Настройка a1200p dahdi_scan не выводит
shadow_mag
Сообщение shadow_mag »
Вопрос такой
Установил asterisk 1.8
далее dahdi
по статье http://voxlink.ru/kb/voip-devices-confi ... vox-dahdi/
плата не видит модули fxs и fxo
01:01.0 Communication controller: Tiger Jet Network Inc. Tiger3XX Modem/ISDN interface
Subsystem: Device 9500:0003
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 96 (250ns min, 32000ns max)
Interrupt: pin A routed to IRQ 19
Region 0: I/O ports at a000
Region 1: Memory at e1001000 (32-bit, non-prefetchable) [size=4K]
Capabilities: [40] Power Management version 2
Flags: PMEClk- DSI+ D1- D2+ AuxCurrent=55mA PME(D0+,D1-,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Kernel driver in use: netjet
Kernel modules: opvxa1200, hisax, netjet
dahdi_hardware
driver should be 'opvxa1200' but is actually 'netjet'
pci:0000:01:01.0 opvxa1200+ e159:0001 OpenVox A800P
service dahdi start
Loading DAHDI hardware modules:
opvxa1200: [ OK ]
Running dahdi_cfg: [ OK ]
dahdi_cfg -vvvvvvvv
DAHDI Tools Version - 2.6.1
DAHDI Version: 2.6.1
Echo Canceller(s): HWEC
Configuration
Channel map:
0 channels to configure.
делаю
dahdi_genconf
Empty configuration -- no spans
Почему не видит модули? Подскажите плиз
Re: Настройка a1200p dahdi_scan не выводит
Ключевую фразу - driver should be 'opvxa1200' but is actually 'netjet' забить в Гугль, получить результат и выполнить.
ded, да.. поколение FreePBX очень ленивое стало.. нагуглил
please disable the modules(hisax, netjet). these will be conflict with analog drivers, if you get in the system,
shadow_mag
Заработало.
Module opvxa1200 conflicts with hisax and netjet, so we've to blacklist them in /etc/modprobe.d/blacklist.conf, add following code:
Code:
# disable kernel load modules which conflicts with opvxa1200 analog card driver
blacklist hisax
blacklist netjet
then unload the module in memory:
Code:
sudo rmmod hisax
sudo rmmod netjet
restart dahdi:
Code:
sudo /etc/init.d/dahdi restart
shadow_mag
Всем спасибо!!!!
