' is now UNREACHABLE! Last qualify: 7
[Aug 5 11:12:05] NOTICE[22674] chan_sip.c: Peer '2271' is now UNREACHABLE! Last qualify: 7
[Aug 5 11:12:05] NOTICE[22674] chan_sip.c: Peer '2274' is now UNREACHABLE! Last qualify: 8
[Aug 5 11:12:05] NOTICE[22674] chan_sip.c: Peer '2276' is now UNREACHABLE! Last qualify: 9
[Aug 5 11:12:05] NOTICE[22674] chan_sip.c: Peer '2201' is now UNREACHABLE! Last qualify: 7
[Aug 5 11:12:05] NOTICE[22674] chan_sip.c: Peer '2283' is now UNREACHABLE! Last qualify: 64
[Aug 5 11:12:05] NOTICE[22674] chan_sip.c: Peer '2202' is now UNREACHABLE! Last qualify: 8
[Aug 5 11:12:05] NOTICE[22674] chan_sip.c: Peer '2223' is now UNREACHABLE! Last qualify: 7
[Aug 5 11:12:05] NOTICE[22674] chan_sip.c: Peer '2212' is now UNREACHABLE! Last qualify: 10
[Aug 5 11:12:06] NOTICE[22674] chan_sip.c: Peer '2221' is now UNREACHABLE! Last qualify: 8
[Aug 5 11:12:06] NOTICE[22674] chan_sip.c: Peer '2222' is now UNREACHABLE! Last qualify: 11
[Aug 5 11:12:06] NOTICE[22674] chan_sip.c: Peer '2231' is now UNREACHABLE! Last qualify: 7
[Aug 5 11:12:06] NOTICE[22674] chan_sip.c: Peer '2232' is now UNREACHABLE! Last qualify: 7
[Aug 5 11:12:06] NOTICE[22674] chan_sip.c: Peer 'UPSTREAM2' is now UNREACHABLE! Last qualify: 39
Затем сразу поднимаются.
Asterisk 11.17.0
Провайдеры за натом
register => XXX:XXXX@192.168.130.1:5150/XXXX
register => XXXX:XXXX@login.mtt.ru/XXXX
;register => PTG:K0l0tundr@192.168.196.103/A2
;register => PTG:K0l0tundr@192.168.212.103/ROSTOVO
;register => PTG:K0l0tundr@192.168.240.59/ROSTOVS
;register => PTG:K0l0tundr@192.168.211.215/GK
allowguest=no
allowexternalinvites=yes
useragent=mycomp
lomitonpeeers=yes
defaultexpiry=360
callevents=yes
language=ru
tcpenable=yes
transport=udp,tcp
;videosupport=yes
nat=force_rport,comedia
canreinvite=no
directmedia=no
qualify=3000
qualifyfreq=60
;t38pt_udptl=yes
faxdetect=no
[ipphone](!)
secret=7777777
callgroup=1
pickupgroup=1
allow=g729
allow=gsm
allow=ulaw
#include "/etc/asterisk/sip_users.conf"
[UPSTREAM]
context=incoming
port=5150
defaultuser=xxxx
fromdomain=192.168.130.1
fromuser=xxxx
secret=xxxx
host=192.168.130.1
dtmfmode=inband
allow=g722
allow=g729
allow=gsm
allow=ulaw
t38pt_udptl=no
insecure=port,invite
[UPSTREAM2]
type=peer
defaultuser=xxxx
fromdomain=login.mtt.ru
;nat=comedia
host=login.mtt.ru
dtmfmode=rfc2833
allow=g729
allow=ulaw
t38pt_udptl=yes
t38pt_rtp=no
t38pt_tcp=no
fromuser=xxxx
secret=xxxxx
username=xxxx
Re: Периодически UNREACHABLE на всех SIP транках
это же локальные пиры!
У вас проблемы в локальной сети/патч корд/розетка RJ-45/коммутатор
denergym
Все пиры разом отлетают, причем все телефоны и астер в рамках одного коммутатора.
Уже меняете коммутатор?
denergym
Менял коммутатор, отключал firewall, не помогло.
Скромные труженики платного суппорта уже вытирают мозолистые руки промасленой ветошью.
Предвкушают!
denergym
Ничего нового
Ага!
Обычный сценарий: местный сисадмин гордо хлопнул дверью (ему указали на дверь), человек, менявший картриджи в принтерах говорит "Давайте я посмотрю, может получится?", пишет на форум: "Друзья! (Мы же все друзья заочно, верно?)
Мне в наследство досталась АТС Астериск, я уже три дня читаю форумы и мануалы, честно - мало что понимаю! Помо жи-и-ите!"
denergym
На самом деле, по другому было.
На филиале развернул астериск, начались проблемки из темы, думаю ага походу надобы умных свитчей поставить по периметру, поставили, проблема не решилась, думаю ага надо QoS повесить по периметру, повесил проверил, приоритет работает, все равно проблема не решилась. По всей видимости все же чего-то астеру не нравитца, глубоко его, да, не знаю, но книжку про будущее телефонии прочитал и в целом понятно . МОжет что-то упустил,да, и если это прям семечки почему не указать где проблема?
srvlookup=no
установить bind на сервер
в свойствах сетевых карт прописать - брать DNS с себя = 127.0.0.1
