FreePBX DISA не записывает разговоры.
Re: FreePBX DISA не записывает разговоры.
CLI> dialplan show sub-record-chec
посмотреть с какими параметрами вы его вызываете и куда должно пойти
у вас вышло из него на 11 приоритете
-- Executing [s@sub-record-check:11] ExecIf("SIP/MSM7495797XXXX-00000053", "1?Return()") in new stack
chubaka
Сообщение chubaka »
asterisk -rx "dialplan show sub-record-check"
[ Context 'sub-record-check' created by 'pbx_config' ]
  'conf' =>         1. Gosub(recconf,1(${EXTEN},${ARG2},${ARG2})) [pbx_config]
                    2. Return()                                   [pbx_config]
  'exten' =>        1. GotoIf($["${REC_POLICY_MODE}"!=""]?callee) [pbx_config]
                    2. Set(__REC_POLICY_MODE=${IF($[${LEN(${FROM_DID})}]?${DB(AMPUSER/${ARG2}/recording/in/external)}:${DB(AMPUSER/${ARG2}/recording/in/internal)})}) [pbx_config]
                    3. GotoIf($["${REC_POLICY_MODE}"="dontcare"]?caller) [pbx_config]
                    4. GotoIf($["${DB(AMPUSER/${FROMEXTEN}/recording/out/internal)}"="dontcare" | "${FROM_DID}"!=""]?callee) [pbx_config]
                    5. ExecIf($[${LEN(${DB(AMPUSER/${FROMEXTEN}/recording/priority)})}]?Set(CALLER_PRI=${DB(AMPUSER/${FROMEXTEN}/recording/priority)}):Set(CALLER_PRI=0)) [pbx_config]
                    6. ExecIf($[${LEN(${DB(AMPUSER/${ARG2}/recording/priority)})}]?Set(CALLEE_PRI=${DB(AMPUSER/${ARG2}/recording/priority)}):Set(CALLEE_PRI=0)) [pbx_config]
                    7. GotoIf($["${CALLER_PRI}"="${CALLEE_PRI}"]?${REC_POLICY}:${IF($[${CALLER_PRI}>${CALLEE_PRI}]?caller:callee)}) [pbx_config]
     [callee]       8. GosubIf($["${REC_POLICY_MODE}"="always"]?record,1(${EXTEN},${ARG2},${FROMEXTEN})) [pbx_config]
                    9. Return()                                   [pbx_config]
     [caller]       10. Set(__REC_POLICY_MODE=${DB(AMPUSER/${FROMEXTEN}/recording/out/internal)}) [pbx_config]
                    11. GosubIf($["${REC_POLICY_MODE}"="always"]?record,1(${EXTEN},${ARG2},${FROMEXTEN})) [pbx_config]
                    12. Return()                                  [pbx_config]
  'force' =>        1. GosubIf($["${REC_POLICY_MODE}"="always"]?record,1(${EXTEN},${REC_POLICY_MODE},${FROMEXTEN})) [pbx_config]
  'out' =>          1. ExecIf($["${REC_POLICY_MODE}"=""]?Set(__REC_POLICY_MODE=${DB(AMPUSER/${FROMEXTEN}/recording/out/external)})) [pbx_config]
                    2. GosubIf($["${REC_POLICY_MODE}"="always"]?record,1(exten,${ARG2},${FROMEXTEN})) [pbx_config]
                    3. Return()                                   [pbx_config]
  'page' =>         1. GosubIf($["${REC_POLICY_MODE}"="always"]?recconf,1(${EXTEN},${ARG2},${FROMEXTEN})) [pbx_config]
  'q' =>            1. GosubIf($["${REC_POLICY_MODE}"="always"]?recq,1(${EXTEN},${ARG2},${FROMEXTEN})) [pbx_config]
  'recconf' =>      1. Set(__CALLFILENAME=${IF($[${MEETME_INFO(parties,${ARG2})}]?${DB(RECCONF/${ARG2})}:${ARG1}-${ARG2}-${ARG3}-${TIMESTR}-${UNIQUEID})}) [pbx_config]
                    2. ExecIf($[!${MEETME_INFO(parties,${ARG2})}]?Set(DB(RECCONF/${ARG2})=${CALLFILENAME})) [pbx_config]
                    3. Set(MEETME_RECORDINGFILE=${IF($[${LEN(${MIXMON_DIR})}]?${MIXMON_DIR}:${ASTSPOOLDIR}/monitor/)}${YEAR}/${MONTH}/${DAY}/${CALLFILENAME}) [pbx_config]
                    4. Set(MEETME_RECORDINGFORMAT=${MIXMON_FORMAT}) [pbx_config]
                    5. ExecIf($["${REC_POLICY_MODE}"!="always"]?Return()) [pbx_config]
                    6. Set(__REC_STATUS=RECORDING)                [pbx_config]
                    7. Set(CDR(recordingfile)=${CALLFILENAME}.${MON_FMT}) [pbx_config]
                    8. Return()                                   [pbx_config]
  'record' =>       1. Set(AUDIOHOOK_INHERIT(MixMonitor)=yes)     [pbx_config]
                    2. MixMonitor(${MIXMON_DIR}${YEAR}/${MONTH}/${DAY}/${CALLFILENAME}.${MIXMON_FORMAT},,${MIXMON_POST}) [pbx_config]
                    3. Set(__REC_STATUS=RECORDING)                [pbx_config]
                    4. Set(CDR(recordingfile)=${CALLFILENAME}.${MON_FMT}) [pbx_config]
                    5. Return()                                   [pbx_config]
  'recq' =>         1. Set(AUDIOHOOK_INHERIT(MixMonitor)=yes)     [pbx_config]
                    2. Set(MONITOR_FILENAME=${MIXMON_DIR}${YEAR}/${MONTH}/${DAY}/${CALLFILENAME}) [pbx_config]
                    3. MixMonitor(${MONITOR_FILENAME}.${MIXMON_FORMAT},${MONITOR_OPTIONS},${MIXMON_POST}) [pbx_config]
                    4. Set(__REC_STATUS=RECORDING)                [pbx_config]
                    5. Set(CDR(recordingfile)=${CALLFILENAME}.${MON_FMT}) [pbx_config]
                    6. Return()                                   [pbx_config]
  'rg' =>           1. GosubIf($["${REC_POLICY_MODE}"="always"]?record,1(${EXTEN},${REC_POLICY_MODE},${FROMEXTEN})) [pbx_config]
  's' =>            1. Set(REC_POLICY_MODE_SAVE=${REC_POLICY_MODE}) [pbx_config]
                    2. GotoIf($["${BLINDTRANSFER}" = ""]?check)   [pbx_config]
                    3. ResetCDR()                                 [pbx_config]
                    4. GotoIf($["${REC_STATUS}" != "RECORDING"]?check) [pbx_config]
                    5. Set(AUDIOHOOK_INHERIT(MixMonitor)=yes)     [pbx_config]
                    6. MixMonitor(${MIXMON_DIR}${YEAR}/${MONTH}/${DAY}/${CALLFILENAME}.${MIXMON_FORMAT},a,${MIXMON_POST}) [pbx_config]
     [check]        7. Set(__MON_FMT=${IF($["${MIXMON_FORMAT}"="wav49"]?WAV:${MIXMON_FORMAT})}) [pbx_config]
                    8. GotoIf($["${REC_STATUS}"!="RECORDING"]?next) [pbx_config]
                    9. Set(CDR(recordingfile)=${CALLFILENAME}.${MON_FMT}) [pbx_config]
                    10. Return()                                  [pbx_config]
     [next]         11. ExecIf($[!${LEN(${ARG1})}]?Return())      [pbx_config]
                    12. ExecIf($["${REC_POLICY_MODE}"="" & "${ARG3}"!=""]?Set(__REC_POLICY_MODE=${ARG3})) [pbx_config]
                    13. GotoIf($["${REC_STATUS}"!=""]?${ARG1},1)  [pbx_config]
                    14. Set(__REC_STATUS=INITIALIZED)             [pbx_config]
                    15. Set(NOW=${EPOCH})                         [pbx_config]
