сервер 192.168.245.20
panas1 192.168.245.22
panas2 192.168.245.23
в логах (в консоле) при попытке коннекта телефона вываливается:
[2013-10-12 14:42:40] NOTICE[2073]: chan_sip.c:27724 handle_request_register: Registration from '<sip:test1251@192.168.245.20>' failed for '192.168.245.23:5060' - No matching peer found
Экстеншены создал. В CLI их видно.
* Name : 1251
Description :
Secret : <Set>
MD5Secret : <Not set>
Remote Secret: <Not set>
Context : from-internal
Record On feature : automon
Record Off feature : automon
Subscr.Cont. : <Not set>
Language :
Tonezone : <Not set>
AMA flags : Unknown
Transfer mode: open
CallingPres : Presentation Allowed, Not Screened
Callgroup :
Pickupgroup :
Named Callgr :
Nam. Pickupgr:
MOH Suggest :
Mailbox : 1251@device
VM Extension : *97
LastMsgsSent : 0/0
Call limit : 2147483647
Max forwards : 0
Dynamic : Yes
Callerid : "1251" <1251>
MaxCallBR : 384 kbps
Expire : -1
Insecure : no
Force rport : No
Symmetric RTP: No
ACL : Yes
DirectMedACL : No
T.38 support : No
T.38 EC mode : Unknown
T.38 MaxDtgrm: -1
DirectMedia : No
PromiscRedir : No
User=Phone : No
Video Support: No
Text Support : No
Ign SDP ver : No
Trust RPID : Yes
Send RPID : No
Subscriptions: Yes
Overlap dial : Yes
DTMFmode : auto
Timer T1 : 500
Timer B : 32000
ToHost : 192.168.245.23
Addr->IP : 192.168.245.23:5060
Defaddr->IP : (null)
Prim.Transp. : UDP
Allowed.Trsp : UDP
Def. Username:
SIP Options : (none)
Codecs : (gsm|ulaw|alaw)
Codec Order : (ulaw:20,alaw:20,gsm:20)
Auto-Framing : No
Status : UNREACHABLE
Useragent :
Reg. Contact :
Qualify Freq : 60000 ms
Keepalive : 0 ms
Sess-Timers : Accept
Sess-Refresh : uas
Sess-Expires : 1800 secs
Min-Sess : 90 secs
RTP Engine : asterisk
Parkinglot :
Use Reason : No
Encryption : No
* Name : 1250
Description :
Secret : <Set>
Language :
AMA flags : Unknown
Transfer mode: open
Callgroup :
Pickupgroup :
Named Callgr :
Nam. Pickupgr:
MOH Suggest :
Mailbox : 1250@device
VM Extension : *97
LastMsgsSent : 32767/65535
Max forwards : 0
Dynamic : Yes
Callerid : "1250" <1250>
Expire : -1
Insecure : no
Force rport : No
Symmetric RTP: No
ACL : Yes
DirectMedACL : No
T.38 support : No
T.38 MaxDtgrm: -1
DirectMedia : No
PromiscRedir : No
User=Phone : No
Video Support: No
Text Support : No
Ign SDP ver : No
Trust RPID : Yes
Send RPID : No
Subscriptions: Yes
Overlap dial : Yes
DTMFmode : rfc2833
Timer T1 : 500
Timer B : 32000
ToHost : 192.168.245.22
Addr->IP : 192.168.245.22:5060
Prim.Transp. : UDP
Allowed.Trsp : UDP
Def. Username:
Auto-Framing : No
Useragent :
Reg. Contact :
Keepalive : 0 ms
Sess-Refresh : uas
Min-Sess : 90 secs
Parkinglot :
Use Reason : No
Encryption : No
sip show peers
Name/username Host Dyn Forcerport ACL Port Status Description
1250 192.168.245.22 D A 5060 UNREACHABLE
1251 192.168.245.23 D A 5060 UNREACHABLE
2 sip peers [Monitored: 0 online, 2 offline Unmonitored: 0 online, 0 offline]
Толку нет.
Прошивку на телефонах обновил до актуальной, с сайта производителя.
Будут идеи? Что то я пока никак не могу понять в чём проблема.
