Sangoma драйвера
kadet
Sangoma драйвера
Сообщение kadet »
Добрый день,
Может кто дружит с Сангомой, помогите, пожалуйста.
История следующая.
Карточка A104
Обновил драйвера.
До обновления проблем с драйверами небыло.
После обновления при выполнении команды
wanrouter start
получаю ошибку
Starting up device: wanpipe1
        wanconfig: Interface w1g1 setup failed
                 : ioctl(ROUTER_IFNEW,w1g1) failed:
                 :      22 - Invalid argument
        Wanpipe drivers could not setup network interface
        Please check /var/log/wanrouter and
        /var/log/messages for errors
В /var/log/messages - "wanpipe1: Error: TDM SPAN not configured! Failed to start channel!"
May 17 14:44:47 voice kernel: [74217.426290] dahdi: Version: 2.9.1.1
May 17 14:44:47 voice kernel: [74217.426498] dahdi: Telephony Interface Registered on major 196
May 17 14:44:47 voice kernel: [74217.427947] WANPIPE(tm) Hardware Support Module 7.0.19.0 (c) 1994-2013 Sangoma Technologies Inc
May 17 14:44:47 voice kernel: [74217.428261] usbcore: registered new interface driver sdlausb
May 17 14:44:47 voice kernel: [74217.428537] WANPIPE(tm) Interface Support Module 7.0.19.0 (c) 1994-2013 Sangoma Technologies Inc
May 17 14:44:47 voice kernel: [74217.430997] WANPIPE(tm) Multi-Protocol WAN Driver Module 7.0.14.0 (c) 1994-2013 Sangoma Technologies Inc
May 17 14:44:47 voice kernel: [74217.431012] wanpipe: Probing for WANPIPE hardware.
May 17 14:44:47 voice kernel: [74217.431219] wanpipe: AFT-A104-SH PCI T1/E1 card found (HDLC rev.26), cpu(s) 1, line(s) 4, bus #7, slot #1, irq #24
May 17 14:44:47 voice kernel: [74217.431230] wanpipe: Allocating maximum 4 devices: wanpipe1 - wanpipe4.
May 17 14:44:47 voice kernel: [74217.431713] WANPIPE: TDM Codecs Initialized
May 17 14:44:47 voice kernel: [74217.436077] WANPIPE(tm) Socket API Module 7.0.19.0 (c) 1994-2013 Sangoma Technologies Inc
May 17 14:44:47 voice kernel: [74217.436081] NET: Registered protocol family 25
May 17 14:44:47 voice kernel: [74217.443089] WANPIPE(tm) WANEC Layer 7.0.19.0 (c) 1995-2006 Sangoma Technologies Inc.
May 17 14:44:47 voice kernel: [74217.443094] wanec_create_dev: Registering Wanpipe ECDEV Device!
May 17 14:44:47 voice kernel: [74217.448551] wanpipe1: Starting WAN Setup
May 17 14:44:47 voice kernel: [74217.448556]
May 17 14:44:47 voice kernel: [74217.448558] Processing WAN device wanpipe1...
May 17 14:44:47 voice kernel: [74217.448561] wanpipe1: Locating: A101/1D/2/2D/4/4D/8/8D/16/16D card, CPU A, PciBus=7, PciSlot=1
May 17 14:44:47 voice kernel: [74217.448568] wanpipe1: Found: A101/1D/2/2D/4/4D/8/8D/16/16D card, CPU A, PciBus=7, PciSlot=1, Port=0
May 17 14:44:47 voice kernel: [74217.448726] wanpipe1: AFT PCI memory at 0xDC500000
May 17 14:44:47 voice kernel: [74217.448728] wanpipe1: IRQ 24 allocated to the AFT PCI card
May 17 14:44:47 voice kernel: [74217.448744] wanpipe1: Starting AFT 2/4/8 Hardware Init.
