app_dial.c:2437 dial_exec_full: Unable to create channel of
xtc
Сообщение xtc »
После очередного падения Интерент канала провайдера, и его долгих манипуляций по восстановлению, перестала работать Исходящая связь на Астериске
sip.conf
context=default ; Default context for incoming calls
allowoverlap=no ; Disable overlap dialing support. (Default is yes)
udpbindaddr=0.0.0.0 ; IP address to bind UDP listen socket to (0.0.0.0 binds to all)
tcpenable=yes ; Enable server for incoming TCP connections (default is no)
tcpbindaddr=0.0.0.0 ; IP address for TCP server to bind to (0.0.0.0 binds to all interfaces)
transport=udp,tcp ; Set the default transports. The order determines the primary default transport.
srvlookup=yes ; Enable DNS SRV lookups on outbound calls
canreinvite=no
disallow=all ; First disallow all codecs
allow=alaw ; Allow codecs in order of preference
language=ru
limitonpeer=yes
callcounter=yes
allowsubscribe=yes
notifyringing=yes
notifyhold=yes
subscribecontext=BLF
register => tcp://7923464xxxx@multifon.ru:xxxxxxx:7923464xxxx@sbc.megafon.ru:5060/1010~60
[7923464xxxx]
dtmfmode=inband
defaultuser=7923464xxxx
type=peer
secret=xxxxxxxx
host=sbc.megafon.ru
fromdomain=multifon.ru
fromuser=7923464xxxx
port=5060
nat=force_rport,comedia
context=megafon-in
insecure=invite,port
transport=tcp
extensions.conf
[default]
exten => _[01][0123456789]X.,1,noop
same => n,answer
same => n,macro(monitor)
;same => n,playback(hello-world)
same => n,dial(sip/10${EXTEN:0:2}/${EXTEN},120,tT)
same => n,hangup
asterisk -vvvr
Connected to Asterisk 11.8.1 currently running on dru (pid = 16943)
Core debug is still 3.
-- Executing [108905074xxxx@default:1] NoOp("SIP/207-00000009", "") in new stack
-- Executing [108905074xxxx@default:2] Answer("SIP/207-00000009", "") in new stack
-- Executing [108905074xxxx@default:3] Macro("SIP/207-00000009", "monitor") in new stack
-- Executing [s@macro-monitor:1] NoOp("SIP/207-00000009", "Call Recording") in new stack
-- Executing [s@macro-monitor:2] Set("SIP/207-00000009", "fn=/var/www/html/cdr/mp3/1430151376.31") in new stack
-- Executing [s@macro-monitor:3] Verbose("SIP/207-00000009", "1430151376.31") in new stack
1430151376.31
-- Executing [s@macro-monitor:4] MixMonitor("SIP/207-00000009", "/var/www/html/cdr/mp3/1430151376.31.wav,b,lame -b 32 /var/www/html/cdr/mp3/1430151376.31.wav /var/www/html/cdr/mp3/1430151376.31.mp3 && chmod 666 /var/www/html/cdr/mp3/1430151376.31.mp3 && rm /var/www/html/cdr/mp3/1430151376.31.wav") in new stack
-- Executing [108905074xxxx@default:4] Dial("SIP/207-00000009", "sip/1010/108905074xxxx,120,tT") in new stack
== Begin MixMonitor Recording SIP/207-00000009
[Apr 27 23:16:17] WARNING[17318][C-00000003]: app_dial.c:2437 dial_exec_full: Unable to create channel of type 'sip' (cause 20 - Subscriber absent)
-- Executing [108905074xxxx@default:5] Hangup("SIP/207-00000009", "") in new stack
== Spawn extension (default, 108905074xxxx, 5) exited non-zero on 'SIP/207-00000009'
