Вот лог mysql при вводе на веб верного логина:admin и пароля.
/usr/libexec/mysqld, Version: 5.0.77-log (Source distribution). started with:
Tcp port: 0 Unix socket: /var/lib/mysql/mysql.sock
Time Id Command Argument
130601 10:42:48 1 Connect UNKNOWN_MYSQL_US@localhost as anonymous on
1 Quit
130601 10:44:28 2 Connect Access denied for user 'asteriskuser'@'localhost' (using password: YES)
130601 10:44:30 3 Connect Access denied for user 'asteriskuser'@'localhost' (using password: YES)
130601 10:45:59 4 Connect Access denied for user 'asteriskuser'@'localhost' (using password: YES)
130601 10:46:01 5 Connect Access denied for user 'asteriskuser'@'localhost' (using password: YES)
130601 10:46:06 6 Connect Access denied for user 'asteriskuser'@'localhost' (using password: YES)
130601 10:46:07 7 Connect Access denied for user 'asteriskuser'@'localhost' (using password: YES)
130601 10:47:32 8 Connect Access denied for user 'asteriskuser'@'localhost' (using password: YES)
130601 10:47:34 9 Connect Access denied for user 'asteriskuser'@'localhost' (using password: YES)Думал поиграться с настройками файла amportal.conf однако не нашел у себя такого скрипта( Run /usr/src/AMP/apply_conf.sh after making changes to this file). На Каждом шагу под жидает какая-то лажа:(
