Multifon + Asterisk(FreePBX) + DTMF
Re: Multifon + Asterisk(FreePBX) + DTMF
nslookup 193.201.229.19
Non-authoritative answer:
19.229.201.193.in-addr.arpa name = dialup-193-201-229-19.misp.ru.
Юююю браза, маза* мегафон на домашней сетке ?
Dangerous13
Сообщение Dangerous13 »
http://multifon.ru/m/q/16/
193.201.229.19 — >6000 UDP (RTP) – для передачи голоса и видео;
В iptables всё разрешил для этих адресов....
При звонке
PRIME_BBCODE_SPOILER_SHOW PRIME_BBCODE_SPOILER: tcpdump
#tcpdump -i any -n -s 0  host 193.201.229.19 or host 193.201.229.35
14:25:09.417882 IP 193.201.229.35.sip > 10.1.0.95.sip: SIP, length: 959
14:25:09.418357 IP 10.1.0.95.sip > 193.201.229.35.sip: SIP, length: 538
14:25:09.552629 IP 193.201.229.35.sip > 10.1.0.95.sip: SIP, length: 355
14:25:09.552811 IP 10.1.0.95.sip > 193.201.229.35.sip: SIP, length: 522
14:25:09.552856 IP 10.1.0.95.sip > 193.201.229.35.sip: SIP, length: 506
14:25:09.593523 IP 193.201.229.35.sip > 10.1.0.95.sip: SIP, length: 366
14:25:28.576409 IP 193.201.229.35.sip > 10.1.0.95.sip: SIP, length: 959
14:25:28.576922 IP 10.1.0.95.sip > 193.201.229.35.sip: SIP, length: 538
14:25:28.737628 IP 10.1.0.95.sip > 193.201.229.35.sip: SIP, length: 554
14:25:28.738018 IP 10.1.0.95.sip > 193.201.229.35.sip: SIP, length: 756
14:25:28.745151 IP 193.201.229.35.sip > 10.1.0.95.sip: SIP, length: 355
14:25:28.745273 IP 10.1.0.95.sip > 193.201.229.35.sip: SIP, length: 506
14:25:28.786103 IP 193.201.229.35.sip > 10.1.0.95.sip: SIP, length: 364
14:25:28.786129 IP 193.201.229.35.sip > 10.1.0.95.sip: SIP, length: 373
14:25:28.786387 IP 10.1.0.95.sip > 193.201.229.35.sip: SIP, length: 512
14:25:44.892219 IP 193.201.229.35.sip > 10.1.0.95.sip: SIP, length: 959
14:25:44.892885 IP 10.1.0.95.sip > 193.201.229.35.sip: SIP, length: 538
14:25:45.041152 IP 193.201.229.35.sip > 10.1.0.95.sip: SIP, length: 355
14:25:45.041492 IP 10.1.0.95.sip > 193.201.229.35.sip: SIP, length: 522
14:25:45.041588 IP 10.1.0.95.sip > 193.201.229.35.sip: SIP, length: 506
14:25:45.082258 IP 193.201.229.35.sip > 10.1.0.95.sip: SIP, length: 366
Сравнил вывод tcpdump`a на старом сервере, на котором белый iP, там как раз идёт постоянное общение с 193.201.229.19 при звонке. Попробую навесить белый IP, надеюсь на положительный результат.
Dangerous13 писал(а):По видимому инвайт присылает мегафон.
Может быть моя проблема связана с тем, что сервер за NAT`om?
Есть вероятность, что на публичный ИП адрес мегафон присылает SDP содержащий 101 non-codec capabilities (dtmf), а если за НАТом - не присылает 101 non-codec capabilities (dtmf)? Подмена SDP?
Dangerous13
Проблему решили переведя сервер в другую сеть, но то-же за НАТом. Первой сетью рулил микротик на котором резался внешний SIP-трафик и к тому-же сеть была офисной.
После перехода на другую сеть пошёл обмен пакетами с голосом от мегафона, то этого была односторонняя связь, сервак посылал пакеты мегафону, а от мегафона не было ответа.
Тему можно закрывать. 3 дня мучился с одyим номером *WALL*
Спасибо всем кто откликнулся и направил на верный путь.
Проще микротик было настроить - делов на полчаса
