cause 20 - Subscriber absent
Yunihiko
Сообщение Yunihiko »
Добрый день форумчане
Книга "Asterisk-Будущее телефонии" была мною прочитана, буквально неделю назад.
Поставил asterisk 11.14.1 на ubuntu 14.04
имеем такие конф файлы
sip.conf
port=5555
bindport=5555
bindaddr=0.0.0.0
language=ru
dtmfmode=RFC2833
localnet=192.168.8.0/255.255.255.0
externip = 111.111.111.111
nat=yes
allow=ulaw
allow=g729
allow=g723.1
register =>505:123@sip.123.ru:5555
register =>506:321@sip.123.ru:5555
;# SIP PROVIDERS #
[46]
context=in
dtmfmode=inband
username=505
type=peer
secret=123
host=sip.123.ru:5561
fromuser=505
fromdomain=sip.123.ru:5555
port=5555
insecure=port,invite
[46_2]
context=in
dtmfmode=inband
username=506
type=peer
secret=321
host=sip.123.ru:5555
fromuser=506
port=5555
[1001]
context=out
username=1001
nat=no
qualify=300
secret=1001
callerid=phone1 <1001>
[1002]
context=out
username=1002
nat=no
qualify=300
secret=1002
callerid=phone2 <1002>
extensions.conf
 static = yes
 writeprotect = no
 clearglobalvars = no
[globals]
  WAV_DIR=/var/www/html/music/wav;
  MP3_DIR=/var/www/html/music/mp3;
  RECORDING=1;
[macro-write-and-call]
  exten => s,1,Set(fname=${UNIQUEID}-${STRFTIME(${EPOCH},,%Y-%m-%d-%H_%M)})
  exten => s,n,Set(monopt=nice -n 19 /usr/bin/lame -b 32  --silent  "${WAV_DIR}/${fname}.wav"  "${MP3_DIR}/${fname}.mp3" && rm -f "${WAV_DIR}/${fname}.wav" && chmod o+r "${MP3}/${fname}.mp3")
  exten => s,n,MixMonitor(${WAV_DIR}/${fname}.wav,b,${monopt})
  exten => s,n,mysql(Connect connid localhost qqq www aaa)
  exten => s,n,Set(CDR(filename)=${fname}.mp3)
  exten => s,n,Dial(${ARG1}/${ARG2},50,Ttr)
  exten => h,1,mysql(Disconnect ${connid})
[default]
include => in
include => out
[in]
include => out
exten => s,1,Dial(SIP/1002,50,Ttr)
[out]
exten => _X.,n,Macro(write-and-call,SIP/46,${EXTEN})
exten => _1XXX,1,Macro(write-and-call,SIP/${EXTEN},${EXTEN})
CLI
    -- Executing [8XXXXXXXXXX@out:1] ChanIsAvail("SIP/1001-00000000", "SIP/46&SIP/46_2,as") in new stack
    -- Executing [8XXXXXXXXXX@out:2] NoOp("SIP/1001-00000000", "Availchan is ") in new stack
    -- Executing [8XXXXXXXXXX@out:3] NoOp("SIP/1001-00000000", "Availstatus is 5&5") in new stack
    -- Executing [8XXXXXXXXXX@out:4] Macro("SIP/1001-00000000", "write-and-call,SIP/46,8XXXXXXXXXX") in new stack
    -- Executing [s@macro-write-and-call:1] Set("SIP/1001-00000000", "fname=1427270324.0-2015-03-25-10_58") in new stack
    -- Executing [s@macro-write-and-call:2] Set("SIP/1001-00000000", "monopt=nice -n 19 /usr/bin/lame -b 32  --silent  "/var/www/html/music/wav/1427270324.0-2015-03-25-10_58.wav"  "/var/www/html/music/mp3/1427270324.0-2015-03-25-10_58.mp3" && rm -f "/var/www/html/music/wav/1427270324.0-2015-03-25-10_58.wav" && chmod o+r "/1427270324.0-2015-03-25-10_58.mp3"") in new stack
    -- Executing [s@macro-write-and-call:3] MixMonitor("SIP/1001-00000000", "/var/www/html/music/wav/1427270324.0-2015-03-25-10_58.wav,b,nice -n 19 /usr/bin/lame -b 32  --silent  "/var/www/html/music/wav/1427270324.0-2015-03-25-10_58.wav"  "/var/www/html/music/mp3/1427270324.0-2015-03-25-10_58.mp3" && rm -f "/var/www/html/music/wav/1427270324.0-2015-03-25-10_58.wav" && chmod o+r "/1427270324.0-2015-03-25-10_58.mp3"") in new stack
