Siemens Gigaset C470 IP - вопросы
Re: Siemens Gigaset C470 IP - вопросы
Your other desk phones don't use hook flash, Asterisk doesn't listen for
hook flash messages on SIP channels, in fact the Siemens phone will send
a hook flash signal to Asterisk if you press the R key but Asterisk
ignores it.
Your desk phones use normal SIP methods to perform transfers (putting a
call on hold with a special Invite message, doing a transfer with a
Refer message...), this functionality is what has been added to the
Siemens phone. Whilst in a call you need to press the "ext call"
button, then you can announce the call to the person on the other end
and select the "transfer" option in the menu on the phone. If you have
the "transfer on hangup" option set to yes then you can just hangup and
the call will transfer, this method can also be used for a blind
transfer, just hangup while the 2nd call is ringing.
As for Asterisk config, if transfers are already working on other SIP
phones you have (using proper SIP transfers, not the ## code) then there
should be no extra config required. That was certainly the case for me
in our office and I've been using this firmware for a couple of months
in BETA before it was released.
Теория:
http://www.dialogic.com/webhelp/img1010 ... ltrans.htm
sorgchik
Сообщение sorgchik »
ну видимо тяжелый случай...
dtmfmode перебирал как на самом телефоне, на пире, так и в sip,conf
:cry:
SVoy
Сообщение SVoy »
:) нужно бы такой "смайлик" сделать..
Готов к труду и обороне!
http://svoy.in.ua - для своих
sorgchik
гуру
sorgchik
длительность "flash" менял... не то..
Параметр dtmfmode= должен быть выставлен в info, то есть hookflash event приходит в виде SIP пакета INFO, при SIP дебаге это видно - прибегает пакетик с расшифровкой. Как это происходит в теории - описано по тому линку сверху (SIP refer). На практике нато полировать с конкретным девайсом.
