Настройка a2billing
А также решения для провайдеров на основе Asterisk и других открытых PBX
patoka
Re: Настройка a2billing
Сообщение patoka »
whoim писал(а):на первом скрине - баланс нулевой?
логи звонка выложите под спойлером
По поводу баланса:
По поводу логов:
[2016-09-15 17:12:11] WARNING[20110][C-00000005] sip/config_parser.c: nat=yes is deprecated, use nat=force_rport,comedia instead
[2016-09-15 17:12:11] WARNING[20110][C-00000005] chan_sip.c: no value given for outbound proxy on line 0 of sip.conf
[2016-09-15 17:12:11] VERBOSE[20110][C-00000005] netsock2.c: == Using SIP RTP TOS bits 184
[2016-09-15 17:12:11] VERBOSE[20110][C-00000005] netsock2.c: == Using SIP RTP CoS mark 5
[2016-09-15 17:12:11] VERBOSE[29231][C-00000005] pbx.c: -- Executing [380681215412@a2billing:1] Answer("SIP/6220641240-00000004", "") in new stack
[2016-09-15 17:12:11] VERBOSE[29231][C-00000005] pbx.c: -- Executing [380681215412@a2billing:2] Wait("SIP/6220641240-00000004", "1") in new stack
[2016-09-15 17:12:12] VERBOSE[29231][C-00000005] pbx.c: -- Executing [380681215412@a2billing:3] DeadAGI("SIP/6220641240-00000004", "a2billing.php,1") in new stack
[2016-09-15 17:12:12] WARNING[29231][C-00000005] res_agi.c: DeadAGI has been deprecated, please use AGI in all cases!
[2016-09-15 17:12:12] VERBOSE[29231][C-00000005] res_agi.c: -- Launched AGI Script /var/lib/asterisk/agi-bin/a2billing.php
[2016-09-15 17:12:12] VERBOSE[29231][C-00000005] res_agi.c: -- AGI Script Executing Application: (DIAL) Options: (SIP/a2billing/380681215412,60,HRrL(7500000:61000:30000))
[2016-09-15 17:12:12] VERBOSE[29231][C-00000005] netsock2.c: == Using SIP RTP TOS bits 184
[2016-09-15 17:12:12] VERBOSE[29231][C-00000005] netsock2.c: == Using SIP RTP CoS mark 5
[2016-09-15 17:12:12] ERROR[29231][C-00000005] netsock2.c: getaddrinfo("a2billing", "(null)", ...): Name or service not known
[2016-09-15 17:12:12] WARNING[29231][C-00000005] chan_sip.c: No such host: a2billing
[2016-09-15 17:12:12] WARNING[29231][C-00000005] app_dial.c: Unable to create channel of type 'SIP' (cause 20 - Subscriber absent)
[2016-09-15 17:12:12] VERBOSE[29231][C-00000005] app_dial.c: == Everyone is busy/congested at this time (1:0/0/1)
[2016-09-15 17:12:12] VERBOSE[29231][C-00000005] res_agi.c: -- <SIP/6220641240-00000004> Playing 'prepaid-dest-unreachable.gsm' (escape_digits=#) (sample_offset 0) (language 'ru')
[2016-09-15 17:12:15] VERBOSE[29231][C-00000005] file.c: -- <SIP/6220641240-00000004> Playing 'prepaid-enter-dest.gsm' (language 'ru')
[2016-09-15 17:12:16] WARNING[20110] sip/config_parser.c: nat=yes is deprecated, use nat=force_rport,comedia instead
[2016-09-15 17:12:16] WARNING[20110] chan_sip.c: no value given for outbound proxy on line 0 of sip.conf
[2016-09-15 17:12:17] WARNING[20110] sip/config_parser.c: nat=yes is deprecated, use nat=force_rport,comedia instead
[2016-09-15 17:12:17] WARNING[20110] chan_sip.c: no value given for outbound proxy on line 0 of sip.conf
[2016-09-15 17:12:17] NOTICE[20110] chan_sip.c: Received SIP subscribe for peer without mailbox: 6220641240
[2016-09-15 17:12:22] VERBOSE[29231][C-00000005] res_agi.c: -- <SIP/6220641240-00000004>AGI Script a2billing.php completed, returning 4
[2016-09-15 17:12:22] VERBOSE[29231][C-00000005] pbx.c: == Spawn extension (a2billing, 380681215412, 3) exited non-zero on 'SIP/6220641240-00000004'
Вы же пишете - опыт с Астериск есть? Как же ваш опыт не видит очевидного - у вас нет такого пира a2billing при попытке звонка
AGI Script Executing Application: (DIAL) Options: (SIP/a2billing/380681215412,60,HRrL........
соответственно -
Вы что, этого не видели? Видели, но не понимаете - как? Вы только по чужой инструкции, неведомо кем написанной, умеете действовать? Изучать надо логи самостоятельно.
Видел этот скрин - a2billing как Custom dial - AGIa2billing/1
Все вопросы по этой конструкции - к автору инструкции.
patoka
Сообщение patoka »
Вот и нашлась ошибка!
Огромное спасибо WHOIM https://forum.asterisk.ru/memberlist.ph ... ile&u=2386 за внимание к вопросу и адекватность общения
Возможно решение данной ошибки кому то еще пригодится...
whoim
Сообщение whoim »
patoka, через полчаса у вас возникнет еще 5-6 вопросов, это я гарантирую.
Рассмотрите возможность почитать материалы по астериску, ибо больше подсказок не будет, если они на поверхности и/или не интересны.
Прошу понять.
ded`а я поддерживаю намного больше, чем Вас :)
И решение он вам показал раньше меня:
