Chan_dongle
1g0r
Chan_dongle
Сообщение 1g0r »
Пытаюсь подключить teleofis 201 USB Edge к asterisk.
Вроде бы устройство определилось, драйвер под грузился и имеется /dev/ttyUSB0
PRIME_BBCODE_SPOILER_SHOW PRIME_BBCODE_SPOILER: #lsusb -v
Bus 001 Device 003: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x0403 Future Technology Devices International, Ltd
idProduct 0x6001 FT232 USB-Serial (UART) IC
bcdDevice 6.00
iManufacturer 1 FTDI
iProduct 2 Teleofis RX201 USB EDGE
iSerial 3 19651961
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 255 Vendor Specific Subclass
bInterfaceProtocol 255 Vendor Specific Protocol
iInterface 2 Teleofis RX201 USB EDGE
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Status: 0x0000
(Bus Powered)
PRIME_BBCODE_SPOILER_SHOW PRIME_BBCODE_SPOILER: dmesg
[ 7.634397] usb 1-1.3: Detected FT232RL
[ 7.634399] usb 1-1.3: Number of endpoints 2
[ 7.634400] usb 1-1.3: Endpoint 1 MaxPacketSize 64
[ 7.634402] usb 1-1.3: Endpoint 2 MaxPacketSize 64
[ 7.634403] usb 1-1.3: Setting MaxPacketSize 64
[ 7.634723] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB0
dongle собран и установлен.
Файл конфигурации выглядит так..
PRIME_BBCODE_SPOILER_SHOW PRIME_BBCODE_SPOILER: dongle.conf
interval=15
[defaults]
autodeletesms=yes
disablesms=no
language=ru
smsaspdu=yes
mindtmfgap=45
mindtmfduration=80
mindtmfinterval=200
callwaiting=auto
disable=no
initstate=start>
dtmf=relax
[gsm]
imei=355798020560298
;imsi=355798020560298
context=dongle-incoming
group=0
rxgain=0
txgain=0
resetdongle=yes
u2diag=-1
usecallingpres=yes
callingpres=allowed_passed_screen
но "dongle show devices" пишет ...
*CLI> dongle show devices
ID___Group__State_______ RSSI__Mode__Submode__Provider__Name__Model__Firmware__IMEI__IMSI__Number
gsm___0_____Not connec___0_____0_______0______NONE______________________________________Unknown
ЧТо не так?
Re: Chan_dongle
вы видать не понимаете как работает dongle
он шлет команды в модем и анализирует ответы, вот по этому он работает только на ограниченном количестве оборудования (ответы у разного оборудования разные)
что бы заработал ваш teleofis 201 USB - надо всего то добавить поддержку в Chan_dongle
1g0r
Re: Chan_dongle
Сообщение 1g0r »
А свисток ZTE MF823 тоже не поддерживается?
Re: Chan_dongle
список оборудования которое работает висит на сайте откуда скачали - bg1 как то обмолвился что готов добавить совместимую модель если ему оплатят это удовольствие
1g0r
Re: Chan_dongle
Сообщение 1g0r »
Нашел E1550...
Все сразу определилось и заработало. Всем спасибо.
Re: Chan_dongle
http://wiki.e1550.mobi/doku.php?id=requirements - список совместимых с chan_dongle модемов. Все Huawei.
awsswa писал(а):bg1 как то обмолвился что готов добавить совместимую модель если ему оплатят это удовольствие
На этой же страничке сверху стоит обнадеживающее
At this moment, only Huawei models are supported. ZTE is on the road…