== Executing [lame -b 32 /var/www/html/cdr/mp3/1430151376.31.wav /var/www/html/cdr/mp3/1430151376.31.mp3 && chmod 666 /var/www/html/cdr/mp3/1430151376.31.mp3 && rm /var/www/html/cdr/mp3/1430151376.31.wav]
== End MixMonitor Recording SIP/207-00000009
dru*CLI>
asterisk -vvvr
sip show registry
Host dnsmgr Username Refresh State Reg.Time
sbc.megafon.ru:5060 N 7923464xxxx@ 165 Registered Mon, 27 Apr 2015 23:24:52
[root@ asterisk]# tcpdump -n -i ppp0 | grep 193
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on ppp0, link-type LINUX_SLL (Linux cooked), capture size 65535 bytes
23:30:23.036836 IP 112.225.88.77.60422 > 193.201.229.35.sip: Flags [P.], seq 1444236671:1444237348, ack 1293132293, win 501, options [nop,nop,TS val 15840992 ecr 199428679], length 677
23:30:23.133157 IP 193.201.229.35.sip > 112.225.88.77.60422: Flags [P.], seq 1:489, ack 677, win 32768, options [nop,nop,TS val 199486547 ecr 15840992], length 488
23:30:23.133199 IP 112.225.88.77.60422 > 193.201.229.35.sip: Flags [P.], seq 677:1913, ack 489, win 501, options [nop,nop,TS val 15841089 ecr 199486547], length 1236
23:30:23.190149 IP 193.201.229.35.sip > 112.225.88.77.60422: Flags [P.], seq 489:873, ack 1913, win 32768, options [nop,nop,TS val 199486605 ecr 15841089], length 384
23:30:23.190181 IP 112.225.88.77.60422 > 193.201.229.35.sip: Flags [P.], seq 1913:2590, ack 873, win 501, options [nop,nop,TS val 15841146 ecr 199486605], length 677
23:30:23.247150 IP 193.201.229.35.sip > 112.225.88.77.60422: Flags [P.], seq 873:1361, ack 2590, win 32768, options [nop,nop,TS val 199486662 ecr 15841146], length 488
23:30:23.247181 IP 112.225.88.77.60422 > 193.201.229.35.sip: Flags [P.], seq 2590:3267, ack 1361, win 501, options [nop,nop,TS val 15841203 ecr 199486662], length 677
23:30:23.304153 IP 193.201.229.35.sip > 112.225.88.77.60422: Flags [P.], seq 1361:1849, ack 3267, win 32768, options [nop,nop,TS val 199486719 ecr 15841203], length 488
23:30:23.309709 IP 112.225.88.77.60422 > 193.201.229.35.sip: Flags [P.], seq 3267:3944, ack 1849, win 501, options [nop,nop,TS val 15841265 ecr 199486719], length 677
23:30:23.367149 IP 193.201.229.35.sip > 112.225.88.77.60422: Flags [P.], seq 1849:2337, ack 3944, win 32768, options [nop,nop,TS val 199486782 ecr 15841265], length 488
23:30:23.390899 IP 112.225.88.77.60422 > 193.201.229.35.sip: Flags [P.], seq 3944:4621, ack 2337, win 501, options [nop,nop,TS val 15841346 ecr 199486782], length 677
23:30:23.447154 IP 193.201.229.35.sip > 112.225.88.77.60422: Flags [P.], seq 2337:2825, ack 4621, win 32768, options [nop,nop,TS val 199486862 ecr 15841346], length 488
23:30:23.476041 IP 112.225.88.77.60422 > 193.201.229.35.sip: Flags [P.], seq 4621:5298, ack 2825, win 501, options [nop,nop,TS val 15841431 ecr 199486862], length 677
23:30:23.533149 IP 193.201.229.35.sip > 112.225.88.77.60422: Flags [P.], seq 2825:3313, ack 5298, win 32768, options [nop,nop,TS val 199486948 ecr 15841431], length 488
23:30:23.561552 IP 112.225.88.77.60422 > 193.201.229.35.sip: Flags [P.], seq 5298:5975, ack 3313, win 501, options [nop,nop,TS val 15841517 ecr 199486948], length 677