May 17 14:44:47 voice kernel: [74217.448764] wanpipe1: Enabling front end link monitor
May 17 14:44:47 voice kernel: [74217.448767] wanpipe1: Global Chip Configuration: used=1 used_type=1
May 17 14:44:47 voice kernel: [74217.452111] wanpipe1: AFT Data Mux Bit Map: 0x01234567
May 17 14:44:47 voice kernel: [74217.452124] wanpipe1: Configuring PMC COMET-QUAD E1 FE
May 17 14:44:47 voice kernel: [74217.452126] wanpipe1: Port 1,HDB3,non-CRC4,120OH
May 17 14:44:47 voice kernel: [74217.452128] wanpipe1: Clk Normal:0, Ch FFFFFFFF
May 17 14:44:47 voice kernel: [74217.452130] wanpipe1: Sig Mode CCS
May 17 14:44:47 voice kernel: [74217.540531] wanpipe1: Front end successful
May 17 14:44:47 voice kernel: [74217.540534] wanpipe1: Configuring FE Line=1 Clock Source: Line=1 Normal
May 17 14:44:47 voice kernel: [74217.540761] wanpipe1: Front End Interface Ready 0x40000000
May 17 14:44:47 voice kernel: [74217.540764] wanpipe1: WARNING: No Echo Canceller channels are available!
May 17 14:44:47 voice kernel: [74217.540777] wanpipe1: Configuring Device :wanpipe1 FrmVr=26
May 17 14:44:47 voice kernel: [74217.540779] wanpipe1: Global MTU = 1500
May 17 14:44:47 voice kernel: [74217.540781] wanpipe1: Global MRU = 1500
May 17 14:44:47 voice kernel: [74217.540782] wanpipe1: Data Mux Map = 0x01234567
May 17 14:44:47 voice kernel: [74217.540784] wanpipe1: Rx CRC Bytes = 0
May 17 14:44:47 voice kernel: [74217.540785] wanpipe1: RBS Signalling = Off
May 17 14:44:47 voice kernel: [74217.540787] wanpipe1: Global TDM Int = Enabled
May 17 14:44:47 voice kernel: [74217.540789] wanpipe1: Global TDM Ring= HW Ring
May 17 14:44:47 voice kernel: [74217.540790] wanpipe1: Global SPAN IRQ= RX/TX
May 17 14:44:47 voice kernel: [74217.540792] wanpipe1: TDM HW TONE = Disabled
May 17 14:44:47 voice kernel: [74217.540793] wanpipe1: Fifo Trigger = rx:50 tx:50 (events per sec)
May 17 14:44:47 voice kernel: [74217.540795] wanpipe1: TDMV Span = 0 : Disabled
May 17 14:44:47 voice kernel: [74217.540797] wanpipe1: TDMV Dummy = Disabled
May 17 14:44:47 voice kernel: [74217.540799] wanpipe1: RTP TAP = Disabled
May 17 14:44:47 voice kernel: [74217.540852]
May 17 14:44:47 voice kernel: [74217.540854] wanpipe1: Error: TDM SPAN not configured! Failed to start channel!
May 17 14:44:47 voice kernel: [74217.544788] wanpipe2: Starting WAN Setup
May 17 14:44:47 voice kernel: [74217.544791]
May 17 14:44:47 voice kernel: [74217.544793] Processing WAN device wanpipe2...
May 17 14:44:47 voice kernel: [74217.544795] wanpipe2: Locating: A101/1D/2/2D/4/4D/8/8D/16/16D card, CPU A, PciBus=7, PciSlot=1
May 17 14:44:47 voice kernel: [74217.544798] wanpipe2: Found: A101/1D/2/2D/4/4D/8/8D/16/16D card, CPU A, PciBus=7, PciSlot=1, Port=1
May 17 14:44:47 voice kernel: [74217.544803] wanpipe2: Starting AFT 2/4/8 Hardware Init.
