Asterisk & Asterisk Manager Suite (AMS)
Sandr
Сообщение Sandr »
Столкнулся с проблемой, не знаю где копать, астериск последний 1.8.4, Нашел на просторах рунета программу AMS (http://www.intuitivecreations.com/contributions/AMS/)
Установил ихнний прокси для AMI (AMP), собрал с зависимостями, которые указаны в файле INSTALL, запускаю, при подсоединение клиента (AMA) вижу лог
[05-15-11 11:19:53] [Debug] configuration.c->set_config_param:410 Assigned debug as 1
[05-15-11 11:19:53] [Debug] configuration.c->set_config_param:408 Assigned asterisk host as 127.0.0.1
[05-15-11 11:19:53] [Debug] configuration.c->set_config_param:410 Assigned asterisk port as 5038
[05-15-11 11:19:53] [Debug] configuration.c->set_config_param:408 Assigned asterisk user as admin
[05-15-11 11:19:53] [Debug] configuration.c->set_config_param:408 Assigned asterisk secret as passwd
[05-15-11 11:19:53] [Debug] configuration.c->set_config_param:410 Assigned communication format as 1
[05-15-11 11:19:53] [Debug] proxy.c->check_lockfile:231 PID File /tmp/ampd.pid already exists, checking for a lock...
[05-15-11 11:19:53] [Info] proxy.c->check_lockfile:246 Clearing stale lockfile
[05-15-11 11:19:53] [Debug] statistics.c->statistics_thread:632 Statistics Thread Starting...
[05-15-11 11:19:53] [Debug] statistics.c->statistics_thread:656 Loading stat cache from DB
[05-15-11 11:19:53] [Debug] ampdb.c->ampdb_get_next:223 Initializing cursor
[05-15-11 11:19:53] [Info] statistics.c->statistics_thread:665 Statistics Thread Ready.
[05-15-11 11:19:53] [Debug] net.c->sock_connect:88 Connected to host 127.0.0.1
[05-15-11 11:19:53] [Info] asterisk.c->asterisk_command_thread:194 Established the asterisk server command connection
[05-15-11 11:19:53] [Info] asterisk.c->asterisk_init_parked_calls:989 Initializing Parked Calls
[05-15-11 11:19:53] [Info] asterisk.c->asterisk_init_agents:788 Initializing Agents
[05-15-11 11:19:53] [Info] asterisk.c->asterisk_init_peers:914 Initializing Peers
[05-15-11 11:19:53] [Debug] asterisk.c->asterisk_init_peers:933 Looking up CID for SIP/9050
[05-15-11 11:19:53] [Debug] asterisk.c->asterisk_init_peers:933 Looking up CID for SIP/9051
[05-15-11 11:19:53] [Debug] asterisk.c->asterisk_init_peers:933 Looking up CID for SIP/ukrtel
[05-15-11 11:19:53] [Info] asterisk.c->asterisk_init_queues:833 Initializing Queue Info
[05-15-11 11:19:53] [Info] asterisk.c->asterisk_init_channels:754 Initializing Channels
[05-15-11 11:19:53] [Info] asterisk.c->asterisk_event_thread:552 Established the asterisk server event connection
[05-15-11 11:19:53] [Info] net.c->sock_bind:128 Listening on host *:3553
[05-15-11 11:19:53] [Debug] asterisk.c->asterisk_event_thread:595 Adding Event 'FullyBooted'
[05-15-11 11:19:57] [Debug] event.c->event_remove_expired:213 Removing expired event: FullyBooted
[05-15-11 11:20:31] [Info] net.c->proxy_server:277 Accepting new client connection: 172.31.31.10
[05-15-11 11:20:31] [Debug] net.c->proxy_client:338 Got size(90): <command Action="login" username="pass" secret="" type="monitor" format="xml" events="1"/>
[05-15-11 11:20:31] [Debug] client.c->client_command:137 Cmd is in XML format
Ошибка сегментирования
Может кто то сталкивался, подскажет? пробовал пересобрать, не помогло..