23:30:23.619156 IP 193.201.229.35.sip > 112.225.88.77.60422: Flags [P.], seq 3313:3801, ack 5975, win 32768, options [nop,nop,TS val 199487034 ecr 15841517], length 488
23:30:23.658944 IP 112.225.88.77.60422 > 193.201.229.35.sip: Flags [P.], seq 5975:6652, ack 3801, win 501, options [nop,nop,TS val 15841614 ecr 199487034], length 677
23:30:23.716145 IP 193.201.229.35.sip > 112.225.88.77.60422: Flags [P.], seq 3801:4289, ack 6652, win 32768, options [nop,nop,TS val 199487130 ecr 15841614], length 488
23:30:23.716172 IP 112.225.88.77.60422 > 193.201.229.35.sip: Flags [P.], seq 6652:7329, ack 4289, win 501, options [nop,nop,TS val 15841671 ecr 199487130], length 677
23:30:23.773149 IP 193.201.229.35.sip > 112.225.88.77.60422: Flags [P.], seq 4289:4777, ack 7329, win 32768, options [nop,nop,TS val 199487188 ecr 15841671], length 488
23:30:23.793131 IP 112.225.88.77.60422 > 193.201.229.35.sip: Flags [P.], seq 7329:8006, ack 4777, win 501, options [nop,nop,TS val 15841748 ecr 199487188], length 677
23:30:23.850154 IP 193.201.229.35.sip > 112.225.88.77.60422: Flags [P.], seq 4777:5265, ack 8006, win 32768, options [nop,nop,TS val 199487265 ecr 15841748], length 488
23:30:23.890142 IP 112.225.88.77.60422 > 193.201.229.35.sip: Flags [.], ack 5265, win 501, options [nop,nop,TS val 15841846 ecr 199487265], length 0
Зарегистрировали этот номер мультифона в зойпере, исходящие работают нормально.
Помогите пожалуйста разобраться, если необходимы дополнительные данные, скажите где посмотреть. Спасибо.
Re: app_dial.c:2437 dial_exec_full: Unable to create channel
А кто вам писал диалплан, в частности -
same => n,dial(sip/10${EXTEN:0:2}/${EXTEN},120,tT) ???
Явно ведь не Вы сами? Потому что было бы сразу самому очевидно почему
С точки зрения приведённых (выше) конфигов строга набора sip/1010/108905074xxxx - полный бред. Который Астериск не понимает, и отвечает Unable to create channel of type 'sip'
по-русски - нет такого пира - SIP/1010
убедитесь -
sip show peers
Вам или сначала читать книгу о будушем телефонии, либо - в платный суппорт.
xtc
Сообщение xtc »
Сервак по наследству.
Количество peerов 16 шт.
Эта строчка
говорит на какой внешний номер из 16 будет уходить звонок - в строке регистрации register => в самом конце указан именно 1010~60 (остальные сделаны по аналогии)
sip/10${EXTEN:0:2} - подставляем первые две набранные цифры и получаем звонок на любой из 16 peer
но так как при звонке выпадает ошибка
[Apr 28 06:27:01] WARNING[1452][C-00000001]: app_dial.c:2437 dial_exec_full: Unable to create channel of type 'sip' (cause 20 - Subscriber absent)
звонки не идут, peerа нет. Хотя sip show peers показывает, что все они registred.
debug
[Apr 27 22:10:52] DEBUG[13847] chan_sip.c: SIP Registry sbc.megafon.ru: refcount now 3
[Apr 27 22:10:52] DEBUG[13847] chan_sip.c: SIP Registry sbc.megafon.ru: refcount now 2
[Apr 27 22:10:52] DEBUG[13847] chan_sip.c: Allocating new SIP dialog for 6b70a4d001487e3c08b0407a6b2498bf@127.0.0.1 - REGISTER (No RTP)
[Apr 27 22:10:52] DEBUG[13847] acl.c: For destination '193.201.229.35', our source address is '112.225.88.77'.
