проблема при приеме факса (free fax for asterisk)
forik
Сообщение forik »
Здравствуйте!
Использую free fax for asterisk 1.6.2.9. При попытке приема факса я слышу только сигналы факс-аппарата, но сам факс не идет.
В sip.conf прописал:
t38pt_udptl=yes
faxdetect=yes
extensions.conf:
exten => s,1,Dial(SIP/gts-sip/xxxxxxxx)
exten => fax,n,Goto(fax-rx,receive,1)
[fax-rx]
exten => receive,1,NoOp(***RECEIVING FAX***)
exten => receive,n,Set(GLOBAL(FAXCOUNT)=$[ ${GLOBAL(FAXCOUNT)} + 1 ])
exten => receive,n,Set(FAXCOUNT=${GLOBAL(FAXCOUNT)})
exten => receive,n,Set(FAXFILE=fax-${FAXCOUNT}-rx.tif)
exten => receive,n,Set(FAXOPT(ecm)=yes)
exten => receive,n,Set(FAXOPT(headerinfo)=MY FAXBACK RX)
exten => receive,n,Set(FAXOPT(localstationid)=1234567890)
exten => receive,n,Set(FAXOPT(maxrate)=14400)
exten => receive,n,Set(FAXOPT(minrate)=2400)
exten => receive,n,ReceiveFAX(/var/spool/asterisk/fax/${FAXFILE})
exten => receive,n,System(echo "Fax received" | mailx -s "fax" -a /var/spool/asterisk/fax/*.tif user@gmail.com)
Re: проблема при приеме факса (free fax for asterisk)
А приложение ReceiveFAX есть?
CLI> core show application ReceiveFAX ??
forik
Сообщение forik »
ded писал(а):А приложение ReceiveFAX есть?
Да, есть.
-= Info about application 'ReceiveFAX' =-
[Synopsis]
Receive a FAX and save as a TIFF/F file.
[Description]
ReceiveFAX(filename[,options]):
The ReceiveFAX() application receives a FAX as a TIFF/F file with specified filename.
The application arguments are:
'd' - enables FAX debugging
'f' - allow audio fallback FAX transfer on T.38 capable channels
's' - send progress Manager events (overrides statusevents setting in res_fax.conf)
Use the FAXOPT function to specify session arguments prior to calling ReceiveFAX()
and use FAXOPT after ReceiveFAX completes to query result status for the session.
The ReceiveFAX() is provided by res_fax, which is a FAX technology agnostic module
that utilizes FAX technology resource modules to complete a FAX transmission.
[Syntax]
Not available
[Arguments]
Not available
[See Also]
Not available
изменил в extensions.conf - оставил только exten=>s,1,Goto(fax-rx,receive,1)
После этого уже в консоль пошло следующее:
Executing [s@gts-out:1] Goto("SIP/gts-sip-0000001b", "fax-rx,receive,1") in new stack
    -- Goto (fax-rx,receive,1)
    -- Executing [receive@fax-rx:1] NoOp("SIP/gts-sip-0000001b", "***RECEIVING FAX***") in new stack
[Nov  8 10:20:57] WARNING[2155]: ast_expr2.fl:445 ast_yyerror: ast_yyerror():  syntax error: syntax error, unexpected '+', expecting $end; Input:
  + 1
[Nov  8 10:20:57] WARNING[2155]: ast_expr2.fl:449 ast_yyerror: If you have questions, please refer to doc/tex/channelvariables.tex.
    -- Executing [receive@fax-rx:2] Set("SIP/gts-sip-0000001b", "GLOBAL(FAXCOUNT)=") in new stack
 == Setting global variable 'FAXCOUNT' to ''
    -- Executing [receive@fax-rx:3] Set("SIP/gts-sip-0000001b", "FAXCOUNT=") in new stack
    -- Executing [receive@fax-rx:4] Set("SIP/gts-sip-0000001b", "FAXFILE=fax--rx.tif") in new stack
    -- Executing [receive@fax-rx:5] Set("SIP/gts-sip-0000001b", "FAXOPT(ecm)=yes") in new stack
    -- Executing [receive@fax-rx:6] Set("SIP/gts-sip-0000001b", "FAXOPT(headerinfo)=MY FAXBACK RX") in new stack
    -- Executing [receive@fax-rx:7] Set("SIP/gts-sip-0000001b", "FAXOPT(localstationid)=1234567890") in new stack
    -- Executing [receive@fax-rx:8] Set("SIP/gts-sip-0000001b", "FAXOPT(maxrate)=14400") in new stack
    -- Executing [receive@fax-rx:9] Set("SIP/gts-sip-0000001b", "FAXOPT(minrate)=2400") in new stack
    -- Executing [receive@fax-rx:10] ReceiveFAX("SIP/gts-sip-0000001b", "/var/spool/asterisk/fax/fax--rx.tif") in new stack
    -- Channel 'SIP/gts-sip-0000001b' receiving FAX '/var/spool/asterisk/fax/fax--rx.tif'
[Nov  8 10:20:59] NOTICE[2155]: chan_sip.c:7236 sip_read: FAX CNG detected but no fax extension
[Nov  8 10:21:00] WARNING[2155]: res_fax.c:1387 receivefax_t38_init: channel 'SIP/gts-sip-0000001b' refused to negotiate T.38
[Nov  8 10:21:00] WARNING[2155]: res_fax.c:1408 receivefax_t38_init: Audio FAX not allowed on channel 'SIP/gts-sip-0000001b' and T.38 negotiation failed; aborting.
