много warning в messages log
Soyuz_MKS
Сообщение Soyuz_MKS »
[2018-04-28 07:01:03] WARNING[2679] chan_sip.c: !!! PLEASE NOTE: Setting 'nat' for a peer/user that differs from the  global setting can make
[2018-04-28 07:01:03] WARNING[2679] chan_sip.c: !!! the name of that peer/user discoverable by an attacker. Replies for non-existent peers/users
[2018-04-28 07:01:03] WARNING[2679] chan_sip.c: !!! will be sent to a different port than replies for an existing peer/user. If at all possible,
[2018-04-28 07:01:03] WARNING[2679] chan_sip.c: !!! use the global 'nat' setting and do not set 'nat' per peer/user.
[2018-04-28 07:01:03] WARNING[2679] chan_sip.c: !!! (config category='2511' global force_rport='Yes' peer/user force_rport='No')
[2018-04-28 09:00:40] WARNING[28691] pbx.c: Extension 's', priority 4 in 'app-speeddial-set', label 'lookup' already in use at priority 3
[2018-04-28 09:00:40] WARNING[28691] pbx_config.c: The use of '_.' for an extension is strongly discouraged and can have unexpected behavior.  Please use '_X.' instead at line 23844 of /etc/asterisk/extensions_additional.conf
[2018-04-28 09:00:41] ERROR[28691] pbx.c: You have to be kidding-- add exten '' to context from-did-direct-ivr? Figure out a name and call me back. Action ignored.
[2018-04-28 09:00:41] WARNING[28691] pbx_config.c: Unable to register extension at line 31187 of /etc/asterisk/extensions_additional.conf
строчка 31187: exten => ,n,Goto(from-did-direct,1) в логе много разных строк указывается.
[2018-04-28 09:00:41] WARNING[28691] pbx_config.c: The use of '_.' for an extension is strongly discouraged and can have unexpected behavior.  Please use '_X.' instead at line 39909 of /etc/asterisk/extensions_additional.conf
[2018-04-28 13:45:08] WARNING[6533] channel.c: Codec mismatch on channel SIP/kcell-00001b63 setting write format to ulaw from alaw native formats (alaw)
[2018-04-28 13:48:38] ERROR[26915] netsock2.c: getaddrinfo("Sipserver", "(null)", ...): Temporary failure in name resolution
[2018-04-28 13:48:38] WARNING[26915] acl.c: Unable to lookup 'Sipserver'
[2018-04-28 13:48:38] ERROR[26915] netsock2.c: getaddrinfo("A.ROOT-SERVERS.NET", "(null)", ...): Temporary failure in name resolution
[2018-04-28 13:48:38] WARNING[26915] acl.c: Unable to lookup 'A.ROOT-SERVERS.NET'
[2018-04-28 13:48:39] WARNING[26915] channel.c: Ignoring invalid group 100 (maximum group is 63)
[2018-04-28 13:48:39] WARNING[26915] chan_sip.c: Format for authentication entry is user[:secret]@realm at line
[2018-04-28 13:48:47] WARNING[6590] res_agi.c: DeadAGI has been deprecated, please use AGI in all cases!
[2018-04-28 13:48:57] WARNING[6594] channel.c: No channel type registered for 'CUSTOM'
[2018-04-28 13:48:57] WARNING[6594] app_dial.c: Unable to create channel of type 'CUSTOM' (cause 66 - Channel not implemented)
[2018-04-28 13:51:56] WARNING[26915] chan_sip.c: Unsupported SDP media type in offer: video 0 RTP/AVP 99
sip.conf правил руками, знаю что не надо так как freepbx перезапишет, но он не перезаписывает (до меня так было), в freepbx nat=no, но в sip_general_additional.conf nat=yes, изменил также ручками на no. При sip reload конфиги не перезаписавются. Это мне помогло решить проблему с падением транков.
Теперь вопрос: Вот эти строки, как можно их решить?dial plan настраиваю только через вебморду, руками никуда не лезу, но extensions.conf (до меня) правили ручками, теперь и он не перезаписываемый.
От модератора:
Используйте теги ! Сообщение отредактировано.
Re: много warning в messages log
1. Портянки принято убирать под споллер.
2 спросите как сделали, то sip. Conf не перезаписывается, ну или проверьте права на файл.
3 править надо custom.
