Cообщение от   Telegram-канал mr_gmr
asterisk -rx "pjsip show endpoint 1002"
вывод покажите
Cообщение от   Telegram-канал yourkozy
вывод покажите
а как так красиво оформить??
pastebin
Скопировал в целом, но думал вот так будет удобнее
ParameterName : ParameterValue
100rel : yes
accept_multiple_sdp_answers : false
accountcode :
acl :
aggregate_mwi : true
allow : (opus|ulaw|alaw|speex)
allow_overlap : true
allow_subscribe : true
allow_transfer : true
allow_unauthenticated_options : false
aors : 1002
asymmetric_rtp_codec : false
auth : auth1002
bind_rtp_to_media_address : false
bundle : false
call_group :
callerid : <unknown>
callerid_privacy : allowed_not_screened
callerid_tag :
codec_prefs_incoming_answer : prefer:pending, operation:intersect, keep:all, transcode:allow
codec_prefs_incoming_offer : prefer:pending, operation:intersect, keep:all, transcode:allow
codec_prefs_outgoing_answer : prefer:pending, operation:intersect, keep:all, transcode:allow
codec_prefs_outgoing_offer : prefer:pending, operation:union, keep:all, transcode:allow
connected_line_method : invite
contact_acl :
context : testcall
cos_audio : 0
cos_video : 0
device_state_busy_at : 0
direct_media : false
direct_media_glare_mitigation : none
direct_media_method : invite
disable_direct_media_on_nat : false
dtls_auto_generate_cert : No
dtls_ca_file :
dtls_ca_path :
dtls_cert_file :
dtls_cipher :
dtls_fingerprint : SHA-256
dtls_private_key :
dtls_rekey : 0
dtls_setup : active
dtls_verify : No
dtmf_mode : rfc4733
fax_detect : false
fax_detect_timeout : 0
follow_early_media_fork : true
force_avp : false
force_rport : true
from_domain :
from_user :
g726_non_standard : false
geoloc_incoming_call_profile :
geoloc_outgoing_call_profile :
ice_support : false
identify_by : username
ignore_183_without_sdp : false
inband_progress : false
incoming_call_offer_pref : local
incoming_mwi_mailbox :
language :
mailboxes :
max_audio_streams : 1
max_video_streams : 1
media_address :
media_encryption : no
media_encryption_optimistic : false
media_use_received_transport : false
message_context :
moh_passthrough : false
moh_suggest : default
mwi_from_user :
mwi_subscribe_replaces_unsolicited : no
named_call_group :
named_pickup_group :
notify_early_inuse_ringing : false
one_touch_recording : false
outbound_auth :
outbound_proxy :
outgoing_call_offer_pref : remote_merge
overlap_context :
pickup_group :
preferred_codec_only : false
record_off_feature : automixmon
record_on_feature : automixmon
refer_blind_progress : true
rewrite_contact : true
rpid_immediate : false
rtcp_mux : true
rtp_engine : asterisk
rtp_ipv6 : false
rtp_keepalive : 0
rtp_symmetric : true
rtp_timeout : 0
rtp_timeout_hold : 0
sdp_owner : asterisk
sdp_session : asterisk
security_mechanisms :
security_negotiation : no
send_aoc : false
send_connected_line : yes
send_diversion : true
send_history_info : false
send_pai : false
send_rpid : false
set_var :
srtp_tag_32 : false
stir_shaken : off
stir_shaken_profile :
sub_min_expiry : 0
subscribe_context :
suppress_q850_reason_headers : false
t38_bind_udptl_to_media_address : false
t38_udptl : false
t38_udptl_ec : none
t38_udptl_ipv6 : false
t38_udptl_maxdatagram : 0
t38_udptl_nat : false
timers : yes
timers_min_se : 90
timers_sess_expires : 1800
tone_zone :
tos_audio : 0
tos_video : 0
transport : transport-udp
trust_connected_line : yes
trust_id_inbound : false
trust_id_outbound : false
use_avpf : true
use_ptime : false
user_eq_phone : false
voicemail_extension :
webrtc : no
Извиняюсь, не понял как там скопировать
как прочтете удалю или как найду как красиво вставить
Cообщение от   Telegram-канал nov_atla
Ужас какой то...
Сообщение свое сделайте в кавычках `