May 17 14:44:47 voice kernel: [74217.544820] wanpipe2: Enabling front end link monitor
May 17 14:44:47 voice kernel: [74217.544824] wanpipe2: Global Chip Configuration skiped: used=2 used_type=2
May 17 14:44:47 voice kernel: [74217.544834] wanpipe2: Configuring PMC COMET-QUAD E1 FE
May 17 14:44:47 voice kernel: [74217.544836] wanpipe2: Port 2,HDB3,non-CRC4,120OH
May 17 14:44:47 voice kernel: [74217.544838] wanpipe2: Clk Normal:0, Ch FFFFFFFF
May 17 14:44:47 voice kernel: [74217.544840] wanpipe2: Sig Mode CCS
May 17 14:44:47 voice kernel: [74217.633226] wanpipe2: Front end successful
May 17 14:44:47 voice kernel: [74217.633228] wanpipe2: Configuring FE Line=2 Clock Source: Line=2 Normal
May 17 14:44:47 voice kernel: [74217.633456] wanpipe2: Front End Interface Ready 0x40000000
May 17 14:44:47 voice kernel: [74217.633458] wanpipe2: WARNING: No Echo Canceller channels are available!
May 17 14:44:47 voice kernel: [74217.633471] wanpipe2: Configuring Device :wanpipe2 FrmVr=26
May 17 14:44:47 voice kernel: [74217.633473] wanpipe2: Global MTU = 1500
May 17 14:44:47 voice kernel: [74217.633474] wanpipe2: Global MRU = 1500
May 17 14:44:47 voice kernel: [74217.633476] wanpipe2: Data Mux Map = 0x01234567
May 17 14:44:47 voice kernel: [74217.633477] wanpipe2: Rx CRC Bytes = 0
May 17 14:44:47 voice kernel: [74217.633479] wanpipe2: RBS Signalling = Off
May 17 14:44:47 voice kernel: [74217.633481] wanpipe2: Global TDM Int = Enabled
May 17 14:44:47 voice kernel: [74217.633482] wanpipe2: Global TDM Ring= HW Ring
May 17 14:44:47 voice kernel: [74217.633484] wanpipe2: Global SPAN IRQ= RX/TX
May 17 14:44:47 voice kernel: [74217.633485] wanpipe2: TDM HW TONE = Disabled
May 17 14:44:47 voice kernel: [74217.633487] wanpipe2: Fifo Trigger = rx:50 tx:50 (events per sec)
May 17 14:44:47 voice kernel: [74217.633489] wanpipe2: TDMV Span = 0 : Disabled
May 17 14:44:47 voice kernel: [74217.633490] wanpipe2: TDMV Dummy = Disabled
May 17 14:44:47 voice kernel: [74217.633492] wanpipe2: RTP TAP = Disabled
May 17 14:44:47 voice kernel: [74217.633537]
May 17 14:44:47 voice kernel: [74217.633539] wanpipe2: Error: TDM SPAN not configured! Failed to start channel!
May 17 14:44:48 voice kernel: [74218.543113] wanpipe1: E1 connected!
May 17 14:44:48 voice kernel: [74218.543132] wanpipe1: AFT communications enabled
May 17 14:44:48 voice kernel: [74218.635104] wanpipe2: E1 disconnected!
May 17 14:44:48 voice kernel: [74218.727104] wanpipe3: E1 disconnected!
May 17 14:44:48 voice kernel: [74218.821113] wanpipe4: E1 disconnected!
