Не работает приветствия!
igariok111
Re: Не работает приветствия!
Сообщение igariok111 »
Все равно приветствие нету.
    -- Executing [246@from-trunk-sip-orange_69521193:1] Set("SIP/orange_69521193-00000008", "GROUP()=OUT_1") in new stack
    -- Executing [246@from-trunk-sip-orange_69521193:2] Goto("SIP/orange_69521193-00000008", "from-trunk,246,1") in new stack
    -- Goto (from-trunk,246,1)
    -- Executing [246@from-trunk:1] Set("SIP/orange_69521193-00000008", "__RINGTIMER=15") in new stack
    -- Executing [246@from-trunk:2] Macro("SIP/orange_69521193-00000008", "exten-vm,novm,246,0,0,0") in new stack
    -- Executing [s@macro-exten-vm:1] Macro("SIP/orange_69521193-00000008", "user-callerid,") in new stack
    -- Executing [s@macro-user-callerid:1] Set("SIP/orange_69521193-00000008", "TOUCH_MONITOR=1477660531.8") in new stack
    -- Executing [s@macro-user-callerid:2] Set("SIP/orange_69521193-00000008", "AMPUSER=068900280") in new stack
    -- Executing [s@macro-user-callerid:3] GotoIf("SIP/orange_69521193-00000008", "0?report") in new stack
    -- Executing [s@macro-user-callerid:4] ExecIf("SIP/orange_69521193-00000008", "1?Set(REALCALLERIDNUM=068900280)") in new stack
    -- Executing [s@macro-user-callerid:5] Set("SIP/orange_69521193-00000008", "AMPUSER=") in new stack
    -- Executing [s@macro-user-callerid:6] GotoIf("SIP/orange_69521193-00000008", "0?limit") in new stack
    -- Executing [s@macro-user-callerid:7] Set("SIP/orange_69521193-00000008", "AMPUSERCIDNAME=") in new stack
    -- Executing [s@macro-user-callerid:8] GotoIf("SIP/orange_69521193-00000008", "1?report") in new stack
    -- Goto (macro-user-callerid,s,15)
    -- Executing [s@macro-user-callerid:15] GotoIf("SIP/orange_69521193-00000008", "0?continue") in new stack
    -- Executing [s@macro-user-callerid:16] Set("SIP/orange_69521193-00000008", "__TTL=64") in new stack
    -- Executing [s@macro-user-callerid:17] GotoIf("SIP/orange_69521193-00000008", "1?continue") in new stack
    -- Goto (macro-user-callerid,s,28)
    -- Executing [s@macro-user-callerid:28] Set("SIP/orange_69521193-00000008", "CALLERID(number)=068900280") in new stack
    -- Executing [s@macro-user-callerid:29] Set("SIP/orange_69521193-00000008", "CALLERID(name)=068900280") in new stack
    -- Executing [s@macro-user-callerid:30] Set("SIP/orange_69521193-00000008", "CDR(cnum)=068900280") in new stack
    -- Executing [s@macro-user-callerid:31] Set("SIP/orange_69521193-00000008", "CDR(cnam)=068900280") in new stack
    -- Executing [s@macro-user-callerid:32] Set("SIP/orange_69521193-00000008", "CHANNEL(language)=en") in new stack
    -- Executing [s@macro-exten-vm:2] Set("SIP/orange_69521193-00000008", "RingGroupMethod=none") in new stack
    -- Executing [s@macro-exten-vm:3] Set("SIP/orange_69521193-00000008", "__EXTTOCALL=246") in new stack
    -- Executing [s@macro-exten-vm:4] Set("SIP/orange_69521193-00000008", "__PICKUPMARK=246") in new stack
    -- Executing [s@macro-exten-vm:5] Set("SIP/orange_69521193-00000008", "RT=") in new stack
    -- Executing [s@macro-exten-vm:6] Gosub("SIP/orange_69521193-00000008", "sub-record-check,s,1(exten,246,)") in new stack
