Прошивка для Cisco 7936
Re: Прошивка для Cisco 7936
Контрольные работы на предмет ошибок тут некому проверять.
Осваивайте sccp debug, tcpdump, и счастье придёт.
goro
Сообщение goro »
 sccp show device SEP0004f2e389df
--- SCCP channel driver device settings ----------------------------------------------------------------------------------
MAC-Address                                    : SEP0004f2e389df
Protocol Version                               : Supported '0', In Use '0'
Protocol In Use                                : NONE Version 0
Device Features                                : 0,00000000000000000000000000000000
Tokenstate                                     : No Token
Keepalive                                      : 60
Registration state                             : None(2)
State                                          : On Hook(0)
MWI light                                      : On(2)
MWI handset light                              : 0000000000000000000000000000000 (0)
MWI During call                                : turn off
Description                                    : Conference Room
Config Phone Type                              : 7936
Skinny Phone Type                              : Undefined: Maybe you forgot the devicetype in your config(0)
Softkey support                                : no
Softkeyset                                     : default => default (0x7fcc1802d320)
BTemplate support                              : no
linesRegistered                                : no
Image Version                                  :
Timezone Offset                                : 0
Capabilities                                   : (nothing)
Codecs preference                              : (alaw/64k (2), alaw/56k (3), ulaw/64k (4), ulaw/56k (5), g729 (11), g729a (12), g729b (15), g729ab (16), g729/annex/b (85))
Audio TOS                                      : 184
Audio COS                                      : 6
Video TOS                                      : 136
Video COS                                      : 5
DND Feature enabled                            : yes
DND Status                                     : Disabled
DND Action                                     : Reject
Can Transfer                                   : on
Can Park                                       : on
Can CFWDALL                                    : on
Can CFWBUSY                                    : on
Can CFWNOANSWER                                : on
Allow ringin notification                      : no
Private softkey                                : on
Dtmf mode                                      : SKINNY
Nat                                            : Auto
Videosupport?                                  : no
Direct RTP                                     : off
Trust phone ip (deprecated)                    : off
Bind Address                                   : ???.???.???.???
Server Address                                 : ???.???.???.???
Deny/Permit                                    : deny:0.0.0.0/0.0.0.0,permit:0.0.0.0/0.0.0.0,
PermitHosts                                    :
Early RTP                                      : Progress
Device State (Acc.)                            : None
Last Used Accessory                            : None
Last dialed number                             :  (0)
Default line instance                          : 0
Custom Background Image                        : ---
Custom Ring Tone                               : ---
PendingUpdate                                  : off
PendingDelete                                  : off
Directed Pickup                                : on
Pickup Context                                 : countrycalls (exists)
Pickup Mode Answer                             : on
+--- Buttons -----------------------------------------------------------------------------------+
| Id   Inst TypeStr                        Type                     pendUpdt pendDel  Default   |
| 1    0    Line                           0                        No       No       No        |
+--- LineButtons -------------------------------------------------------------------------------+
| Id   Name                    Suffix Label                         CfwdType   CfwdNumber       |
+--- SpeeddialButtons --------------------------------------------------------------------------+
| Id   Name                    Number                               Hint                        |
+--- FeatureButtons ----------------------------------------------------------------------------+
| Id   Name                    Options                              Status                      |
+--- ServiceURLButtons -------------------------------------------------------------------------+
| Id   Name                    URL                                                              |
+--- Variables ---------------------------------------------------------------------------------+
| Name                         Value                                                            |
| testvar                      value                                                            |
+--- CallStatistics ---------------------------------------------------------------------------------------------------+
| Type     Calls    PcktSnt  PcktRcvd Lost     Jitter   Latency  Quality  avgQual  meanQual maxQual  rConceal sConceal |
| LAST     0        0        0        0        0        0        0.000000 0.000000 0.000000 0.000000 0.000000 0        |
| AVG      0        0        0        0        0        0        0.000000 0.000000 0.000000 0.000000 0.000000 0        |
Вы справитесь!
