Тебе надо логи FreePBX
Логи FeePBX как будто чисто информационные:
# tail -f /var/log/asterisk/freepbx.log
[2025-06-10 10:11:12] [freepbx.INFO]: Deprecated way to add Console commands for module api, adding console commands this way can have negative performance impacts. Please use module.xml. See: https://wiki.freepbx.org/display/FOP/Adding+fwconsole+commands [] []
[2025-06-10 10:11:12] [freepbx.INFO]: Deprecated way to add Console commands for module backup, adding console commands this way can have negative performance impacts. Please use module.xml. See: https://wiki.freepbx.org/display/FOP/Adding+fwconsole+commands [] []
[2025-06-10 10:11:12] [freepbx.INFO]: Deprecated way to add Console commands for module iotserver, adding console commands this way can have negative performance impacts. Please use module.xml. See: https://wiki.freepbx.org/display/FOP/Adding+fwconsole+commands [] []
[2025-06-10 10:11:12] [freepbx.INFO]: Deprecated way to add Console commands for module voicemail, adding console commands this way can have negative performance impacts. Please use module.xml. See: https://wiki.freepbx.org/display/FOP/Adding+fwconsole+commands [] []
[2025-06-10 10:11:21] [freepbx.INFO]: Depreciated Function module_getinfo detected in /var/www/html/admin/modules/cxpanel/functions.inc.php on line 71 [] []
[2025-06-10 10:11:21] [freepbx.INFO]: Depreciated Function module_getinfo detected in /var/www/html/admin/modules/cxpanel/functions.inc.php on line 80 [] []