    -- Executing [s@sub-record-check:1] Set("SIP/orange_69521193-00000008", "REC_POLICY_MODE_SAVE=") in new stack
    -- Executing [s@sub-record-check:2] GotoIf("SIP/orange_69521193-00000008", "1?check") in new stack
    -- Goto (sub-record-check,s,7)
    -- Executing [s@sub-record-check:7] Set("SIP/orange_69521193-00000008", "__MON_FMT=wav") in new stack
    -- Executing [s@sub-record-check:8] GotoIf("SIP/orange_69521193-00000008", "1?next") in new stack
    -- Goto (sub-record-check,s,11)
    -- Executing [s@sub-record-check:11] ExecIf("SIP/orange_69521193-00000008", "0?Return()") in new stack
    -- Executing [s@sub-record-check:12] ExecIf("SIP/orange_69521193-00000008", "0?Set(__REC_POLICY_MODE=)") in new stack
    -- Executing [s@sub-record-check:13] GotoIf("SIP/orange_69521193-00000008", "0?exten,1") in new stack
    -- Executing [s@sub-record-check:14] Set("SIP/orange_69521193-00000008", "__REC_STATUS=INITIALIZED") in new stack
    -- Executing [s@sub-record-check:15] Set("SIP/orange_69521193-00000008", "NOW=1477660531") in new stack
    -- Executing [s@sub-record-check:16] Set("SIP/orange_69521193-00000008", "__DAY=28") in new stack
    -- Executing [s@sub-record-check:17] Set("SIP/orange_69521193-00000008", "__MONTH=10") in new stack
    -- Executing [s@sub-record-check:18] Set("SIP/orange_69521193-00000008", "__YEAR=2016") in new stack
    -- Executing [s@sub-record-check:19] Set("SIP/orange_69521193-00000008", "__TIMESTR=20161028-161531") in new stack
    -- Executing [s@sub-record-check:20] Set("SIP/orange_69521193-00000008", "__FROMEXTEN=068900280") in new stack
    -- Executing [s@sub-record-check:21] Set("SIP/orange_69521193-00000008", "__CALLFILENAME=exten-246-068900280-20161028-161531-1477660531.8") in new stack
    -- Executing [s@sub-record-check:22] Goto("SIP/orange_69521193-00000008", "exten,1") in new stack
    -- Goto (sub-record-check,exten,1)
    -- Executing [exten@sub-record-check:1] GotoIf("SIP/orange_69521193-00000008", "0?callee") in new stack
    -- Executing [exten@sub-record-check:2] Set("SIP/orange_69521193-00000008", "__REC_POLICY_MODE=dontcare") in new stack
    -- Executing [exten@sub-record-check:3] GotoIf("SIP/orange_69521193-00000008", "1?caller") in new stack
    -- Goto (sub-record-check,exten,10)
    -- Executing [exten@sub-record-check:10] Set("SIP/orange_69521193-00000008", "__REC_POLICY_MODE=") in new stack
    -- Executing [exten@sub-record-check:11] GosubIf("SIP/orange_69521193-00000008", "0?record,1(exten,246,068900280)") in new stack
    -- Executing [exten@sub-record-check:12] Return("SIP/orange_69521193-00000008", "") in new stack
    -- Executing [s@macro-exten-vm:7] Macro("SIP/orange_69521193-00000008", "dial-one,,t,246") in new stack
    -- Executing [s@macro-dial-one:1] Set("SIP/orange_69521193-00000008", "DEXTEN=246") in new stack
    -- Executing [s@macro-dial-one:2] Set("SIP/orange_69521193-00000008", "DIALSTATUS_CW=") in new stack
    -- Executing [s@macro-dial-one:3] GosubIf("SIP/orange_69521193-00000008", "0?screen,1()") in new stack
    -- Executing [s@macro-dial-one:4] GosubIf("SIP/orange_69521193-00000008", "0?cf,1()") in new stack
    -- Executing [s@macro-dial-one:5] GotoIf("SIP/orange_69521193-00000008", "1?skip1") in new stack