[Apr 27 22:10:52] DEBUG[13847] chan_sip.c: Setting SIP_TRANSPORT_TCP with address 112.225.88.77:5060
[Apr 27 22:10:52] DEBUG[13847] chan_sip.c: SIP Registry sbc.megafon.ru: refcount now 4
[Apr 27 22:10:52] DEBUG[13847] chan_sip.c: Scheduled a registration timeout for sbc.megafon.ru id #121
[Apr 27 22:10:52] DEBUG[13847] chan_sip.c: Initializing initreq for method REGISTER - callid 6b70a4d001487e3c08b0407a6b2498bf@127.0.0.1
[Apr 27 22:10:52] DEBUG[13847] chan_sip.c: Trying to put 'REGISTER si' onto TCP socket destined for 193.201.229.35:5060
[Apr 27 22:10:52] DEBUG[13853] chan_sip.c: Starting thread for TCP server
[Apr 27 22:10:52] DEBUG[13847] chan_sip.c: Allocating new SIP dialog for 5aa325f12639b9616e02948817113428@127.0.0.1 - REGISTER (No RTP)
[Apr 27 22:10:52] DEBUG[13847] chan_sip.c: Scheduled a registration timeout for sbc.megafon.ru id #119
[Apr 27 22:10:52] DEBUG[13847] chan_sip.c: Initializing initreq for method REGISTER - callid 5aa325f12639b9616e02948817113428@127.0.0.1
[Apr 27 22:10:52] DEBUG[13831] chan_sip.c: Checking device state for peer 79234641204
[Apr 27 22:10:52] DEBUG[13831] devicestate.c: Changing state for SIP/79234641204 - state 1 (Not in use)
[Apr 27 22:10:52] DEBUG[13831] devicestate.c: device 'SIP/79234641204' state '1'
[Apr 27 22:10:52] DEBUG[13854] app_queue.c: Device 'SIP/79234641204' changed to state '1' (Not in use) but we don't care because they're not a member of any queue.
[Apr 27 22:10:52] DEBUG[13847] chan_sip.c: Destroying SIP dialog 25e03edd6480fcac1181e6142eb5d228@112.225.88.77:5060
[Apr 27 22:10:52] DEBUG[13853] chan_sip.c: SIP Registry sbc.megafon.ru: refcount now 4
[Apr 27 22:10:52] DEBUG[13853] chan_sip.c: SIP Registry sbc.megafon.ru: refcount now 3
[Apr 27 22:10:52] DEBUG[13853] chan_sip.c: Initializing already initialized SIP dialog 5aa325f12639b9616e02948817113428@127.0.0.1 (presumably reinvite)
[Apr 27 22:10:52] DEBUG[13853] chan_sip.c: Trying to put 'REGISTER si' onto TCP socket destined for 193.201.229.35:5060
[Apr 27 22:10:52] DEBUG[13847] chan_sip.c: Allocating new SIP dialog for 6a458cc83c5dbfb501f927b637ff9845@127.0.0.1:5060 - OPTIONS (No RTP)
[Apr 27 22:10:52] DEBUG[13847] acl.c: For destination '192.168.0.206', our source address is '192.168.219.1'.