May 17 14:44:49 voice kernel: [74219.545009] wanpipe1: Enable E1 Interrupts
wanrouter hwprobe verbose
| Wanpipe Hardware Probe Info (verbose) |
1 . AFT-A104-SH : SLOT=1 : BUS=7 : IRQ=24 : CPU=A : PORT=1 : HWEC=0 : V=26
+01:PMC4354: PCI: NONE
2 . AFT-A104-SH : SLOT=1 : BUS=7 : IRQ=24 : CPU=A : PORT=2 : HWEC=0 : V=26
+02:PMC4354: PCI: NONE
3 . AFT-A104-SH : SLOT=1 : BUS=7 : IRQ=24 : CPU=A : PORT=3 : HWEC=0 : V=26
+03:PMC4354: PCI: NONE
4 . AFT-A104-SH : SLOT=1 : BUS=7 : IRQ=24 : CPU=A : PORT=4 : HWEC=0 : V=26
+04:PMC4354: PCI: NONE
Sangoma Card Count: A104=1
/etc/wanpipe1.conf
# WANPIPE1 Configuration File
# Date: Wed Dec 6 20:29:03 UTC 2006
# Note: This file was generated automatically
# by /usr/local/sbin/setup-sangoma program.
# If you want to edit this file, it is
# recommended that you use wancfg program
# to do so.
# Sangoma Technologies Inc.
[devices]
wanpipe1 = WAN_AFT_TE1, Comment
[interfaces]
w1g1 = wanpipe1, , TDM_VOICE, Comment
[wanpipe1]
CARD_TYPE = AFT
S514CPU = A
CommPort = PRI
AUTO_PCISLOT = NO
PCISLOT = 1
PCIBUS = 7
FE_MEDIA = E1
FE_LCODE = HDB3
FE_FRAME = NCRC4
FE_LINE = 1
TE_CLOCK = NORMAL
TE_REF_CLOCK = 0
TE_SIG_MODE = CCS
TE_HIGHIMPEDANCE = NO
TE_RX_SLEVEL = 430
HW_RJ45_PORT_MAP = DEFAULT
LBO = 120OH
FE_TXTRISTATE = NO
MTU = 1500
UDPPORT = 9000
TTL = 255
IGNORE_FRONT_END = NO
TDMV_SPAN = 1
TDMV_DCHAN = 16
TE_AIS_MAINTENANCE = NO #NO: defualt YES: Start port in AIS Blue Alarm and keep line down
#wanpipemon -i w1g1 -c Ttx_ais_off to disable AIS maintenance mode
#wanpipemon -i w1g1 -c Ttx_ais_on to enable AIS maintenance mode
TDMV_HW_DTMF = NO # YES: receive dtmf events from hardware
TDMV_HW_FAX_DETECT = NO # YES: receive fax 1100hz events from hardware
HWEC_OPERATION_MODE = OCT_NORMAL # OCT_NORMAL: echo cancelation enabled with nlp (default)
# OCT_SPEECH: improves software tone detection by disabling NLP (echo possible)
# OCT_NO_ECHO:disables echo cancelation but allows VQE/tone functions.
HWEC_DTMF_REMOVAL = NO # NO: default YES: remove dtmf out of incoming media (must have hwdtmf enabled)
HWEC_NOISE_REDUCTION = NO # NO: default YES: reduces noise on the line - could break fax
HWEC_ACUSTIC_ECHO = NO # NO: default YES: enables acustic echo cancelation
HWEC_NLP_DISABLE = NO # NO: default YES: guarantees software tone detection (possible echo)
HWEC_TX_AUTO_GAIN = 0 # 0: disable -40-0: default tx audio level to be maintained (-20 default)
HWEC_RX_AUTO_GAIN = 0 # 0: disable -40-0: default tx audio level to be maintained (-20 default)
HWEC_TX_GAIN = 0 # 0: disable -24-24: db values to be applied to tx signal
HWEC_RX_GAIN = 0 # 0: disable -24-24: db values to be applied to tx signal
[w1g1]