    -- Goto (macro-dial-one,s,8)
    -- Executing [s@macro-dial-one:8] GotoIf("SIP/orange_69521193-00000008", "0?nodial") in new stack
    -- Executing [s@macro-dial-one:9] GotoIf("SIP/orange_69521193-00000008", "0?continue") in new stack
    -- Executing [s@macro-dial-one:10] Set("SIP/orange_69521193-00000008", "EXTHASCW=") in new stack
    -- Executing [s@macro-dial-one:11] GotoIf("SIP/orange_69521193-00000008", "1?next1:cwinusebusy") in new stack
    -- Goto (macro-dial-one,s,12)
    -- Executing [s@macro-dial-one:12] GotoIf("SIP/orange_69521193-00000008", "0?docfu:skip3") in new stack
    -- Goto (macro-dial-one,s,16)
    -- Executing [s@macro-dial-one:16] GotoIf("SIP/orange_69521193-00000008", "1?next2:continue") in new stack
    -- Goto (macro-dial-one,s,17)
    -- Executing [s@macro-dial-one:17] GotoIf("SIP/orange_69521193-00000008", "1?continue") in new stack
    -- Goto (macro-dial-one,s,25)
    -- Executing [s@macro-dial-one:25] GotoIf("SIP/orange_69521193-00000008", "0?nodial") in new stack
    -- Executing [s@macro-dial-one:26] GosubIf("SIP/orange_69521193-00000008", "1?dstring,1():dlocal,1()") in new stack
    -- Executing [dstring@macro-dial-one:1] Set("SIP/orange_69521193-00000008", "DSTRING=") in new stack
    -- Executing [dstring@macro-dial-one:2] Set("SIP/orange_69521193-00000008", "DEVICES=246") in new stack
    -- Executing [dstring@macro-dial-one:3] ExecIf("SIP/orange_69521193-00000008", "0?Return()") in new stack
    -- Executing [dstring@macro-dial-one:4] ExecIf("SIP/orange_69521193-00000008", "0?Set(DEVICES=46)") in new stack
    -- Executing [dstring@macro-dial-one:5] Set("SIP/orange_69521193-00000008", "LOOPCNT=1") in new stack
    -- Executing [dstring@macro-dial-one:6] Set("SIP/orange_69521193-00000008", "ITER=1") in new stack
    -- Executing [dstring@macro-dial-one:7] Set("SIP/orange_69521193-00000008", "THISDIAL=SIP/246") in new stack
    -- Executing [dstring@macro-dial-one:8] GosubIf("SIP/orange_69521193-00000008", "1?zap2dahdi,1()") in new stack
    -- Executing [zap2dahdi@macro-dial-one:1] ExecIf("SIP/orange_69521193-00000008", "0?Return()") in new stack
    -- Executing [zap2dahdi@macro-dial-one:2] Set("SIP/orange_69521193-00000008", "NEWDIAL=") in new stack
    -- Executing [zap2dahdi@macro-dial-one:3] Set("SIP/orange_69521193-00000008", "LOOPCNT2=1") in new stack
    -- Executing [zap2dahdi@macro-dial-one:4] Set("SIP/orange_69521193-00000008", "ITER2=1") in new stack
    -- Executing [zap2dahdi@macro-dial-one:5] Set("SIP/orange_69521193-00000008", "THISPART2=SIP/246") in new stack
    -- Executing [zap2dahdi@macro-dial-one:6] ExecIf("SIP/orange_69521193-00000008", "0?Set(THISPART2=DAHDI/246)") in new stack
    -- Executing [zap2dahdi@macro-dial-one:7] Set("SIP/orange_69521193-00000008", "NEWDIAL=SIP/246&") in new stack
    -- Executing [zap2dahdi@macro-dial-one:8] Set("SIP/orange_69521193-00000008", "ITER2=2") in new stack
    -- Executing [zap2dahdi@macro-dial-one:9] GotoIf("SIP/orange_69521193-00000008", "0?begin2") in new stack
    -- Executing [zap2dahdi@macro-dial-one:10] Set("SIP/orange_69521193-00000008", "THISDIAL=SIP/246") in new stack
    -- Executing [zap2dahdi@macro-dial-one:11] Return("SIP/orange_69521193-00000008", "") in new stack
