Не входят звонки по sip-trunk
PGovorov
Сообщение PGovorov »
Всем доброго дня, помогите с настройкой входящей линии с sip.
Лог звонка:
  • [2014-09-03 09:23:36] VERBOSE[63935][C-000003b3] netsock2.c: == Using SIP RTP TOS bits 184
    [2014-09-03 09:23:36] VERBOSE[63935][C-000003b3] netsock2.c: == Using SIP RTP CoS mark 5
    [2014-09-03 09:23:36] VERBOSE[17470][C-000003b3] pbx.c: -- Executing [vlan221_101@from-sip-external:1] NoOp("SIP/meganet.ru-000002ee", "Received incoming SIP connection from unknown peer to vlan221_101") in new stack
    [2014-09-03 09:23:36] VERBOSE[17470][C-000003b3] pbx.c: -- Executing [vlan221_101@from-sip-external:2] Set("SIP/meganet.ru-000002ee", "DID=vlan221_101") in new stack
    [2014-09-03 09:23:36] VERBOSE[17470][C-000003b3] pbx.c: -- Executing [vlan221_101@from-sip-external:3] Goto("SIP/meganet.ru-000002ee", "s,1") in new stack
    [2014-09-03 09:23:36] VERBOSE[17470][C-000003b3] pbx.c: -- Goto (from-sip-external,s,1)
    [2014-09-03 09:23:36] VERBOSE[17470][C-000003b3] pbx.c: -- Executing [s@from-sip-external:1] GotoIf("SIP/meganet.ru-000002ee", "0?checklang:noanonymous") in new stack
    [2014-09-03 09:23:36] VERBOSE[17470][C-000003b3] pbx.c: -- Goto (from-sip-external,s,5)
    [2014-09-03 09:23:36] VERBOSE[17470][C-000003b3] pbx.c: -- Executing [s@from-sip-external:5] Set("SIP/meganet.ru-000002ee", "TIMEOUT(absolute)=15") in new stack
    [2014-09-03 09:23:36] VERBOSE[17470][C-000003b3] func_timeout.c: -- Channel will hangup at 2014-09-03 09:23:51.321 MSK.
    [2014-09-03 09:23:36] VERBOSE[17470][C-000003b3] pbx.c: -- Executing [s@from-sip-external:6] Log("SIP/meganet.ru-000002ee", "WARNING,"Rejecting unknown SIP connection from 77.73.232.100"") in new stack
    [2014-09-03 09:23:36] WARNING[17470][C-000003b3] Ext. s: "Rejecting unknown SIP connection from 77.73.232.100"
    [2014-09-03 09:23:36] VERBOSE[17470][C-000003b3] pbx.c: -- Executing [s@from-sip-external:7] Answer("SIP/meganet.ru-000002ee", "") in new stack
    [2014-09-03 09:23:36] VERBOSE[17470][C-000003b3] pbx.c: -- Executing [s@from-sip-external:8] Wait("SIP/meganet.ru-000002ee", "2") in new stack
    [2014-09-03 09:23:38] VERBOSE[17470][C-000003b3] pbx.c: -- Executing [s@from-sip-external:9] Playback("SIP/meganet.ru-000002ee", "ss-noservice") in new stack
    [2014-09-03 09:23:38] VERBOSE[17470][C-000003b3] file.c: -- <SIP/meganet.ru-000002ee> Playing 'ss-noservice.ulaw' (language 'en')
    [2014-09-03 09:23:43] VERBOSE[17470][C-000003b3] pbx.c: -- Executing [s@from-sip-external:10] PlayTones("SIP/meganet.ru-000002ee", "congestion") in new stack
    [2014-09-03 09:23:43] VERBOSE[17470][C-000003b3] pbx.c: -- Executing [s@from-sip-external:11] Congestion("SIP/meganet.ru-000002ee", "5") in new stack
Настройки транка
  • host=voip.megaon.ru
    username=vlan221_101
    secret=*********
    fromuser=vlan221_101
    fromdomain=kaspergroup.ddns.net
    nat=yes
    context=from-trunk
    dtmfmode=rfc2833
    allow=pcmu&pcma&g729
Строка регистрации:
  • vlan221_101:***********@voip.megaon.ru/vlan221_101
Во входящей маршрутиризации созданы правила с DID vlan221_001 и пустым DID, звонки не проходят.
Требования сервера:
  • Сервер регистрации voip.megaon.ru
    Порт 5060 UDP
    Прокси - сервер voip.megaon.ru
    Порт 5060 UDP
    Кодеки PCMU, PCMA (g.711 a,u) g.729 (приоритетными следует указать кодеки PCMU, PCMA)
    метод передачи DTMF-сигнализации согласно RFC2833
    Протокол SIP V2.0
    login - login для аутентификации
    passwd - пароль для аутентификации
    обязательным условием является наличие регистрации
    обязательным условием является наличие аутентификации при исходящих вызовах
    при подключении за NAT длительность регистрации следует указать 5 минут
    при отсутствии NAT время регистрации следует указать 1 час
Последний раз редактировалось PGovorov 03 сен 2014, 09:39, всего редактировалось 1 раз.
Re: Не входят звонки по sip-trunk
перевод на русский язык, дорого @ ded
PGovorov
Не обратил внимания на эту строку, перевести могу и сам)))) спасибо, значит вопрос к поставщику услуг??
вы сами отбиваете = поставщик то тут причем ?
PGovorov
тогда кто подскажет, как не включая Allow Anonymous Inbound SIP Calls разрешить все входящие?
PGovorov
Входящие приходят от разных IP
host=voip.megaon.ru - резольвится на ИП адрес 178.236.16.36, а вызов прибегает с адреса 77.73.232.100, для Астериска это unknown SIP connection. Вариантов решения несколько, и все на вашей стороне. Например - создать ещё один пир host=77.73.232.100, и ещё один, и ещё. Их число не бесконечно. А лучше бы аутентифицировать входящий.
PGovorov писал(а):тогда кто подскажет, как не включая Allow Anonymous Inbound SIP Calls разрешить все входящие?
Как не открывая двери разрешить всем входить?
PGovorov
Понял, спасибо, проверил на Allow Anonymous Inbound SIP Calls yes входящие приходят, еще вопросик, есть IVR с разрешением ввода внутренних номеров, но при вводе номера не срабатывет перевод вызова не extension и сообщает we have not received desired response ... сигнал в тоне
PGovorov
Asterisk не принимает сигнал, который отправляется, говорит, что не набрано, повторите, что с этим делать?
PGovorov
Так же только что выяснил, что не отправляется сигнал и с астериска на другие звонки
