asternic call center stats не рисует графики
monstr
Сообщение monstr »
Привет, all!!!
Имею сервак с centos 6.6
Установлен asternic call center stats последняя версия с сайта
И веб морда не рисует графики
В место графиков вот такой код
val1=314&var1=SIP/164@agents/n&title=Общая длительность по агентам (сек)&bgcolor=0xF0ffff&bgcolorchart=0xdfedf3&fade1=0xff6600&fade2=0xff6600&colorbase=0xfff3b3&reverse=1
val1=3&var1=SIP/164@agents/n&title=Количество звонков по агентам&bgcolor=0xF0ffff&bgcolorchart=0xdfedf3&fade1=0xff6600&fade2=0xff6600&colorbase=0xfff3b3&reverse=1
В логах апача:
[Fri Jan 30 17:29:02 2015] [error] [client 172.16.14.95] PHP Notice:  Undefined variable: total_hangup in /var/www/html/queue-stats/answered.php on line 70, referer: http://stat.aster.int/queue-stats/
[Fri Jan 30 17:29:02 2015] [error] [client 172.16.14.95] PHP Notice:  Undefined variable: total_hold in /var/www/html/queue-stats/answered.php on line 102, referer: http://stat.aster.int/queue-stats/
[Fri Jan 30 17:29:02 2015] [error] [client 172.16.14.95] PHP Notice:  Undefined index: Four in /var/www/html/queue-stats/answered.php on line 105, referer: http://stat.aster.int/queue-stats/
[Fri Jan 30 17:29:02 2015] [error] [client 172.16.14.95] PHP Notice:  Undefined variable: abandon_end_pos in /var/www/html/queue-stats/answered.php on line 186, referer: http://stat.aster.int/queue-stats/
[Fri Jan 30 17:29:02 2015] [error] [client 172.16.14.95] PHP Notice:  Undefined variable: abandon_start_pos in /var/www/html/queue-stats/answered.php on line 187, referer: http://stat.aster.int/queue-stats/
[Fri Jan 30 17:29:02 2015] [error] [client 172.16.14.95] PHP Notice:  Undefined variable: total_hold_abandon in /var/www/html/queue-stats/answered.php on line 188, referer: http://stat.aster.int/queue-stats/
[Fri Jan 30 17:29:02 2015] [error] [client 172.16.14.95] PHP Notice:  Undefined index: SIP/164@agents/n in /var/www/html/queue-stats/answered.php on line 223, referer: http://stat.aster.int/queue-stats/
[Fri Jan 30 17:29:02 2015] [error] [client 172.16.14.95] PHP Notice:  Undefined variable: total_hold2 in /var/www/html/queue-stats/answered.php on line 225, referer: http://stat.aster.int/queue-stats/
[Fri Jan 30 17:29:02 2015] [error] [client 172.16.14.95] PHP Notice:  Undefined index: SIP/164@agents/n in /var/www/html/queue-stats/answered.php on line 225, referer: http://stat.aster.int/queue-stats/
[Fri Jan 30 17:29:02 2015] [error] [client 172.16.14.95] PHP Notice:  Undefined variable: total_time2 in /var/www/html/queue-stats/answered.php on line 226, referer: http://stat.aster.int/queue-stats/
[Fri Jan 30 17:29:02 2015] [error] [client 172.16.14.95] PHP Notice:  Undefined index: SIP/164@agents/n in /var/www/html/queue-stats/answered.php on line 226, referer: http://stat.aster.int/queue-stats/
[Fri Jan 30 17:29:02 2015] [error] [client 172.16.14.95] PHP Notice:  Undefined variable: grandtotal_hold in /var/www/html/queue-stats/answered.php on line 227, referer: http://stat.aster.int/queue-stats/
[Fri Jan 30 17:29:02 2015] [error] [client 172.16.14.95] PHP Notice:  Undefined variable: grandtotal_time in /var/www/html/queue-stats/answered.php on line 228, referer: http://stat.aster.int/queue-stats/
[Fri Jan 30 17:29:02 2015] [error] [client 172.16.14.95] PHP Notice:  Undefined variable: grandtotal_calls in /var/www/html/queue-stats/answered.php on line 229, referer: http://stat.aster.int/queue-sta
rpm -qa | grep php
php-gd-5.3.3-40.el6_6.x86_64
php-mcrypt-5.3.3-3.el6.x86_64
php-mbstring-5.3.3-40.el6_6.x86_64
php-pdo-5.3.3-40.el6_6.x86_64
php-5.3.3-40.el6_6.x86_64
php-xml-5.3.3-40.el6_6.x86_64
php-ldap-5.3.3-40.el6_6.x86_64
php-mysql-5.3.3-40.el6_6.x86_64
php-eaccelerator-0.9.6.1-1.el6.x86_64
php-common-5.3.3-40.el6_6.x86_64
php-cli-5.3.3-40.el6_6.x86_64
rpm -qa | grep http
httpd-2.2.15-39.el6.centos.x86_64
httpd-tools-2.2.15-39.el6.centos.x86_64
Причем в другом месте стоит centos 6,5 с предпоследним asternic call center stats, и php пакеты такие же (версия только 5.3.3-27) и там всё путём.
php.ini так же сделан как и на centos 6.6
yur4ik
Re: asternic call center stats не рисует графики
Сообщение yur4ik »
А каким образом это связанно с Asterisk ? Проблема то явно в самом модуле , так почему не задать вопрос на форуме разработчиков модуля ...
gd не установлен.
php-gd - это только нахлобучка сверху
rpm -qa gd ?