    -- Executing [dstring@macro-dial-one:9] Set("SIP/orange_69521193-00000008", "DSTRING=SIP/246&") in new stack
    -- Executing [dstring@macro-dial-one:10] Set("SIP/orange_69521193-00000008", "ITER=2") in new stack
    -- Executing [dstring@macro-dial-one:11] GotoIf("SIP/orange_69521193-00000008", "0?begin") in new stack
    -- Executing [dstring@macro-dial-one:12] Set("SIP/orange_69521193-00000008", "DSTRING=SIP/246") in new stack
    -- Executing [dstring@macro-dial-one:13] Return("SIP/orange_69521193-00000008", "") in new stack
    -- Executing [s@macro-dial-one:27] GotoIf("SIP/orange_69521193-00000008", "0?nodial") in new stack
    -- Executing [s@macro-dial-one:28] GotoIf("SIP/orange_69521193-00000008", "0?skiptrace") in new stack
    -- Executing [s@macro-dial-one:29] GosubIf("SIP/orange_69521193-00000008", "1?ctset,1():ctclear,1()") in new stack
    -- Executing [ctset@macro-dial-one:1] Set("SIP/orange_69521193-00000008", "DB(CALLTRACE/246)=068900280") in new stack
    -- Executing [ctset@macro-dial-one:2] Return("SIP/orange_69521193-00000008", "") in new stack
    -- Executing [s@macro-dial-one:30] Set("SIP/orange_69521193-00000008", "D_OPTIONS=t") in new stack
    -- Executing [s@macro-dial-one:31] ExecIf("SIP/orange_69521193-00000008", "0?SIPAddHeader(Alert-Info: )") in new stack
    -- Executing [s@macro-dial-one:32] ExecIf("SIP/orange_69521193-00000008", "0?SIPAddHeader()") in new stack
    -- Executing [s@macro-dial-one:33] ExecIf("SIP/orange_69521193-00000008", "0?Set(CHANNEL(musicclass)=)") in new stack
    -- Executing [s@macro-dial-one:34] GosubIf("SIP/orange_69521193-00000008", "0?qwait,1()") in new stack
    -- Executing [s@macro-dial-one:35] Set("SIP/orange_69521193-00000008", "__CWIGNORE=") in new stack
    -- Executing [s@macro-dial-one:36] Set("SIP/orange_69521193-00000008", "__KEEPCID=TRUE") in new stack
    -- Executing [s@macro-dial-one:37] GotoIf("SIP/orange_69521193-00000008", "0?usegoto,1") in new stack
    -- Executing [s@macro-dial-one:38] GotoIf("SIP/orange_69521193-00000008", "1?godial") in new stack
    -- Goto (macro-dial-one,s,43)
    -- Executing [s@macro-dial-one:43] Dial("SIP/orange_69521193-00000008", "SIP/246,,t") in new stack
  == Using SIP RTP TOS bits 184
    -- Called SIP/246
    -- SIP/246-00000009 is ringing
  == Spawn extension (macro-dial-one, s, 43) exited non-zero on 'SIP/orange_69521193-00000008' in macro 'dial-one'
  == Spawn extension (macro-exten-vm, s, 7) exited non-zero on 'SIP/orange_69521193-00000008' in macro 'exten-vm'
  == Spawn extension (from-trunk, 246, 2) exited non-zero on 'SIP/orange_69521193-00000008'
    -- Executing [h@from-trunk:1] Macro("SIP/orange_69521193-00000008", "hangupcall,") in new stack
    -- Executing [s@macro-hangupcall:1] GotoIf("SIP/orange_69521193-00000008", "1?endmixmoncheck") in new stack
    -- Goto (macro-hangupcall,s,20)
    -- Executing [s@macro-hangupcall:20] NoOp("SIP/orange_69521193-00000008", "End of MIXMON check") in new stack
    -- Executing [s@macro-hangupcall:21] GotoIf("SIP/orange_69521193-00000008", "1?nomeetmemon") in new stack
    -- Goto (macro-hangupcall,s,39)
    -- Executing [s@macro-hangupcall:39] NoOp("SIP/orange_69521193-00000008", "End of MEETME check") in new stack
