callback в Elastix.
truthful-liar
callback в Elastix.
Сообщение truthful-liar »
Всем привет! Пытаюсь поправить скрипт коллбека эластикса, чтобы тот сначала звонил на внутренний номер, потом наружу.
Поменял местами номера, но скрипт не отрабатывает. переменные $channel, $exten, $context.
БЫЛО
$channel = "Local/".$callback_number."@from-internal";
$exten = $callback_exten;
$contex = $callback_context;
СТАЛО
$channel = "SIP/".$callback_exten."@".$callback_context;
$exten = "Local/".$callback_number;
$contex = "@from-internal";
Где я ошибся?
Полный код скрипта:
#!/usr/bin/php -q
<?php
This Callback script takes 7 arguments:
1- number to dial
2- context.exten.priority to dump number into
3- optional time in seconds to sleep before calling back
eg: callback 14032448089 ext-meetme.200.1
//Copyright (C) 2004 Coalescent Systems Inc. (info@coalescentsystems.ca)
//Copyright (C) 2010 Astrogen LLC
//This file is part of FreePBX.
//    FreePBX is free software: you can redistribute it and/or modify
//    it under the terms of the GNU General Public License as published by
//    the Free Software Foundation, either version 2 of the License, or
//    (at your option) any later version.
//    FreePBX is distributed in the hope that it will be useful,
//    but WITHOUT ANY WARRANTY; without even the implied warranty of
//    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
//    GNU General Public License for more details.
//    You should have received a copy of the GNU General Public License
//    along with FreePBX.  If not, see <http://www.gnu.org/licenses/>.
<?php
if ($argc < 3) {
  cb_fatal("Wrong number of arguments, should be:\n".$argv[0]." callback_number callback_destination [delay_seconds]\n");
$callback_number = $argv[1];
$callback_destination = $argv[2];
$pause_seconds = isset($argv[3]) ? $argv[3] : 0;
// bootstrap the connection to get astman up
$restrict_mods = true;
$bootstrap_settings['freepbx_auth'] = false;
if (!@include_once(getenv('FREEPBX_CONF') ? getenv('FREEPBX_CONF') : '/etc/freepbx.conf')) {
  include_once('/etc/asterisk/freepbx.conf');
if($pause_seconds) {
	sleep($pause_seconds);
// figure out context, exten, priority
$dest = explode(".",$callback_destination);
$callback_context = $dest[0];
$callback_exten = $dest[1];
$callback_priority = $dest[2];
//define the args for Originate
$context = $callback_context;
$priority = $callback_priority;
$timeout = "15000";
$callerid = "Callback";
$variable = "";
$account = "";
$application = "";
$data = "";
if ($bootstrap_settings['astman_connected']) {
	$astman->Originate($channel, $exten, $context, $priority, $timeout, $callerid, $variable, $account, $application, $data);
  $astman->disconnect();
} else {
	cb_fatal("Cannot connect to Asterisk Manager with ".$amp_conf["AMPMGRUSER"]."/".$amp_conf["AMPMGRPASS"]);
function cb_fatal($text) {
	echo "[FATAL] ".$text."\n";
	exit(1);
Re: callback в Elastix.
Получается SIP/1234@callback-context , и куда по вашему это уйдет? Исправляйте. Вообще всё неправильно. Не трогайте , пожалуйста , код, это не для Вас.
truthful-liar
А разве $callback_context не должна возвращать нужный контекст, переданый скрипту?
как должен выглядеть $channel для звонка на внутренний номер?
P.S. Все мы учились по немногу... Я только в начале большого пути.
спасибо, разобрался!! :)
должно было быть
$channel = "SIP/".$callback_exten;
$exten = $callback_number;
$contex = "from-internal";
truthful-liar
И еще вопрос! Коллбек на конкретный экстеншн отрабатывает на ура! Как звонок с коллбека завернуть на ринг груп?
Попробывал использовать фолоу ми, работает. Но это ж отдельный телефон надо держать для этих целей :D
подозреваю что вместо "SIP/" надо указать чтото другое. Как сказать, что это очередь или ринг групп.
Вы справитесь!
truthful-liar
ну серьезно... возможно ли в параметр Channel команды Originate записать очередь или ринг групп?
By default - возможно вообще всё что угодно!
Надо стараться.
truthful-liar
очень полезно, спасибо! Использовал запись типа Local/номергруппы@from-internal