[Nov  8 10:21:00] ERROR[2155]: res_fax.c:1612 receivefax_exec: error initializing channel 'SIP/gts-sip-0000001b' in T.38 mode
  == Spawn extension (fax-rx, receive, 10) exited non-zero on 'SIP/gts-sip-0000001b'
Не понимаю, как при звонке обнаружить входящий факс. Помогите пожалуйста!
Срочные переводы с английского. Недорого.
forik
Сообщение forik »
Все равно не получается принять:
== Using UDPTL CoS mark 5
-- Executing [s@gts-out:1] Goto("SIP/gts-sip-00000021", "fax-rx,fax,1") in new stack
-- Goto (fax-rx,fax,1)
-- Executing [fax@fax-rx:1] NoOp("SIP/gts-sip-00000021", "***RECEIVING FAX***") in new stack
-- Executing [fax@fax-rx:2] Set("SIP/gts-sip-00000021", "GLOBAL(FAXCOUNT)=1") in new stack
== Setting global variable 'FAXCOUNT' to '1'
-- Executing [fax@fax-rx:3] Set("SIP/gts-sip-00000021", "GLOBAL(FAXCOUNT)=2") in new stack
== Setting global variable 'FAXCOUNT' to '2'
-- Executing [fax@fax-rx:4] Set("SIP/gts-sip-00000021", "FAXCOUNT=2") in new stack
-- Executing [fax@fax-rx:5] Set("SIP/gts-sip-00000021", "FAXFILE=fax-2-rx.tif") in new stack
-- Executing [fax@fax-rx:6] Set("SIP/gts-sip-00000021", "FAXOPT(ecm)=yes") in new stack
-- Executing [fax@fax-rx:7] Set("SIP/gts-sip-00000021", "FAXOPT(headerinfo)=MY FAXBACK RX") in new stack
-- Executing [fax@fax-rx:8] Set("SIP/gts-sip-00000021", "FAXOPT(localstationid)=88432920231") in new stack
-- Executing [fax@fax-rx:9] Set("SIP/gts-sip-00000021", "FAXOPT(maxrate)=14400") in new stack
-- Executing [fax@fax-rx:10] Set("SIP/gts-sip-00000021", "FAXOPT(minrate)=2400") in new stack
-- Executing [fax@fax-rx:11] ReceiveFAX("SIP/gts-sip-00000021", "/var/spool/asterisk/fax/fax-2-rx.tif") in new stack
-- Channel 'SIP/gts-sip-00000021' receiving FAX '/var/spool/asterisk/fax/fax-2-rx.tif'
[Nov 8 11:48:41] WARNING[2589]: res_fax.c:1387 receivefax_t38_init: channel 'SIP/gts-sip-00000021' refused to negotiate T.38
[Nov 8 11:48:41] WARNING[2589]: res_fax.c:1408 receivefax_t38_init: Audio FAX not allowed on channel 'SIP/gts-sip-00000021' and T.38 negotiation failed; aborting.
[Nov 8 11:48:41] ERROR[2589]: res_fax.c:1612 receivefax_exec: error initializing channel 'SIP/gts-sip-00000021' in T.38 mode
== Spawn extension (fax-rx, fax, 11) exited non-zero on 'SIP/gts-sip-00000021'
Как я понял, не получается по t38 принять? Если так, то пробовал отключать fax set t38cap off и включал g711 fax set g711cap on. Но, как показано выше, все равно идет по т38 (?)
Если ваш пир SIP/gts-sip пихает по Т38, то все равно пойдёт по Т38, Вы ему не указчик?
forik
Сообщение forik »
Но раз сам сип провайдер по т38 мне передает, то почему астериск то не принимает? Слезами умываться скоро начну(
если так
t38pt_udptl=yes,redundancy,maxdatagram=400
[gts-sip]
forik, Вы решили, что факс - это ать-два, готово?
http://asterisk.ru/knowledgebase/foip
forik
Сообщение forik »
Vlad1983 писал(а):t38pt_udptl=yes,redundancy,maxdatagram=400
Все тоже.
ded писал(а):forik, Вы решили, что факс - это ать-два, готово?
Я читал эту статью, но не сдаваться же теперь. Пробовал hylafax + iaxmodem, но не разобрался нормально. Теперь с FFA разбираюсь. Может быть c app_fax попробовать, благо он уже стоит..