ACTIVE_CH = ALL
TDMV_HWEC = NO
MTU = 8
/etc/wanpipe/wanrouter.rc
#!/bin/bash
# router.rc WAN router meta-configuration file.
# This file defines variables used by the router shell scripts
# and should be located in /etc/wanpipe directory. These are:
# ROUTER_BOOT = Boot flag (YES/NO).
# WAN_CONF_DIR = Where to put wanpipe config files.
# WAN_INTR_DIR = Where to put wanpipe interface files.
# WAN_LOG = Where to put start-up log file.
# WAN_LOCK = File used as a lock.
# WAN_LOCK_DIR =
# WAN_IP_FORWARD = Enable IP Forwarding on startup.
# WAN_DEVICES = Name of the wanpipe devices to be
# loaded on 'wanrouter start'
# (ex: "wanpipe1 wanpipe2 wanpipe3...")
# Note: Name of wanpipe devices correspond
# to the configuration files in
# WANPIPE_CONF_DIR directory:
# (ex. /etc/wanpipe/wanpipe1.conf )
# Note: This file is 'executed' by the shell script, so
# the usual shell syntax must be observed.
ROUTER_BOOT=YES
WAN_CONF_DIR=/etc/wanpipe
WAN_INTR_DIR=/etc/wanpipe/interfaces
WAN_BIN_DIR=/usr/sbin
WAN_LOG=/var/log/wanrouter
WAN_LOCK=/var/lock/wanrouter
WAN_LOCK_DIR=/var/lock
WAN_IP_FORWARD=NO
NEW_IF_TYPE=NO
WAN_LIB_DIR=/etc/wanpipe/lib
WAN_ADSL_LIST=/etc/wanpipe/wan_adsl.list
WAN_ANNEXG_LOAD=NO
WAN_SCTP_LOAD=NO
WAN_LIP_LOAD=NO
WAN_DYN_WANCONFIG=NO
WAN_SCRIPTS_DIR=/etc/wanpipe/scripts
WAN_FIRMWARE_DIR=/etc/wanpipe/firmware
WAN_DEVICES_REV_STOP_ORDER=YES
WAN_DEVICES="wanpipe1 wanpipe2 wanpipe3 wanpipe4 "
Помогите побороть, пожалуйста - совсем не знаю что еще попробовать.
Заранее спасибо!
Re: Sangoma драйвера
А нет ли каких нибудь аннотация на тему - какая версия dahdi теперь нужна ?
судя по логам - карточку видит - не видит конфигурацию из файликов
точно все файлики лежат так где и должны быть ?
kadet
Сообщение kadet »
Да, карточку видит.
Так оно же само в процессе установки драйверов файлики и раскидывает...
А разве dahdi на данном этапе имеет влияние/значение? Я думал дахди только к астериску...
"До обновления проблем с драйверами небыло." . И зачем тогда обновляли?
kadet
Сообщение kadet »
Это длинная история :) Были некоторые проблемы с сервером, после чего были некоторые неувязки между астериском и карточкой, было решено обновиться. Вопрос не в этом - это прошлое. Как бы победить настоящее? :)
kadet писал(а):А разве dahdi на данном этапе имеет влияние/значение? Я думал дахди только к астериску...
DAHDI драйвера ядра - нужны. Астериск не понимает wanpipe, только dahdi.
http://wiki.sangoma.com/Wanpipe-for-Asterisk-DAHDI
Посмотрите документацию Sangoma в каком порядке поднимать wanpipe & сервис dahdi.
http://wiki.sangoma.com/Dahdi-Support-I ... ructions-0
Астериск при этом лучше бы потушить вообще.
Если всё ок (типа dahdi_tools покажет порт) то можно конфигурить /etc/asterisk/*dahdi* и поднимать Астериск.
kadet
Сообщение kadet »
Извините, я имел ввиду, разве имеют влияние драйвера Dahdi на ту ошибку, что я указал. Я думал, что Dahdi вступают в игру уже после того как wanpipe нормально работают для того чтоб астериск мог общаться с драйверами wanpipe через ядро. В данный момень проблема в том, что не поднимаются корректо интерфейсы до dahdi. Или я что-то путаю?
UPD. Ded, спасибо. Судя по этой документации таки имеют Dahdi какое-то влияние..... Попробую пересобрать Dahdi новый и на него навесить новый wanpipe...
kadet
Сообщение kadet »
К сожалению, установка последней версии dahdi + oslec и рекомпиляция и установка wanpipe дала все теже результаты :(
Платный суппорт?
kadet
Сообщение kadet »
Если Вы спрашиваете есть ли, то нет. Если предлагаете как вариант тоже боюсь, что нет.
Но все равно спасибо :)