[Apr 27 22:10:52] DEBUG[13847] chan_sip.c: Setting SIP_TRANSPORT_UDP with address 192.168.219.1:5060
[Apr 27 22:10:52] DEBUG[13847] chan_sip.c: SIP call-id changed from '6a458cc83c5dbfb501f927b637ff9845@127.0.0.1:5060' to '627cc2ce0f6f704b3849beef4de1ce66@192.168.219.1:5060'
[Apr 27 22:10:52] DEBUG[13847] chan_sip.c: Initializing initreq for method OPTIONS - callid 627cc2ce0f6f704b3849beef4de1ce66@192.168.219.1:5060
[Apr 27 22:10:52] DEBUG[13847] chan_sip.c: Trying to put 'OPTIONS sip' onto UDP socket destined for 192.168.0.206:53940
[Apr 27 22:10:52] DEBUG[13847] chan_sip.c: Allocating new SIP dialog for 2ae953370e562e3c799db06e6a72cd0f@127.0.0.1 - REGISTER (No RTP)
[Apr 27 22:10:52] DEBUG[13847] chan_sip.c: Scheduled a registration timeout for sbc.megafon.ru id #124
[Apr 27 22:10:52] DEBUG[13847] chan_sip.c: Initializing initreq for method REGISTER - callid 2ae953370e562e3c799db06e6a72cd0f@127.0.0.1
[Apr 27 22:10:52] DEBUG[13853] chan_sip.c: Initializing already initialized SIP dialog 6b70a4d001487e3c08b0407a6b2498bf@127.0.0.1 (presumably reinvite)
[Apr 27 22:10:52] DEBUG[13853] chan_sip.c: Initializing already initialized SIP dialog 2ae953370e562e3c799db06e6a72cd0f@127.0.0.1 (presumably reinvite)
[Apr 27 22:10:52] DEBUG[13847] chan_sip.c: Allocating new SIP dialog for 19cbb680345a96ec56abbdcf699de8f6@127.0.0.1 - REGISTER (No RTP)
Понимаю, что пытается, но не может, а вот куда посмотреть дальше не знаю. Перестало все работать после падения интернета, провайдер долго разбирался, потом инет заработал, входящие есть, а исходящих нету.
Маршруты для мультифона прописывали и через сайт и через симку *137# и т.д. В зойпере исходящие идут.
xtc
Сообщение xtc »
вот так это выглядит в show peers
dru*CLI> sip show peers
Name/username Host Dyn Forcerport Comedia ACL Port Status Description
1001 (Unspecified) D Auto (No) No 0 UNKNOWN
1002 (Unspecified) D Auto (No) No 0 UNKNOWN
1003 (Unspecified) D Auto (No) No 0 UNKNOWN
1004 (Unspecified) D Auto (No) No 0 UNKNOWN
1005 (Unspecified) D Auto (No) No 0 UNKNOWN
1006 (Unspecified) D Auto (No) No 0 UNKNOWN
1007 (Unspecified) D Auto (No) No 0 UNKNOWN
1008 (Unspecified) D Auto (No) No 0 UNKNOWN
1009 (Unspecified) D Auto (No) No 0 UNKNOWN
1010 (Unspecified) D Auto (No) No 0 UNKNOWN
1011 (Unspecified) D Auto (No) No 0 UNKNOWN
1012 (Unspecified) D Auto (No) No 0 UNKNOWN
1013 (Unspecified) D Auto (No) No 0 UNKNOWN
1014 (Unspecified) D Auto (No) No 0 UNKNOWN
1015 (Unspecified) D Auto (No) No 0 UNKNOWN
1016 (Unspecified) D Auto (No) No 0 UNKNOWN
А зачем Вы по два раза пишите тут одно и то же? Для тупых? Надеюсь, тут таких нет.
Раз -
Два -
Я пишу - у вас нет SIP пиров, Астериск говорит Вам об этом!
Да хоть 160.
Не идут? Ну надо же!
Зачем Вы это тут всё пишете? sip show peers показывает, что их нет, а registred - показывает sip show registry, это информация провайдеру куда посылать входящие к вам вызовы, не имеет никакого отношения к исходящим.
В разделе для новичков есть блок-схемы решения проблем при исходящих. Вот по шагам и идите.. Не надо тут больше глупости писать.
xtc
Сообщение xtc »
ddkprog спасибо большое! разобрались