                    16. Set(__DAY=${STRFTIME(${NOW},,%d)})        [pbx_config]
                    17. Set(__MONTH=${STRFTIME(${NOW},,%m)})      [pbx_config]
                    18. Set(__YEAR=${STRFTIME(${NOW},,%Y)})       [pbx_config]
                    19. Set(__TIMESTR=${YEAR}${MONTH}${DAY}-${STRFTIME(${NOW},,%H%M%S)}) [pbx_config]
                    20. Set(__FROMEXTEN=${IF($[${LEN(${AMPUSER})}]?${AMPUSER}:${IF($[${LEN(${REALCALLERIDNUM})}]?${REALCALLERIDNUM}:unknown)})}) [pbx_config]
                    21. Set(__CALLFILENAME=${ARG1}-${ARG2}-${FROMEXTEN}-${TIMESTR}-${UNIQUEID}) [pbx_config]
                    22. Goto(${ARG1},1)                           [pbx_config]
  Include =>        'sub-record-check-custom'                     [pbx_config]
-= 11 extensions (66 priorities) in 1 context. =-
Вызываю его с параметром s
cat /etc/asterisk/extensions_override_freepbx.conf
[disa]
include => disa-custom
exten => 1,1,Authenticate(4585,)
exten => 1,n,Set(_DISA=disa^1^newcall)
exten => 1,n(newcall),Set(_DISACONTEXT=from-internal)
exten => 1,n,Set(_KEEPCID=TRUE)
exten => 1,n,Set(_HANGUP=${TRUNK_OPTIONS})
exten => 1,n,Set(TIMEOUT(digit)=5)
exten => 1,n,Set(TIMEOUT(response)=30)
exten => 1,n,DISA(no-password,disa-dial)
exten => 1,n(end),Hangup
exten => 3,1,Answer
exten => 3,n,Set(_DISA=disa^3^newcall)
exten => 3,n,Gosub(sub-record-check,s,1(${_DISA},always))
exten => 3,n(newcall),Set(_DISACONTEXT=from-internal)
exten => 3,n,Set(_KEEPCID=TRUE)
exten => 3,n,Set(_HANGUP=${TRUNK_OPTIONS})
exten => 3,n,Set(TIMEOUT(digit)=5)
exten => 3,n,Set(TIMEOUT(response)=30)
exten => 3,n,DISA(no-password,disa-dial)
exten => 3,n(end),Hangup
;--== end of [disa] ==--;
Буду пробовать запустить с другими параметрами.
у народа от жары моск расплылся совсем
на обум сочиняю
exten => 3,n,Gosub(sub-record-check,s,14(record))
если получится разберитесь почему заработало и высылайте коньяк
chubaka
Сообщение chubaka »
Если ставлю параметр record
Не могу прослушать файл так как почему-то ставится точка
Если ставлю параметр recq
[2013-06-28 12:02:30] WARNING[18057]: file.c:1169 ast_writefile: Unable to open file ///.wav: Permission denied
[2013-06-28 12:02:30] ERROR[18057]: app_mixmonitor.c:335 mixmonitor_thread: Cannot open ///.wav
Если ставлю параметр q
Не могу прослушать файл так как почему-то ставится точка и дальнейшей разговор тоже не пишется
какая нафиг "точка"
поставьте QuickTime
chubaka
Сообщение chubaka »
Влад спасибо большое заработало
Буду разбираться с заполнением строк.
chubaka
Сообщение chubaka »
Ага функционал админки известен , а вот внутренности * буду курить,тестировать и творить.
Всем большое спасибо !
vincetti
Сообщение vincetti »
Имею подобную проблему, но с записью IVR (пишется только разговор людей)
вроде и логично, но не всё понятно:
s, 14 - это шаг в макросе
что дает указание (record)? после конца s выполняется record?..
(record) - это метка.
Если раньше посылали на конкретный шаг Goto(s,22) например, то при вставках и и зменении порядкового номера шага логика ломалась, стали отсылать к метке.