    -- Executing [s@macro-hangupcall:40] GotoIf("SIP/orange_69521193-00000008", "1?noautomon") in new stack
    -- Goto (macro-hangupcall,s,45)
    -- Executing [s@macro-hangupcall:45] NoOp("SIP/orange_69521193-00000008", "TOUCH_MONITOR_OUTPUT=") in new stack
    -- Executing [s@macro-hangupcall:46] GotoIf("SIP/orange_69521193-00000008", "1?noautomon2") in new stack
    -- Goto (macro-hangupcall,s,52)
    -- Executing [s@macro-hangupcall:52] NoOp("SIP/orange_69521193-00000008", "MONITOR_FILENAME=") in new stack
    -- Executing [s@macro-hangupcall:53] GotoIf("SIP/orange_69521193-00000008", "1?noautomon3") in new stack
    -- Goto (macro-hangupcall,s,59)
    -- Executing [s@macro-hangupcall:59] NoOp("SIP/orange_69521193-00000008", "MIXMONITOR_FILENAME=") in new stack
    -- Executing [s@macro-hangupcall:60] GotoIf("SIP/orange_69521193-00000008", "1?noautomon4") in new stack
    -- Goto (macro-hangupcall,s,62)
    -- Executing [s@macro-hangupcall:62] NoOp("SIP/orange_69521193-00000008", "ONETOUCH_RECFILE=") in new stack
    -- Executing [s@macro-hangupcall:63] NoOp("SIP/orange_69521193-00000008", "CDR recordingfile set to: ") in new stack
    -- Executing [s@macro-hangupcall:64] GotoIf("SIP/orange_69521193-00000008", "1?skiprg") in new stack
    -- Goto (macro-hangupcall,s,67)
    -- Executing [s@macro-hangupcall:67] GotoIf("SIP/orange_69521193-00000008", "1?skipblkvm") in new stack
    -- Goto (macro-hangupcall,s,70)
    -- Executing [s@macro-hangupcall:70] GotoIf("SIP/orange_69521193-00000008", "1?theend") in new stack
    -- Goto (macro-hangupcall,s,72)
    -- Executing [s@macro-hangupcall:72] AGI("SIP/orange_69521193-00000008", "hangup.agi") in new stack
    -- Launched AGI Script /var/lib/asterisk/agi-bin/hangup.agi
    -- <SIP/orange_69521193-00000008>AGI Script hangup.agi completed, returning 0
    -- Executing [s@macro-hangupcall:73] Hangup("SIP/orange_69521193-00000008", "") in new stack
  == Spawn extension (macro-hangupcall, s, 73) exited non-zero on 'SIP/orange_69521193-00000008' in macro 'hangupcall'
  == Spawn extension (from-trunk, h, 1) exited non-zero on 'SIP/orange_69521193-00000008'
Потому что при звонке на номер 246 у вас выставлено звонить на номера внутренней маршрутизации , что и происходит. Попросите вашего системного администратора вас проконсультировать по настройке телефонии.
Уберите входящий маршрут 246 -
и вообще все входящие, оставьте только один: Any DID / Any CID
igariok111
Можете объяснить где его убрать, все перерыл, но что то не получается.
1) SIP пир в транках - orange_69521193 через который поступает вызов, должен иметь контекст from-trunk. Есть такое?
2) Звонок в логе не может начинаться с
там выше ещё что-то было. Было?
Вроде старался, объяснил как мог. Сверх того - уже не смогу, видимо плохой объясняльщик.
zzuz писал(а):Попросите вашего системного администратора вас проконсультировать по настройке телефонии.
igariok111
Все решил вопрос, спасибо всем за ответ, и извините, я только начитаю во всем это разбираться.
проблема в этом и была, звонок шел сразу в группу out_1 потом на 246 ( локальный номер ).
через веб не нашел как менять, поменял в extensions_additional.
Сочувствуем.