    -- Executing [s@macro-write-and-call:4] MYSQL("SIP/1001-00000000", "Connect connid localhost asterisk asterisk asteriskcdrdb") in new stack
    -- Executing [s@macro-write-and-call:5] Set("SIP/1001-00000000", "CDR(filename)=1427270324.0-2015-03-25-10_58.mp3") in new stack
    -- Executing [s@macro-write-and-call:6] Dial("SIP/1001-00000000", "SIP/46/8XXXXXXXXXX,50,Ttr") in new stack
[Mar 25 10:58:44] WARNING[2564][C-00000000]: app_dial.c:2437 dial_exec_full: Unable to create channel of type 'SIP' (cause 20 - Subscriber absent)
    -- Auto fallthrough, channel 'SIP/1001-00000000' status is 'CHANUNAVAIL'
  == Begin MixMonitor Recording SIP/1001-00000000
  == Executing [nice -n 19 /usr/bin/lame -b 32  --silent  "/var/www/html/music/wav/1427270324.0-2015-03-25-10_58.wav"  "/var/www/html/music/mp3/1427270324.0-2015-03-25-10_58.mp3" && rm -f "/var/www/html/music/wav/1427270324.0-2015-03-25-10_58.wav" && chmod o+r "/1427270324.0-2015-03-25-10_58.mp3"]
  == End MixMonitor Recording SIP/1001-00000000
sip show peers
aster*CLI> sip show peers
Name/username             Host                                    Dyn Forcerport Comedia    ACL Port     Status      Description
1001/1001                 192.168.8.248                           D  Auto (No)  No             51614    OK (2 ms)
1002/1002                 192.168.8.247                           D  Auto (No)  No             37683    OK (4 ms)
46/505                  (Unspecified)                               Auto (No)  No             0        Unmonitored
46_2/506                (Unspecified)                               Auto (No)  No             0        Unmonitored
sip show registry
aster*CLI> sip show registry
Host                                    dnsmgr Username       Refresh State                Reg.Time
sip.123.ru:5555                        N      506                105 Registered           Wed, 25 Mar 2015 11:03:32
sip.123.ru:5555                        N      505                105 Registered           Wed, 25 Mar 2015 11:03:32
2 SIP registrations.
при попытке sip set debug peer 46
Unable to get IP address of peer 'it46'
Между собой абоненты говорить могут, во вне позвонить не могу, cause 20 - Subscriber absent
Подскажите пожалуйста в чем проблема, в какую сторону копать?
Wapo
Re: cause 20 - Subscriber absent
Сообщение Wapo »
Сейчас прибежит ded предложением "переведу дорого".
Ну НЕТ у вас канала SIP/46/....
Судя по
вы пытаетесь звонить в мир с внутреннего номера 1001 через неведомый пир 46, который прописали абы как, от балды,
[46]
context=in
dtmfmode=inband
username=505
type=peer
secret=123
fromuser=505
port=5555
поэтому он не виден как пир
и уж конечно
потому что он в статусе Unspecified
и регистрация тут не при чём. она показывает статус того, что ваш Астериск зарегистрировался у sip.123.ru и готов принимать входящие.
Исходящие ваши при этом никак не связаны с этим процессом.
Такой синтаксис
[46]
context=in
dtmfmode=inband
username=505
type=peer
secret=123
host=sip.123.ru:5561 Вы нашли в книке про будущее телефонии?
Линейкой по пальцам!
Yunihiko
Wapo, переводить умею, спасибо, просто не всегда понятна причина.
Ded, уже ударил себя по пальцам, глупая ошибка...в упор её не замечал почему то.
Большое спасибо.
ps: а книгу действительно прочел...мое упущение, что так произошло.
