a400p freebsd
shadow_mag
Re: a400p freebsd
Сообщение shadow_mag »
Или например свести астериксы
например завести номер на фре чтоб тот обрабатывал номер городской и передавал его на centOs
shadow_mag
Re: a400p freebsd
В общем я их свел CentOs клиент Freebsd сервер
теперь centoS пишет
-- Called SIP/OUT200/83519438635
-- SIP/OUT200-00000066 is circuit-busy
-- Executing [s@macro-dialout-trunk:23] NoOp("SIP/104-00000065", "Dial failed for some reason with DIALSTATUS = CONGESTION and HANGUPCAUSE = 1") in new stack
-- Executing [s@macro-dialout-trunk:24] GotoIf("SIP/104-00000065", "0?continue,1:s-CONGESTION,1") in new stack
-- Goto (macro-dialout-trunk,s-CONGESTION,1)
-- Executing [s-CONGESTION@macro-dialout-trunk:1] Set("SIP/104-00000065", "RC=1") in new stack
-- Executing [s-CONGESTION@macro-dialout-trunk:2] Goto("SIP/104-00000065", "1,1") in new stack
-- Goto (macro-dialout-trunk,1,1)
-- Executing [1@macro-dialout-trunk:1] Goto("SIP/104-00000065", "continue,1") in new stack
-- Executing [continue@macro-dialout-trunk:1] NoOp("SIP/104-00000065", "TRUNK Dial failed due to CONGESTION HANGUPCAUSE: 1 - failing through to other trunks") in new stack
-- Executing [continue@macro-dialout-trunk:2] Set("SIP/104-00000065", "CALLERID(number)=104") in new stack
-- Executing [438635@from-internal:7] Macro("SIP/104-00000065", "outisbusy,") in new stack
-- Executing [s@macro-outisbusy:1] Progress("SIP/104-00000065", "") in new stack
-- Executing [s@macro-outisbusy:2] GotoIf("SIP/104-00000065", "0?emergency,1") in new stack
-- Executing [s@macro-outisbusy:3] GotoIf("SIP/104-00000065", "0?intracompany,1") in new stack
-- Executing [s@macro-outisbusy:4] Playback("SIP/104-00000065", "all-circuits-busy-now&pls-try-call-later, noanswer") in new stack
[2013-05-23 21:58:49] WARNING[13414]: file.c:653 ast_openstream_full: File all-circuits-busy-now does not exist in any format
[2013-05-23 21:58:49] WARNING[13414]: file.c:959 ast_streamfile: Unable to open all-circuits-busy-now (format 0x4 (ulaw)): No such file or directory
[2013-05-23 21:58:49] WARNING[13414]: app_playback.c:475 playback_exec: ast_streamfile failed on SIP/104-00000065 for all-circuits-busy-now&pls-try-call-later, noanswer
[2013-05-23 21:58:49] WARNING[13414]: file.c:653 ast_openstream_full: File pls-try-call-later does not exist in any format
[2013-05-23 21:58:49] WARNING[13414]: file.c:959 ast_streamfile: Unable to open pls-try-call-later (format 0x4 (ulaw)): No such file or directory
-- Executing [s@macro-outisbusy:5] Congestion("SIP/104-00000065", "20") in new stack
[2013-05-23 21:58:49] WARNING[13414]: channel.c:4646 ast_prod: Prodding channel 'SIP/104-00000065' failed
== Spawn extension (macro-outisbusy, s, 5) exited non-zero on 'SIP/104-00000065' in macro 'outisbusy'
== Spawn extension (from-internal, 438635, 7) exited non-zero on 'SIP/104-00000065'
-- Executing [h@from-internal:1] Hangup("SIP/104-00000065", "") in new stack
== Spawn extension (from-internal, h, 1) exited non-zero on 'SIP/104-00000065'
Freebsd
NOTICE[1112]: chan_sip.c:23351 handle_request_invite: Call from '' (192.168.22.99:5060) to extension '83519438635' rejected because extension not found in context 'default'.
shadow_mag
Re: a400p freebsd
Это понятно, что в настройках. Но в ростелеком я звонил там бесполезно что то спрашивать.
с CentOs все сложно я ее плохо знаю очень плохо.
Aven
Re: a400p freebsd
Сообщение Aven »
Может книжку почитать? И английский язык базовый подучить?
shadow_mag
Re: a400p freebsd
Ну насчет книжки почитаю.
Блин просто чуть чуть осталось.
Уже голова болит.
Почему он рругается на него если я прописал его в peer
host=192.168.22.97
username=200200
secret=123456
context=home1
insecure=port,invite
allow=alaw&ulaw
shadow_mag
Re: a400p freebsd
В общем заработало
shadow_mag
Re: a400p freebsd
Большое спасибо за поддержку!
